5 страниц V « < 3 4 5
[MP] Freedom 7FR [MPKGBOX + QVGA], новый монстр!
OCM770
сообщение 9.6.2009, 16:16 Закрепленное сообщение!
Пользователь №: 196 171
Freedom 7FR
Based on R6637_G_81.00.7FR + R6637_G_81.11.2CR Fixes
Credits
For this MP I would specially like to thank my friend Kidscracker, for helping me out on some things, backing me up on this project, and of course developing Mpkgbox, looking forward to working with you again Carlos wink.gif
Second I would like to thank tankrider, Skrilax_CZ and NestorM for clearing up some doubts I had and giving me suggestions for this MP.
Then I would like to thank the Motorola modding communities on the net, especially ModMyMoto which is where I grew up and MMUS for taking me in as part of their team. Both communities very friendly and helpful, keep it up guys biggrin.gif. Motofan as well for having awesome developers wink.gif
Благодарности:
За этот МодПак я особо рад сказать спасибо моему другу Kidscracker, за помощь мне с разными вещами, возвращение меня в проект, и конечно за разработку Mpkgbox. Расчитываю посотрудничать с тобой ещё, Карлос wink.gif
Второе: хочу поблагодарить tankrider, Skrilax_CZ и NestorM за то, что развеяли мои сомнения и за пожелания к моду.
Далее я хотел бы сказать спасибо сетевым сообществам моддеров Motorola, особенно ModMyMoto, которое меня взрастило, и MMUS, которое приняло меня в свои ряды. Оба сообщества очень дружелюбны и полезны, такими и будьте, ребята. Также и Motofan за выдающихся разработчиков.wink.gif
Change log:
This MP was originally based on R6637_G_81.11.2CR and it had a patched kernel that enabled swap, among some other features that are really only cosmetic. I decided to base this on R6637_G_81.00.7FR after it was discovered that it could record in QVGA. 7FR Camera libs won’t work on 2CR and while trying to make them work I ended up with a huge mess and other things started breaking. So I decided to base it on 7FR, unfortunately however, The custom kernel from 2CR will not run 100% well with 7FR, if it is flashed this way the wifi stops working. So I made a came to the conclusion QVGA was more important than a custom kernel with swap, therefore this firmware does NOT have SWAP capability. Im sure you guys will understand. If someone can get there hands on 7FR Source code please let me know so I can patch the kernel as this source is not available on Motorola’s site due to 7FR being a developers release.
История изменений:
МП изначально основывался на прошивке R6637_G_81.11.2CR с патченным ядром, включающим подкачку, а среди других изменений были в основном только косметические. Я решил перейти на R6637_G_81.00.7FR после того, как обнаружил, что в ней доступна запись видео в QVGA. Библиотеки (либы) камеры от 7FR не подходили для 2CR и в попытках заставить их работать я наломал немало дров, а точнее, работоспособного до того софта. Так что базовой стала 7FR, и, к сожалению, от самодельного ядра 2CR пришлось отказаться - на 100% с 7FR совместимым оно не было, после прошивки с ним отказывался работать wi-fi. Я решил, что запись видео в QVGA намного важнее, чем и ядро, и подкачка, поэтому эта прошивка БЕЗ функции СВОПА. Уверен, вы меня поймёте. А если у кого руки дойдут, и будут исходники 7FR, дайте мне знать - пропатчим ядро, а то так-то код недоступен на сайте Моторолы, ибо 7FR - релиз для разработчиков.
скрыть.
CG36 Mods:
  • MPKGBOX
  • QVGA Recording
  • Telnet&FTP (Modem&Tools)
  • Run Scripts from File Manager
  • Unrar and Unzip from File Manager
  • Show* Modules
  • Removal of certain modules to increase firmware speed
Extras:
  • Custom Bootscreen
  • Skins: Alkali, Kodak, Indium, Tuscan (Alkali is not present in 062A version)
Instructions (инструкция как шить)
  1. Use RSD Lite 4.x for all flashing - используем RSD версии 4.x для прошивки
  2. Flash noRSA bootloader that corresponds to your bootloader - сначала прошиваем бут noRSA
  3. Flash the version of Freedom 7FR that corresponds to your bootloader - прошиваем сответствующую версию прошивки для вашего бута (для 062А -062A Version 1a и т.д.)
  4. Flash Update 1B corresponding to your bootloader - прошиваем обновление (для 062A бута - Update 1B 062A)
  5. Прошиваем русский ленг отсюда: ЛЕНГПАКИ ДЛЯ ZN5
Download Link:This MP does NOT have the lost calls after reboot bug
Это делает MP не имеют потерянных вызовов после перезагрузки ошибка
Сообщение отредактировал AstaRoth - 30.6.2009, 16:05
1nTeRacT
сообщение 9.7.2009, 6:56
Пользователь №: 139 825
Модель телефона: MOTOZINE ZN5
Прошивка: G_81.03.0ER
Цитата(Pux42 @ 9.7.2009, 9:45) *
Мужики подскажите прошьюсь Motorola Software Update на родную-какие группы можно прошить для видео 320 240 радио с рдс поддержка зип архивов -данная прошивка не устраивает-1день держит батарею можно ли как продлить ей жизнь !
cg36 и cg52 можешь взять от этой проши! хотя думаю что смысла небудет... так же из-за этих групп будет мало держать батарею!
ink71
сообщение 9.7.2009, 18:48
Из: Республика Беларусь
Пользователь №: 103 216
Модель телефона: ZN5 t-Mobile
Прошивка: Шустрая ;)
Цитата(seregared1 @ 9.7.2009, 9:28) *
Блин а у меня WiFi не включается на этой проше (с апдейтом). Может у кого было такое и как побороли?
А апдейт явно 36 или 35 группа. Кодовые группы 36 и 35 от 0ER и 7FR не совсем корректно работают, если их перемешивать. Из-за этого твои проблемы. И, к сожалению, их не побороть (во всяком случае пока).
r.o.m.a.N
сообщение 9.7.2009, 20:19
Motoroma
Пользователь №: 95 283
Прошивка: 49R 4.4.4
Чтоб вафля работала, надо CG35 прошить от 07. В этой теме я выкладывал
OCM770
сообщение 10.7.2009, 5:29
I found the way to run custom kernel, thus the next release (hopefully tomorrow or the day after) will have Custom 2CR Kernel (SWAP included)
Я нашел способ запустить собственное ядро, таким образом, что следующий релиз (надеюсь завтра или послезавтра) будет иметь 2CR пользовательского ядра (SWAP включены)
Max75
сообщение 10.7.2009, 13:24
Из: Austria, Wien
Пользователь №: 47 985
Модель телефона: V8 Luxury /xt925 /X-Style
Чудное)
у всех на этой прошивке в файлменеджере не показывает превьюшки картинок?
на обычной прошивке у меня показывало превью на любые залитые с компа картинки, а тут показывает только на фотки которые им сделаны.
DeshFXs
сообщение 12.7.2009, 11:39
Из: Жуковский, МО
Пользователь №: 137 130
Модель телефона: Moto X
Прошивка: LiquidSmooth
Max75, многие жалуются, но у меня показывались(щас на новой сижу). Тогда ставил самую первую без обновлений
Pux42
сообщение 13.7.2009, 8:42
Пользователь №: 125 793
Модель телефона: L7E
SMG чем прошивать
1nTeRacT
сообщение 13.7.2009, 8:57
Цитата(Pux42 @ 13.7.2009, 12:42) *
SMG чем прошивать
из smg собрать sbf и прошить!
FAN_TV
сообщение 20.7.2009, 9:08
Из: UKRAINA
Пользователь №: 197 530
Модель телефона: XT907
Прошивка: LS KKBL V3.2
OCM770
Может вернемся к самой первой 7ER_64 // 000AA045, на ней все работает кроме стиранием списка вызовов при рестарте . А в остальном мне на все 100% она катит . Батарея ОК, СМС и Емаил ОК. камера мне нравится и фокус тоже , видео 240*320 вполне нормально и больше не хочу. Спасибо smile.gif
vergasi
сообщение 17.4.2010, 7:37
Пользователь №: 195 041
Модель телефона: l7
Прошивка: KILLER_acr
Что за хрень,вчера работали залитые с правами java,сегодня не открываются? helpsmilie.gif
Добавлено позже (17.4.2010, 10:45):
И ещё,на МТС ну никак не хочет любая аська работать.Опера работает.
hivjad
сообщение 25.4.2010, 15:11
Из: Крым,г. Керчь
Пользователь №: 189 908
Модель телефона: SE X10/Arc S/Xoom
Прошивка: 2.3.3/3.2
Я так понимаю,увеличили просто разрешение видео-съёмки,а "поднять" частоту кадров в секунду до 25-30к/с ревльно,а то толку от "старых" 15 при 320*240?
[MP] Freedom 7FR [MPKGBOX + QVGA], новый монстр! · Motorola ZINE ZN5, ZN5 T-Mobile · Forum
Текстовая версия Сейчас: 14.9.2025, 21:09
