8 страниц V « < 4 5 6 7 8 >
[MP] Freedom Features Update [SWAP + CIF + MPKGBOX]
OCM770
сообщение 10.7.2009, 7:33 Закрепленное сообщение!
Пользователь №: 196 171
By OCM770 in cooperation with Kidscracker and Skrilax_CZ
Based on R6637_G_81.00.7FR + R6637_G_81.11.2CR Fixes & Kernel
Credits
For this MP I would specially like to thank my friend Kidscracker, for helping me out on some things, backing me up on this project, and of course developing Mpkgbox, he is a great person and an awesome developer wink.gif
Second I would like to thank Skrilax_CZ for giving me great suggestions for this MP and of course patching the camera libs and mediaplayer lib. Also thanks to fldodger for fixing the Alkali skin and Skrilax for perfecting it.
Also thanks to Ant-ON for developing zTaskMan, AnarH and Tim_22R for making the main menu svg files
Then I would like to thank the Motorola modding communities on the net, especially ModMyMoto which is where I grew up and MMUS for taking me in as part of their team. Both communities very friendly and helpful, keep it up guys :D
Change log:
So I wasn’t satisfied with Freedom 7FR. I was convinced it was possible to run a custom kernel and have everything else working correctly. At last I figured out how to do so and took the opportunity to change more things, adding more features and some tweaks and bugfixes. So I present to you this MP which in my opinion excels over my previous one. As more mods come out and more developers obtain a ZN5 I will continue making more MP’s. I hope you like this MP wink.gif
Kernel Mods:
  • SWAP Support
  • Squashfs 3.4 Support. Now this is a real handy feature for developers. Using this kernel in another firmware you can use Squashfs 3.4 to squash the code groups using a block size of up to 1MB for a greater compression. It uses default block size of 128kb. Compared to Squashfs 2.2 with a max block size of 64kb.
  • EXT2, EXT3, NTFS Support
  • IPv6 support (needs to be tested)
CG36 Mods:
  • Bash (as a replacement for busybox ash)
  • busybox version 11.14.1 with many more features than standard busybox (as /bin/busybox_full)
  • EasyThemes by ilove3d (drop skin folders in /ezxlocal/download/mystuff/skins/) with SVG support.
  • Mediaplayer can play CIF videos.
  • zTaskMan included under Office Tools and Main Menu (in CG52)
  • Modification of some SVG files to edit softkey size in main menu and make main menu 15 icons
  • SWAP file gets turned off when connected in memory card mode and automatically re-enabled when disconnected from PC. This to avoid the phone crashing.
  • Mpkgbox (by kidscracker, original by ilove3d)
  • RAW and Binned RAW Pictures with fixed remaining picture estimate and red icons in iconres.ezx
  • CIF Recording 15FPS
  • Telnet&FTP (Modem&Tools)
  • Run Scripts from File Manager
  • Unrar and Unzip from File Manager
  • Show* Modules
  • Removal of certain modules to increase firmware speed
Extras:
  • Optional Features (read below)
  • Custom Bootscreen
  • Custom Startup/Shutdown Animations
  • 15 icon main menu (animated with optional features)
  • Skins: Alkali (fixed), Kodak, Indium
Optional Features & SWAP
Right after flashing this firmware the phone will prompt to install Optional Features. What these do is install the medl and medld.conf folder along with some GUI tweaks (changed font, main menu animation, etc). You can chose to install these in Phone Memory or Memory Card (I HIGHLY recommend installing them to phone memory). Either choosing to install these or to not install them the phone will only prompt once. (To make the script run again delete /ezxlocal/medl or if you chose not to install them delete /ezxlocal/delete_to_run_initial_script).
Even if you chose not to install Optional Features the phone will still prompt if you want to install and enable SWAP. Once again, you can install this feature to phone memory or memory card ( I still recommend to install to phone memory). You can chose a swap file size of 32mb or 64mb ( I recommend 64mb for 062A users and 32mb for 062DP users). This part of the script will also only run once (to make it run again remove /ezxlocal/delete_to_run_initial_swap and /ezxlocal/download/mystuff/swapfile (for internal memory) or /mmc/mmca1/swapfile (for external memory))
Instructions
  1. Use RSD Lite 4.x for all flashing
  2. Download the version that corresponds to your bootloader (062DP is also for 062B users)
  3. Flash noRSA bootloader that corresponds to your bootloader
  4. Flash the version of Freedom Features Update that corresponds to your bootloader
  5. Follow Optional Features Instructions and wait for it to reboot (if by any chance it doesn’t reboot wait 3-5 minutes then remove/reinsert battery)
Download Link: Known Bugs:
  • Volume for mediaplayer can’t be modified from homescreen
ПЕРЕВОД:
От OCM770, совместно с Kidscracker и Skrilax_CZ
Основан на R6637_G_81.00.7FR + R6637_G_81.11.2CR Испрвлениях & Ядре
Благодарности
За этот монстрпак я должен особенно поблагодарить моего друга Kidscracker-а, за помощь мне в нескольких вещах, за то что вернул меня в этот проект и, конечно, за разработку Mpkgbox. Он великий человек и офигенный разработчик.
Во-вторых я хочу поблагодарить Skrilax_CZ за большие предложения для этого MP и, конечно, за патчинг либ камеры и медиаплеера. Также спасибо fldodger-у за исправления скина Alkali и Skrilax за доведение его до ума.
Также спасибо Ant-ON-у за разработку zTaskMan-а, AnarH-у and Tim_22R за переделку svg файлов для главного меню.
Далее я хочу поблагодарить сообщества моддеров телефонов Motorola в сети, особенно ModMyMoto, где я вырос, и MMUS за то что взяли меня как часть своей команды. Оба этих сообщества очень дружелюбны и готовы помочь, будьте такими всегда, ребята.
Изменения:
Итак, я не удовлетворился Freedom 7FR. Я был убежден, что возможно запустить свое ядро и все будет работать правильно. Наконец, я понял как это можно сделать и воспользовался этой возможностью, чтобы изменить больше вещей, добавить больше возможностей и некоторое количество фишек и исправлений ошибок. Итак, я представляю вам этот MP, который, по моему мнению превосходит предыдущий. По мере появления новых модов и новых разработчиков, имеющих ZN5 я продолжу делать больше монстрепаков. Я надеюсь вам понравится этот MP.
Моды ядра:
  • Поддержка swap.
  • Поддержка Squashfs 3.4. Это действительно удобная функция для разработчиков. Используя это ядро в других прошивках вы можете использовать Squashfs 3.4 для сборки кодовых групп с размером блока до 1 мегабайта для большего сжатия. По умолчанию используется размер блока 128 килобайт. По сравнению с Squashfs 2.2 с максимальным размером блока 64 килобайта.
  • Поддержка EXT2, EXT3, NTFS
  • Поддержка Ipv6 (необходимо тестирование)
Моды в CG36:
  • Bash (как замена для busybox ash)
  • busybox версии 11.14.1 с намного большим количеством функций чем стандартный busybox (как /bin/busybox_full)
  • EasyThemes от ilove3d (кидайте скины в папку skin в /ezxlocal/download/mystuff/skins/) с поддержкой SVG.
  • Mediaplayer теперь может проигрывать CIF видео.
  • ZtaskMan, включенный в меню Органайзер и Главное меню (в CG52)
  • Модификация нескольких SVG файлов для изменения размера подписей к софт-клавишам и 15 иконок в галвном меню
  • Swap файл выключается, когда телефон подключается в режиме карты памяти и автоматически включается при отключении от ПК. Это позволяет избежать зависание телефона.
  • Mpkgbox (от kidscracker-а, изначально от ilove3d)
  • RAW и Binned RAW режимы фото с исправленными рамкой и иконками в iconres.ezx
  • CIF запись видео 15FPS
  • Запуск скриптов из файл-менеджера
  • Распаковка rar и zip из файл-менеджера
  • Show* модули
  • Удалены определенные модули для увеличения скорости работы прошивки
Дополнительно:
  • Дополнительные возможности (читайте ниже)
  • Измененная загрузочная картинка
  • Измененная анимация на включение/выключение
  • Главное меню с 15 иконками (анимированное с дополнительными возможностями)
  • Скины: Alkali (исправленный), Kodak, Indium
Дополнительные возможности & SWAP
Сразу после прошивки телефон спросит, устанавливать ли дополнительные возможности. Что при этом делается — устанавливается папка medl и medld.conf вместе с несколькими настройками GUI (измененный шрифт, главное меню, анимация и т.д.). Вы можете выбрать куда устанавливать, в память телефона или на карту памяти (я НАСТОЙЧИВО рекомендую устанавливать мод в память телефона). Неважно, выберите вы установку или отмену установки, телефон больше об этом не спросит. (Чтобы запустить скрипт снова удалите /ezxlocal/medl или, если вы выбрали не устанавливать, удалите файл /ezxlocal/delete_to_run_initial_script). Даже если вы выбрали не устанавливать дополнительные возможности телефон спросит, хотите ли вы установить и включить Swap. И снова, вы можете установить его в память телефона или на карту памяти ( я снова рекомендую устанавливать в память телефона). Вы можете выбрать размер swap-файла, 32 или 64 мегабайта (я рекомендую 64 мегабайта для пользователей с бутом 062A и 32 для пользователей с бутом 062DP). Эта часть скрипта также запускается только один раз (чтобы запустить его снова удалите /ezxlocal/delete_to_run_initial_swap и /ezxlocal/download/mystuff/swapfile (для памяти телефона) или /mmc/mmca1/swapfile (для карты памяти)).
Инструкции.
  1. Используйте RSD Lite 4.x для всех прошиваний
  2. Скачайте версию, которая соответсвует вашему бутлоадеру (062DP также подходит и для пользователей с 062B)
  3. Прошейте noRSA бут, который соответствует вашему буту.
  4. Прошейте версию Freedom Features Update, которая соответствует вашему буту.
  5. Следуйте инструкции установки дополнительных возможностей и ждите, пока телефон перезагрузится (если он не перезагрузится, подождите 3-5 минут и вытащите/вставьте батарею)
Ссылка для скачивания:Известные проблемы:
Громкость в медиаплеере нельзя изменить пока плеер свернут на главном экране.
Senx Lukas K. and Neomoto for translate on Russian
перевод на РУССКИЙ
Сообщение отредактировал EXL - 25.11.2010, 7:47
syberside
сообщение 30.7.2009, 18:58
Из: Новоуральск
Пользователь №: 176 082
Прошивка: ICS 4.0.4
AstaRoth как на твой взгляд качество фото по сравнению с другими прошами(05р,оер и т.д.)?
AstaROth: я не парюсь особо в сравнениях фоток с разных прош -мой опыт показывает что хорошие фотки можно получить на большинстве прошивок выбирая ракуср-освещенность - регулируя экспозицию и т.д. Меня устраивает полностью.
Сообщение отредактировал AstaRoth - 30.7.2009, 21:36
FAN_TV
сообщение 30.7.2009, 20:11
Из: UKRAINA
Пользователь №: 197 530
Модель телефона: XT907
Прошивка: LS KKBL V3.2
syberside
Если вы хотите я могу выложить фотки одним телефоном с разными прошами ! smile.gif
syberside
сообщение 30.7.2009, 20:43
Из: Новоуральск
Прошивка: ICS 4.0.4
ну тогда с меня плюс... но плз одно место с одного ракурса и при одном освещении.
иначе оценить коректно не получится.
ожно даже разные места, например улицу комнату и т.д.
D-1c3
сообщение 30.7.2009, 20:51
Пользователь №: 150 086
Прошивка: свежая
ну так че, мне обоснует кто нить в чем опасность свапа?
кстати, залейте прошу на айфолдер плс!! с меня +
SanchoNT
сообщение 30.7.2009, 21:21
Из: Нижний Тагил
Пользователь №: 184 870
Прошивка: 4.4.4
залил
http://ifolder.ru/13335352
FAN_TV
сообщение 30.7.2009, 22:38
Из: UKRAINA
Добавлено позже (30.7.2009, 22:50):
ну смотрите
Добавлено позже (30.7.2009, 22:52):
ну смотрите OER-O5R-7FR-FREDOV
Нард могу бросить полный зип все фотоки под надписями над каждой прошивкой !!!
Сообщение отредактировал FAN_TV - 30.7.2009, 23:00
syberside
сообщение 31.7.2009, 2:06
Из: Новоуральск
Прошивка: ICS 4.0.4
D-1c3, да не обоснует никто!!!
нет никакой опасности, даже тему закрыли (в разделе про линукс телы).
если не уверен ставь на флэшку.
FAN_TV, спасибо! сам хотел проверить, а тут уже готовые! так держать thumbsup.gif
AstaRoth, ну просто я очень много фоткаю, и особо с настройками играть времени обычно нет, "ловлю секунду" так сказать laugh.gif . По.тому и хочу знать как фотки поумолчанию
2all кстати у одного меня на 2цр 128 нет экспозиции?
Добавлено позже (31.7.2009, 8:23):
Кстати, видео и фото в одних либах хранится? если заменить либы камеры своими пропадет только рав? кто нить может попробовать нагрузить камеру на этом монстре? т.е. сделать подряд без остановки снимков 5? у меня уже на 2 писал что камера занята!а на моей проше сейчас хоть 20 снимков делай! ему все равно.
Stray39
сообщение 31.7.2009, 5:29
Пользователь №: 198 407
Модель телефона: MOTOZINE ZN5
Прошивка: пока не определился
Сравнивать снимки сделанные в разное время (по моему еще и в разные дни) с разным освещением.. не знаю...по этой подборке выходит что O5R самые галимые фото выдает.. как по мне то на любой прошивке фото практически одинаковые ( я не имею в виду эту подборку)...
Сообщение отредактировал Stray39 - 31.7.2009, 5:33
FAN_TV
сообщение 31.7.2009, 5:40
Из: UKRAINA
Stray39
Ну вот смотри 05R еще 2 фотки
Hitch
сообщение 31.7.2009, 10:35
Вечномолодой
Из: Рая
Пользователь №: 46 265
Прошивка: Bada 1.2
FAN_TV, отето вы выложили снимок 05R, в сравнении с другими прошивками. Там даже фокус не взялся laugh.gif
Когда просят выложить сравнительные фото - нужно делать всё в один день, в одно время(например обед...с 12ти по 3 часа дня) с нормальным фокусом. Тоесть делается по три кадра с каждой прошивки, выбирается по одному лучшему, и выкладываются.
А снимки с последнего вашего сообщения меня вообще убили. За всё время сколько у меня была зина - хуже снимков у меня сделать не получалось laugh.gif вы наверно нарошно запачкали дисплей пальцами и во время сьёмки трусили телефон?
Сообщение отредактировал Hitch - 31.7.2009, 10:36
D-1c3
сообщение 31.7.2009, 15:17
Прошивка: свежая
ну и отлично. а то пугают тут некоторые
Цитата(SanchoNT @ Сегодня, 1:21)
благодарю от души! бесят все предыдущие файлообменники
M@t@rol@4k@
сообщение 31.7.2009, 16:42
Из: УкраЇна
Пользователь №: 171 145
Прошивка: Android Pie 9
Monday - Party!
Как по мне так все понятно.05R лучше всех sport_boxing.gif ,далше 0ER,и в конце 7FR/FREEDOM thumbdown.gif
!Pavlik!
сообщение 31.7.2009, 16:53
Из: Нижний Новгород
Пользователь №: 160 141
Модель телефона: RAZR XT910
+1,ставил данный монстр,в итоге пришлось опять поставить 0ER
D-1c3
сообщение 31.7.2009, 19:17
Прошивка: свежая
да ну, вы чё.. я никогда с этого монстра не слезу уже. жду следующих обновлений
единственное что может не устраивать- качество фото, но по мне норм
syberside
сообщение 31.7.2009, 19:29
Из: Новоуральск
Прошивка: ICS 4.0.4
ну эт ты ещё 2CR 128/2BR 128 не видел (эт я говорю ващы фоты поглядев). biggrin.gif
Entom
сообщение 1.8.2009, 20:10
Из: Крыма!
Пользователь №: 159 951
Модель телефона: iPhone 4s
Прошивка: iOS 7
Люблю Apple, уважаю Motorola.
поставил эту прошу.
скажите это только у меня она так ужасно тормозит или криво встала?
AstaRoth: прошей еще раз строго следую инструкции - подключай 64 Мб свапа и т.д.
Сообщение отредактировал AstaRoth - 2.8.2009, 8:04
SanchoNT
сообщение 1.8.2009, 20:14
Из: Нижний Тагил
Прошивка: 4.4.4
Цитата(Entom @ 2.8.2009, 2:10) *
поставил эту прошу.
если юзать без свапа то наблюдаются ужасные лаги
CjYoung
сообщение 2.8.2009, 0:53
Пользователь №: 14 233
Модель телефона: Milestone, ZN5, L7
У меня проша залагала(так же как и от ТМПдо) через пару недель юзанья. Притом так жостко...
Чую что свап виноват. Тк на прошлой разработке фридома не было такого. Ходил радовался. Щас на 05R
D-1c3
сообщение 2.8.2009, 13:07
Прошивка: свежая
отличная проша. тел с ней стал более-менее юзабельным)
единственное что не нравится- наличие тетриса, судоку и оперы которые нельзя удалить)))
хотелось бы чтоб их убрали в следущих апдейтах
меня еще камера напугала при первом запуске. автофокус не работал. потом перезапустил и все стало норм
кстати куда лучше ставить свап? я сначала поставил и папку other и свап на флешку (это было моей ошибкой. при подключении к компу в режиме карты памяти шрифт и эфекты в меню обнулялись)
а теперь я все поставил в телефон. свап я думал лучше на флешку но там было написано phone memory (recomended)) и я не удержался, поставил как рекомендуется))
Добавлено позже (2.8.2009, 17:24):
Цитата(V!iT @ 24.7.2009, 10:51)
ruslan-yfa
ты случайно не ставил скрипт восстановления частоты каждую минуту?????
а то у меня тоже так было))
Цитата(Tobias37 @ 25.7.2009, 11:31)
Это все легко исправляется, нужно просто скрипт с поднятием частоты запихнуть в отдельный файлик и запустить его из любого авторана. Чтото вроде такого
/bin/sh /mmc/mmca1/.system/cpu_clock.sh
Тогда в камере все в порядке будет =)
что за скрипт?? где его взять?7
r.o.m.a.N
сообщение 2.8.2009, 14:59
Motoroma
Пользователь №: 95 283
Прошивка: 49R 4.4.4
Кто сказал что нельзя? о_О
D-1c3
сообщение 2.8.2009, 15:35
Прошивка: свежая
уместный вопрос) ну и как же их удалить?
sim_emrom
сообщение 2.8.2009, 16:09
Из: Ханты-Мансийск
Пользователь №: 195 802
Модель телефона: Spica
Прошивка: a.v.2.1
Если мешают - удали из UserMenuTree. Если из принципа против них - найди и удали другим макаром biggrin.gif
V!iT
Из: Украина -> Мелитополь
Пользователь №: 196 457
Модель телефона: Motorola ZN5
Прошивка: Symbiosis OER
удаляй это:
/ezxlocal/download/appwrite/am/InstalledDB
ВСЕ ЧТО УСТАНОВЛЕНО В ПАМЯТЬ ТЕЛЕФОНА - УДАЛИТСЯ!!!
sim_emrom
сообщение 2.8.2009, 16:11
Из: Ханты-Мансийск
Прошивка: a.v.2.1
D-1c3
сообщение 2.8.2009, 18:59
Прошивка: свежая
sim_emrom, мне с первого раза понятно))
V!iT, благодарю! отличный способ) буду знать)
Добавлено позже (2.8.2009, 23:55):
Entom
сообщение 2.8.2009, 22:06
Из: Крыма!
Прошивка: iOS 7
У меня телефон после этой проши стал зависать. У кого то такое было? очень похоже, что забивается оперативка.
syberside
сообщение 2.8.2009, 23:16
Из: Новоуральск
Прошивка: ICS 4.0.4
Entom а ты на что откатился?
Entom
сообщение 3.8.2009, 4:18
Из: Крыма!
Прошивка: iOS 7
Я неправильно выразился. У меня на этой прошивке зависания. Кто-нить знает как оперативу чичтить, свап?
D-1c3
сообщение 3.8.2009, 14:18
Прошивка: свежая
а куда лучше свап ставить? вроде если на флешку поставить то тел пошустрее пашет. или я не прав?
Lukas K.
сообщение 3.8.2009, 14:24
Из: Омск
Пользователь №: 140 402
Прошивка: NSv2.1 + ZE0.9b
D-1c3, ну рекомендованно в память телефона) не, если свап на флешке, то не быстрее..
insanity
сообщение 4.8.2009, 5:38
Из: Himki
Пользователь №: 135 172
Модель телефона: ZN5
Цитата(D-1c3 @ 3.8.2009, 20:18) *
кто нить пробовал вешать таск ман встроенный в прошу на клавишу галереи?
если да, то как? или выложите файлы готовые.
а то я чёт не задумываясь сделал все по мануалу из темы про зтаскман и получилось так что у меня их 2 независимых smile.gif один в меню, а другой на кнопке галереи
кстати маджикс бокс не вешается на галерею при нажатии load. да даже если б и вешался, от него толку никакого. незарегистрированый он крайне бесполезный. работает только одна полезная функция- sysinfo
Я повесил.. Таким же способом как написанно в теме "Устанавливаем zTaskMan и вешаем его на кнопку галереи" с той лишь разницей, что вставлять ничего не надо, т.к. zTaskMan уже есть в этом списке. Просто заменить строки.
Entom
сообщение 4.8.2009, 9:11
Из: Крыма!
Прошивка: iOS 7
Объясняю.
1. Видеосъемка виснет;
2. Частые непроизвольные зависания;
3. Программы довольно долго открываются;
4. Фотографии получаются просто ужас;
5. Плеер ужасно заикаится и тормозит;
6. Очень мало держит батарея (по несколько раз за день заряжал).
Пока всё.
M@t@rol@4k@
сообщение 4.8.2009, 11:23
Из: УкраЇна
Monday - Party!
Чтобы не быть голословным поддержу аргументы Entom'a.Никакого чудо-ускорения не было.Наоборот после 0ER с правленной либой этот монстр выглядел ужасным тормозом.Камерой пользоватся нереально когда фоткаешь картинка на экране зависает и махать телефоном в стороны бесполезно,о качестве фото я вообще промолчу (((,видео он редко сохранит,постоянно зависает.Плеер тут работает все же медленнее.Все плюсы MPKGBOX'A нивелируются его медлительностью,программы в нем порой минутами открываются, а порой вообще нет реакции.И из-за этой я вспомнил свой RAZR2 V8.Но там была причина его магко говоря недлительной работы,а тут при таком не самом слабом АКБ просто недопустимо заряжать каждый день при пассивном использовании и по 2 раза в день при активном.
И не надо писать,что я типа не понял как SWAP включить и что это все я где-то недоглядел.Если бы!.Самому хочется MPKGBOX но он не стоит того,чтобы эту прошу ставить!
Сообщение отредактировал M@t@rol@4k@ - 4.8.2009, 11:25
D-1c3
сообщение 4.8.2009, 14:12
Прошивка: свежая
insanity, благодарю!
Entom, M@t@rol@4k@, не знаю, извините че там у вас. для меня это звучит как бред. эта проша самая быстрая из всех что я перепробовал (а перепробовал я практически все)
и никаких глюков и подвисаний. наобород всё очень быстро и оперативки всегда хватает.
и снимки нормальные! не намного хуже чем в 0ER. меня устраивает вполне. на снимках всегда всё различимо)
короче я доволен. лучше проши для себя ещё не встречал
M@t@rol@4k@
сообщение 4.8.2009, 16:18
Из: УкраЇна
Monday - Party!
D-1c3,
Я всегда изначально считаю людей достаточно развитыми в плане мышления (хотя по практике не все такие) и чтобы изменить мое мнение нужно "отличится".Я тебя ни в коем случаи не держу за дебила,но я же тоже врать не стану??!Еще китаец не начал нам выплачивать пособия из своего дохода,если мы будем хвалить его монстр и обплевывать остальные наработки...
Сообщение отредактировал M@t@rol@4k@ - 4.8.2009, 16:20
сообщение 4.8.2009, 20:00
Вы даже не представляете как меня начинает злить -когда куча нахлебников сидит и критикует по чем есть-а сам ировным счетом НИЧЕГо не сделали. Вы написали какую либо программу? Кто-то на МФ видел ваш монстр чудесны и безглючный? Вобщем еще раз флуд начнется и мы распрощаемся надолго. Я просто предупредил smile.gif
To Entom, из описанных тобою пунктов отвечу:
1. Видеосъемка виснет; - у меня она висла на всех модах кроме 05 заводской проши. И еще - в таком разрешении - которое в модах кроме фридома - видео не знаю как вам- но мне точно не нужно никак. Пункт видеосъемка для меня на всех прошах кроме Фридома просто несуществует
2. Частые непроизвольные зависания - не встречал такого. что сделать нужно чтоб тел зависал? прошит Фридом -полет нормальный который день.
3. Программы довольно долго открываются- да? опять таки -не замечал.у меня все шустро.
4. Фотографии получаются просто ужас- просто ужас? а у меня чуть хуже чем на 05 проше не более того
5. Плеер ужасно заикаится и тормозит-на всех прошивках у моторолы плейер заикается и ужасно тормозит!
6. Очень мало держит батарея (по несколько раз за день заряжал) - дольше всего на заводской проше батарея держала- как прошил -все меньше и меньше и у всех так всегда было есть и будет.
V!iT
сообщение 4.8.2009, 20:18
Видеосъемка виснет - а кто то пробовал поставить 532мегагерц и ВЫключить автосохранение!?!?!?!
У меня НИРАЗУ не зависал!
Все работает шустро!
плеер НЕ заикается,зависит от ленга! ИМХО
У меня НЕ стоит либа правленная!
Сообщение отредактировал V!iT - 4.8.2009, 20:18
syberside
сообщение 4.8.2009, 20:26
Из: Новоуральск
Прошивка: ICS 4.0.4
AstaRoth извени конечно, но вопрос про версию по моему можно было оставить shout.gif ...
AstaRoth: флуда очень много - если тебе так важен вопрос- напиши его еще раз
Сообщение отредактировал AstaRoth - 4.8.2009, 21:11
Glyad
сообщение 5.8.2009, 6:36
Пользователь №: 107 060
Модель телефона: Motorola ROKR E1 ZN5
Многие так хвалят этого монстра, а я не пойму неужели ни у кого нет элементарной на первый взгляд проблемы с блокировкой и выходом из нее? И последующим зависанием экрана? Все остальное - качество фото, видео, скорость меня тоже устраивает. Я все жду обновления и устранения этого трабла, если кто поможет буду благодарен smile.gif
FAN_TV
сообщение 5.8.2009, 7:58
Из: UKRAINA
Glyad
У меня меньше пол доли секунды !!! И обще все летает !!!! smile.gif thumbsup.gif
[MP] Freedom Features Update [SWAP + CIF + MPKGBOX] · Motorola ZINE ZN5, ZN5 T-Mobile · Forum
Текстовая версия Сейчас: 10.9.2025, 13:34
