8 страниц V < 1 2 3 4 > »
[MP] Freedom Features Update [SWAP + CIF + MPKGBOX]
OCM770
сообщение 10.7.2009, 7:33 Закрепленное сообщение!
Пользователь №: 196 171
By OCM770 in cooperation with Kidscracker and Skrilax_CZ
Based on R6637_G_81.00.7FR + R6637_G_81.11.2CR Fixes & Kernel
Credits
For this MP I would specially like to thank my friend Kidscracker, for helping me out on some things, backing me up on this project, and of course developing Mpkgbox, he is a great person and an awesome developer wink.gif
Second I would like to thank Skrilax_CZ for giving me great suggestions for this MP and of course patching the camera libs and mediaplayer lib. Also thanks to fldodger for fixing the Alkali skin and Skrilax for perfecting it.
Also thanks to Ant-ON for developing zTaskMan, AnarH and Tim_22R for making the main menu svg files
Then I would like to thank the Motorola modding communities on the net, especially ModMyMoto which is where I grew up and MMUS for taking me in as part of their team. Both communities very friendly and helpful, keep it up guys :D
Change log:
So I wasn’t satisfied with Freedom 7FR. I was convinced it was possible to run a custom kernel and have everything else working correctly. At last I figured out how to do so and took the opportunity to change more things, adding more features and some tweaks and bugfixes. So I present to you this MP which in my opinion excels over my previous one. As more mods come out and more developers obtain a ZN5 I will continue making more MP’s. I hope you like this MP wink.gif
Kernel Mods:
  • SWAP Support
  • Squashfs 3.4 Support. Now this is a real handy feature for developers. Using this kernel in another firmware you can use Squashfs 3.4 to squash the code groups using a block size of up to 1MB for a greater compression. It uses default block size of 128kb. Compared to Squashfs 2.2 with a max block size of 64kb.
  • EXT2, EXT3, NTFS Support
  • IPv6 support (needs to be tested)
CG36 Mods:
  • Bash (as a replacement for busybox ash)
  • busybox version 11.14.1 with many more features than standard busybox (as /bin/busybox_full)
  • EasyThemes by ilove3d (drop skin folders in /ezxlocal/download/mystuff/skins/) with SVG support.
  • Mediaplayer can play CIF videos.
  • zTaskMan included under Office Tools and Main Menu (in CG52)
  • Modification of some SVG files to edit softkey size in main menu and make main menu 15 icons
  • SWAP file gets turned off when connected in memory card mode and automatically re-enabled when disconnected from PC. This to avoid the phone crashing.
  • Mpkgbox (by kidscracker, original by ilove3d)
  • RAW and Binned RAW Pictures with fixed remaining picture estimate and red icons in iconres.ezx
  • CIF Recording 15FPS
  • Telnet&FTP (Modem&Tools)
  • Run Scripts from File Manager
  • Unrar and Unzip from File Manager
  • Show* Modules
  • Removal of certain modules to increase firmware speed
Extras:
  • Optional Features (read below)
  • Custom Bootscreen
  • Custom Startup/Shutdown Animations
  • 15 icon main menu (animated with optional features)
  • Skins: Alkali (fixed), Kodak, Indium
Optional Features & SWAP
Right after flashing this firmware the phone will prompt to install Optional Features. What these do is install the medl and medld.conf folder along with some GUI tweaks (changed font, main menu animation, etc). You can chose to install these in Phone Memory or Memory Card (I HIGHLY recommend installing them to phone memory). Either choosing to install these or to not install them the phone will only prompt once. (To make the script run again delete /ezxlocal/medl or if you chose not to install them delete /ezxlocal/delete_to_run_initial_script).
Even if you chose not to install Optional Features the phone will still prompt if you want to install and enable SWAP. Once again, you can install this feature to phone memory or memory card ( I still recommend to install to phone memory). You can chose a swap file size of 32mb or 64mb ( I recommend 64mb for 062A users and 32mb for 062DP users). This part of the script will also only run once (to make it run again remove /ezxlocal/delete_to_run_initial_swap and /ezxlocal/download/mystuff/swapfile (for internal memory) or /mmc/mmca1/swapfile (for external memory))
Instructions
  1. Use RSD Lite 4.x for all flashing
  2. Download the version that corresponds to your bootloader (062DP is also for 062B users)
  3. Flash noRSA bootloader that corresponds to your bootloader
  4. Flash the version of Freedom Features Update that corresponds to your bootloader
  5. Follow Optional Features Instructions and wait for it to reboot (if by any chance it doesn’t reboot wait 3-5 minutes then remove/reinsert battery)
Download Link: Known Bugs:
  • Volume for mediaplayer can’t be modified from homescreen
ПЕРЕВОД:
От OCM770, совместно с Kidscracker и Skrilax_CZ
Основан на R6637_G_81.00.7FR + R6637_G_81.11.2CR Испрвлениях & Ядре
Благодарности
За этот монстрпак я должен особенно поблагодарить моего друга Kidscracker-а, за помощь мне в нескольких вещах, за то что вернул меня в этот проект и, конечно, за разработку Mpkgbox. Он великий человек и офигенный разработчик.
Во-вторых я хочу поблагодарить Skrilax_CZ за большие предложения для этого MP и, конечно, за патчинг либ камеры и медиаплеера. Также спасибо fldodger-у за исправления скина Alkali и Skrilax за доведение его до ума.
Также спасибо Ant-ON-у за разработку zTaskMan-а, AnarH-у and Tim_22R за переделку svg файлов для главного меню.
Далее я хочу поблагодарить сообщества моддеров телефонов Motorola в сети, особенно ModMyMoto, где я вырос, и MMUS за то что взяли меня как часть своей команды. Оба этих сообщества очень дружелюбны и готовы помочь, будьте такими всегда, ребята.
Изменения:
Итак, я не удовлетворился Freedom 7FR. Я был убежден, что возможно запустить свое ядро и все будет работать правильно. Наконец, я понял как это можно сделать и воспользовался этой возможностью, чтобы изменить больше вещей, добавить больше возможностей и некоторое количество фишек и исправлений ошибок. Итак, я представляю вам этот MP, который, по моему мнению превосходит предыдущий. По мере появления новых модов и новых разработчиков, имеющих ZN5 я продолжу делать больше монстрепаков. Я надеюсь вам понравится этот MP.
Моды ядра:
  • Поддержка swap.
  • Поддержка Squashfs 3.4. Это действительно удобная функция для разработчиков. Используя это ядро в других прошивках вы можете использовать Squashfs 3.4 для сборки кодовых групп с размером блока до 1 мегабайта для большего сжатия. По умолчанию используется размер блока 128 килобайт. По сравнению с Squashfs 2.2 с максимальным размером блока 64 килобайта.
  • Поддержка EXT2, EXT3, NTFS
  • Поддержка Ipv6 (необходимо тестирование)
Моды в CG36:
  • Bash (как замена для busybox ash)
  • busybox версии 11.14.1 с намного большим количеством функций чем стандартный busybox (как /bin/busybox_full)
  • EasyThemes от ilove3d (кидайте скины в папку skin в /ezxlocal/download/mystuff/skins/) с поддержкой SVG.
  • Mediaplayer теперь может проигрывать CIF видео.
  • ZtaskMan, включенный в меню Органайзер и Главное меню (в CG52)
  • Модификация нескольких SVG файлов для изменения размера подписей к софт-клавишам и 15 иконок в галвном меню
  • Swap файл выключается, когда телефон подключается в режиме карты памяти и автоматически включается при отключении от ПК. Это позволяет избежать зависание телефона.
  • Mpkgbox (от kidscracker-а, изначально от ilove3d)
  • RAW и Binned RAW режимы фото с исправленными рамкой и иконками в iconres.ezx
  • CIF запись видео 15FPS
  • Запуск скриптов из файл-менеджера
  • Распаковка rar и zip из файл-менеджера
  • Show* модули
  • Удалены определенные модули для увеличения скорости работы прошивки
Дополнительно:
  • Дополнительные возможности (читайте ниже)
  • Измененная загрузочная картинка
  • Измененная анимация на включение/выключение
  • Главное меню с 15 иконками (анимированное с дополнительными возможностями)
  • Скины: Alkali (исправленный), Kodak, Indium
Дополнительные возможности & SWAP
Сразу после прошивки телефон спросит, устанавливать ли дополнительные возможности. Что при этом делается — устанавливается папка medl и medld.conf вместе с несколькими настройками GUI (измененный шрифт, главное меню, анимация и т.д.). Вы можете выбрать куда устанавливать, в память телефона или на карту памяти (я НАСТОЙЧИВО рекомендую устанавливать мод в память телефона). Неважно, выберите вы установку или отмену установки, телефон больше об этом не спросит. (Чтобы запустить скрипт снова удалите /ezxlocal/medl или, если вы выбрали не устанавливать, удалите файл /ezxlocal/delete_to_run_initial_script). Даже если вы выбрали не устанавливать дополнительные возможности телефон спросит, хотите ли вы установить и включить Swap. И снова, вы можете установить его в память телефона или на карту памяти ( я снова рекомендую устанавливать в память телефона). Вы можете выбрать размер swap-файла, 32 или 64 мегабайта (я рекомендую 64 мегабайта для пользователей с бутом 062A и 32 для пользователей с бутом 062DP). Эта часть скрипта также запускается только один раз (чтобы запустить его снова удалите /ezxlocal/delete_to_run_initial_swap и /ezxlocal/download/mystuff/swapfile (для памяти телефона) или /mmc/mmca1/swapfile (для карты памяти)).
Инструкции.
  1. Используйте RSD Lite 4.x для всех прошиваний
  2. Скачайте версию, которая соответсвует вашему бутлоадеру (062DP также подходит и для пользователей с 062B)
  3. Прошейте noRSA бут, который соответствует вашему буту.
  4. Прошейте версию Freedom Features Update, которая соответствует вашему буту.
  5. Следуйте инструкции установки дополнительных возможностей и ждите, пока телефон перезагрузится (если он не перезагрузится, подождите 3-5 минут и вытащите/вставьте батарею)
Ссылка для скачивания:Известные проблемы:
Громкость в медиаплеере нельзя изменить пока плеер свернут на главном экране.
Senx Lukas K. and Neomoto for translate on Russian
перевод на РУССКИЙ
Сообщение отредактировал EXL - 25.11.2010, 7:47
Злодей
сообщение 10.7.2009, 17:57
Из: Чебоксары
Пользователь №: 51 069
Модель телефона: Мото Зайн
Прошивка: 7fr
Господа, перезалейте, плиз, прошу на другие сервера.. С www.mediafire.com чет не качает ((
Nuke142
сообщение 10.7.2009, 18:46
Пользователь №: 201 901
Модель телефона: ZN5
Зеркала:
http://multi-up.com/115472
http://share.netbynet.ru/862Freedom_Features_Update_062A.rar
А вообще, фигня этот ваш Raw и Binded Raw - в этих режимах телефон позже делает снимок, не попадая в момент вспышки и опаздывая. Фото получаются вообще без намека на освещенность thumbdown.gif
Ну блин.. теперь снятие видео в режиме Large повисло на 11 секунде и помогло только вытаскивание аккумулятора.
Сообщение отредактировал Nuke142 - 10.7.2009, 18:52
insanity
сообщение 10.7.2009, 18:55
Из: Himki
Пользователь №: 135 172
letitbit.net
Entom
сообщение 10.7.2009, 19:05
Из: Крыма!
Пользователь №: 159 951
Модель телефона: iPhone 4s
Прошивка: iOS 7
Люблю Apple, уважаю Motorola.
Т.е. также висит при съемке как и в предыдущей версии. А плеер тормозит также?
Stray39
сообщение 10.7.2009, 19:19
Пользователь №: 198 407
Модель телефона: MOTOZINE ZN5
Прошивка: пока не определился
Подскажите после установки этой проги при подключении к PSD в первой строке выводит --PSTSendCommand
а уж потом во второй Зина! Что это!? PSTSendCommand
Сообщение отредактировал Stray39 - 10.7.2009, 19:20
1nTeRacT
сообщение 10.7.2009, 19:20
Пользователь №: 139 825
Прошивка: G_81.03.0ER
у меня в предыдущей версии снимало всё нормально ничего не висло...
CjYoung
сообщение 10.7.2009, 20:07
Пользователь №: 14 233
Модель телефона: Milestone, ZN5, L7
Висло. притом постоянно, читал выше люди пишут, что опять виснет. Плеер летает!
DeshFXs
сообщение 10.7.2009, 20:17
Из: Жуковский, МО
Пользователь №: 137 130
Модель телефона: Moto X
Прошивка: LiquidSmooth
CjYoung, ничего не виснет, видео 20 минут снимал, в RAW отлично снимает, все отл =)
CjYoung
сообщение 10.7.2009, 20:36
только что 11 сек записал - завис на последнем кадре. БЛИНСТВО. такая сьёмка не пойдёт, через рас. вдруг заснять чото надо а оно хоп и зависло. Автору переведите там. БАГ довольно неприятный.
M@t@rol@4k@
сообщение 10.7.2009, 20:37
Из: УкраЇна
Пользователь №: 171 145
Прошивка: Android Pie 9
Monday - Party!
Freedom II Turbo
CG36 с правленной (либа из этой проши,правленная вручную) либой libezxappbase.so.1.0.0 по методу "Делаем ZN5 быстрее".Шить поверх самой проши.
http://webfile.ru/3766708
Freedom II LP002EE
ПОЛНЫЙ языковой пакет для этой проши.
http://webfile.ru/3766711
Сообщение отредактировал M@t@rol@4k@ - 10.7.2009, 21:47
Nuke142
сообщение 10.7.2009, 20:52
M@t@rol@4k@, либа исправляет зависания видео, или запаздывание снятия фото, которое происходит после вспышки ?
И надеюсь в ближайшие дни кто-нибудь выскажится на счет потребления энергии с этой прошивкой.
Сообщение отредактировал Nuke142 - 10.7.2009, 20:52
Stray39
сообщение 10.7.2009, 20:54
Freedom II Turbo
CG36 с правленной либой libezxappbase.so.1.0.0 по методу "Делаем ZN5 быстрее".Шить поверх самой проши.
НЕ СТАВИТСЯ!
M@t@rol@4k@
сообщение 10.7.2009, 20:55
Из: УкраЇна
Monday - Party!
Nuke142,
Нет,это дает возможность использования стандартного лэнга.По ускорению равно турболэнгу.Только что пофоткал.Такого ГаФФна я уже давно не видел(((((.Даже не знаю,наверно завтра на 0ER откачусь.Фотки УЖАСНЫЕ.Камера тормозит( в режиме видоискателя.)Все фотки размытые((((.Телефон все равно тормозит((.Вообщем кошмар.
Добавлено позже (10.7.2009, 23:56):
Stray39,
Я только что себе прошил.
Еще постоянно греется батарея.При проигрывании видео опять тупит.
Сообщение отредактировал M@t@rol@4k@ - 10.7.2009, 21:00
Stray39
сообщение 10.7.2009, 21:00
Stray39,
M@t@rol@4k@
сообщение 10.7.2009, 21:01
Из: УкраЇна
Monday - Party!
Вообщем проша глючная до потери ума.
Добавлено позже (11.7.2009, 0:05):
При проигрывании фильма завис намертво.Шью 0ER.
Сообщение отредактировал M@t@rol@4k@ - 10.7.2009, 21:03
Gadzil88
сообщение 10.7.2009, 21:05
Пользователь №: 114 586
Модель телефона: Z6; ZN5, milestone
Прошивка: хз
качество фото не очень и видео виснет на 9 - 12 сек.
M@t@rol@4k@
сообщение 10.7.2009, 21:07
Из: УкраЇна
Monday - Party!
Еще и сам перезагрузился ((((((((((
Добавлено позже (11.7.2009, 0:09):
Из-за этого полдня мучал HDD'шники чтоб Linux паралелльно поставить и либу всунуть.(Думал,что вообще ракета будет thumbdown.gif ).Ставить крайне не рекомендую.RAW и Binned RAW не нужны при таком качестве фотканья.Да и цена за видео большая получается.Глючит везде.Зависает.Перезагружается.Еще и предложил SWAP в телефон поставить spiteful.gif sport_boxing.gif thumbdown.gif (Эт чтоб вся моя память в теле накрылась через полгода).Ни одно видео даже 720х640(Samsung Omnia II,5MP) этого не стоят.Да,обидно,что iPhone 3GS с 3MP снимает в VGA разрешении.Но ЭТО просто извращенство.
Сообщение отредактировал M@t@rol@4k@ - 10.7.2009, 21:43
ssasha
сообщение 10.7.2009, 21:26
Пользователь №: 51 199
Модель телефона: e398, zn5, Defy
Выскажу свое впечатление.
Телефон очень долго включается и сильно тормозит, видеокамера виснет, меню теперь не помещается в экран и имеет нелепую анимацию. Шрифт чудовищный. Такое впечатление что очень хотелось внести максимум визуальных изменений в сравнительно неплохое оформление, которое таким трудом далось мотороле.
Работающая почта и загадочный свап того не стоят. Вернусь на предидущую версию.
Stray39
сообщение 10.7.2009, 21:47
Проша сырая это факт! Но парень то много работы сделал, а это чего то да и стоит ( учитывая что остальные моды просто остановились в развитии полностью) так что думаю что эти не доработки со временем будут устранены... thumbsup.gif и ребята по добрей надо быть.....
M@t@rol@4k@
сообщение 10.7.2009, 21:53
Из: УкраЇна
Monday - Party!
Stray39,
Это не от злости.Это конструктивная критика.Работы очень много было сделано.Это факт.Но эти глюки невозможно убрать!Это связано с тем,что это инженерная проша.Автор и так скрестил ее с 128-мегабайтным вариантом для исправления критических ошибок и совместимости с обеими вариантами железа.Если хвататся за видео,то толку не будет.Если же делать все то же на 0ER (камера не в счет),то это тоже отличная проша была бы.И работала бы в разы шустрее.Я уважаю работу автора,но эти глюки часть этой проши.
Сообщение отредактировал M@t@rol@4k@ - 10.7.2009, 21:56
Stray39
сообщение 10.7.2009, 22:21
Значт так перепрошил прогу по новой и не ставил не турболенгов не правленых либ на ускорение, чистая проша... видео отсняло 1 минуту без проблем и не зависло...
OCM770
сообщение 10.7.2009, 22:59
No Offense but if you dont like it dont use it, simple as that.
VGA RECORD CAN NOT AND WILL NEVER BE ABLE TO BE DONE... EVER!!!!! The hardware does not support it!!
Не преступление, но если вам не нравится Dont его использовать, просто.
VGA ОТЧЕТ не может и никогда не может быть сделано ... EVER !!!!! Аппаратура не может поддержать его!!
Stray39
сообщение 10.7.2009, 23:03
OCM770 you well done you all get! Good luck!
CjYoung
сообщение 11.7.2009, 1:44
Хорошо, что понимаете, что создатель сделал много. но я так же скажу прошивочка посырее предыдущих будет. А так - очень хорошо, я доволен. Уже своп - это огромный плюс. Не пишет закрыть приложения. Пока на ней посижу, потещу. но видео не стоит фото(тоесть видео есть, но виснет. и фокус галимый)
trace2343
сообщение 11.7.2009, 2:31
Из: UA
Пользователь №: 199 910
Модель телефона: zn5
Прошивка: R6637_G_81.05ER
OCM770 БОЛЬШОЕ СПАСИБО за разработку! есть огрехи но они устраняться!
Stray39
сообщение 11.7.2009, 7:04
А нельзя ли прикрутить к этой проге либу от предыдущей версии с разрешением 240Х320 и ускорением , но так чтобы работал zTaskMan и MPKGBOX? А то я поставил тот что был так они естественно перестали работать... shuffle.gif
portapro
сообщение 11.7.2009, 8:19
Пользователь №: 202 542
Прошивка: Symbiosis 3
как у вас видео зависает?сколько не пробовал никогда не зависло!прошивка нравиться пока ,есть недоработки...а так все устраивает на 100%, перезагрузок тоже не было.
1nTeRacT
сообщение 11.7.2009, 8:49
вот и у меня так же.... видео раньше тоже не зависало... и не перегружается щас...) пока всё устраивает!
Сообщение отредактировал 1nTeRacT - 11.7.2009, 8:49
SUF-X
сообщение 11.7.2009, 9:32
Пользователь №: 106 092
Модель телефона: ZN5, ROKR E1
Прошивка: FreedomUF, DaR_79R
автофокус работает, если расстояние меньше 0,5 метра
M@t@rol@4k@
сообщение 11.7.2009, 10:00
Из: УкраЇна
Monday - Party!
OCM770,
I respect your work.A lot of features in this FW were impossible till this mod.I just say,that majority of its bugs can't be solved.They are a part of FW.Enabling of CIF recording is a great achievment!But now it's very unstable.
Добавлено позже (11.7.2009, 13:03):
У меня лично есть такая идея.Только это для понимающих.Надо сравнить файлы которые отвечают за сьемку видео в 7FR и 05R/0ER.Теоретически,если найти зависимость,то можно просто оставить алгоритм фотосьемки от 05R/0ER и заменить/добавить нужные алгоритмы для снятия видео от 7FR.
Просто уже выяснилось,что простой заменой файлов дело не решается,видимо есть еще какие-то файлы,которые за это отвечают.
Я конечно понимаю,что проще сказать,чем сделать.Но логичнее будет пойти таким путем,чем дальше "насиловать" инженерную прошу.
Сообщение отредактировал M@t@rol@4k@ - 11.7.2009, 10:09
Gadzil88
сообщение 11.7.2009, 10:44
Прошивка: хз
видео перестало виснуть.
странно.))))))
Спасибо Автору за разработку!
Сообщение отредактировал Gadzil88 - 11.7.2009, 10:45
Кипелов
сообщение 11.7.2009, 11:42
Пользователь №: 106 051
Модель телефона: V360\A853\XT862
Прошивка: HOT MIX V360\2.2\906
Выложите несколько фоток. Просто интересно на сколько хуже стоковой фотографирует. а видео сколько кадров\сек снимает?
D-1c3
сообщение 11.7.2009, 11:58
Пользователь №: 150 086
Прошивка: свежая
товарищи, обратите внимание на этот псот. чё все ленивые такие?? уже куча удобных скриншутеров есть! mad.gif
и еще. чё все так боятся свапа? назовите мне хоть одного человека у которого через полгода из за него испортился телефон
!Pavlik!
сообщение 11.7.2009, 12:10
Из: Нижний Новгород
Пользователь №: 160 141
Модель телефона: RAZR XT910
Пример фотки на этой проше
DeshFXs
сообщение 11.7.2009, 12:14
Из: Жуковский, МО
D-1c3, кто боится свапа? 0_о
Скрины нету толка делать - все тоже, только в меню 15 иконок, все остальное далется своими ручками. Что такого ты хочешь на скринах увидеть?
Видео снимает шикарно по сравнению со всем что было, качество фото не изменилось, работает в разы шустрее (скорость почти не меняется после прошивки турбо ленга) вообще не тупит. Менеджер задач работает без сбоев, многозадачность ява не проверял, но по случайности запустил kdplayer и асю - работали вместе, с 3мя уже напряги(просит закрыть одно) браузер не тупит. У кнопки галереи осталось прямое назначение. Незнаю что еще сказать.
D-1c3
сообщение 11.7.2009, 12:22
Прошивка: свежая
Цитата(M@t@rol@4k@ @ Сегодня, 1:07)
Еще и предложил SWAP в телефон поставить (Эт чтоб вся моя память в теле накрылась через полгода)
FAN_TV
сообщение 11.7.2009, 13:28
Из: UKRAINA
Пользователь №: 197 530
Модель телефона: XT907
Прошивка: LS KKBL V3.2
Вот фото одним телефоном с разными прошами 1-05, 2-7Fr,3- FRED . Сравнивайте . Один минус Батарея плохо держит. А в остальном thumbsup.gif thumbsup.gif thumbsup.gif
DeshFXs
сообщение 11.7.2009, 13:46
Из: Жуковский, МО
FAN_TV, И...? средняя конешн лучше, но тут все дело в освещении, если уж сравнивать, то нужно фотографировать что-то одно и делать это в течение минут 30и
Mar4elo
сообщение 11.7.2009, 13:48
Пользователь №: 191 089
Прошивка: Symbiosis III
Прошил сегодня. С самого начала, проша действительно чуток тупила. Дальше, не знаю как, начала бегать шустро по меню.
Плеер тупит. Во время проигрывания песни, меняеш громкость, начинает жувать звук.))))
Снял видео. Хватило на 2 сек и зависло. Хотя мне та видео по барабану. Почти никогда не пользовался этой функцией.
Раздражает полоса, которая внизу, когда смотриш список звонков.
Спасибо автору за работу.
Сообщение отредактировал Mar4elo - 11.7.2009, 13:54
Hitch
сообщение 11.7.2009, 14:39
Вечномолодой
Из: Рая
Пользователь №: 46 265
Прошивка: Bada 1.2
вчера поставил себе эту прошу, ощущения:
Неприятные моменты:
* в режиме блокировки если будет нажата какая-то кнопка, и после неё сдвинуть ползунок в сторону разблокировки - телефон подвисает секунды на 3. неприятно.
* в "Вызовы" последняя строчка не отображается, и там отображается часть фоновой картинки и дата. (как выяснили устраняется путём залития стандартного шрифта)
* телефон весьма серьёзно тупит в плеере, тормозит в сравнении с 0ер прошей.
* само по себе передвижение по меню и подпунктам (например вход в "Поиск Медиа" и "Профили") подтормаживает больше, чем, скажем, на 0ер.
* качество фотоснимков желает желать лучшего. качество ужасно.
* буквы отстают от "курсора" при печатании, в яве и интернете.
* качелька громкости не работает в фоновом режиме плеера.
Положительные моменты:
* Уже установленный PinkMod.
* Уже установленный zTaskMan.
* MPKGBox.
* В галерее, в разделе "Функции", добавилась функция "PhotoArt", где можно добавлять фото всякие эффекты (блондинкам будет фишка полезная).
* Видео в CIF, впринципе среднего качества. Для зн5 это фантастически) однако был у меня н82, умел снимать видео в VGA, никогда этим не пользовался smile.gif Поэтому и здесь мне наплевать какое разрешение видео.
* swap (спорный плюс)
* если в режиме плеера нажать "красный телефончик" - то плеер перейдёт в фон, если потом ещё нажать "красный телефончик" - тогда уже плеер будет закрыт. Таким образом устранён тормоз плеера при выходе из него.
Если учитывать, что из этих плюсов можно ручками поставить PinkMod и zTaskMan... то остальные плюсы прошивки выглядят блекло на фоне её минусов. Кроме конечно же MPKG smile.gif
Было бы чудненько, еслиб кто-нибудь собрал монстра, из обычной 05R. Прикрутил к ней PinkMod, zTaskMan, MPKG, swap и поставил какую-нибудь качественную, нетормозящую тему+шрифт (тема и шрифт это конечно не очень важно, но это своего рода "почерк" монстра).
Либо на базе 0ЕР.
Сообщение отредактировал Hitch - 11.7.2009, 14:45
[MP] Freedom Features Update [SWAP + CIF + MPKGBOX] · Motorola ZINE ZN5, ZN5 T-Mobile · Forum
Текстовая версия Сейчас: 10.9.2025, 11:01
