8 страниц V < 1 2 3 4 5 > »
[MP] Freedom Features Update [SWAP + CIF + MPKGBOX]
OCM770
сообщение 10.7.2009, 7:33 Закрепленное сообщение!
Пользователь №: 196 171
By OCM770 in cooperation with Kidscracker and Skrilax_CZ
Based on R6637_G_81.00.7FR + R6637_G_81.11.2CR Fixes & Kernel
Credits
For this MP I would specially like to thank my friend Kidscracker, for helping me out on some things, backing me up on this project, and of course developing Mpkgbox, he is a great person and an awesome developer wink.gif
Second I would like to thank Skrilax_CZ for giving me great suggestions for this MP and of course patching the camera libs and mediaplayer lib. Also thanks to fldodger for fixing the Alkali skin and Skrilax for perfecting it.
Also thanks to Ant-ON for developing zTaskMan, AnarH and Tim_22R for making the main menu svg files
Then I would like to thank the Motorola modding communities on the net, especially ModMyMoto which is where I grew up and MMUS for taking me in as part of their team. Both communities very friendly and helpful, keep it up guys :D
Change log:
So I wasn’t satisfied with Freedom 7FR. I was convinced it was possible to run a custom kernel and have everything else working correctly. At last I figured out how to do so and took the opportunity to change more things, adding more features and some tweaks and bugfixes. So I present to you this MP which in my opinion excels over my previous one. As more mods come out and more developers obtain a ZN5 I will continue making more MP’s. I hope you like this MP wink.gif
Kernel Mods:
  • SWAP Support
  • Squashfs 3.4 Support. Now this is a real handy feature for developers. Using this kernel in another firmware you can use Squashfs 3.4 to squash the code groups using a block size of up to 1MB for a greater compression. It uses default block size of 128kb. Compared to Squashfs 2.2 with a max block size of 64kb.
  • EXT2, EXT3, NTFS Support
  • IPv6 support (needs to be tested)
CG36 Mods:
  • Bash (as a replacement for busybox ash)
  • busybox version 11.14.1 with many more features than standard busybox (as /bin/busybox_full)
  • EasyThemes by ilove3d (drop skin folders in /ezxlocal/download/mystuff/skins/) with SVG support.
  • Mediaplayer can play CIF videos.
  • zTaskMan included under Office Tools and Main Menu (in CG52)
  • Modification of some SVG files to edit softkey size in main menu and make main menu 15 icons
  • SWAP file gets turned off when connected in memory card mode and automatically re-enabled when disconnected from PC. This to avoid the phone crashing.
  • Mpkgbox (by kidscracker, original by ilove3d)
  • RAW and Binned RAW Pictures with fixed remaining picture estimate and red icons in iconres.ezx
  • CIF Recording 15FPS
  • Telnet&FTP (Modem&Tools)
  • Run Scripts from File Manager
  • Unrar and Unzip from File Manager
  • Show* Modules
  • Removal of certain modules to increase firmware speed
Extras:
  • Optional Features (read below)
  • Custom Bootscreen
  • Custom Startup/Shutdown Animations
  • 15 icon main menu (animated with optional features)
  • Skins: Alkali (fixed), Kodak, Indium
Optional Features & SWAP
Right after flashing this firmware the phone will prompt to install Optional Features. What these do is install the medl and medld.conf folder along with some GUI tweaks (changed font, main menu animation, etc). You can chose to install these in Phone Memory or Memory Card (I HIGHLY recommend installing them to phone memory). Either choosing to install these or to not install them the phone will only prompt once. (To make the script run again delete /ezxlocal/medl or if you chose not to install them delete /ezxlocal/delete_to_run_initial_script).
Even if you chose not to install Optional Features the phone will still prompt if you want to install and enable SWAP. Once again, you can install this feature to phone memory or memory card ( I still recommend to install to phone memory). You can chose a swap file size of 32mb or 64mb ( I recommend 64mb for 062A users and 32mb for 062DP users). This part of the script will also only run once (to make it run again remove /ezxlocal/delete_to_run_initial_swap and /ezxlocal/download/mystuff/swapfile (for internal memory) or /mmc/mmca1/swapfile (for external memory))
Instructions
  1. Use RSD Lite 4.x for all flashing
  2. Download the version that corresponds to your bootloader (062DP is also for 062B users)
  3. Flash noRSA bootloader that corresponds to your bootloader
  4. Flash the version of Freedom Features Update that corresponds to your bootloader
  5. Follow Optional Features Instructions and wait for it to reboot (if by any chance it doesn’t reboot wait 3-5 minutes then remove/reinsert battery)
Download Link: Known Bugs:
  • Volume for mediaplayer can’t be modified from homescreen
ПЕРЕВОД:
От OCM770, совместно с Kidscracker и Skrilax_CZ
Основан на R6637_G_81.00.7FR + R6637_G_81.11.2CR Испрвлениях & Ядре
Благодарности
За этот монстрпак я должен особенно поблагодарить моего друга Kidscracker-а, за помощь мне в нескольких вещах, за то что вернул меня в этот проект и, конечно, за разработку Mpkgbox. Он великий человек и офигенный разработчик.
Во-вторых я хочу поблагодарить Skrilax_CZ за большие предложения для этого MP и, конечно, за патчинг либ камеры и медиаплеера. Также спасибо fldodger-у за исправления скина Alkali и Skrilax за доведение его до ума.
Также спасибо Ant-ON-у за разработку zTaskMan-а, AnarH-у and Tim_22R за переделку svg файлов для главного меню.
Далее я хочу поблагодарить сообщества моддеров телефонов Motorola в сети, особенно ModMyMoto, где я вырос, и MMUS за то что взяли меня как часть своей команды. Оба этих сообщества очень дружелюбны и готовы помочь, будьте такими всегда, ребята.
Изменения:
Итак, я не удовлетворился Freedom 7FR. Я был убежден, что возможно запустить свое ядро и все будет работать правильно. Наконец, я понял как это можно сделать и воспользовался этой возможностью, чтобы изменить больше вещей, добавить больше возможностей и некоторое количество фишек и исправлений ошибок. Итак, я представляю вам этот MP, который, по моему мнению превосходит предыдущий. По мере появления новых модов и новых разработчиков, имеющих ZN5 я продолжу делать больше монстрепаков. Я надеюсь вам понравится этот MP.
Моды ядра:
  • Поддержка swap.
  • Поддержка Squashfs 3.4. Это действительно удобная функция для разработчиков. Используя это ядро в других прошивках вы можете использовать Squashfs 3.4 для сборки кодовых групп с размером блока до 1 мегабайта для большего сжатия. По умолчанию используется размер блока 128 килобайт. По сравнению с Squashfs 2.2 с максимальным размером блока 64 килобайта.
  • Поддержка EXT2, EXT3, NTFS
  • Поддержка Ipv6 (необходимо тестирование)
Моды в CG36:
  • Bash (как замена для busybox ash)
  • busybox версии 11.14.1 с намного большим количеством функций чем стандартный busybox (как /bin/busybox_full)
  • EasyThemes от ilove3d (кидайте скины в папку skin в /ezxlocal/download/mystuff/skins/) с поддержкой SVG.
  • Mediaplayer теперь может проигрывать CIF видео.
  • ZtaskMan, включенный в меню Органайзер и Главное меню (в CG52)
  • Модификация нескольких SVG файлов для изменения размера подписей к софт-клавишам и 15 иконок в галвном меню
  • Swap файл выключается, когда телефон подключается в режиме карты памяти и автоматически включается при отключении от ПК. Это позволяет избежать зависание телефона.
  • Mpkgbox (от kidscracker-а, изначально от ilove3d)
  • RAW и Binned RAW режимы фото с исправленными рамкой и иконками в iconres.ezx
  • CIF запись видео 15FPS
  • Запуск скриптов из файл-менеджера
  • Распаковка rar и zip из файл-менеджера
  • Show* модули
  • Удалены определенные модули для увеличения скорости работы прошивки
Дополнительно:
  • Дополнительные возможности (читайте ниже)
  • Измененная загрузочная картинка
  • Измененная анимация на включение/выключение
  • Главное меню с 15 иконками (анимированное с дополнительными возможностями)
  • Скины: Alkali (исправленный), Kodak, Indium
Дополнительные возможности & SWAP
Сразу после прошивки телефон спросит, устанавливать ли дополнительные возможности. Что при этом делается — устанавливается папка medl и medld.conf вместе с несколькими настройками GUI (измененный шрифт, главное меню, анимация и т.д.). Вы можете выбрать куда устанавливать, в память телефона или на карту памяти (я НАСТОЙЧИВО рекомендую устанавливать мод в память телефона). Неважно, выберите вы установку или отмену установки, телефон больше об этом не спросит. (Чтобы запустить скрипт снова удалите /ezxlocal/medl или, если вы выбрали не устанавливать, удалите файл /ezxlocal/delete_to_run_initial_script). Даже если вы выбрали не устанавливать дополнительные возможности телефон спросит, хотите ли вы установить и включить Swap. И снова, вы можете установить его в память телефона или на карту памяти ( я снова рекомендую устанавливать в память телефона). Вы можете выбрать размер swap-файла, 32 или 64 мегабайта (я рекомендую 64 мегабайта для пользователей с бутом 062A и 32 для пользователей с бутом 062DP). Эта часть скрипта также запускается только один раз (чтобы запустить его снова удалите /ezxlocal/delete_to_run_initial_swap и /ezxlocal/download/mystuff/swapfile (для памяти телефона) или /mmc/mmca1/swapfile (для карты памяти)).
Инструкции.
  1. Используйте RSD Lite 4.x для всех прошиваний
  2. Скачайте версию, которая соответсвует вашему бутлоадеру (062DP также подходит и для пользователей с 062B)
  3. Прошейте noRSA бут, который соответствует вашему буту.
  4. Прошейте версию Freedom Features Update, которая соответствует вашему буту.
  5. Следуйте инструкции установки дополнительных возможностей и ждите, пока телефон перезагрузится (если он не перезагрузится, подождите 3-5 минут и вытащите/вставьте батарею)
Ссылка для скачивания:Известные проблемы:
Громкость в медиаплеере нельзя изменить пока плеер свернут на главном экране.
Senx Lukas K. and Neomoto for translate on Russian
перевод на РУССКИЙ
Сообщение отредактировал EXL - 25.11.2010, 7:47
r.o.m.a.N
сообщение 11.7.2009, 15:15
Motoroma
Пользователь №: 95 283
Прошивка: 49R 4.4.4
Цитата(Hitch @ Сегодня, 18:39)
если в режиме плеера нажать "красный телефончик" - то плеер перейдёт в фон, если потом ещё нажать "красный телефончик" - тогда уже плеер будет закрыт. Таким образом устранён тормоз плеера при выходе из него.
На 0Е тоже так
Hitch
сообщение 11.7.2009, 15:31
Вечномолодой
Из: Рая
Пользователь №: 46 265
Прошивка: Bada 1.2
r.o.m.a.N, хм) ну в глаза мне бросилось это только сейчас. Хорошо если так smile.gif
portapro
Пользователь №: 202 542
Модель телефона: zn5
Прошивка: Symbiosis 3
Hitch[i] полностью тебя поддерживаю, мне бы тоже такою прошивку хотелось бы..
Nuke142
сообщение 11.7.2009, 15:40
Пользователь №: 201 901
Модель телефона: ZN5
Hitch, +1. тоже такую хочется, а то с этими прошиваниями гемор и запутано.
Сообщение отредактировал Nuke142 - 11.7.2009, 15:41
Entom
сообщение 11.7.2009, 17:37
Из: Крыма!
Пользователь №: 159 951
Модель телефона: iPhone 4s
Прошивка: iOS 7
Люблю Apple, уважаю Motorola.
Блин, я так и не понял зависает камера при съемке видео или нет? И еще: нормально ли работает со стерео-блютуз? А то в предыдущей версии не хотело соединять.
FAN_TV
сообщение 11.7.2009, 18:24
Из: UKRAINA
Пользователь №: 197 530
Модель телефона: XT907
Прошивка: LS KKBL V3.2
Entom
При первом запуске зависла , потом перегрузил телефон и все работает!
trace2343
сообщение 11.7.2009, 18:54
Из: UA
Пользователь №: 199 910
Прошивка: R6637_G_81.05ER
у меня видео зависло после 3й сьмки длиной 1 минута. Пришлось вытягивать акум. сейчас перешёл на 05 доволен как слон-фокусируеться в полной темноте, но иногда сильно засвечивает.
DeshFXs
сообщение 11.7.2009, 21:31
Из: Жуковский, МО
Пользователь №: 137 130
Модель телефона: Moto X
Прошивка: LiquidSmooth
Блин, виснет в видео конечно иногда, из-за этого вообще теряется смысл видео - ну ду, клевое качество, но вот так будет момент, допустим, смешной, снимешь веселое видео, нажмешь стоп, и тут БАЦ не сохранилось, обидно( пофиксить бы это и цены не будет прошивке
P.S. когда виснет при зажатии красной кнопки тело в любом случае выключается - это плюс, акб вынимать ненадо (непонимаю в чем дело у предыдущего поста).
И еще... видео виснет только в тот момент, когда заканчиваешь снимать (при нажатии на фиолетовую кнопку) а так хоть час снимай.
Еслиб было можно как то просчитать - на который раз зависнет =\
Сообщение отредактировал DeshFXs - 11.7.2009, 21:32
DeshFXs
сообщение 12.7.2009, 10:29
Из: Жуковский, МО
Entom, видео зависает(см. пред. пост). А стерео блютус... у меня eq5 - проблем нет, музыка не прирывается, все работает
Сообщение отредактировал DeshFXs - 12.7.2009, 11:45
Zine91
сообщение 12.7.2009, 13:01
Пользователь №: 196 940
r.o.m.a.N
сообщение 12.7.2009, 13:59
Motoroma
Прошивка: 49R 4.4.4
Zine91,
http://ru.wikipedia.org/wiki/RAW_(формат_д....84.D0.B8.D0.B8
trace2343
сообщение 12.7.2009, 14:19
Из: UA
Пожалуйста вытяните тему оформления из этой прошивки!!! я ее поставлю на 05R
DeNGer!)
сообщение 12.7.2009, 14:37
Пользователь №: 199 381
Модель телефона: E8+ZN5(T-mobile)
Прошивка: самая новая
Zine91,
ВОт что пишут: Напрямую печатать снимки в RAW не получится, они воспринимаются как черно-белые, хотя на самом деле являются 12-разрядными. Здесь мы сталкивается с одной проблемой: снимки в формате RAW, полученные камерой Motorola ZN5, являются 8-рязрядными, а сохраняются в памяти в формате TIFF. То есть название формата RAW – лишь маркетинговая фишка, в реальности этого нет.
Формат TIFF получается из RAW путем компрессии, но, в отличие от JPEG, без потери деталей, что тоже само по себе неплохо, в любом случае возможность уникальна среди камерофонов. Снимки опять же черно-белые, восстанавливать их цвет также необходимо в графических редакторах. Но по сравнению с получаемыми JPEG-файлами, число деталей больше, а цветопередача может быть откорректирована по вашему усмотрению без каких-либо проблем.
Кипелов
сообщение 12.7.2009, 15:56
Пользователь №: 106 051
Модель телефона: V360\A853\XT862
Прошивка: HOT MIX V360\2.2\906
Цитата(DeNGer!) @ 12.7.2009, 21:37) *
Zine91,
А это может решить проблему шумов?
CjYoung
сообщение 12.7.2009, 16:23
Пользователь №: 14 233
Модель телефона: Milestone, ZN5, L7
Нет.
По поводу глючности - прошивка опять стала несталибильной. Камеру ещё на качество не проверял.
БЫЛИ ЗАМЕЧЕНЫ ГЛЮКИ:
1. шум от усилителя, даже не шум а тихий треск(помогла перезагрузка)
2. Опять виснет видео по нажатию на стоп.
3. Глючный скин
Но нашёл и плюсы:
Теперь не вылетает окно о просьбе закрыть приложение, тк обкакаться оти излишка оперативки.
И плеер стал шустрее гораздо. Даже во время проигрывания можно выполнять сторонние функции. тупит, но терпимо)
Сообщение отредактировал CjYoung - 12.7.2009, 16:23
sim_emrom
сообщение 12.7.2009, 18:26
Из: Ханты-Мансийск
Пользователь №: 195 802
Модель телефона: Spica
Прошивка: a.v.2.1
CjYoung, последние 2 пункта от свопа... Таких проблем и OER Custom от tmp_do нет... Вот починили бы там запуск камеры - цены бы ей не было.
В общем-то, все сошлись на том, что наше дело - копать либы камеры от этой проши, искать в чём разница от наших... Так давайте займёмся уже.
Если правильно понял, тут только CIF-съемка, а QVGA как?
DeshFXs
сообщение 12.7.2009, 18:57
Из: Жуковский, МО
путем опытных исследований могу предположить, что при съемке видео тело не может зависнуть, виснет оно только в момент сохранения файла в память телефона, скорее всего, прежде чем мы нажимаем "сохранить как" оно сохраняется в память телефона, а после перезаписывается на флэху. Грубо говоря, телефону не всегда хватает оперативной памяти на сохранение столь крупного видео-файла(а у него ведь разрешение возрасло). Своп, возможно усугубляет это дело, хотелось бы проверить влияет ли как-то на это дело своп, но сносить уже настроеную прошивку, чтобы проверить... мне влом XD если кому надо - проверьте =)
Сообщение отредактировал DeshFXs - 12.7.2009, 18:58
syberside
сообщение 12.7.2009, 19:46
Из: Новоуральск
Пользователь №: 176 082
Прошивка: ICS 4.0.4
а реально ли выцепить CIF чтоб на тмобайловский тел впихнуть?
проши то обычные не подойдут...
M@t@rol@4k@
сообщение 12.7.2009, 19:59
Из: УкраЇна
Пользователь №: 171 145
Прошивка: Android Pie 9
Monday - Party!
syberside,
Эсли я не ошибаюсь,то для T-Mobile как раз 062DP версия.
Сообщение отредактировал M@t@rol@4k@ - 12.7.2009, 19:59
syberside
сообщение 12.7.2009, 20:02
Из: Новоуральск
Прошивка: ICS 4.0.4
и может кто нить подсказать, вообще реально ли фичи монстра портировать на тмоб аппарот sad.gif
M@t@rol@4k@
сообщение 12.7.2009, 20:06
Из: УкраЇна
Monday - Party!
syberside,
Я же говорю,попробуй 062DP версию.Все равно основа монстра на "вашей"проше.И запасись стоковой для T-Mobile.Или у тебя встанет фридом,или выбьет эррор,ты поверху стоковую прошьешь,и все как было.
Добавлено позже (12.7.2009, 23:09):
trace2343,
Сама тема вытянута была мною еще с предидущей версии мода.(Ищи в скинах "Alkali".На последних страницах. Там я свой фон и заставку добавил).Если нужны еще и фон меню и т.д. и т.п.,то это уже не ко мне.
Вот тема:
https://forum.motofan.ru/index.php?act=Attach&type=post&id=207623
Сообщение отредактировал M@t@rol@4k@ - 13.7.2009, 10:07
Stray39
сообщение 12.7.2009, 20:31
Пользователь №: 198 407
Модель телефона: MOTOZINE ZN5
Прошивка: пока не определился
Ребята вытащите плиз тему ALKALI из этой проши,тема нравится .......
r.o.m.a.N
сообщение 12.7.2009, 21:16
Motoroma
Прошивка: 49R 4.4.4
Разбери CG52, и вытащи....
Stray39
сообщение 12.7.2009, 21:32
Прога сегодня порадовала... запустил браузер + мини оперу+ открыл галерею + плеер музыку грав smile.gif и не каких тормозов и криков Закройте що не будь бо не хватае мозгу все обробыть.... thumbsup.gif отлично...и видео снимало 2 минуты и схоронилось без проблем... clap.gif
syberside
сообщение 12.7.2009, 21:36
Из: Новоуральск
Прошивка: ICS 4.0.4
я так и не понял там qwga есть?
Zine91
сообщение 12.7.2009, 22:22
syberside
сообщение 12.7.2009, 22:50
Из: Новоуральск
Прошивка: ICS 4.0.4
надо цветовой фильтр применить. например в фотошопе, но где то писали, что на диске прога,которая это тоже делает shuffle.gif
Stray39
сообщение 13.7.2009, 4:06
syberside
http://www.google.com.ua/language_tools?hl=ru
Neomoto
сообщение 13.7.2009, 8:15
Из: Белгород
Пользователь №: 72 604
Модель телефона: MotoZINE ZN5
Прошивка: sym X beta
Цитата(Zine91 @ Сегодня, 2:22)
так а как мне этот рав в цветной перевести , или это неаозможно?
мануал на английском http://www.mmus.us/forum/showthread.php?t=7965
перевод гуглом
CjYoung
сообщение 13.7.2009, 8:24
Про своп знаю. забыл написать)))
С видео в циф формате телефон снимает в несколько раз лучше, чем в qvga. Нет резких выпаданий кадров. битрейд выше напорядок. да и мне показалось, что там не 15 кадров а выше(если брать к примеру сьёмку qvga где токак так вылетали кадры)
Есть идея(тупая может быть). Если сделать принудительное сохранение и нажимать самому может лаг пройдёт!? У меня пока нет времени.
Сообщение отредактировал CjYoung - 13.7.2009, 8:25
M@t@rol@4k@
сообщение 13.7.2009, 9:47
Из: УкраЇна
Monday - Party!
Stray39,
Тему Alkali уже я вытащил давным двано.Ищи в "Скины ZN5" на последних страницах.
Вот:
Сообщение отредактировал M@t@rol@4k@ - 13.7.2009, 10:06
Glyad
сообщение 13.7.2009, 11:51
Пользователь №: 107 060
Модель телефона: Motorola ROKR E1 ZN5
Как проблему с выходом из режима блокировки клавиатуры устранить? Долго висит, не показываются крупные часы
1nTeRacT
сообщение 13.7.2009, 12:01
Пользователь №: 139 825
Прошивка: G_81.03.0ER
пока никто не знает! я думаю это самый важный недостаток, после качества фото !
может это из-за свопа? есть ли данная проблема в 0ЕR_cust ? из-за скина это точно не зависит(
uzHeR
Из: Kuzbass
Пользователь №: 38 217
Прошивка: ZE0.7
что скажете по сравнению со старым творением???
смысл ставить есть нет
по видео: сегодня 3 минуты снимал как гнут ложки фокасники... иии... видео зависло!!!111
Glyad
сообщение 13.7.2009, 12:06
В 0ER_noRSA_custom с блокировкой никаких проблем не было
syberside
сообщение 13.7.2009, 18:50
Из: Новоуральск
Прошивка: ICS 4.0.4
а кто нить пробовал у автора монстра попросить помочь с CIF видео и RAW фото?
Сообщение отредактировал syberside - 13.7.2009, 19:19
M@t@rol@4k@
сообщение 13.7.2009, 18:53
Из: УкраЇна
Monday - Party!
syberside,
Именно из-за возможности этих двух факторов автор отказался от 0ER как основы мода,и "связал свою судьбу" с 7FR.Изначально изюминкой мода был лишь MPKGBOX.Если с RAW что-то и получилось(модно активировать,но при смене разрешения пропадает из списка),то с CIF никак.
syberside
сообщение 13.7.2009, 19:23
Из: Новоуральск
Прошивка: ICS 4.0.4
M@t@rol@4k@, ну может это на 2CR_128 возможно?
и разве нельзя будет на др проши, типа OER портануть?
M@t@rol@4k@
сообщение 13.7.2009, 20:27
Из: УкраЇна
Monday - Party!
syberside,
Можно портануть все,кроме того,что связано с камерой.Там дело даже не в либах.Их заменяли.но ничего не получилось.Там что-то более серьезное.Я тоже надеюсь,что придумают способ обнаружить зависимости,и подправить файлы самой 0ER(тоесть оставить прежние алгоритмы фото, и добавить CIF).Но пока это просто невозможно.И на 2СR тоже вряд ли.Простая замена ничего не дала.Дело в самой инженерной версии,там очень много отличий.Именно поэтому 7FR глючит,нестабильна и большенство ее багов стали ее неотьемлимыми функциями.Именно поэтому я не верю,что следующий апдейт сделает ее быстрой и безглючной.Для этого нужно все переписать заново,хотя бы половину.
Сообщение отредактировал M@t@rol@4k@ - 13.7.2009, 20:29
CjYoung
сообщение 13.7.2009, 20:37
На касте тож самое. Тока там ваще пока не перезагрузишь часы не исчезнут. Тут достаточно поставить блок и снять и всё пучком.
А ЧО МОЙ ВАРИАНТ ПОПРОБЫВАЛИ!?))
[MP] Freedom Features Update [SWAP + CIF + MPKGBOX] · Motorola ZINE ZN5, ZN5 T-Mobile · Forum
Текстовая версия Сейчас: 10.9.2025, 11:01
