8 страниц V  1 2 3 > »
[MP] Freedom Features Update [SWAP + CIF + MPKGBOX]
OCM770
сообщение 10.7.2009, 7:33 Закрепленное сообщение!
Пользователь №: 196 171
By OCM770 in cooperation with Kidscracker and Skrilax_CZ
Based on R6637_G_81.00.7FR + R6637_G_81.11.2CR Fixes & Kernel
Credits
For this MP I would specially like to thank my friend Kidscracker, for helping me out on some things, backing me up on this project, and of course developing Mpkgbox, he is a great person and an awesome developer wink.gif
Second I would like to thank Skrilax_CZ for giving me great suggestions for this MP and of course patching the camera libs and mediaplayer lib. Also thanks to fldodger for fixing the Alkali skin and Skrilax for perfecting it.
Also thanks to Ant-ON for developing zTaskMan, AnarH and Tim_22R for making the main menu svg files
Then I would like to thank the Motorola modding communities on the net, especially ModMyMoto which is where I grew up and MMUS for taking me in as part of their team. Both communities very friendly and helpful, keep it up guys :D
Change log:
So I wasn’t satisfied with Freedom 7FR. I was convinced it was possible to run a custom kernel and have everything else working correctly. At last I figured out how to do so and took the opportunity to change more things, adding more features and some tweaks and bugfixes. So I present to you this MP which in my opinion excels over my previous one. As more mods come out and more developers obtain a ZN5 I will continue making more MP’s. I hope you like this MP wink.gif
Kernel Mods:
  • SWAP Support
  • Squashfs 3.4 Support. Now this is a real handy feature for developers. Using this kernel in another firmware you can use Squashfs 3.4 to squash the code groups using a block size of up to 1MB for a greater compression. It uses default block size of 128kb. Compared to Squashfs 2.2 with a max block size of 64kb.
  • EXT2, EXT3, NTFS Support
  • IPv6 support (needs to be tested)
CG36 Mods:
  • Bash (as a replacement for busybox ash)
  • busybox version 11.14.1 with many more features than standard busybox (as /bin/busybox_full)
  • EasyThemes by ilove3d (drop skin folders in /ezxlocal/download/mystuff/skins/) with SVG support.
  • Mediaplayer can play CIF videos.
  • zTaskMan included under Office Tools and Main Menu (in CG52)
  • Modification of some SVG files to edit softkey size in main menu and make main menu 15 icons
  • SWAP file gets turned off when connected in memory card mode and automatically re-enabled when disconnected from PC. This to avoid the phone crashing.
  • Mpkgbox (by kidscracker, original by ilove3d)
  • RAW and Binned RAW Pictures with fixed remaining picture estimate and red icons in iconres.ezx
  • CIF Recording 15FPS
  • Telnet&FTP (Modem&Tools)
  • Run Scripts from File Manager
  • Unrar and Unzip from File Manager
  • Show* Modules
  • Removal of certain modules to increase firmware speed
Extras:
  • Optional Features (read below)
  • Custom Bootscreen
  • Custom Startup/Shutdown Animations
  • 15 icon main menu (animated with optional features)
  • Skins: Alkali (fixed), Kodak, Indium
Optional Features & SWAP
Right after flashing this firmware the phone will prompt to install Optional Features. What these do is install the medl and medld.conf folder along with some GUI tweaks (changed font, main menu animation, etc). You can chose to install these in Phone Memory or Memory Card (I HIGHLY recommend installing them to phone memory). Either choosing to install these or to not install them the phone will only prompt once. (To make the script run again delete /ezxlocal/medl or if you chose not to install them delete /ezxlocal/delete_to_run_initial_script).
Even if you chose not to install Optional Features the phone will still prompt if you want to install and enable SWAP. Once again, you can install this feature to phone memory or memory card ( I still recommend to install to phone memory). You can chose a swap file size of 32mb or 64mb ( I recommend 64mb for 062A users and 32mb for 062DP users). This part of the script will also only run once (to make it run again remove /ezxlocal/delete_to_run_initial_swap and /ezxlocal/download/mystuff/swapfile (for internal memory) or /mmc/mmca1/swapfile (for external memory))
Instructions
  1. Use RSD Lite 4.x for all flashing
  2. Download the version that corresponds to your bootloader (062DP is also for 062B users)
  3. Flash noRSA bootloader that corresponds to your bootloader
  4. Flash the version of Freedom Features Update that corresponds to your bootloader
  5. Follow Optional Features Instructions and wait for it to reboot (if by any chance it doesn’t reboot wait 3-5 minutes then remove/reinsert battery)
Download Link: Known Bugs:
  • Volume for mediaplayer can’t be modified from homescreen
ПЕРЕВОД:
От OCM770, совместно с Kidscracker и Skrilax_CZ
Основан на R6637_G_81.00.7FR + R6637_G_81.11.2CR Испрвлениях & Ядре
Благодарности
За этот монстрпак я должен особенно поблагодарить моего друга Kidscracker-а, за помощь мне в нескольких вещах, за то что вернул меня в этот проект и, конечно, за разработку Mpkgbox. Он великий человек и офигенный разработчик.
Во-вторых я хочу поблагодарить Skrilax_CZ за большие предложения для этого MP и, конечно, за патчинг либ камеры и медиаплеера. Также спасибо fldodger-у за исправления скина Alkali и Skrilax за доведение его до ума.
Также спасибо Ant-ON-у за разработку zTaskMan-а, AnarH-у and Tim_22R за переделку svg файлов для главного меню.
Далее я хочу поблагодарить сообщества моддеров телефонов Motorola в сети, особенно ModMyMoto, где я вырос, и MMUS за то что взяли меня как часть своей команды. Оба этих сообщества очень дружелюбны и готовы помочь, будьте такими всегда, ребята.
Изменения:
Итак, я не удовлетворился Freedom 7FR. Я был убежден, что возможно запустить свое ядро и все будет работать правильно. Наконец, я понял как это можно сделать и воспользовался этой возможностью, чтобы изменить больше вещей, добавить больше возможностей и некоторое количество фишек и исправлений ошибок. Итак, я представляю вам этот MP, который, по моему мнению превосходит предыдущий. По мере появления новых модов и новых разработчиков, имеющих ZN5 я продолжу делать больше монстрепаков. Я надеюсь вам понравится этот MP.
Моды ядра:
  • Поддержка swap.
  • Поддержка Squashfs 3.4. Это действительно удобная функция для разработчиков. Используя это ядро в других прошивках вы можете использовать Squashfs 3.4 для сборки кодовых групп с размером блока до 1 мегабайта для большего сжатия. По умолчанию используется размер блока 128 килобайт. По сравнению с Squashfs 2.2 с максимальным размером блока 64 килобайта.
  • Поддержка EXT2, EXT3, NTFS
  • Поддержка Ipv6 (необходимо тестирование)
Моды в CG36:
  • Bash (как замена для busybox ash)
  • busybox версии 11.14.1 с намного большим количеством функций чем стандартный busybox (как /bin/busybox_full)
  • EasyThemes от ilove3d (кидайте скины в папку skin в /ezxlocal/download/mystuff/skins/) с поддержкой SVG.
  • Mediaplayer теперь может проигрывать CIF видео.
  • ZtaskMan, включенный в меню Органайзер и Главное меню (в CG52)
  • Модификация нескольких SVG файлов для изменения размера подписей к софт-клавишам и 15 иконок в галвном меню
  • Swap файл выключается, когда телефон подключается в режиме карты памяти и автоматически включается при отключении от ПК. Это позволяет избежать зависание телефона.
  • Mpkgbox (от kidscracker-а, изначально от ilove3d)
  • RAW и Binned RAW режимы фото с исправленными рамкой и иконками в iconres.ezx
  • CIF запись видео 15FPS
  • Запуск скриптов из файл-менеджера
  • Распаковка rar и zip из файл-менеджера
  • Show* модули
  • Удалены определенные модули для увеличения скорости работы прошивки
Дополнительно:
  • Дополнительные возможности (читайте ниже)
  • Измененная загрузочная картинка
  • Измененная анимация на включение/выключение
  • Главное меню с 15 иконками (анимированное с дополнительными возможностями)
  • Скины: Alkali (исправленный), Kodak, Indium
Дополнительные возможности & SWAP
Сразу после прошивки телефон спросит, устанавливать ли дополнительные возможности. Что при этом делается — устанавливается папка medl и medld.conf вместе с несколькими настройками GUI (измененный шрифт, главное меню, анимация и т.д.). Вы можете выбрать куда устанавливать, в память телефона или на карту памяти (я НАСТОЙЧИВО рекомендую устанавливать мод в память телефона). Неважно, выберите вы установку или отмену установки, телефон больше об этом не спросит. (Чтобы запустить скрипт снова удалите /ezxlocal/medl или, если вы выбрали не устанавливать, удалите файл /ezxlocal/delete_to_run_initial_script). Даже если вы выбрали не устанавливать дополнительные возможности телефон спросит, хотите ли вы установить и включить Swap. И снова, вы можете установить его в память телефона или на карту памяти ( я снова рекомендую устанавливать в память телефона). Вы можете выбрать размер swap-файла, 32 или 64 мегабайта (я рекомендую 64 мегабайта для пользователей с бутом 062A и 32 для пользователей с бутом 062DP). Эта часть скрипта также запускается только один раз (чтобы запустить его снова удалите /ezxlocal/delete_to_run_initial_swap и /ezxlocal/download/mystuff/swapfile (для памяти телефона) или /mmc/mmca1/swapfile (для карты памяти)).
Инструкции.
  1. Используйте RSD Lite 4.x для всех прошиваний
  2. Скачайте версию, которая соответсвует вашему бутлоадеру (062DP также подходит и для пользователей с 062B)
  3. Прошейте noRSA бут, который соответствует вашему буту.
  4. Прошейте версию Freedom Features Update, которая соответствует вашему буту.
  5. Следуйте инструкции установки дополнительных возможностей и ждите, пока телефон перезагрузится (если он не перезагрузится, подождите 3-5 минут и вытащите/вставьте батарею)
Ссылка для скачивания:Известные проблемы:
Громкость в медиаплеере нельзя изменить пока плеер свернут на главном экране.
Senx Lukas K. and Neomoto for translate on Russian
перевод на РУССКИЙ
Сообщение отредактировал EXL - 25.11.2010, 7:47
Nuke142
сообщение 10.7.2009, 8:29
Пользователь №: 201 901
Модель телефона: ZN5
Я еще не знаком с 7FR, пишут что там аккумулятор меньше держится.
Исправлена ли сдесь эта проблема ?
И вопрос: нужно ли предварительно шить оригинальный 7FR ?
tav112
сообщение 10.7.2009, 9:55
Пользователь №: 100 741
Модель телефона: mpx200, KRZR3, Zn5
Если кто поставил... e-mail открывается?
Hitch
сообщение 10.7.2009, 10:15
Вечномолодой
Из: Рая
Пользователь №: 46 265
Прошивка: Bada 1.2
ставить предыдущую верси ненадо. читаем инструкцию. прошился, будемс тестить )
Добавлено позже (10.7.2009, 13:18):
первые впечатления от прошивки афигительные ) шустрая, красивая, установленны иконки 3х5 с пульсирующим эффектом и плавным меню, как в пинк эволюшин )
пока доволен... ) кстати скин по стандарту стоит старый добрый стоковый с Е2, с прикольный шрифтом ) жаль русского нет ))
ставьте ВСЕ ) ВСЕ )
Сообщение отредактировал Hitch - 10.7.2009, 10:35
1nTeRacT
сообщение 10.7.2009, 10:19
Пользователь №: 139 825
Модель телефона: MOTOZINE ZN5
Прошивка: G_81.03.0ER
это не оригинальный 7ФР и шить предварительно ничего не нада, качаешь архив и шьёшь этот мод поверх любой проши
ЗЫ без модуля камеры даже не проверить как снимает телефон ((( жаль очень жаль ((((
Добавлено позже (10.7.2009, 14:25):
Ставь турболенг и будет тебе русский
Сообщение отредактировал 1nTeRacT - 10.7.2009, 10:23
M@t@rol@4k@
сообщение 10.7.2009, 10:27
Из: УкраЇна
Пользователь №: 171 145
Прошивка: Android Pie 9
Monday - Party!
Оптишитесь пожалуйста как тут дело с фотками?Качество лучшилось?(Про автофокус даже не спрашиваю)
Hitch
сообщение 10.7.2009, 10:28
Вечномолодой
Из: Рая
Прошивка: Bada 1.2
тогда шрифта такого не будет уже) надо подбирать )
а что с афтофокусом?
у меня проблем не было ни на прошлой 7фр, ни на этой)
качество хз, в солнечную погоду все прошивки хорошо снимают. а вот режимы RAW и binned RAW добавились wink.gif )))))))))))) ееееееееееееееееес)))))))
Сообщение отредактировал Hitch - 10.7.2009, 10:29
1nTeRacT
сообщение 10.7.2009, 10:29
тока что поставил...
шрифт такой же маленький...в меню некоторые буквы жирные тока)
и так же 16 букв встроке !
а что за Mediaplayer can play CIF videos. ?
CIF - Часто в различных видео-приложениях используется только четверть стандартного телевизионного кадра, этот размер известен как CIF (Common Intermediate Format).
так а что он тут даёт обычными словами?!
Сообщение отредактировал 1nTeRacT - 10.7.2009, 10:40
Nuke142
сообщение 10.7.2009, 10:32
так а что тут с энергопотреблением ? по прежнему увеличено по сравнению с другими прошивками ?
Hitch
сообщение 10.7.2009, 10:34
Вечномолодой
Из: Рая
Прошивка: Bada 1.2
1nTeRacT, дык он тут маленький, мне это нравится ) на дисплее вмещается наверное строк 16 )) и буквы аккуратные ))
Nuke142, прошивка только только вышла, как мы это проверим? Надо тестировать. Время покажет
M@t@rol@4k@
сообщение 10.7.2009, 10:45
Из: УкраЇна
Monday - Party!
QVGA - 320x240.
CIF - 352x288.Тоесть телефон играет ролики с CIF разрешением.(А раньше что не играл??).Ну он по любому играть их должен.(Снял видео в CIF разрешении, а открыть не может )) )
1nTeRacT
сообщение 10.7.2009, 10:47
Цитата(M@t@rol@4k@ @ 10.7.2009, 14:45) *
QVGA - 320x240.
а снимает он как? в QVGA или в CIF? мне просто не проверить )
Hitch
Вечномолодой
Из: Рая
Прошивка: Bada 1.2
вот именно что еслиб ты раньше закинул на телефон ролик 355х288 - он бы его не играл, а выбил бы ошибку. А сейчас играет, доработали плеер smile.gif
1nTeRacT, снимает CIF, 355x288
Сообщение отредактировал Hitch - 10.7.2009, 10:47
Megahalem
сообщение 10.7.2009, 10:51
Пользователь №: 202 173
Модель телефона: Motozine ZN5
После прошивки предлагает выбрать размер СВАПа - какой надо выбрать? 32Мб или 64 Мб?
Hitch
сообщение 10.7.2009, 10:53
Вечномолодой
Из: Рая
Прошивка: Bada 1.2
Инструкция:
для владельцев европейских зн5 - выбрать 64мб. Для Т-мобайл - 32мб.
M@t@rol@4k@
сообщение 10.7.2009, 10:54
Из: УкраЇна
Monday - Party!
Кто пробовал в cg36 правленную либу libezxappbase.so.1.0.0 встраивать?("Делаем ZN5 быстрее").
Сообщение отредактировал M@t@rol@4k@ - 10.7.2009, 10:58
Megahalem
сообщение 10.7.2009, 11:14
Список вызовов снизу обрезается - видно часы и подписи к кнопкам. Как это исправить?
1nTeRacT
сообщение 10.7.2009, 11:16
это наверное глюк этого скина ! если дойдешь до частых вызовов то снизу дорисовывается окошко...
Сообщение отредактировал 1nTeRacT - 10.7.2009, 11:17
r.o.m.a.N
сообщение 10.7.2009, 11:17
Motoroma
Пользователь №: 95 283
Прошивка: 49R 4.4.4
Лучше не впихивать либу от 0Е, а родную либу изменить
Добавлено позже (10.7.2009, 15:18):
Цитата(Megahalem @ Сегодня, 15:14)
Как это исправить?
Это глюк скинов. Везде так
Hitch
сообщение 10.7.2009, 11:27
Вечномолодой
Из: Рая
Прошивка: Bada 1.2
прошил русский турболенг, и странно... шрифт остался с Фридома, размер букв тоже. Но и русский появился) это радует)
Megahalem
сообщение 10.7.2009, 11:29
Да, действительно только на теме Kodak наблюдается данный глюк. Жаль, мне эта тема больше всех нравится sad.gif
1nTeRacT
сообщение 10.7.2009, 11:30
Megahalem, это на всех скинах так ! не тока на кодак!
Сообщение отредактировал 1nTeRacT - 10.7.2009, 11:32
Hitch
сообщение 10.7.2009, 11:32
Вечномолодой
Из: Рая
Прошивка: Bada 1.2
p.s: заметил приятную фишку ) когда слушаешь музыку, и в режиме плеера нажимаешь "красный телефончик" то плеер не закрывается, а сворачивается в фоновый режим smile.gif нажимаешь ещё раз "красный телефончик" и тогда он уже закрывается )
Сообщение отредактировал Hitch - 10.7.2009, 11:33
Megahalem
сообщение 10.7.2009, 11:33
На других темах дата не налазит у меня на список вызовов.
tav112
сообщение 10.7.2009, 11:49
Мущины! Если не в лом, проверьте, e-mail открывается?
Hitch
сообщение 10.7.2009, 12:23
Вечномолодой
Из: Рая
Прошивка: Bada 1.2
всё же прошивка глючная. подвисает иногда тел
частенько это бывает при выходе из блокировки. раздупляется секунд 10. дорабатывать нужно.
D-1c3
сообщение 10.7.2009, 12:29
Пользователь №: 150 086
Прошивка: свежая
народ, кто поставил, выложите плс скрины демонстрирующие шрифт и свистоперделки меню
и еще изменения, которые считаете важными
DeshFXs
сообщение 10.7.2009, 12:33
Из: Жуковский, МО
Пользователь №: 137 130
Модель телефона: Moto X
Прошивка: LiquidSmooth
D-1c3, блин, слей все что нужно, и прошей =) бестолку так объяснять
seregared1
сообщение 10.7.2009, 12:36
Пользователь №: 193 812
Прошивка: 05R+56 флекс
OCM770 THANKS A LOT FOR A WONDERFUL MOD!!!!
Сори за капс у меня эмоции!
4 часа полет нормальный.
Видео снимает/смотрит QCIF - Супер
Фото - нормально (но ИМХО стоковая прошивка 05 самая лучшая в плане фото).
О нехватке памяти не заикался хотя я SWAP поставил 32 мб.
По поводу нижней строки в списках вызова - это проблема шрифта. (поставтьте стоковый шрифт и проблема исчезнет - 99%) мне это не мешает.
WIFI - Работает!
заметил только 1 мизерный недостаток
не обновляет миниатюры для картинок в памяти телефона(было и на старой 7FR) хотя на карте памяти все работает.
Ура товарищи!!!!!!!11
DeshFXs
сообщение 10.7.2009, 12:49
Из: Жуковский, МО
блин, есть минус, при вводе текста, мигающий курсор находится совсем не там где будет буква( короче попробуйте, наберите ченить smile.gif
гммм, это замечено было только когда я менял настройки интернета, а в других местах норм. что не может не радовать, но все же - 0_о
Сообщение отредактировал DeshFXs - 10.7.2009, 12:55
Lukas K.
сообщение 10.7.2009, 13:36
Из: Омск
Пользователь №: 140 402
Прошивка: NSv2.1 + ZE0.9b
как можно поставить стандартный шрифт? а то этот курсор, который вот вообще не там (в сообщениях норм, а в поле настроек и нтернете есть.. в яве вообще сильно.. много в аське сижу с телефона и очень неприятно.. при том чем длиннее сообщение, тем дальше курсор))).. и жирные буквы некоторые.. и некая неаккуратность.. напрягает очень сильно.
Сообщение отредактировал Lukas K. - 10.7.2009, 13:38
MotoDr
сообщение 10.7.2009, 13:42
Пользователь №: 197 783
Модель телефона: Atrix HD
Прошивка: пока что труп
открывается и работает как надо
курсор да... живет своею жизнью
Сообщение отредактировал MotoDr - 10.7.2009, 13:43
r.o.m.a.N
сообщение 10.7.2009, 14:06
Motoroma
Прошивка: 49R 4.4.4
DeshFXs,
Lukas K.,
стандартный ленг прошейте
Lukas K.
сообщение 10.7.2009, 15:08
Из: Омск
так я прошил ленг из темы про ленги.. из закрепленного поста и шрифт остался тот же и косяки те же
1nTeRacT
сообщение 10.7.2009, 15:39
из темы про ленги, там турболенги... прошей стандартный Ленг 002E в теме Прошивки для ZN5
хотя я думаю не поможет.... нужно менять шрифт в кг52 ! или маунтить, как это делать в мануалах!
Сообщение отредактировал 1nTeRacT - 10.7.2009, 15:39
insanity
Из: Himki
Пользователь №: 135 172
А как тут повесить zTaskManRun на кнопку галереи?
sim_emrom
сообщение 10.7.2009, 15:41
Из: Ханты-Мансийск
Пользователь №: 195 802
Модель телефона: Spica
Прошивка: a.v.2.1
Ну так наверно, если шрифт не меняется, то он замаунтен, ребята! spiteful.gif
В medld.conf посмотрите или скриптом / mgx смены шрифта поставьте стандартный.
Про e-mail сам OCM770 в старой теме о Freedom 7FR говорил, что в этой версии пофиксено.
Hitch, про то что подвисает тел - немного напугал... Хотя у меня на Sie E71 такое бывало в свое время, пережить можно.
Огромное спасибо за мод - завтра скачаю (с анлима) и поставлю наконец smile.gif
К тем, кто уже поставил: zTaskMan на клавише висит или только через меню к нему? shades.gif
Lukas K.
сообщение 10.7.2009, 15:46
Из: Омск
1nTeRacT, так а со стандартным совсем долго работать будет..
OCM770
сообщение 10.7.2009, 16:04
zTaskMan is on the main menu, not on the gallery button (if set to gallery button then go to my media from camera options quits working).
zTaskMan на главном меню, а не на галерею кнопку (если установлена в галерее кнопку затем перейдите к моим средствам массовой информации с камеры на эту завершает работы).
!Pavlik!
сообщение 10.7.2009, 17:55
Из: Нижний Новгород
Пользователь №: 160 141
Модель телефона: RAZR XT910
Кому нужен стандартный шрифт,удаляем из medld.conf строчки:
mount -o bind /ezxlocal/Other/myfont.ttf /usr/language/fonts/AMCSL.TTF
mount -o bind /ezxlocal/Other/myfont.ttf /usr/language/fonts/NUMBER.TTF
[MP] Freedom Features Update [SWAP + CIF + MPKGBOX] · Motorola ZINE ZN5, ZN5 T-Mobile · Forum
Текстовая версия Сейчас: 10.9.2025, 14:41
