3 страниц V  1 2 3 >
Nik_Black_Diamond™ By Nikhil007™ ( nikhill), New fw for e8
nikhill
сообщение 21.8.2009, 8:39
Из: India
Пользователь №: 204 325
Модель телефона: e8
Nik_Black_Diamond™ By Nikhil007™ (Nikhil Dhayatkar)
IPB Image
Hi guys here's my new fw for the Rokr E8 !! Its based on Dragon_Hunter_13ER by xianyuhui .. Thanks to xianyuhui , Sandip_2u( For helping in some issues of the fw ) , ilove3d for Mpkgbox series , tulanix for providing excellent applications ,all authors of mgx apps incuded in this flash And special thanks to MMUS.US & Itfunz.com !!
Cg31 is not present in this fw so its not a locked flash and no one will get any bootloader error !! You can flash this over Dragon_Hunter_13ER personally tested by me !!
Features :
1.Cpu Speed 532 Mhz while booting itself ( Amazingly fast !! Let me know what you feel about the speed ) .. To switch off this Cpu Speed just delete S01_532Mhz.txt from unknown folder in phone memory !!
2.Memory Card Script added sos.txt so no glitch in opening at memory card mode in any theme no need to switch to onyx theme here onyx theme is named as cmcc !
3.Samba present by default !
4.Sidebar present by default hacked for all users by me http://www.mmus.us/forum//showthread.php?t=10218. Azaan present in the fw !!
5.Modified Onyx theme mixture of onyx,orange and cmcc theme by xianyuhui named as cmcc in the fw !!
6.Video high bitrate patch added by default !!
7.Some wallpapers,video and ringtones included !! In ringtones check Mum calling and Hanana !!
8.Java full Access enabled !
9.Now set up legal provisions in Html Version File Manager you will get it in the Mgx apps list !!
10.Animated picture included while opening browser !!
11.Turn Off Bluetooth present in Shortcuts ..it is shown when bluetooth is On !!
12.Copy and Paste skins to skins folder .. Even .mgs installation possible ..
13.Java heap size 4096 by default .
14.Message Alert For different contacts .
15.Fm Radio Timeout
IPB Image
Linux ( A new introduction )
Linux is a new icon and software introduced !! It has been set in Office tools by default !!
If you want you can bring it in the main menu !! More explained below !!
IPB Image
New app ( Black Diamond )
IPB Image
In this app you have :
IPB Image
1. Mpkgbox Switcher :
Mpkgbox 1 ( Open Source ) ; Mpkgbox 2.0 ( Registration Reqd . ) & Magicbox ( Registration Reqd.)
A new trick if you open Mpkgbox 2.0 , register it and then open Magic box . Magic box automatically gets registered i.e becomes Magicbox Pro !!
IPB Image
IPB Image
IPB Image
2. Icon to Adjust :
By default the linux icon is present in the office tools !! This thing gives you an option if you want to switch Linux in the main menu in place of Mpkgbox !!
IPB Image
3. Right icon
In the main screen for the right softkey a new icon is shown !! Looks brilliant you can set this On and Off from here !! For using a different icon and adding in the theme the icon name has to be youtube_simple.png ( 48*20 ) and youtube_big.png ( 125 * 24 ) the figures given in brackets are dimensions of the icon !
IPB Image
4.Networking Wizard
You can set the telnet,ftp and Samba enabled in the fw On and Off from here !!
IPB Image
Linux icon :
For adding the linux icon in different skins the name is certificate_mgr_big.png ( 96*96 ) ,certificate_mgr_std.png ( 49*49 ),certificate_mgr_simple ( 19*19 )
Mgx apps in Linux by Default in the fw are :
IPB Image
IPB Image
1.Rockbox by tulanix with 21 themes + 98 equalizer presets
IPB Image
IPB Image IPB Image
2.Mplayer latest version by tulanix ( Without gain )
3.Picture Flow by crazysunh
4.Sms tracker by tulanix
5.Text Editor by Nestor M
6.E8 Terminal by tulanix
7.Pirate by Nikhil007
a compilation of 13 mgx apps ,
that are : Virtual Memory , Menu Editor v1.1 , Find Lost Java , Backup , Add Turn Off BT to Shortcuts , SysInfo 2.0 , Modify Shortcuts , Java Heap Sizer , Hide , Cpu Speed , Stop Keyboard Vibration , Java Rename , Snapper
In navigation key ( i.e. Up,Down,Right and Left ) you can add all the apps which are present in the linux directory !!
Abt Flashing and recommendations :
As Cg31 is not present all users can flash this !!
More abt it and flashing steps here :http://www.mmus.us/forum/showthread.php?t=9083
Imp : Flash after Flashing NO Rsa BL !!
After flashing its recommended to perform a master reset atleast !! if u want to check what the actual speed of the fw is then perform delete all data so after nothing will be there in the phone it speeds up till eternity !!
Autorun Scripts can be added in locations :
/mmc/mmca1/first.txt
/mmc/movinand1/first.txt
/mmc/movinand1/unKnown/myfont.ttf
/mmc/movinand1/unKnown/mynum.ttf
/ezxlocal/autorun.txt
/mmc/mmca1/autorun/S??*
/mmc/movinand1/unKnown/S??*
Usefull paths:
mgx applications are installed:
/mmc/mmca1/mpkgbox
/mmc/movinand1/mpkgbox
mgs skins are installed:
/mmc/movinand1/skins
international language files:
/mmc/movinand1/.mpkgbox/
note: just write the file as xxx_${LANGUAGE_STRING}.lng
follow the ones which you get from ezx_system.cfg
the lang file is a shell script, you can understand it easily too.
FTP:
connect via USB tool or modem tools mode, access FTP in Filezilla,
through ftp://192.168.16.2, username is 'root', password not exist
TELNET:
telnet enabled
connect via USB tool or modem tools mode, access TELNET
through telnet 192.168.16.2, username is 'root', password not exist
Samba :
1.Connect the phone to your pc in usb & tools mode
2.In the address bar type \\192.168.16.2\ and hit enter
3.Bingo!...you have full access to file system ,without using filezilla
iF u r posting this monster pack anywhere on any site it is specified that you should mention my name as im the author .. and should mention the courtesy as MMUS !! Plz post this description as the original description when posting on any other site ..
It is needed to mention these things ..if u dont post you will be forbidden or plzz dont use the mp ..
Thankyou ,
Nikhil Dhayatkar ( Nikhil007™ )
Moderator MMUS , Moderator E8 and Em30 English Station on Itfunz.com , nikhill on motofan.ru and nikhil007 on motofunvn.com,e8mod.pl & moto.it168.com
Special Thanks to MMUS.US,Moto.it168.com,Itfunz.com,Motofunvn.com,Motofan.ru and E8mod.pl !!
Thanking MMUS again for supporting me and all members who are using this flash !!
1 more thing plzz add the fw you are using to your signature ..This might help us moderators to solve ur problems !! Please report to me if any bugs are found i will surely try to solve them !! Thankyou !!
look here for details : http://www.mmus.us/forum/showthread.php?p=95767#post95767
Plz someone add up this fw here i couldn't add a download link because of low connectivity !!
Сообщение отредактировал nikhill - 21.8.2009, 12:32
alxey
сообщение 21.8.2009, 8:48
Из: Kiev
Пользователь №: 144 371
Прошивка: E8 EM30 V8
hello. how we can make the sidebar or the Azaan? how did you do that?
Jinchuu
Пользователь №: 197 088
Модель телефона: e8
nice work nikhill
i must FW it
but now i think it's great even without FW
Сообщение отредактировал Jinchuu - 21.8.2009, 8:53
Hitch
сообщение 21.8.2009, 10:36
Вечномолодой
Из: Рая
Пользователь №: 46 265
Прошивка: Bada 1.2
Забираем с цивильных серверов, ребята
Black Diamond
Letitbit
rapidshare.ru
ifolder.ru
Сообщение отредактировал Hitch - 21.8.2009, 11:53
nikhill
сообщение 21.8.2009, 12:32
Из: India
Модель телефона: e8
Now enable sidebar for any network tutorial posted here : http://www.mmus.us/forum//showthread.php?t=10218
Pumba398
сообщение 21.8.2009, 13:17
Пользователь №: 119 961
Модель телефона: MotoROKR E8
Прошивка: Z-Mod 2.4.5 Final
nikhill, great work ! Thanks for uploading for us, Russian motofans smile.gif
Good luck with your next builds of FW
Messiv
сообщение 21.8.2009, 13:31
Пользователь №: 188 676
Модель телефона: E8
Прошивка: ...
Русский язык был бы, то поставил)
klaraivanovna
сообщение 21.8.2009, 13:35
Пользователь №: 185 158
Модель телефона: Droid Maxx
ЭЭЭЭЭЭЭЭЭЭЭЭЭЭЭЭ!!!!! Я чеготоо туплю unsure.gif Хса работает на всех симках?
Сообщение отредактировал stigr - 22.8.2009, 12:41
вадя1994
сообщение 21.8.2009, 13:40
Из: Харьков
Пользователь №: 202 401
klaraivanovna,
Добавлено позже (21.8.2009, 18:18):
залил прошу, но такое чюство что граффики вообще нет ! ( темы)
вместо всего желтые восклицательные знаки и нечего нормально не работает !!! что делать ??
Добавлено позже (21.8.2009, 18:20):
прошьюсь еще раз, посмотрим....
Добавлено позже (21.8.2009, 18:30):
та же фигня !! кто еще прошивал отпишитесь
xxSlipxx
сообщение 21.8.2009, 15:59
Из: izhevsk_style
Пользователь №: 188 346
Модель телефона: Rokr e8
Прошивка: 07R :)
Прошил, вся графика на месте, качал с их сайта, потом пересобрал и сменил ленг. :О
Больше ничего не делал.
Hitch
сообщение 21.8.2009, 16:09
Вечномолодой
Из: Рая
Прошивка: Bada 1.2
вадя1994, хм... странно. у меня тоже нет графики.
xxSlipxx, залей свою прошивку пересобранную с русским ленгом на ifolder.ru
вадя1994
сообщение 21.8.2009, 16:15
Из: Харьков
Hitch,
xxSlipxx,
какие у вас біли проши до прошивки блек даймондом ?
pes992
сообщение 21.8.2009, 16:21
Из: Кемерово
Пользователь №: 184 606
Модель телефона: V80,Е398,XT5
Прошивка: Android 2.2
xxSlipxx,
можешь выложить свою сборку?
xxSlipxx
сообщение 21.8.2009, 16:28
Из: izhevsk_style
Прошивка: 07R :)
ссори, но скайлинк ограничивает аплод, на 153кбит/сек до утра не залью. :о sad.gif
до этого стояла 1cr_a, по инструкции активировал хса панель, все робит. smile.gif
ХСА на русском, если есть русский лэнг.
ЗЫ пробую заливать.
Сообщение отредактировал xxSlipxx - 21.8.2009, 16:33
Messiv
сообщение 21.8.2009, 16:29
Модель телефона: E8
Прошивка: ...
хса панелька на руском?)
вадя1994
сообщение 21.8.2009, 16:33
Из: Харьков
xxSlipxx,
тогда обьясни по пунктам что ты делал и дай ссылку на прошу с их сайта
xxSlipxx
сообщение 21.8.2009, 16:38
Из: izhevsk_style
Прошивка: 07R :)
Попробуйте перед прошивкой удалить все данные, я ничего особенного не делал, прост скачал и заменил лэнг русским. для загрузки нужна регистрация. ВОТ ССЫЛЬ!
Сообщение отредактировал xxSlipxx - 21.8.2009, 16:41
pes992
сообщение 21.8.2009, 16:41
Из: Кемерово
простите за тупой вопрос...а ленг эт какая кодовая группа?
Льоша
сообщение 21.8.2009, 16:44
Пользователь №: 181 618
Прошивка: z-mod 2.10
ЦГ46
Fakelof
сообщение 21.8.2009, 16:46
Пользователь №: 187 896
Модель телефона: Motor EM30
Прошивка: 04.06r
А реально хса на em30 портануть?
nikhill
сообщение 21.8.2009, 16:51
Из: India
Модель телефона: e8
See the post here : http://www.mmus.us/forum//showthread.php?t=10215 A bug observed in the fw has been cleared by me !!
Льоша
Вот уже
П.С: Эта хса класная штука)) Кстати у меня часи появились на главном екране)
Добавлено позже (21.8.2009, 20:11):
Выложите плиз кто может из папки /mmc/movinand1/linux/setting файл setting.sh
Сообщение отредактировал Льоша - 21.8.2009, 16:53
вадя1994
сообщение 21.8.2009, 17:38
Из: Харьков
zidane
сообщение 21.8.2009, 17:47
Пользователь №: 136 304
Модель телефона: ve66
как хса то включить?
вадя1994
сообщение 21.8.2009, 17:48
Из: Харьков
zidane,
на, читай
Добавлено позже (21.8.2009, 20:50):
люди !!!
у кого нить получялось поставить Nik_Black_Diamond™ на гуд шток ??
если нет, то на что получялось ??
alxey
сообщение 21.8.2009, 17:58
Из: Kiev
тут можно попеременно включать то хса то азаан(мусульманская хса)?
Льоша
сообщение 21.8.2009, 17:59
Да
No1
сообщение 21.8.2009, 18:22
Пользователь №: 204 283
Модель телефона: e8
что такое xca ?
и кто нибудь уже поставил эту прошивку поверх гудстока?
вадя1994
сообщение 21.8.2009, 18:29
Из: Харьков
No1,
пока никому не удалось.
хса это панелька сбоку екрана
Elvis271
сообщение 21.8.2009, 18:32
Пользователь №: 149 269
Модель телефона: E8
хм.. ну у меня получилось.. я в конце закрыть нажал прост...
хорошая прошивка.. ток рокбокс се так бессмысленен без нормального сворачивания/разворачивания...
pes992
сообщение 21.8.2009, 19:06
Из: Кемерово
блин со стока прошился.......просто вибрирует и потом отключаеться
Добавлено позже (21.8.2009, 19:08):
и знаки восклицательные
betelgeize
сообщение 21.8.2009, 19:26
Из: Мелитополь
Пользователь №: 183 296
Модель телефона: ROKR E8
Прошивка: R6713_G_71.14.1CR_A
pes992, бут не а3 часом уц меня а9 проблем нет
вадя1994
сообщение 21.8.2009, 19:30
Из: Харьков
betelgeize,
а3
я прошил только послепрошивки 1цр
pes992
сообщение 21.8.2009, 19:31
Из: Кемерово
да А3...ну вроде же написано что для всех бутов....и что мне теперь делать?((((
вадя1994
сообщение 21.8.2009, 20:04
Из: Харьков
Сообщение отредактировал stigr - 22.8.2009, 12:46
pes992
сообщение 21.8.2009, 20:06
Из: Кемерово
вадя1994,
ты с как со стока прошился?
вадя1994
сообщение 21.8.2009, 20:17
Из: Харьков
сначяла прошил Новая прошива для Е8
потом блек даймонд
pes992
сообщение 21.8.2009, 20:34
Из: Кемерово
Добавлено позже (21.8.2009, 20:49):
А как поставить New iLove3d MPKGBox, Теперь бесплатный и с открытым кодом
Добавлено позже (21.8.2009, 21:24):
тоже хса не получаеться
Льоша
сообщение 21.8.2009, 21:27
Что именно не получается?Если нужно могу написать мануал по-руски если надо даже со скринами
Сообщение отредактировал Льоша - 21.8.2009, 21:28
pes992
сообщение 21.8.2009, 21:34
Из: Кемерово
Остался тока один вопрос.... А как поставить New iLove3d MPKGBox, Теперь бесплатный и с открытым кодом?
А с хса мне мозг позволил разобраться!!!!!!ура!!!!
Добавлено позже (21.8.2009, 21:49):
А хотя бы в бокс русский язык запихнуть?
Nik_Black_Diamond™ By Nikhil007™ ( nikhill), New fw for e8 · Motorola ROKR E8, EM30 · Forum
3 страниц V  1 2 3 >
Текстовая версия Сейчас: 13.9.2025, 18:10
