4 страниц V  1 2 3 > »
Nik_Black_Diamond_Final_Superb™ By Nikhil007™, New fw for e8
nikhill
сообщение 9.9.2009, 12:36
Из: India
Пользователь №: 204 325
Модель телефона: e8
Nik_Black_Diamond_Final_Superb™ By Nikhil007™ (Nikhil Dhayatkar)
IPB Image
Hi guys here's my new fw for the Rokr E8 !! Its based on Dragon_Hunter_13ER by xianyuhui .. Thanks to xianyuhui , Sandip_2u( For helping in some issues of the fw ) , ilove3d for Mpkgbox series , tulanix for providing excellent applications ,Xmifeng for 532 Mhz Script , all authors of mgx apps incuded in this flash And special thanks to MMUS.US & Itfunz.com !!
A complete bug free flash !!
Cg31 is not present in this fw so its not a locked flash and no one will get any bootloader error !! You can flash this over Dragon_Hunter_13ER personally tested by me !!
Imp : Flash after Flashing NO Rsa BL !!
After flashing its recommended to perform a master reset atleast !! if u want to check what the actual speed of the fw is then perform delete all data so after nothing will be there in the phone it speeds up till eternity !! Master reset and Master clear work very gr8 no bug with it !!
As it has been observed that some users were getting multiple messages that problem is solved in this fw !! with the download link i've provided a no rsa consumer bootloader just flash it before you flash this monster pack !! you wont get any multiple incoming message bug then !!
Features :
1.Cpu Speed 339 Mhz by default .. But i am providing the script made by my friend Xmifeng at moto.it168.com by which you can run Cpu Speed at 532Mhz by default !!
2.Sidebar hacked works for all networks http://www.mmus.us/forum/showthread.php?p=95822#post95822 .. Some network id's which were requested are added by default !! The network id's added by default are : [204-20],[226-03],[208-01],[226-10],[228-03],[260-03],[302-72],[310-26],[231-01],[234-33],[295-02],[340-01],[370-01],[404-22],[460-00],[460-01],[460-02],[603-02],[612-03],[624-02],[646-02],[647-00],[652-02],[334-020],[310-410],[310-260],[748-01],[404-60],[234-10],[724-02],[452-01],[452-07],[404-80],[724-05],[724-31],[724-02],[724-10],[404-84],[724-05],[452-02],[452-03],[452-04],[452-05],[452-06],[405-13],[510-01],[722-34],[722-07],[722-310]
IPB Image
3.Samba present by default !
4.Azaan is also present !! It is turned on by default so when the phone loads up for the first time it wil show azaan first and then sidebar just turn azaan off in phone settings \ homescreen \ custom homescreen
5.Modified Onyx theme mixture of onyx,orange and cmcc theme by xianyuhui named as Cmcc in the fw !!
6.Video high bitrate patch added by default !!
7.Some wallpapers,video and ringtones included !! In ringtones check Mum calling and Hanana !! Check Vibrate Ringtone this ringtone actually vibrates the phone !!
8.Java full Access enabled !
10.Animated picture included while opening browser !!
11.Turn Off Bluetooth present in Shortcuts ..it is shown when bluetooth is On
12.New Shortcut Call Plan added . Thanks to devilsking for this mod !! You get the call plan from your network provider ..You can see the shortcut in above screenshot..
13.Copy and Paste skins to skins folder .. Even .mgs installation possible ..
14.Java heap size 4096 by default .
IPB Image
15.Message Alert Present By Default .
15.Video Slideshow present ..
16.A new skin RedBlackRokr5 by bev and its HSA by Enigmatic !! Thanks to both of them at motofan.ru !! This skin is included in the preload folder which is on the phone memory !! just enter it preload\skins\RBR copy this RBR folder to skins folder on phone memory !!
17.Mpkgbox 2.0 Pro Free Version added !!
18.MagicBox Pro Latest version has been added !!
build 200909: (see specific description MagxCN Home)
Optimize the speed of the menu, click Display
optimize the speed of boot time since the launch of
to provide MGX and JAVA programs by name sort function, support Chinese pinyin sorting
expedited procedures to provide custom label
support directly to install MPKGBOX tag MGX
Registration prompted a more intuitive interface to facilitate the importation License, without affecting the non-registered users of psychological feelings
IPB Image
IPB Image
IPB Image
Now non registered users when they press the music key get mediafinder
IPB Image
For non registered users whenever they close Magicbox this message appears
IPB Image
If they press any button then registration window appears otherwise it doesn't !!
18.Bluetooth PIN is reduced
See when you bond to some device the phone asks you for a pin we till now needed to apply a four digit code then only it worked !! Now you can bond with just one number also !!
19.Some more additions
bash4.0, / bin / bash
busybox1.14.3, / bin / busybox_full
20.Install jar apps to these sub windows
IPB Image
IPB Image
21.Master reset and Clear work now no bugs with it !! Thanks to Sandip_2u !
22.Linux ( A new introduction )
Linux is a new icon and software introduced !! It has been set in Office tools by default !!
If you want you can bring it in the main menu !! More explained below !!
In this app you have :
1. Mpkgbox Switcher :
Mpkgbox 1 ( Open Source ) ; Mpkgbox 2.0 ( Registration Reqd . ) ; Mpkgbox 2.0 Pro Free version & New Magicbox registration required !!
IPB Image
A new trick if you open Mpkgbox 2.0 , register it and then open Magic box . Magic box automatically gets registered !! Or you can Mpkgbox 2.0 Pro free version !!
2. Icon to Adjust :
By default the linux icon is present in the office tools !! This thing gives you an option if you want to switch Linux in the main menu in place of Mpkgbox !!
IPB Image
3. Right icon
In the main screen for the right softkey a new icon is shown !! Looks brilliant you can set this On and Off from here !! For using a different icon and adding in the theme the icon name has to be youtube_simple.png ( 48*20 ) and youtube_big.png ( 125 * 24 ) the figures given in brackets are dimensions of the icon !
IPB Image
4.Networking Wizard
You can set the telnet,ftp and Samba enabled in the fw On and Off from here !!
IPB Image
Linux icon :
For adding the linux icon in different skins the name is certificate_mgr_big.png ( 96*96 ) ,certificate_mgr_std.png ( 49*49 ),certificate_mgr_simple ( 19*19 )
Mgx apps in Linux by Default in the fw are :
IPB Image
IPB Image
IPB Image
1.Rockbox by tulanix with 21 themes + 97 equalizer presets
IPB Image
IPB Image IPB Image
2.Mplayer latest version by tulanix ( Without gain )
3.Picture Flow by crazysunh
4.Sms tracker by tulanix
5.Text Editor by Nestor M
6.E8 Terminal by tulanix
7.Pirate by Nikhil007
a compilation of 12 mgx apps ,
that are : Virtual Memory , Find Lost Java , Backup , Add Turn Off BT to Shortcuts , SysInfo 2.0 , Modify Shortcuts , Java Heap Sizer , Hide , Cpu Speed , Stop Keyboard Vibration , Java Rename , Snapper
8.FileManager 2.0
9.ImageMagic Beta
10.Stop Rockbox
Sometimes the rockbox gets minimized but the song keeps playing so to stop rockbox this app can be used !!
It has three options ,
IPB Image
By the first option you just set the time in minutes of what time you want rockbox to go off for eg.1 then the song stops in 1 min !!
By the second option you can set the time as well as shutdown the phone !!\
11.Sidekey
now you can put Rockbox and many other apps to the sidekey which is defined for camera !! You can even add Music to it !! So if you are using Magicbox Pro you can still load up music by the Sidekey !! The camera can be assigned in sidebar ! More abt that is explained as you read this readme !!
13.Cpu Full Speed
Now no need of adding the 532 Mhz script anywhere by this app just enable it to Full Speed and the phone will be superfast !! Still im providing the script with the download !!
Now that i've explained all this some more things need to be explained :
Sidebar Any Shortcut
Guys the sidebar in the fifth tab from up has something named options.Now you can assign any shortcut you want there ..
See this :
IPB Image
With this package I am even providing MotorolaSetup application for getting your browser profiles .
Here's a step by step procedure :
First install the .jad file provided.Then start the application
IPB Image
When you start it press the left softkey start .Now it will give you these browser profiles
IPB Image
Dont select any of them just click on Cancel .After that it will give you this window
IPB Image
Click on Yes now it will show you this window
IPB Image
After the process gets complete it will show you this window :
IPB Image
Say exit and wait in sometime such a message will come on your homescreen
IPB Image
Just click on install and your browser profiles will get installed ..
Abt Flashing and recommendations :
As Cg31 is not present all users can flash this !!
More abt it and flashing steps here :http://www.mmus.us/forum/showthread.php?t=9083
Autorun Scripts can be added in locations :
/mmc/mmca1/first.txt
/mmc/movinand1/first.txt
/mmc/movinand1/unKnown/myfont.ttf
/mmc/movinand1/unKnown/mynum.ttf
/ezxlocal/autorun.txt
/mmc/mmca1/autorun/S??*
/mmc/movinand1/unKnown/S??*
Usefull paths:
mgx applications are installed:
/mmc/mmca1/mpkgbox
/mmc/movinand1/mpkgbox
mgs skins are installed:
/mmc/movinand1/skins
international language files:
/mmc/movinand1/.mpkgbox/
note: just write the file as xxx_${LANGUAGE_STRING}.lng
follow the ones which you get from ezx_system.cfg
the lang file is a shell script, you can understand it easily too.
FTP:
connect via USB tool or modem tools mode, access FTP in Filezilla,
through ftp://192.168.16.2, username is 'root', password not exist
TELNET:
telnet enabled
connect via USB tool or modem tools mode, access TELNET
through telnet 192.168.16.2, username is 'root', password not exist
Samba :
1.Connect the phone to your pc in usb & tools mode
2.In the address bar type \\192.168.16.2\ and hit enter
3.Bingo!...you have full access to file system ,without using filezilla
iF u r posting this monster pack anywhere on any site it is specified that you should mention my name as im the author .. and should mention the courtesy as MMUS !! Plz post this description as the original description when posting on any other site ..
It is needed to mention these things ..if u dont post you will be forbidden or plzz dont use the mp ..
Thankyou ,
Nikhil Dhayatkar ( Nikhil007™ )
Moderator MMUS , Moderator E8 and Em30 English Station on Itfunz.com , nikhill on motofan.ru and nikhil007 on motofunvn.com,e8mod.pl & moto.it168.com
Special Thanks to MMUS.US,Moto.it168.com,Itfunz.com,Motofunvn.com,Motofan.ru and E8mod.pl !!
Thanking MMUS again for supporting me and all members who are using this flash !!
1 more thing plzz add the fw you are using to your signature ..This might help us moderators to solve ur problems !! Please report to me if any bugs are found i will surely try to solve them !! Thankyou !!
Download link available here : http://www.mmus.us/forum//showthread.php?t=10522
Pumba398
сообщение 9.9.2009, 12:46
Пользователь №: 119 961
Модель телефона: MotoROKR E8
Прошивка: Z-Mod 2.4.5 Final
nikhill
Excellent work!
Bro, but can you name a list of differences from your last firmware Nik Black Diamond 2 Final? please smile.gif because i have no trouble with Black Diamond 2 and thinking flash this FW or not)))
and is this FW have all features that has MartinczFala_Eclipse_III_Final and E8 ilove3d_1013RE_Magic_Elba_Pro3 Release ?
Сообщение отредактировал Pumba398 - 9.9.2009, 13:00
ViP)
сообщение 9.9.2009, 15:34
Пользователь №: 143 805
Модель телефона: E8
ссылки на другие обменники...
fileshare.in.ua (UA-IX)
letitbit.net
Сообщение отредактировал ViP) - 9.9.2009, 15:34
nikhill
сообщение 9.9.2009, 16:53
Из: India
Модель телефона: e8
@ Pumba398 bro it has all the features of ilove3d's and martincz's fw + master reset and clear bug has been fixed + stop rb ,cpu full speed and sidekey are new apps added see read the complete main post !! even magicbox is new !! Try this 1 as it is the final with no bugs !!
Pumba398
сообщение 9.9.2009, 16:58
nikhill, thanks for the answer!
Tomorrow i`ll try this FW smile.gif You`ve done great job
Сообщение отредактировал Pumba398 - 9.9.2009, 17:02
sandycorp
сообщение 9.9.2009, 17:13
Из: Нижний Новгород
Пользователь №: 112 812
Модель телефона: E8, V9, ZN5
Работает на ура!
Прошлая версия очень понравилась, а здесь баги пофиксены - я только хотел про них сообщить)))
Молодей! Спасибо!
Только что-то турболенг не встает (похоже руки не хотят)))
Какой лучше поставить? (ленг)
Pumba398
сообщение 9.9.2009, 17:15
sandycorp, да ну забудьте вы про этот турболенг)) он уже не нужен вообще так как тут всё сделано для того чтобы можно было ставить любой ленг, какой захочешь) в прошлой проше он тоже не нужен был, да и ваще во всех маломальски новых прошивках он не нужен, в самой проше какое то значение уже правлено.
Сообщение отредактировал Pumba398 - 9.9.2009, 17:18
sandycorp
сообщение 9.9.2009, 17:18
Из: Нижний Новгород
Pumba398, ссылку на любой можно озвучить?
(сорри за оффтоп)
nikhill
сообщение 9.9.2009, 17:21
Из: India
Модель телефона: e8
No probs Pumba398 im glad you like the fw ..
Pumba398
сообщение 9.9.2009, 17:22
sandycorp, в топике прошлой проши давал, вот отсюда можно стянуть ftp://motofan.ru/Proshivki/ROKR_E8/R6713_...LANG002E.sbf.gz
Ну я вот уже на какую прошу не ставлю данный ленг, всё отлично подходит, быстро и без лагов.
LITEZ
сообщение 9.9.2009, 17:45
Из: Брест
Пользователь №: 126 842
Модель телефона: E398+Е8
Прошивка: 49r+1CR_A
Её можно ставить на R6713_G_71.14.1CR_A?
Witazzew
сообщение 9.9.2009, 18:02
Из: Ухта
Пользователь №: 180 655
Модель телефона: 910
LITEZ,
да, но только если бут NoRsa
DAmNNY
сообщение 9.9.2009, 18:33
Из: Улей
Пользователь №: 12 781
Модель телефона: E8+Milestone
А может кто нить напишет шаги установки?
Прошивка, ленг, резет (и обязателен ли он)?
Pumba398
сообщение 9.9.2009, 21:03
DAmNNY, на всех монстрах от Nikhil007 желательно делать мастер очистку либо до перепрошивки, либо обязательно сразу после (советует ещё карту памяти вынимать, хотя я её всегда оставляю). Я всегда её делаю и реально ни разу на его проши не жаловался. Ну а так да, НоРСА если стоит то прошивка - мастер очистка (до перепрошивки или после) - ленг
Сообщение отредактировал Pumba398 - 9.9.2009, 21:04
Boaz
сообщение 10.9.2009, 6:57
Из: Магнитогорск
Пользователь №: 197 485
Модель телефона: ROKR E8
Прошивка: Rokr Envy
я надеюсь после прошивки желтых восклицательных знаков по всему экрану не будет?
МихАйс
сообщение 10.9.2009, 7:16
Из: г. Воронеж
Пользователь №: 63 323
Модель телефона: Moto G
эта прошивка на много быстрее чем ver 2. final. очень радует пользоваться samba(и сразы и заливаю через комп файлы а на телефоне не отключая кабеля устанавливаю),очень быстро работает..
кто нибудь знает на этой проше есть свап?
Добавлено позже (10.9.2009, 12:07):
Nikhil, your fw long start telefon! mad.gif what may be problem?
Dontsay
сообщение 10.9.2009, 7:53
Из: республика Адыгея, г. Майкоп
Пользователь №: 196 386
Модель телефона: MOTOROKR E8
Прошивка: Black Diamond
Такая проблемка появилась - после прошивки монстра Black Diamond,телефон после выключения включается не сразу!Как будто стартер на машине глючит и выключатель нада опускать несколько раз!!!!!! sad.gif Не пойму в чем фигня!!!!!! ph34r.gif Подскажите ПЛЗ!!!!
___________
помоему прошивка криво лягла попробуй перешить тело ещё раз.
Сообщение отредактировал stigr - 10.9.2009, 8:00
МихАйс
сообщение 10.9.2009, 8:04
Из: г. Воронеж
у меня тоже самое... помоему дело не в кривости...
зы,ещё вчера на зарядку поставил, через 2 часа пришёл,а он даже и не думал заряжаться...тем более включаться..
LITEZ
сообщение 10.9.2009, 8:39
Из: Брест
Прошивка: 49r+1CR_A
Такая же ерунда, но не постоянно! И не только на этой прошивке. Мне кацца, что это кнопка разболтана!
yurezzz13
сообщение 10.9.2009, 8:53
Из: Lviff
Пользователь №: 180 486
Прошивка: 07R
такая фигня у меня стабильно была и на стоковой проше, включался только после 3 попыток
МихАйс
сообщение 10.9.2009, 8:55
Из: г. Воронеж
может быть это после прошития noRSA шного бута? ведь раньше у меня такого не было sad.gif
yurezzz13
сообщение 10.9.2009, 9:10
Из: Lviff
Прошивка: 07R
возможно, точно сказать не могу
Spitfire398
сообщение 10.9.2009, 9:11
Из: Ukraine
Пользователь №: 161 149
Прошивка: Z-Mod E8
У меня и щас подобного нету ... Бут ноу РСА
DAmNNY
сообщение 10.9.2009, 10:10
Из: Улей
Если сделать mr после прошивки, разве различные файлы не потрутся?
И чем лучше всего тел.книгу забэкапить?
LITEZ
сообщение 10.9.2009, 10:25
Из: Брест
Прошивка: 49r+1CR_A
Скопируй /ezxlocal/sysDatabase/. Там она! А если ещё и картинки и музыку аккуратно скопируешь, а после прошивки в те же папки закинешь, то и мелодии и фото на контактах сохраняться!!!
VaniCheL
сообщение 10.9.2009, 19:09
Из: Челябинск
Пользователь №: 203 058
Прошивка: 4.5.1-134_DFP-139
я бэкап книги делаю с помощью MPT, которая на диске в коробке с телефоном шла. имхо очень удобно. нажал кнопку - и все зарезервировано shades.gif
Добавлено позже (11.9.2009, 2:57):
+ ковырять календарь и записнукнигу через МРТ одно удовольствие
Boaz
сообщение 11.9.2009, 3:26
Из: Магнитогорск
Прошивка: Rokr Envy
у меня проблем со включением никогда не было...птьфу птьфу птьфу...а что говорите эта херь возникает прошив этот black diamond
nikhill
сообщение 11.9.2009, 4:12
Из: India
Модель телефона: e8
I hope everyone are liking my fw here !! Thankyou for using it !!
Boaz
сообщение 11.9.2009, 4:30
Из: Магнитогорск
Прошивка: Rokr Envy
Nikhil, I had a problem with your firmware NASA Eclipse, after flashing were yellow exclamation marks over the screen with this firmware as?
ViP)
сообщение 11.9.2009, 5:28
Модель телефона: E8
у меня тоже бывает траблы с включением, не с первого раза врубается....заметил что от прошивки не зависит....может кнопочка уже подустала просто!?))
yurezzz13
сообщение 11.9.2009, 6:17
Из: Lviff
Прошивка: 07R
А у меня, после прошивки этим монстром, с первого раза стал включатся...удивило...легкое нажатие и экран загрузки, до этого всегда 3 раза с усердием зажимал...странно это... ph34r.gif
midnight_diver
сообщение 11.9.2009, 6:22
Пользователь №: 46 729
Модель телефона: Rokr E8
Прошивка: zMod 2.4.4
Скин стоковый с этой прошивки может кто скинуть? Заранее благодарен.
Dontsay
сообщение 11.9.2009, 7:38
С кнопочкой все в порядке!До этого на 1сr_a работало отлично!Вот думаю нада все таки последним даймондом прошиться!Мож все дело в проше блэк даймонд2 финал????
Кстати я слил ленг ***.sbf!Его нада прошивать после прошивки тела или разбирать прошу и менять КГ???И еще если в прошлой версии блэк даймонда есть баг с очисткой и полным сбросом,а у меня сейчас стоит именно он,если я прошью тело и потом сделаю мастер клин - прокатит это??? ph34r.gif
Сообщение отредактировал Dontsay - 11.9.2009, 7:39
Boaz
сообщение 11.9.2009, 8:44
Из: Магнитогорск
Прошивка: Rokr Envy
хм. ну вообще то можно и после, результат не измениться, если после у тебя файл sbf должен состоять из двух файлов: ramdld и cg46, ну это понятно. После прошивки, ну думаю да, хотя по логике вещей, лучше до) shades.gif
Dontsay
сообщение 11.9.2009, 10:49
Так вот сброс до прошивания сделать не вариант,тк изначально в блэк даймонде есть баг на очистку и сброс!!!! sad.gif Сброс и очистка не возможны! sad.gif sad.gif sad.gif
Nikita83
сообщение 11.9.2009, 11:26
Из: Россия
Пользователь №: 198 249
Прошивка: X1_MOD_14_1cr
По моему в архиве со второй версией лежит скрипт на очистку данных, вроде его надо кидать в корень карты памяти и при следующем включение все должно очистится.
Решил сегодня посмотреть, что за прошивка и прошил. Что могу сказать.... Красиво, много лишнего, не совсем удобна(необходимо подпиливать под себя, в прочем как и все прошивки) и все таки она тяжеловата и малость задумчива. Особых глюков не обнаружил. Вернулся на 14_1CR(естественно модифицированый).
P.S. Возникает такое ощущение, что баг с включением телефона возникает после того как побалуешся с авторанами и маунтами, а в этой прошивке насколько я понимаю, их черезчур многоватоsmile.gif
Сообщение отредактировал Nikita83 - 11.9.2009, 11:50
Pumba398
сообщение 11.9.2009, 11:46
Dontsay, не бойся я сделал мастер очистку после перепрошивки на данного монстра. Всё стало отлично, до мастер очистки кстати монстр подтупливал))зато после как ракета, немножко даже побыстрее Блэк Даймонд 2
Сообщение отредактировал Pumba398 - 11.9.2009, 11:47
Dontsay
сообщение 11.9.2009, 12:37
Сегодня прошьюсь и завтра отпишусь!!!!
aic_sp
сообщение 11.9.2009, 12:48
Пользователь №: 204 990
Модель телефона: motorola E8
Прошивка: MartinkzFalaEclipse
подскажите, как боковую панель включить и вынести приложения на нее? а еще ассоциировать типы файлов для приложения(например, мплеер), неудобно..что все надо через само приложение запускать...спасибо..сильно не ругайтесь за нубские вопросы..
Сообщение отредактировал aic_sp - 11.9.2009, 12:48
Ilya_GC
сообщение 11.9.2009, 13:14
Пользователь №: 170 313
Модель телефона: milestone, RAZR
Прошивка: CM 7 Roadracer
У меня проблемы с включением телефона начались сразу, как только поставил Goodstock, до этого стояла 1CR c неподписанной CG 52 и было всё прекрасно! Сегодня поставлю эту прошу, посмотрю, что будет.
Nik_Black_Diamond_Final_Superb™ By Nikhil007™, New fw for e8 · Motorola ROKR E8, EM30 · Forum
Текстовая версия Сейчас: 18.7.2025, 20:31
