2 страниц V  1 2 >
[MP] Magx Reloaded V1
OCM770
сообщение 14.9.2009, 2:23 Закрепленное сообщение!
Пользователь №: 196 171
OCM770 in Cooperation with Kidscracker and Skrilax_CZ proudly present:
Magx Reloaded V1
In English:
Disclaimer:
  • We (OCM770, Kidscracker, Skrilax_CZ) take no responsability for damaged phones, the user has full responsability. We are not responsible for any data loss and or bricked phones.
  • We assume the user has read this README file and knows what he is doing.
Credits:
  • MP Created by OCM770 in cooperation with Kidscracker and Skrilax_CZ.
  • Credit to Skrilax_CZ for all patched libraries/binaries, Language Pack and MP Suggestions.
  • Credit to Kidscracker for making MgxBox and MP Suggestions.
  • Credit to Javierox for helping me with some doubts and providing the base partition scripts.
  • Credit to Kleto for helping with some doubts.
  • Credit to fldodger for providing HSA icons and Beta tester.
  • Credit to ANT-ON for zTaskMan.
  • Credit to Chacha_Ivanov for libezxappbase mod.
  • Credit to abraham for base UnionFS patch.
  • Credit to ilove3d for EasyThemes.
Main Features
  • Read/Write File System. Yes, full write access to the file system, with the exception of /etc (security measures).
  • MgxBox. New MGX Managing utility created by Kidscracker, can also install applications to the main menu.
  • Squashfs 3.3 . Supports higher block size values (up to 1MB)
Features:
  • CG35:
  • Support for UNIONFS
  • Support for SWAP
  • Support for EXT2
  • Support for EXT3
  • Support for NTFS
  • Support for SQUASHFS 3.3
  • CG36:
  • NEW MgxBox
  • FTP&Telnet
  • UnionFS
  • Swap Auto Enable
  • EasyThemes
  • SDL Preinstalled in /usr/lib
  • Bash
  • Bftpd 2.4
  • Busybox 1.14.3 as /bin/busybox_full
  • FTP Show hidden directories
  • 15 Item Main menu with 15 Item Grid Reorder
  • QVGA Camera with RAW | Binnaed RAW Support
  • CPU 532Mhz during power on
  • Hostname enabled
  • Message Of the Day mod
  • Issue and Issue.net mod
  • FTP Message Of the Day
  • PS1 Variable mod
  • Run Scripts from FM
  • Rar/Zip from FM
  • show* Modules
  • libezxappbase.so.1.0.0 speed mod
  • Removal of certain modules to increase speed
  • EXT2 Managing utilites in /usr/bin
  • mediaplayer red key homescreen mod
CG42:
  • Custom Boot Screen
CG43:
  • HSA pre-enabled for Mexico, Peru, Czech Republic, 2 US Tmobile Network and some Russian Networks
  • Enabled IM with MSN/ICQ/AIM/Yahoo Messenger
  • No preloaded MMS settings
  • Preloaded WiFi Profile for Wifi Only
  • Working sort in phonebook
  • Default USB Connection set to Modem&Tools
  • Java Heap Size 4mb
CG44:
  • Java Full Permissions Mod
CG52:
  • zTaskMan 0.3
  • Autorun Script
  • Selectable Aditional Features
  • Skins:
  • Alkali as default
  • Kodak
  • Indium
  • Preinstalled Java Apps:
  • Opera Mini 4.2
  • Tetris
  • Sudoku
  • Song ID
  • Motorola SETUP
  • Motorola BACKUP
  • Motorola TEXT
  • Several Games
  • Partition Scripts
  • Custom Menu
  • Applications Folder
  • HSA Icons
Instalation:
  • Flash noRSA Bootloader. *IMPORTANT* FLASH VERSION DESIGNED FOR YOUR BOOTLOADER ONLY! noRSA 062A for 062A ||| noRSA 062DP for 062B and 062DP
  • Flash Magx Reloaded V1
  • Follow Aditional Features Prompt
*IMPORTANT* ENABLING RWFS WILL FORMAT YOUR MICRO SD CARD. IF YOU ENABLE THIS OPTION YOU **WILL** LOSE ALL DATA ON IT!
  • Download Links:
[/B]
Known Bugs:
  • Browser downloads will not work when RWFS is enabled. Remove SD Card or disable RWFS to download from browser.
  • Camera gives "Camera Busy" error message when Camera runs with lens closed.
Guide to using RWFS(In English).
RWFS (Read Write File System) uses the unionfs file system to make squashfs file systems writeable, it does this by storing all changes in the file system in a writeable directory, the second partition on the memory card in this case. RWFS will prompt you to choose your memory card size when you chose to install it, it will take 400mb of your SD card for the ext2 partition, with the exception of 1gb cards, it will take 200mb.
If you delete a file from any previously ro directory it will create a file on the memory card with prefix .wh_[filename] so if you delete /usr/bin/mediaplayer a file will be created in /mmc/mmca2/usr/bin called .wh_mediaplayer . If you delete this .wh_ file and reboot the file will come back in /usr/bin . If you add a file called file1 to /usr/bin the file will be created in /mmc/mmca2/usr/bin/file1 but you will see the actual file in /usr/bin .
The directories with read/write access are /bin /lib /usr /sbin /root /home
Now what if you mess something up and the phone will not boot? Don't panic. Basically you have two options and neither one requires any formatting:
a) If you have access to the second partition from any other device, delete the file which caused the phone not to boot, if you have no idea, wipe it out totally or at least the files of which you don't know what they do. (Note: enable showing hidden files / folders)
B) If you cannot access the second partition by any other means than the phone, plug your memory card to PC and in folder ".Reloaded" create a file "no_unionfs". (Without the quotes and case sensitive). Put your memory card back to the phone and now mmca2 is still accessible, but not mounted as unionfs. Delete the file which caused the phone not to boot, if you have no idea, wipe it out totally or at least the files of which you don't know what they do. The delete the "no_unionfs" file in mmca1 and reboot.
OCM770 в сотрудничестве с Kidscracker и and Skrilax_CZ с гордостью представляют:
Magx Reloaded V1
Оговорка:
  • Мы, (OCM770, Kidscracker, Skrilax_CZ) не несем никакой ответственности за поврежденные телефоны, за них ответственен пользователь. Мы не ответственны за любую потерю данных или трупы телефонов.
  • Мы надеемся, что пользователь прочтет README файл и будет знать, что он делает.
Благодарности:
  • MP создан OCM770 в сотрудничестве сKidscracker и Skrilax_CZ.
  • Спасибо Skrilax_CZ за все его патчи для либ/бинарников, языковой пакет и предложения по MP.
  • Спасибо Kidscracker за его MgxBox и предложения по MP.
  • Спасибо Javierox за помощь мне с некоторыми проблемами и за предоставление основных скриптов разделов.
  • Спасибо Kleto за помощь с некоторыми проблемами.
  • Спасибо fldodger за HAS иконки и бета-тестирование.
  • Спасибо ANT-ON за zTaskMan.
  • Спасибо Chacha_Ivanov за libezxappbase мод.
  • Спасибо abraham за основу патча UnionFS.
  • Спасибо ilove3d за EasyThemes.
Основные возможности:
    Read/Write файловая система. Да, полный доступ для записи в файловую систему, за исключением /etc (меры безопасности).
  • MgxBox. Новая утилита для управления MGX пакетами, созданная Kidscracker, которая также может прописывать приложения в главное меню.
  • Squashfs 3.3. Поддержка больших значений размера блока (вплоть до1MB)
Возможности:
CG35:
  • Поддержка UNIONFS
  • Поддержка SWAP
  • Поддержка EXT2
  • Поддержка EXT3
  • Поддержка NTFS
  • Поддержка SQUASHFS 3.3
CG36:
  • Новый MgxBox
  • FTP&Telnet
  • UnionFS
  • Автовключение Swap
  • EasyThemes
  • SDL предустановлен в /usr/lib
  • Bash
  • Bftpd 2.4
  • FTP показывает скрытые папки
  • Главное меню с 15 иконками и возможностью пересортировки
  • QVGA Камера с поддержкой RAW | Binned RAW
  • Постоянная частота CPU 532Mhz
  • Hostname включен
  • Мод Сообщение Дня
  • Мод Issue and Issue.net
  • FTP Сообщение Дня
  • PS1 Variable мод
  • Запуск скриптов из ФМ
  • Rar/Zip из ФМ
  • show* Модули
  • Мод увеличения скорости в libezxappbase.so.1.0.0
  • Удалены Removal of определенные модули для увеличения скорости работы
  • Утилиты управления EXT2 в /usr/bin
  • Медиаплеер «red key homescreen» мод
CG42:
  • Изменен экран загрузки
CG43:
  • HSA включен для Мексики, Перу, Чешской республики, двух US T-mobile сетей и некоторых русских сетей.
  • Включен IM с поддержкой MSN/ICQ/AIM/Yahoo.
  • Нет предустановленных настроек MMS.
  • Предустановленный WiFi профиль для Wifi Only
  • Работает сортировка в контактах.
  • По умолчанию в Соединениях стоит Modem&Tools
  • Размер Heap для Java 4mb
CG44:
  • Мод полных прав для Java
CG52:
  • zTaskMan 0.3
  • Autorun скрипт
  • Выбираемые дополнительные возможности
  • Скины:
  • Alkali по умолчанию
  • Kodak
  • Indium
  • Предустановленные Java приложения:
  • Opera Mini 4.2
  • Tetris
  • Sudoku
  • Song ID
  • Motorola SETUP
  • Motorola BACKUP
  • Motorola TEXT
  • Несколько игр
  • Скрипты разметки
  • Измененное меню
  • Папка приложений
  • HSA иконки
Установка:
  • Прошиваем noRSA Bootloader. *ВАЖНО* ПРОШИВАЙТЕ ВЕРСИЮ, СООТВЕТСТВУЮЩУЮ ВАШЕМУ БУТУ! noRSA 062A для 062A ||| noRSA 062DP для 062B и 062DP
  • Прошиваем Magx Reloaded V1
  • Следуем диалогу дополнительных возможностей
  • *ВАЖНО* ВКЛЮЧЕНИЕ RWFS ОТФОРМАТИРУЕТ ВАШУ MICRO SD КАРТУ. ЕСЛИ ВЫ ВКЛЮЧИТЕ ЭТУ ОПЦИЮ, ВЫ **ТОЧНО** ПОТЕРЯЕТЕ ВСЕ ДАННЫЕ НА НЕЙ!
Ссылки на скачивание::Известные баги:
  • Загрузка файлов браузером не работает когда RWFS включен. Вы тащите SD карту или выключите RWFS для загрузки из браузера.
  • Камера выдает сообщение об ошибке "Камера занята" когда шторка камеры закрыта.
Руководство по использованию RWFS.
RWFS (Read Write File System) использует файловую систему unionfs, чтобы сделать файловую систему squashfs доступной для записи, она хранит все изменения в ФС в директории, доступной для записи, в нашем случае это второй раздел на карте памяти. RWFS попросит вас выбрать размер вашей карты памяти, когда вы выберите её установку, она займет 400 мегабайт вашей SD карты, создав раздел ext2, за исключением карт размером 1gb, на них раздел будет 200 mb.
Если вы удалите файл из любой папки, которая была раньше только для чтения, то создастся файл на карте памяти с префиксом .wh_[filename], например если вы удалите /usr/bin/mediaplayer, то создастся файл /mmc/mmca2/usr/bin с именем .wh_mediaplayer. Если вы удалите этот .wh_ file и перезагрузитесь, файл /usr/bin/mediaplayer вернется в /usr/bin. Если вы добавите файл с именем file1 в /usr/bin, файл будет создан в /mmc/mmca2/usr/bin/file1, но вы будете его видеть в /usr/bin.
Папки, которые теперь доступны для записи – это /bin /lib /usr /sbin /root /home.
Теперь, что если вы что-то сделали и телефон не загружается? Не паникуйте. Вы изначально имеете две возможности и ни одна из них не требует какого-либо форматирования.
  • Если вы имеете доступ к второму разделу флешки с любого другого устройства, удалите файл, который не дает телефону загружаться, если же вы без понятия что происходит, удалите все файлы в разделе, о которых вы не знаете что они делают и зачем нужны. (Замечание: включите отображение скрытых папок/файлов).
  • Если вы не имеете доступа ко второму разделу кроме как с телефона, подключите вашу карту памяти к ПК и в папке ".Reloaded" создайте файл "no_unionfs". (Без кавычек, чувствительно к регистру.) Подключите вашу карту памяти в телефон и теперь mmca2 опять доступна, но не подмонтирована как unionfs. Удалите файл, который вызвал проблему загрузки телефона, если же вы без понятия что происходит, удалите все файлы в разделе, о которых вы не знаете что они делают и зачем нужны. Удалите файл "no_unionfs" в mmca1 и перезагрузитесь.
Перевод на русский диалогов распаковки архивов и запуска скриптов, MgxBox-а, а также добавление в меню PEManager-а (заменяет Кодак), работающая распаковка архивов и запуск скриптов:
Качаем
, распаковываем
1. rar
scripts
zip
кидать в /usr/local/Reloaded/ (или монтировать, если не ставили RWFS)
2. mime.types
UserMenuTree
UserMime
кидать в /ezxlocal/download/appwrite/am/ (скопируется даже без RWFS)
3. SysRegistry
кидать в /usr/data_resource/preloadapps/ (или монтировать, если не ставили RWFS)
4. Сам PEManager кидать в /ezxlocal/download/mystuff/.system/PEM/
Сам PEManager ищите где хотите, выкладывать его запрещено.
5. MgxBox_en.lng
кидаем в /usr/SYSqtapp/Mgxbox/ (или монтировать, если не ставили RWFS)
PS: не забываем благодарить Neomoto за удобное оформление темы, перевод на русский язык как саомй темы- так и мануалов + русификаторы!
Neomoto
сообщение 14.9.2009, 3:13
Из: Белгород
Пользователь №: 72 604
Модель телефона: MotoZINE ZN5
Прошивка: sym X beta
script or native program? And thank you for this mod!!
OCM770
сообщение 14.9.2009, 3:56
Script
portapro
сообщение 14.9.2009, 5:14
Пользователь №: 202 542
Модель телефона: zn5
Прошивка: Symbiosis 3
С какой прошивки здесь стоят либы камеры?и разрешение видио какое?
Аста: дублируйте, пожалуйста, ваши посты на английском - OCM770 будет легче на них отвечать.
Сообщение отредактировал AstaRoth - 14.9.2009, 7:41
povodir
сообщение 14.9.2009, 5:42
Из: Красноярский край.Железногорск
Пользователь №: 32 393
Прошивка: последняя
вместо авторазгона лучше ручной выбор частоты проца
Stray39
сообщение 14.9.2009, 6:03
Пользователь №: 198 407
Модель телефона: MOTOZINE ZN5
Прошивка: пока не определился
portapro
Цитата(portapro @ Сегодня, 8:14)
# QVGA Camera with RAW | Binnaed RAW Support
Сразу скажу авто фокус работает... но камеру надо запустить выключить и запустить по новой.. пример фото в макро... zn5_0005.jpg цвето передача нормальная zn5_0009.jpg на улице при облоках фото как по мне темноваты zn5_0007.jpg...
по юзабильности ... задумчивый мод, но как по мне так все они не очень...
Жаль что таскмана не повесил на длинное нажатие зеленой кнопки...
С МРТ конектится...
При первом заходе в плеер наблюдаются тормоза ...при увеличении или понижении громкости плеер заикается ... thumbdown.gif можно регулировать громкость когда плеер в свернутом состоянии thumbsup.gif громкость приемлемая ...при нажатии на красную кнопку плеер сворачивается в режим ожидания thumbsup.gif и самая большая лажа плеера в этой прошивке он постоянно заикается и тормозит thumbdown.gif а это извините уже большой минус всей прошивке
Добавлено позже (14.9.2009, 9:38):
шейте без карты памяти... перестал заикаться после прошивки без карты плеер
FAN_TV
сообщение 14.9.2009, 6:43
Из: UKRAINA
Пользователь №: 197 530
Модель телефона: XT907
Прошивка: LS KKBL V3.2
Stray39
Не знаю как у вас но у меня все отлично работает и плейер и радио ничто не заикается !!! Электронная почта работает, Опера пашет , Радио стало даже чутливейше принимать станции . НСА панель работает. Фотки супер ! Вопщем все ОК! Автору Большой Распект !!! thumbsup.gif thumbsup.gif thumbsup.gif
66_ЛЁХА_99
сообщение 14.9.2009, 11:18
Пользователь №: 108 652
Модель телефона: Motorola ZN5
Прошивка: R6637 G 81 03 0ER
Добавлено позже (14.9.2009, 19:35):
При попытке подключить телефон к компу в режиме карта памяти: 1-й раз телефон перезагрузился, 2-й раз завис намертво, 3-й раз тоже все зависло threaten.gif 4-ая попытка закончилась перезагрузкой biggrin.gif
Сообщение отредактировал 66_ЛЁХА_99 - 14.9.2009, 12:07
FAN_TV
сообщение 14.9.2009, 11:40
Из: UKRAINA
В MP не хочет работать с программой motorola phone tools , да и icq тоже не работает.
In the MP does not want to work with the program motorola phone tools, yes, and icq does not work either.
66_ЛЁХА_99
сообщение 14.9.2009, 14:30
Блин, почему то ещё раз прошить не получается, телефон почему-то зависает после прошивки!! Я хотел RWFS отключить может баг с невозможностью подключения в режиме карта памяти пропадет!
Karaban
сообщение 14.9.2009, 16:19
Пользователь №: 189 840
Модель телефона: Iphone 3gs
Прочитав, все я понял что лучше RWFS,не устанавливать...но что это такое ??Интиресно)) smile.gif , а так прошивка прикольная мнне нравится..скорость мне показалось что больше чем на Evolution
Беру свои слова назад, ПЛЕЕР ТОРМОЗ ПОЛНЫЙ
Сообщение отредактировал Karaban - 14.9.2009, 16:44
uzHeR
сообщение 14.9.2009, 16:39
Из: Kuzbass
Пользователь №: 38 217
Модель телефона: ZN5
Прошивка: ZE0.7
какмбы вребут телефон уже 5й раз уходит, когда я перекидывал файлы на флешку в режиме карты памяти
M@t@rol@4k@
сообщение 14.9.2009, 18:12
Из: УкраЇна
Пользователь №: 171 145
Прошивка: Android Pie 9
Monday - Party!
sals999,
В описании написано,что в конфиг добавлены "основные" операторы России.Если сама не запустилась,значит нужно в конфиг ХСА код своего оператора дописывать.
Сообщение отредактировал M@t@rol@4k@ - 14.9.2009, 18:12
66_ЛЁХА_99
сообщение 14.9.2009, 18:36
В общем установить ещё раз я так и не смог, после прошивки зависает намертво!
сообщение 14.9.2009, 19:11
Друзья, не спешите шить -пока внимательно не прочитаете "шапку"
Флешка во время прошивки форматируется - ДЕЛАЕМ БЕКАП!!!!
у меня после прошивки карта памяти почти не доступна в норм режиме - то есть арзделы создались -но дефолтный очень маленький получился. Будем думать вместе - если спрошивать совета у друзей! У них же работает!
Stray39
сообщение 14.9.2009, 19:17
блин и как тут контакты восстановить если с МРТ не конектится... а что интересно после первой перепрошивки контачило... shuffle.gif
Аста: я контакты на симке храню и перед прошивкой внимательно читаю мануалы. Всем рекомендую так делать-потому что всякое бывае
Сообщение отредактировал AstaRoth - 14.9.2009, 19:26
FAN_TV
сообщение 14.9.2009, 19:49
Из: UKRAINA
А у меня на симке 250 больше не влазит, в общей сложности 340 контактов, вот пор тирую постоянно с МРТ на телефон !
А телефон летает как ракета!!! И никаких проблем с SD картой нет !
AstaRoth: опиши подробнее как устанавливал и какие пункты выбирал? (карта памяти или память телефона, свап и тд)
Сообщение отредактировал AstaRoth - 14.9.2009, 19:57
Neomoto
сообщение 14.9.2009, 19:51
Из: Белгород
RWFS устанавливал?
FAN_TV
сообщение 14.9.2009, 21:06
Из: UKRAINA
Прошиваю телефон как обычно, без сим карты и сд карты. Как телефон про шился , вставляю сим карту и сд карту. Включаю телефон, и постоянно жму да , свап 64 на телефон и все остальное тоже ок жму, вот и все дела.Карта у меня 4гига , в конце всей операции на экране высветилось 2 . Телефон после перегрузился вот и все.
Да но сд карта нечего совместного не имеет с МРТ и тем болие с включением IM с поддержкой MSN/ICQ/AIM/Yahoo где не работает icq у меня. А выдает ошибку сбой подключения к ICQ. Ну и чорт с ним установил jimm на игры там все работает.
OCM770
сообщение 15.9.2009, 2:48
sals999
сообщение 15.9.2009, 7:02
Из: Россия_МО_Пушкино
Пользователь №: 192 983
Прошивка: Symbiosis X
Цитата(sals999 @ 14.9.2009, 22:06) *
Аста: у меня она по дефолту включилась. У тебя оператор какой?
66_ЛЁХА_99
сообщение 15.9.2009, 7:35
У меня так и не получилось подключить телефон в режиме карта памяти, отключал RWFS результат нулевой, пришлось откатится laugh.gif Кстати по поводу прошивки, первый раз все было нормально без проблем, но во второй мне это удалось сделать с трудом, нужно вытащить флешку и симку, только после этого прошивать и устанавливать дополнительные опции (свап, rwfs и т.д.), в конце снова вставляем фоешку и сим карту. Иначе телефон зависает!
Сообщение отредактировал 66_ЛЁХА_99 - 15.9.2009, 7:42
uzHeR
сообщение 15.9.2009, 9:27
Из: Kuzbass
Прошивка: ZE0.7
http://www.rapidshare.ru/1173020
с рапидшары
Сообщение отредактировал uzHeR - 15.9.2009, 14:36
Entom
сообщение 15.9.2009, 10:01
Из: Крыма!
Пользователь №: 159 951
Модель телефона: iPhone 4s
Прошивка: iOS 7
Люблю Apple, уважаю Motorola.
Прошивал без симки и флэхи - всё равно виснет при передачи файлов с компа. И еще - никак RSD Lite не хочет писать PASS. Может в этом дело?
66_ЛЁХА_99
сообщение 15.9.2009, 11:11
Entom, при передачи файлов с компьютера при любом раскладе виснет, либо перезагружается.
Чтобы RSD писал PASS без всяких танцов с бубнами, нужно USB кабель подключать напрямую без всяких шнуров переходников и т.д. К примеру : бывает, что в системном блоке для удобства usb порты выведены спереди корпуса, они подключены к материнке тоже через шнуры, так, что их нельзя использовать. Официальная программа по прошивке Nokia вообще отказывается прошивать в таких случаях, а у нас такого нет. И это снижает % удачной прошивки телефона. Ещё, чтобы PASS появился можно просто по окончании выключить телефон на красную кнопку, а потом зайти в boot режим.
portapro
сообщение 15.9.2009, 11:36
Entom,
Прошивал и с симкой и с флешкой -ничего не лагает и не виснет...в конце прошивки тела написало PASS!только функцию rwfs не включал при выборе её.
Entom
сообщение 15.9.2009, 11:55
Из: Крыма!
Прошивка: iOS 7
Всё равно PASS никак не высвечивается. Висит на 100% In progress... Скиньте кто-нить свой RSD Lite
Offset: Запрещенно, только вне форума.
Сообщение отредактировал Offset - 15.9.2009, 12:23
sals999
сообщение 15.9.2009, 13:18
авто разгон до 532 Мгц у всех работает? у меня почему то 266 постоянно
Аста: у меня тоже самое (
Добавлено позже (15.9.2009, 17:31):
Цитата(Offset @ 15.9.2009, 16:21) *
Сделайте заркала, обеих версий на slil.ru или ifolder.ru - Даю +3 к рейтингу.
держи, залил
http://ifolder.ru/14017684 --Magx_Reloaded_V1_062A.rar (67.67 MB)
http://ifolder.ru/14017796 --Magx_Reloaded_V1_062DP.rar (67.74 MB)
Сообщение отредактировал sals999 - 15.9.2009, 13:38
Neomoto
сообщение 15.9.2009, 20:07
Из: Белгород
OCM770,
Цитата(OCM770 @ Вчера, 6:23)
Run Scripts from FM
Rar/Zip from FM
don't work.. exept .csh
where is rokr app that must work with sh lin mgx mgt tar gz rar zip?
application/x-rokr           sh lin mgx mgt tar gz rar zip
syberside
сообщение 16.9.2009, 1:40
Из: Новоуральск
Пользователь №: 176 082
Прошивка: ICS 4.0.4
держи, залил
версия для тмобайл- ошибка crc
Добавлено позже (16.9.2009, 7:47):
хм, если я правильно понял, то либы камеры тут от 2cr_128... А они, повторюсь, на мой взгляд самые лучшие. clap.gif
OCM770 thank you for our mp! it's great!
neo:не, либы камеры тут портированы с 7fr
Сообщение отредактировал Neomoto - 16.9.2009, 6:47
sals999
сообщение 16.9.2009, 6:59
ошибка при распаковке архива или что? архивы если что не трогал, скачал и перезалил просто
Сообщение отредактировал sals999 - 16.9.2009, 7:01
syberside
сообщение 17.9.2009, 1:43
Из: Новоуральск
Прошивка: ICS 4.0.4
как это с 17ф? о_О по фоткам вижу, что это теже что и у меня сейчас на 2цр. 17ф и 2цр как небо и земля отличаются!
FAN_TV
сообщение 17.9.2009, 5:23
Из: UKRAINA
Народ хочу спросить у кого работает. IM с поддержкой MSN/ICQ/AIM/Yahoo.
Аста: у меня не работает - пишет: "Сбой подключения к ICQ"
Сообщение отредактировал AstaRoth - 17.9.2009, 13:43
Neomoto
сообщение 17.9.2009, 9:05
Из: Белгород
цитата с mmus.us
Цитата(OCM770;100353)
Wrong, camera libs from 7FR have been ported to 0ER. Its a matter or preference, 0ER tends to be more stable as its a released firmware while 7FR is prototype, they have the exact same mods and features.
Karaban
сообщение 18.9.2009, 19:28
Нашел Баг, выбераю настройка камеры фото raw...(( оно нефоткает((перезагружать пробывал.
syberside
сообщение 19.9.2009, 1:24
Из: Новоуральск
Прошивка: ICS 4.0.4
блин! кто нить на тмобайл ставил?! то что на айфолдере качал 2 раза- ошибка црс!
а с линка автора вообще нифика больше 35 % не качается! залейте на депозит или форум пожалуйста, с меня плюс!
sals999
сообщение 19.9.2009, 6:44
есть баг с ошибкой распаковки sad.gif щас перезалью
Добавлено позже (19.9.2009, 11:53):
исправил ошибку црц, не знаю как повлияло на работоспособность прошивки... залил на ifolder, на депозите глюк у меня
http://ifolder.ru/14076691 --Magx_Reloaded_V1_062DP.rar
syberside
сообщение 20.9.2009, 1:11
Из: Новоуральск
Прошивка: ICS 4.0.4
неужели никто с тмоб. аппаратам не ставил эту прошивку?
скачал с медиафайр.... там тоже самое. То есть это нам на радость выложили прошу с ошибкой внутри? stink.gif
neo: попробуйте по этой (0ER) ссылке скачать, или, если зарегистрированы на mmus.us, то по этим: этой (0ER) или этой (7FR)
Сообщение отредактировал Neomoto - 20.9.2009, 6:04
syberside
сообщение 21.9.2009, 21:54
Из: Новоуральск
Прошивка: ICS 4.0.4
neomoto, спасибо, качаю.
Но что то я в ступоре, дак проша всётаки на базе чего сделана? на скринах 2cr_128 написано, но ссылки на oer/17f... в чем прикол?)))
ядро от 2cr_128, остальное от 0ER или 7fr(не 17f) соответственно.
Сообщение отредактировал Neomoto - 22.9.2009, 12:58
FAN_TV
сообщение 30.9.2009, 5:31
Из: UKRAINA
Народ а укаво как батарея на етой проше держыт , лично у меня в дежурке 2 дня , при разговорах с трудом день дотягивает.
[MP] Magx Reloaded V1 · Motorola ZINE ZN5, ZN5 T-Mobile · Forum
2 страниц V  1 2 >
Текстовая версия Сейчас: 14.9.2025, 4:49
