2 страниц V < 1 2
[MP] Magx Reloaded V1
OCM770
сообщение 14.9.2009, 2:23 Закрепленное сообщение!
Пользователь №: 196 171
OCM770 in Cooperation with Kidscracker and Skrilax_CZ proudly present:
Magx Reloaded V1
In English:
Disclaimer:
  • We (OCM770, Kidscracker, Skrilax_CZ) take no responsability for damaged phones, the user has full responsability. We are not responsible for any data loss and or bricked phones.
  • We assume the user has read this README file and knows what he is doing.
Credits:
  • MP Created by OCM770 in cooperation with Kidscracker and Skrilax_CZ.
  • Credit to Skrilax_CZ for all patched libraries/binaries, Language Pack and MP Suggestions.
  • Credit to Kidscracker for making MgxBox and MP Suggestions.
  • Credit to Javierox for helping me with some doubts and providing the base partition scripts.
  • Credit to Kleto for helping with some doubts.
  • Credit to fldodger for providing HSA icons and Beta tester.
  • Credit to ANT-ON for zTaskMan.
  • Credit to Chacha_Ivanov for libezxappbase mod.
  • Credit to abraham for base UnionFS patch.
  • Credit to ilove3d for EasyThemes.
Main Features
  • Read/Write File System. Yes, full write access to the file system, with the exception of /etc (security measures).
  • MgxBox. New MGX Managing utility created by Kidscracker, can also install applications to the main menu.
  • Squashfs 3.3 . Supports higher block size values (up to 1MB)
Features:
  • CG35:
  • Support for UNIONFS
  • Support for SWAP
  • Support for EXT2
  • Support for EXT3
  • Support for NTFS
  • Support for SQUASHFS 3.3
  • CG36:
  • NEW MgxBox
  • FTP&Telnet
  • UnionFS
  • Swap Auto Enable
  • EasyThemes
  • SDL Preinstalled in /usr/lib
  • Bash
  • Bftpd 2.4
  • Busybox 1.14.3 as /bin/busybox_full
  • FTP Show hidden directories
  • 15 Item Main menu with 15 Item Grid Reorder
  • QVGA Camera with RAW | Binnaed RAW Support
  • CPU 532Mhz during power on
  • Hostname enabled
  • Message Of the Day mod
  • Issue and Issue.net mod
  • FTP Message Of the Day
  • PS1 Variable mod
  • Run Scripts from FM
  • Rar/Zip from FM
  • show* Modules
  • libezxappbase.so.1.0.0 speed mod
  • Removal of certain modules to increase speed
  • EXT2 Managing utilites in /usr/bin
  • mediaplayer red key homescreen mod
CG42:
  • Custom Boot Screen
CG43:
  • HSA pre-enabled for Mexico, Peru, Czech Republic, 2 US Tmobile Network and some Russian Networks
  • Enabled IM with MSN/ICQ/AIM/Yahoo Messenger
  • No preloaded MMS settings
  • Preloaded WiFi Profile for Wifi Only
  • Working sort in phonebook
  • Default USB Connection set to Modem&Tools
  • Java Heap Size 4mb
CG44:
  • Java Full Permissions Mod
CG52:
  • zTaskMan 0.3
  • Autorun Script
  • Selectable Aditional Features
  • Skins:
  • Alkali as default
  • Kodak
  • Indium
  • Preinstalled Java Apps:
  • Opera Mini 4.2
  • Tetris
  • Sudoku
  • Song ID
  • Motorola SETUP
  • Motorola BACKUP
  • Motorola TEXT
  • Several Games
  • Partition Scripts
  • Custom Menu
  • Applications Folder
  • HSA Icons
Instalation:
  • Flash noRSA Bootloader. *IMPORTANT* FLASH VERSION DESIGNED FOR YOUR BOOTLOADER ONLY! noRSA 062A for 062A ||| noRSA 062DP for 062B and 062DP
  • Flash Magx Reloaded V1
  • Follow Aditional Features Prompt
*IMPORTANT* ENABLING RWFS WILL FORMAT YOUR MICRO SD CARD. IF YOU ENABLE THIS OPTION YOU **WILL** LOSE ALL DATA ON IT!
  • Download Links:
[/B]
Known Bugs:
  • Browser downloads will not work when RWFS is enabled. Remove SD Card or disable RWFS to download from browser.
  • Camera gives "Camera Busy" error message when Camera runs with lens closed.
Guide to using RWFS(In English).
RWFS (Read Write File System) uses the unionfs file system to make squashfs file systems writeable, it does this by storing all changes in the file system in a writeable directory, the second partition on the memory card in this case. RWFS will prompt you to choose your memory card size when you chose to install it, it will take 400mb of your SD card for the ext2 partition, with the exception of 1gb cards, it will take 200mb.
If you delete a file from any previously ro directory it will create a file on the memory card with prefix .wh_[filename] so if you delete /usr/bin/mediaplayer a file will be created in /mmc/mmca2/usr/bin called .wh_mediaplayer . If you delete this .wh_ file and reboot the file will come back in /usr/bin . If you add a file called file1 to /usr/bin the file will be created in /mmc/mmca2/usr/bin/file1 but you will see the actual file in /usr/bin .
The directories with read/write access are /bin /lib /usr /sbin /root /home
Now what if you mess something up and the phone will not boot? Don't panic. Basically you have two options and neither one requires any formatting:
a) If you have access to the second partition from any other device, delete the file which caused the phone not to boot, if you have no idea, wipe it out totally or at least the files of which you don't know what they do. (Note: enable showing hidden files / folders)
B) If you cannot access the second partition by any other means than the phone, plug your memory card to PC and in folder ".Reloaded" create a file "no_unionfs". (Without the quotes and case sensitive). Put your memory card back to the phone and now mmca2 is still accessible, but not mounted as unionfs. Delete the file which caused the phone not to boot, if you have no idea, wipe it out totally or at least the files of which you don't know what they do. The delete the "no_unionfs" file in mmca1 and reboot.
OCM770 в сотрудничестве с Kidscracker и and Skrilax_CZ с гордостью представляют:
Magx Reloaded V1
Оговорка:
  • Мы, (OCM770, Kidscracker, Skrilax_CZ) не несем никакой ответственности за поврежденные телефоны, за них ответственен пользователь. Мы не ответственны за любую потерю данных или трупы телефонов.
  • Мы надеемся, что пользователь прочтет README файл и будет знать, что он делает.
Благодарности:
  • MP создан OCM770 в сотрудничестве сKidscracker и Skrilax_CZ.
  • Спасибо Skrilax_CZ за все его патчи для либ/бинарников, языковой пакет и предложения по MP.
  • Спасибо Kidscracker за его MgxBox и предложения по MP.
  • Спасибо Javierox за помощь мне с некоторыми проблемами и за предоставление основных скриптов разделов.
  • Спасибо Kleto за помощь с некоторыми проблемами.
  • Спасибо fldodger за HAS иконки и бета-тестирование.
  • Спасибо ANT-ON за zTaskMan.
  • Спасибо Chacha_Ivanov за libezxappbase мод.
  • Спасибо abraham за основу патча UnionFS.
  • Спасибо ilove3d за EasyThemes.
Основные возможности:
    Read/Write файловая система. Да, полный доступ для записи в файловую систему, за исключением /etc (меры безопасности).
  • MgxBox. Новая утилита для управления MGX пакетами, созданная Kidscracker, которая также может прописывать приложения в главное меню.
  • Squashfs 3.3. Поддержка больших значений размера блока (вплоть до1MB)
Возможности:
CG35:
  • Поддержка UNIONFS
  • Поддержка SWAP
  • Поддержка EXT2
  • Поддержка EXT3
  • Поддержка NTFS
  • Поддержка SQUASHFS 3.3
CG36:
  • Новый MgxBox
  • FTP&Telnet
  • UnionFS
  • Автовключение Swap
  • EasyThemes
  • SDL предустановлен в /usr/lib
  • Bash
  • Bftpd 2.4
  • FTP показывает скрытые папки
  • Главное меню с 15 иконками и возможностью пересортировки
  • QVGA Камера с поддержкой RAW | Binned RAW
  • Постоянная частота CPU 532Mhz
  • Hostname включен
  • Мод Сообщение Дня
  • Мод Issue and Issue.net
  • FTP Сообщение Дня
  • PS1 Variable мод
  • Запуск скриптов из ФМ
  • Rar/Zip из ФМ
  • show* Модули
  • Мод увеличения скорости в libezxappbase.so.1.0.0
  • Удалены Removal of определенные модули для увеличения скорости работы
  • Утилиты управления EXT2 в /usr/bin
  • Медиаплеер «red key homescreen» мод
CG42:
  • Изменен экран загрузки
CG43:
  • HSA включен для Мексики, Перу, Чешской республики, двух US T-mobile сетей и некоторых русских сетей.
  • Включен IM с поддержкой MSN/ICQ/AIM/Yahoo.
  • Нет предустановленных настроек MMS.
  • Предустановленный WiFi профиль для Wifi Only
  • Работает сортировка в контактах.
  • По умолчанию в Соединениях стоит Modem&Tools
  • Размер Heap для Java 4mb
CG44:
  • Мод полных прав для Java
CG52:
  • zTaskMan 0.3
  • Autorun скрипт
  • Выбираемые дополнительные возможности
  • Скины:
  • Alkali по умолчанию
  • Kodak
  • Indium
  • Предустановленные Java приложения:
  • Opera Mini 4.2
  • Tetris
  • Sudoku
  • Song ID
  • Motorola SETUP
  • Motorola BACKUP
  • Motorola TEXT
  • Несколько игр
  • Скрипты разметки
  • Измененное меню
  • Папка приложений
  • HSA иконки
Установка:
  • Прошиваем noRSA Bootloader. *ВАЖНО* ПРОШИВАЙТЕ ВЕРСИЮ, СООТВЕТСТВУЮЩУЮ ВАШЕМУ БУТУ! noRSA 062A для 062A ||| noRSA 062DP для 062B и 062DP
  • Прошиваем Magx Reloaded V1
  • Следуем диалогу дополнительных возможностей
  • *ВАЖНО* ВКЛЮЧЕНИЕ RWFS ОТФОРМАТИРУЕТ ВАШУ MICRO SD КАРТУ. ЕСЛИ ВЫ ВКЛЮЧИТЕ ЭТУ ОПЦИЮ, ВЫ **ТОЧНО** ПОТЕРЯЕТЕ ВСЕ ДАННЫЕ НА НЕЙ!
Ссылки на скачивание::Известные баги:
  • Загрузка файлов браузером не работает когда RWFS включен. Вы тащите SD карту или выключите RWFS для загрузки из браузера.
  • Камера выдает сообщение об ошибке "Камера занята" когда шторка камеры закрыта.
Руководство по использованию RWFS.
RWFS (Read Write File System) использует файловую систему unionfs, чтобы сделать файловую систему squashfs доступной для записи, она хранит все изменения в ФС в директории, доступной для записи, в нашем случае это второй раздел на карте памяти. RWFS попросит вас выбрать размер вашей карты памяти, когда вы выберите её установку, она займет 400 мегабайт вашей SD карты, создав раздел ext2, за исключением карт размером 1gb, на них раздел будет 200 mb.
Если вы удалите файл из любой папки, которая была раньше только для чтения, то создастся файл на карте памяти с префиксом .wh_[filename], например если вы удалите /usr/bin/mediaplayer, то создастся файл /mmc/mmca2/usr/bin с именем .wh_mediaplayer. Если вы удалите этот .wh_ file и перезагрузитесь, файл /usr/bin/mediaplayer вернется в /usr/bin. Если вы добавите файл с именем file1 в /usr/bin, файл будет создан в /mmc/mmca2/usr/bin/file1, но вы будете его видеть в /usr/bin.
Папки, которые теперь доступны для записи – это /bin /lib /usr /sbin /root /home.
Теперь, что если вы что-то сделали и телефон не загружается? Не паникуйте. Вы изначально имеете две возможности и ни одна из них не требует какого-либо форматирования.
  • Если вы имеете доступ к второму разделу флешки с любого другого устройства, удалите файл, который не дает телефону загружаться, если же вы без понятия что происходит, удалите все файлы в разделе, о которых вы не знаете что они делают и зачем нужны. (Замечание: включите отображение скрытых папок/файлов).
  • Если вы не имеете доступа ко второму разделу кроме как с телефона, подключите вашу карту памяти к ПК и в папке ".Reloaded" создайте файл "no_unionfs". (Без кавычек, чувствительно к регистру.) Подключите вашу карту памяти в телефон и теперь mmca2 опять доступна, но не подмонтирована как unionfs. Удалите файл, который вызвал проблему загрузки телефона, если же вы без понятия что происходит, удалите все файлы в разделе, о которых вы не знаете что они делают и зачем нужны. Удалите файл "no_unionfs" в mmca1 и перезагрузитесь.
Перевод на русский диалогов распаковки архивов и запуска скриптов, MgxBox-а, а также добавление в меню PEManager-а (заменяет Кодак), работающая распаковка архивов и запуск скриптов:
Качаем
, распаковываем
1. rar
scripts
zip
кидать в /usr/local/Reloaded/ (или монтировать, если не ставили RWFS)
2. mime.types
UserMenuTree
UserMime
кидать в /ezxlocal/download/appwrite/am/ (скопируется даже без RWFS)
3. SysRegistry
кидать в /usr/data_resource/preloadapps/ (или монтировать, если не ставили RWFS)
4. Сам PEManager кидать в /ezxlocal/download/mystuff/.system/PEM/
Сам PEManager ищите где хотите, выкладывать его запрещено.
5. MgxBox_en.lng
кидаем в /usr/SYSqtapp/Mgxbox/ (или монтировать, если не ставили RWFS)
PS: не забываем благодарить Neomoto за удобное оформление темы, перевод на русский язык как саомй темы- так и мануалов + русификаторы!
сообщение 30.9.2009, 8:05
у меня батарея как обычно держит. в обычном режиме 2-3 дня. если яву запустить на целый день-то к вечеру сядет.
D-1c3
сообщение 30.9.2009, 16:34
Пользователь №: 150 086
Прошивка: свежая
MgxBox из этой проши достать возможно? или как всегда, это является строго "фишкой" этой проши и по-крысячески не выкладывается?
Аста: возможно все- учи матчасть. Если самому не хватает ума -спрашивай авторов, может и дадут.
в следущий раз, прежде чем давать подобные "полезные" советы, спрашивай нуждаюсь ли я в них
Сообщение отредактировал D-1c3 - 1.10.2009, 17:40
Neomoto
сообщение 1.10.2009, 15:25
Из: Белгород
Пользователь №: 72 604
Модель телефона: MotoZINE ZN5
Прошивка: sym X beta
D-1c3, mgxbox - opensource приложение, и его можно использовать как угодно
Ant-ON
сообщение 1.10.2009, 17:06
Пользователь №: 49 304
Прошивка: CM12 / CM10 / PM2
Я бы сырцы глянул... Не знаешь где качнуть можно?
Льоша
сообщение 1.10.2009, 17:50
Пользователь №: 181 618
Прошивка: z-mod 2.10
Вот в первом посте MpkgBox2.0 Pro free version Zn5, U9, E8, EM30
это не то, не путай MpkgBox2.0 от ilove3d с MgxBox от kidscracker
Сообщение отредактировал Neomoto - 1.10.2009, 18:11
Neomoto
сообщение 1.10.2009, 18:12
Из: Белгород
Ant-ON, kidscracker обещает скоро выложить в открытый доступ, но можешь у него попросить, думаю тебе он не откажет smile.gif
V!iT
сообщение 2.10.2009, 7:24
Из: Украина -> Мелитополь
Пользователь №: 196 457
Модель телефона: Motorola ZN5
Прошивка: Symbiosis OER
Кто может выложить разобранную 36группу и сисрегистри ?????
portapro
сообщение 3.10.2009, 7:00
Пользователь №: 202 542
Модель телефона: zn5
Прошивка: Symbiosis 3
я не пойму как тут установленные мгх найти,установил квейк 2 -он нигде не появился,хотя видно что установлен на карте памяти в папке Mgxbox , обьясните где ярлык запуска искать или как запустить его...а рокбокс пишет что установился ,но нигде ничего нету.
у mgxbox-a есть такой глюк - он не показывает некоторые приложения, например не показывал zn5_FileManager пока я его не переименовал в просто FileManager (файл cfg тоже надо переименовывать). Также так и не смог заставить показывать scummvm и еще что-то, уже не помню
Сообщение отредактировал Neomoto - 3.10.2009, 8:08
lDeNl
сообщение 3.10.2009, 7:03
Zine Master
Пользователь №: 189 506
Модель телефона: Nokia N8
Прошивка: Belle
Скорее всего тоже надо руками до устанавливать... то есть разархивируешь архив на компе и всю папку по FTP заливаешь туда где она должна быть память телефона/mmc.
Сообщение отредактировал lDeNl - 3.10.2009, 7:15
syberside
сообщение 3.10.2009, 10:02
Из: Новоуральск
Пользователь №: 176 082
Прошивка: ICS 4.0.4
У меня такие проблемы когда в имени файла пробел есть. Удаляю пробелы из имени и все нормально ставится и отображается. Это п7зип виноват. Он не понимает ни пробелов ни русского... Спросить хотел: у кого нить версия проши отображается как на скринах? Я так и не нашей 2цр версии...
FAN_TV
сообщение 12.10.2009, 19:43
Из: UKRAINA
Пользователь №: 197 530
Модель телефона: XT907
Прошивка: LS KKBL V3.2
Кто может выложить готовую CG43 с етой прошы (+) будет.
Yoki
сообщение 14.10.2009, 10:31
Из: UA KH
Пользователь №: 123 162
Модель телефона: Casio Commando
что сделать чтоб работала встроенная аська, где править конфиг или чтонужно?
insanity
сообщение 16.10.2009, 11:43
Из: Himki
Пользователь №: 135 172
Модель телефона: ZN5
У меня не работает авторазгон проца.. Всё время на 399MHz.. Как исправить?
Полный доступ java приложениям это хорошо, а можно ещё сделать запуск нескольких java одновременно?
____________________________
The autoacceleration of proca does not work for me.. All of time on 399mhz.. How to correct?
Complete access java applications is it good, and it is possible yet to do a start a few java simultaneously?
ink71
сообщение 18.10.2009, 14:06
Из: Республика Беларусь
Пользователь №: 103 216
Модель телефона: ZN5 t-Mobile
Прошивка: Шустрая ;)
Лови для бута 062А! Переименуй в *.sbf
Прикрепленный файл Magx_ReloadedV1_0ER_062A_CG43.rar   ( 370.04 килобайт ) Кол-во скачиваний: 239
FAN_TV
сообщение 18.10.2009, 18:15
Из: UKRAINA
ink71
Архив битый , может перезальйош.
сообщение 18.10.2009, 18:27
FAN_TV,
Это не архив а sbf!
Karaban
сообщение 5.12.2009, 21:34
Пользователь №: 189 840
Модель телефона: Iphone 3gs
Кто небудь ставил на эту прошивку скрипт Multilunch ? я поставил выбираю что б на зеленую клавишу стаял Таск менед.,а он незапускается:( запускается голосовой набор.
syberside
сообщение 5.2.2010, 12:11
Из: Новоуральск
Прошивка: ICS 4.0.4
Кто нить, у кого стоит проша, скиньте плз mgxbox, с меня плюс.
ЗЫ: я прошу снес)
syberside
Из: Новоуральск
Прошивка: ICS 4.0.4
ЗЫ: я прошу снес)
ink71
сообщение 5.2.2010, 17:51
ЗЫ: я прошу снес)
Лови!
[MP] Magx Reloaded V1 · Motorola ZINE ZN5, ZN5 T-Mobile · Forum
2 страниц V < 1 2
Текстовая версия Сейчас: 14.9.2025, 7:31
