6 страниц V < 1 2 3 > »
[mgx] Rockbox Version 3.4 (100% Functional), Ставим. Обсуждаем.
Offset
сообщение 30.9.2009, 12:05 Закрепленное сообщение!
Leo
Пользователь №: 126 712
RockBox
Hello everybody, I hereby present the official version of the magnificent RockBox.
Some time ago and I adapted the Douglas RockBox Beta (version 3.3) of the Rokr Z6 developed by CepiPeres, was a great application but had some bugs and problems.
Well, then, was recently released on the website of RockBox version 3.4 of this fantastic multimedia center.
Team Motocaker Team took the opportunity to upgrade the family's RockBox MOTOMAGX.
I decided to adapt and adjust to this latest version to our dear ZN5 and the result was amazing. So I'm here to share with you the new version of RockBox.
What's new in this application compared to the Beta:
-Now the application no longer needs to be closed Plugin, just press the power button (red) to close the application.
-Now we can listen to music and continue stirring in the application, we can see photos, play games, use some mini-application, do whatever we want.
-Added the game Doom within the application to play while we hear that favorite song.
-Is it possible to play videos at 25fps in MPEG format.
-Is it possible to play ATRAC3 audio files.
-Is it possible to play audio files AC3.
-Is it possible to play AAC audio files.
-System stabilized and made some adjustments.
Keyboard Configuration:
- Volume Buttons: Controls the volume.
- Smart button: Main Menu.
- Directional Up and Down: Controls the volume and menu controls.
- Directs Right: Next and Select.
- Directional Left: Backwards and Back.
- Center Button: Selects functions.
- Left Softkey: Pause and Play in Playback mode.
- Right Softkey: Stop the music / Exit (when using a plugin or game that does not run correctly).
- Red Button: Close the application.
- Green Button: Capture screen images.
The application has 3 display modes: Portrait, Landscape and Landscape II.
Images of the application:
I recommend installing it on the Memory Card.
Works perfectly in Freedom Evolution Brazil 2.0 by Junior Passos, Evo2 and Evo3 by iLove3d.
Download:
http://www.4shared.com/file/136344685/6e89...Box_ZN5_EN.html
Sorry my English.
Credits:
Motocaker Team (RockBox)
Ant-ON (SDL)
Junior Passos (Ported for ZN5)
Оригинал топик
скачать с сервера mmus СКАЧАТЬ (необходима регистрация)
Скачать с ifolder.ru
Установка RockBox 3.4 (mgx): автор мануала: EXL
1.Скачиваем сам mgx-пакет RockBox, открываем его с помощью архиватора (Я пользуюсь WinRar). Извлекаем папку RockBox в любое доступное место на жестком диске.
2. (Внимание! Телофон должен быть прошит любым пользовательским модом с поддержкой MPKGBOX)!!!
Подключаем телефон в режиме КАРТЫ ПАМЯТИ и кидаем папку RockBox в папку mpkgbox на вашей флешке. Отключаем телефон, заходим в MPKGBOX, вибираем вкладку "карта памяти", запускаем RockBox. Установка завершена!
Общая настройка:
1. Создание главного плейлиста - заходим Playlists, Create Playlist (Создаётся плейлист каталога MMC/Music/).
Просмотр и воспроизведение песен плейлиста - Playlists, View Current Playlist
2. Плеер оснащен очень удобной Базой Данных, в которой музыка из каталога MMC/Music/ сортируется на множество категорий - начиная с Исполнителя, Альбома и заканчивая Годом, Номером трека и даже первой буквой различных категорий! Создать базу можно в меню Database.
3. В плеере есть встроенный Файл-Менеджер (меню - Files), чтобы вызвать контекстное меню в нём, нужно зажать центральную клавишу джойстика.
4. Plugins - здесь сосредоточены игры(присутствует даже Doom), небольшие програмки и визуализация/заставки для плеера. Стоит отметить, что не все плагины работают корректно.
5. System - информация о телефоне и RockBox'e, установка времени сна и др.
Пользовательская настройка: (Пункт Settings)
1. Sound Settings - Здесь можно настроить звучание под себя.
Основные пункты изменяющие звук:
1.1. Stereo Width - рекомендую поставить 250% (Расширение стереобазы)
1.2. Equalizer - Сначала включаем (Enable EQ, Yes), Затем либо настраиваем сами, либо воспользуемся
предустановками (Browse EQ Presets) которые действительно меняют звук!
Совет: 1. Самое качественное звучание - настройка Best Sound Quality (На мой взгляд)
2. Самое громкое Rock Clear + Sound Settings, Limiter Preamp нужно поставить в значение 8.0 db
1.3. Limiter Preamp - Если песня тихая, изменяем значение этого параметра на большее (Например 8.0 db)
2. Playback Settings - Здесь выставляете настройки проигрывания (Повтор, Случайное воспроизведение и др.)
3. General Settings - Общие настройки плеера. Здесь можно выставить русский язык (Language)!
ВНИМАНИЕ! Чтобы русский язык отображался, он должен поддерживаться текущим шрифтом!
4. Theme Settings - Настройка тем.
4.1 Browse Theme Files - Здесь выбираем нужную Вам тему плеера.
4.2 Font - Установка шрифта плеера. (Русский язык отображается например в шрифте unifont)
4.3 While Playing Screen - Установка оболочки самого проигрывателя.
4.4 Show Icons -Настройка показа иконок
5. Manage Settings - Здесь можно сбросить все настройки плеера по дефолту, если вы где-то напортачили. (Reset Settings)
Клавиатура:
Вверх, вниз: громкость в плеере и вверх-вниз в меню.
Вправо: "Следующий трек", Удержание: "Перемотка вперед" - в плеере и выбор в меню.
Влево: "Предыдущий трек", Удержание: "Перемотка назад" - в плеере и назад в меню.
Качелька громкости: управляет громкостью в плеере. Для регулирования необходимо зажать (Длинная шкала)
Центральная кнопка джойстика: Выбор и контекстное меню при зажатии.
Левая софт-клавиша: Пауза и воспроизведение в режиме воспроизведения.
Право софт-клавиша: Стоп/выход (при использовании плагина или игры, которая не работает должным образом).
Красная кнопка: Выход из плеера.
Зеленая кнопка: Скриншот экрана.
Шрифты, поддерживающие русский язык:
11-Nimbus
13-Nimbus
15-Adobe-Helvetica
16-GNU-Unifont
19-Nimbus
cfsj-12pt
Corbel_12
Epsy+asian-12
FZXSQJ-12pt
helvR12
kaiti-14pt
msyh-12pt
msyh-13pt
myfont-12pt
nimbus+uming-14
nimbus-12
nimbus-19
Segoe_UIB_12
shaonv-14pt
simsun_ok
st
STCAIYUN-14pt
unifont
Сменить язык интерфейса в RockBox можно, зайдя в Settings, потом Theme Setings, потом Font устанавливаем - жмем Unifont, возвращаемся назад к пункту General Settings, входим там папка Language.В ней выбираем язык какой хотим.
Еще раз пользуясь случаем благодарим этих камрадов:
Ant-ON (SDL)
Сообщение отредактировал Offset - 12.11.2010, 19:17
uzHeR
сообщение 30.9.2009, 19:27
Из: Kuzbass
Пользователь №: 38 217
Модель телефона: ZN5
Прошивка: ZE0.7
на симбиозе работает. с плейлистами не разобрался
и да, язык английский онли
сообщение 30.9.2009, 19:29
V!iT,
Да все так ставили на Simbiosise.
Язык должен поддерживаться шрифтом! Мне русский не сильно нужен, но если тебе надо, то выбери допустим шрифт unifont а затем русский язык!
Очень порадовали предустановленные настройки эквалайзера!!! И довольно тонкая и точная настройка воспроизведения и музыкального потока, давно такого ждал!
З.Ы как обстоит дело с проигрыванием Mpeg видео? Кто-нибудь пробовал?
Offset , спасибо за оперативную работу!
SILIVILI
сообщение 30.9.2009, 20:06
Из: Россия_Омск
Пользователь №: 132 866
Модель телефона: ZN5 ^ E398 ^ Atrix
Прошивка: ??? ^ ???
У меня почему то иногда выскакивает дата с раб. стола smile.gif , но при любом нажатии Роксбокс опять перекрывает
сообщение 30.9.2009, 20:38
uzHeR, Создай Базу Данных и перезапусти RockBox! И снова зайди в базу данных
SILIVILI, Возможно это потому что у тебя 05R, я такого пока не замечал!
Добавлено позже (1.10.2009, 3:44):
Кстати во встроенном File Manager'e контекстное меню вызывается долгим нажатием на центр джойстика
Vitala
сообщение 30.9.2009, 21:55
Из: Одесса
Пользователь №: 99 109
Модель телефона: Бритва
он вроде готовые подхватывает, так что можешь так заколбасить плейлисты...
moto_mr_hard
сообщение 1.10.2009, 1:02
Пользователь №: 187 432
Модель телефона: moto_u9,v535,e398
Прошивка: по настроению
SILIVILI
у меня такая же фигня с датой на у9...
пробовал запускать фильм mpeg - только зфук и все
SanchoNT
сообщение 1.10.2009, 3:37
Из: Нижний Тагил
Пользователь №: 184 870
Прошивка: 4.4.4
это вполне нормально
SILIVILI
сообщение 1.10.2009, 4:15
Из: Россия_Омск
Прошивка: ??? ^ ???
Ночью не пробывал музыку включать, с утра попробывал на воспроизведении пишет codec failure и не играет музыка smile.gif
сообщение 1.10.2009, 5:59
moto_mr_hard, -Is it possible to play videos at 25fps in MPEG format.
Видео должно быть не более 25 кадров в секунду
Annihilator83
сообщение 1.10.2009, 7:10
Пользователь №: 97 739
Модель телефона: E6+Zn5
Прошивка: R533_G_11.12.10P
Насколько я понял умные буржуины и радио как-то прикрутили в рокбокс. А нам слабо? Готов пресет для Киева написатьsmile.gif
Сообщение отредактировал Annihilator83 - 1.10.2009, 7:10
D-1c3
сообщение 1.10.2009, 7:19
Пользователь №: 150 086
Прошивка: свежая
Vitala, нет( пробовал всех форматов уже. он их не играет, потом заходишь в "текущий плейлист", все треки там зафиксированы и рядом надпись Err. создавал все списки плеером aimp. какие еще будут предложения?
1nTeRacT
сообщение 1.10.2009, 8:23
Пользователь №: 139 825
Модель телефона: MOTOZINE ZN5
Прошивка: G_81.03.0ER
копирую в папку инсталлерс, устанавливаю, в проше Magx Reloaded V1 , всё успешно установилось, вот тока не появляется рокбокс нигде ((( вопрос где лежит?! ((((((((
Vitala
сообщение 1.10.2009, 8:25
Из: Одесса
D-1c3,
все пучком, видно не правильно плейлист создаешь (адреса к файлам) у меня просто альбомами музыка залита и в каждой папке/альбоме есть плейлист от него, он прекрасно запускается и играет, и отображается в тек плейлисте без всяких ерроров и тп)
FAN_TV
сообщение 1.10.2009, 8:36
Из: UKRAINA
Пользователь №: 197 530
Модель телефона: XT907
Прошивка: LS KKBL V3.2
1nTeRacT
Вот я тоже с такой бедой и сежу !!! Может кто то что то подскажет !
сообщение 1.10.2009, 8:42
на рЕлоаде тоже самое-никудa а не ставится. на mmus нужно спрашивать именно в теме Релоада.
Annihilator83, по поводу прикрутки радио-думаю нам самим не под силу-ты смотрел общий сайт для Рокбокса- у нас же адаптированная версия под наши моторы, причем адаптнули не мы-а теже камрады с mmus/
1nTeRacT
сообщение 1.10.2009, 8:45
FAN_TV всё установил! просто разорхивируй в папку mgxbox и всё !
Сообщение отредактировал 1nTeRacT - 1.10.2009, 8:48
Neomoto
Из: Белгород
Пользователь №: 72 604
Модель телефона: MotoZINE ZN5
Прошивка: sym X beta
D-1c3, насчет плейлистов прочитай Софт для ZN5.
В целом, плеер мне понравится. Работает быстро, никакой "тормознутости" (прошивка FFU), треки переключает в два раза быстрее стандартного плеера, из плохого - много лишней фигни, которая как я думаю сказывается на скорости работы приложения, невозможность сворачивать/разворачивать плеер, а также возвращаться к нему если вдруг кто позвонил, ну, вы поняли о чем я smile.gif Еще тихий по сравнению со стандартным плеером, но это вроды бы исправимо
Сообщение отредактировал Neomoto - 1.10.2009, 8:56
moto_mr_hard
сообщение 1.10.2009, 8:54
я пытался воспроизвести вибео с частотой 15 кадров в секунду
1nTeRacT
сообщение 1.10.2009, 9:04
а как сворачивать рокбокс ???
uzHeR
сообщение 1.10.2009, 9:10
Из: Kuzbass
Прошивка: ZE0.7
а инет радио работает? или это к мплееру?
Neomoto
сообщение 1.10.2009, 9:23
Из: Белгород
1nTeRacT, я ж написал что никак как раз-таки нельзя, и это большой минус.
SILIVILI
сообщение 1.10.2009, 10:23
Из: Россия_Омск
Прошивка: ??? ^ ???
Мне еще не нравится в нем что он создает папку в ezxlocal с насройками и тд, я считаю это лишним засорять память телефона, я не мог зайти по ФТП П2к-командером из за этой папки криво считывало данные, после удаления этой папки роксбокса П2к командер все норм заработал.
Сообщение отредактировал SILIVILI - 1.10.2009, 10:25
Vitala
сообщение 1.10.2009, 10:34
Из: Одесса
запускай таскман и ткни - свернуть все)
Neomoto
сообщение 1.10.2009, 10:39
Из: Белгород
если сделать так, то рокбокс просто убивается. У меня так.
1nTeRacT
сообщение 1.10.2009, 10:43
мне на релоаде до таскмена не добраться))
это он на симбиозе на зелёной висит... а тут на зелёной голосовой набор
Аста: длинное нажатие на зеленую - таскмен на Релоаде выскакивает, если нет юзай прогу MultiLaunch
Сообщение отредактировал AstaRoth - 1.10.2009, 11:04
Vitala
Из: Одесса
Neomoto,
у меня просто уходит в фон и дальше я спокойно делаю все, что угодно smile.gif
Neomoto
сообщение 1.10.2009, 13:41
Из: Белгород
круто! а какая прошивка? И рокбокс последний?
Vitala
сообщение 1.10.2009, 14:01
Из: Одесса
Neomoto,
рокбос из этой темы + симбиозис 2.1
Mar4elo
Пользователь №: 191 089
Прошивка: Symbiosis III
Перезалейте пожалуйста на какой то другой файлообменик.
сообщение 1.10.2009, 14:26
Хм... у меня одного после установки RockBox в режиме карты памяти не заходит в съёмный диск (память телефона) на компе?
Enigmatic
сообщение 1.10.2009, 16:31
Пользователь №: 202 254
Прошивка: разная
Ексель, здарова! Это Топ с робина. wink.gif В память не заходит наверно из-за того что монтируется вся фс на флэшку. А вообще хорошо вам теперь, софт новый валит. Будем надеятся что и для ешки будет новый рокбокс. smile.gif
!Pavlik!
сообщение 1.10.2009, 16:37
Из: Нижний Новгород
Пользователь №: 160 141
Модель телефона: RAZR XT910
Mar4elo,
Чем тебе ifolder не нравится?
Скажи на какой - залью
сообщение 1.10.2009, 18:38
Упс извиняюсь ребята не заходит из-за свапа, сделанного в памяти телефона.
Кстати где RockBox сохраняет свои плейлисты?
Сообщение отредактировал EXL - 1.10.2009, 18:40
SILIVILI
сообщение 1.10.2009, 18:54
Из: Россия_Омск
Прошивка: ??? ^ ???
Смотри в ezxlocal/.rockBox
Entom
сообщение 2.10.2009, 4:56
Из: Крыма!
Пользователь №: 159 951
Модель телефона: iPhone 4s
Прошивка: iOS 7
Люблю Apple, уважаю Motorola.
Что-то на симбиосе не хочет устанавливатся.
V!iT
сообщение 2.10.2009, 7:11
Из: Украина -> Мелитополь
Пользователь №: 196 457
Модель телефона: Motorola ZN5
Прошивка: Symbiosis OER
Mar4elo
сообщение 2.10.2009, 8:27
!Pavlik!, та оно у меня почему то не хочет грузит. У меня постоянно с Ифолдером проблемы какие то.
Если можно, то типа Рапидшары или Депозита.))))
V!iT
сообщение 2.10.2009, 10:14
RockBox ZN5
Karaban
сообщение 2.10.2009, 10:18
Пользователь №: 189 840
Модель телефона: Iphone 3gs
Цитата(V!iT @ 2.10.2009, 8:11) *
Я расспаковал в mpgbox и ничего он запускается выбираеш какой режим экрана выбрал и глухо ничего непоказывает((
Mar4elo
сообщение 2.10.2009, 11:10
Ура!!!!Получилось установить.
V!iT спс за сылку, но твой файл почему то не хочет устанавливаться. Скачал с самого первого поста и скопировал в папку Installers (вроде бы так пишется), и все пошло.
Первый впечатления. БОМБА!!!! Качество проигрывания песен стало лучше, быстро бегает по менюшке, быстро обновило базу с песнями, играет на много вроде бы громче стандартного.
Это мое личное впечатление, как человека, который юзает этот проигрыватель впервые.
Сообщение отредактировал Mar4elo - 4.10.2009, 21:06
[mgx] Rockbox Version 3.4 (100% Functional), Ставим. Обсуждаем. · Motorola ZINE ZN5, ZN5 T-Mobile · Forum
Текстовая версия Сейчас: 1.8.2025, 15:18
