6 страниц V « < 2 3 4 5 6 >
[mgx] Rockbox Version 3.4 (100% Functional), Ставим. Обсуждаем.
Offset
сообщение 30.9.2009, 12:05 Закрепленное сообщение!
Leo
Пользователь №: 126 712
RockBox
Hello everybody, I hereby present the official version of the magnificent RockBox.
Some time ago and I adapted the Douglas RockBox Beta (version 3.3) of the Rokr Z6 developed by CepiPeres, was a great application but had some bugs and problems.
Well, then, was recently released on the website of RockBox version 3.4 of this fantastic multimedia center.
Team Motocaker Team took the opportunity to upgrade the family's RockBox MOTOMAGX.
I decided to adapt and adjust to this latest version to our dear ZN5 and the result was amazing. So I'm here to share with you the new version of RockBox.
What's new in this application compared to the Beta:
-Now the application no longer needs to be closed Plugin, just press the power button (red) to close the application.
-Now we can listen to music and continue stirring in the application, we can see photos, play games, use some mini-application, do whatever we want.
-Added the game Doom within the application to play while we hear that favorite song.
-Is it possible to play videos at 25fps in MPEG format.
-Is it possible to play ATRAC3 audio files.
-Is it possible to play audio files AC3.
-Is it possible to play AAC audio files.
-System stabilized and made some adjustments.
Keyboard Configuration:
- Volume Buttons: Controls the volume.
- Smart button: Main Menu.
- Directional Up and Down: Controls the volume and menu controls.
- Directs Right: Next and Select.
- Directional Left: Backwards and Back.
- Center Button: Selects functions.
- Left Softkey: Pause and Play in Playback mode.
- Right Softkey: Stop the music / Exit (when using a plugin or game that does not run correctly).
- Red Button: Close the application.
- Green Button: Capture screen images.
The application has 3 display modes: Portrait, Landscape and Landscape II.
Images of the application:
I recommend installing it on the Memory Card.
Works perfectly in Freedom Evolution Brazil 2.0 by Junior Passos, Evo2 and Evo3 by iLove3d.
Download:
http://www.4shared.com/file/136344685/6e89...Box_ZN5_EN.html
Sorry my English.
Credits:
Motocaker Team (RockBox)
Ant-ON (SDL)
Junior Passos (Ported for ZN5)
Оригинал топик
скачать с сервера mmus СКАЧАТЬ (необходима регистрация)
Скачать с ifolder.ru
Установка RockBox 3.4 (mgx): автор мануала: EXL
1.Скачиваем сам mgx-пакет RockBox, открываем его с помощью архиватора (Я пользуюсь WinRar). Извлекаем папку RockBox в любое доступное место на жестком диске.
2. (Внимание! Телофон должен быть прошит любым пользовательским модом с поддержкой MPKGBOX)!!!
Подключаем телефон в режиме КАРТЫ ПАМЯТИ и кидаем папку RockBox в папку mpkgbox на вашей флешке. Отключаем телефон, заходим в MPKGBOX, вибираем вкладку "карта памяти", запускаем RockBox. Установка завершена!
Общая настройка:
1. Создание главного плейлиста - заходим Playlists, Create Playlist (Создаётся плейлист каталога MMC/Music/).
Просмотр и воспроизведение песен плейлиста - Playlists, View Current Playlist
2. Плеер оснащен очень удобной Базой Данных, в которой музыка из каталога MMC/Music/ сортируется на множество категорий - начиная с Исполнителя, Альбома и заканчивая Годом, Номером трека и даже первой буквой различных категорий! Создать базу можно в меню Database.
3. В плеере есть встроенный Файл-Менеджер (меню - Files), чтобы вызвать контекстное меню в нём, нужно зажать центральную клавишу джойстика.
4. Plugins - здесь сосредоточены игры(присутствует даже Doom), небольшие програмки и визуализация/заставки для плеера. Стоит отметить, что не все плагины работают корректно.
5. System - информация о телефоне и RockBox'e, установка времени сна и др.
Пользовательская настройка: (Пункт Settings)
1. Sound Settings - Здесь можно настроить звучание под себя.
Основные пункты изменяющие звук:
1.1. Stereo Width - рекомендую поставить 250% (Расширение стереобазы)
1.2. Equalizer - Сначала включаем (Enable EQ, Yes), Затем либо настраиваем сами, либо воспользуемся
предустановками (Browse EQ Presets) которые действительно меняют звук!
Совет: 1. Самое качественное звучание - настройка Best Sound Quality (На мой взгляд)
2. Самое громкое Rock Clear + Sound Settings, Limiter Preamp нужно поставить в значение 8.0 db
1.3. Limiter Preamp - Если песня тихая, изменяем значение этого параметра на большее (Например 8.0 db)
2. Playback Settings - Здесь выставляете настройки проигрывания (Повтор, Случайное воспроизведение и др.)
3. General Settings - Общие настройки плеера. Здесь можно выставить русский язык (Language)!
ВНИМАНИЕ! Чтобы русский язык отображался, он должен поддерживаться текущим шрифтом!
4. Theme Settings - Настройка тем.
4.1 Browse Theme Files - Здесь выбираем нужную Вам тему плеера.
4.2 Font - Установка шрифта плеера. (Русский язык отображается например в шрифте unifont)
4.3 While Playing Screen - Установка оболочки самого проигрывателя.
4.4 Show Icons -Настройка показа иконок
5. Manage Settings - Здесь можно сбросить все настройки плеера по дефолту, если вы где-то напортачили. (Reset Settings)
Клавиатура:
Вверх, вниз: громкость в плеере и вверх-вниз в меню.
Вправо: "Следующий трек", Удержание: "Перемотка вперед" - в плеере и выбор в меню.
Влево: "Предыдущий трек", Удержание: "Перемотка назад" - в плеере и назад в меню.
Качелька громкости: управляет громкостью в плеере. Для регулирования необходимо зажать (Длинная шкала)
Центральная кнопка джойстика: Выбор и контекстное меню при зажатии.
Левая софт-клавиша: Пауза и воспроизведение в режиме воспроизведения.
Право софт-клавиша: Стоп/выход (при использовании плагина или игры, которая не работает должным образом).
Красная кнопка: Выход из плеера.
Зеленая кнопка: Скриншот экрана.
Шрифты, поддерживающие русский язык:
11-Nimbus
13-Nimbus
15-Adobe-Helvetica
16-GNU-Unifont
19-Nimbus
cfsj-12pt
Corbel_12
Epsy+asian-12
FZXSQJ-12pt
helvR12
kaiti-14pt
msyh-12pt
msyh-13pt
myfont-12pt
nimbus+uming-14
nimbus-12
nimbus-19
Segoe_UIB_12
shaonv-14pt
simsun_ok
st
STCAIYUN-14pt
unifont
Сменить язык интерфейса в RockBox можно, зайдя в Settings, потом Theme Setings, потом Font устанавливаем - жмем Unifont, возвращаемся назад к пункту General Settings, входим там папка Language.В ней выбираем язык какой хотим.
Еще раз пользуясь случаем благодарим этих камрадов:
Ant-ON (SDL)
Сообщение отредактировал Offset - 12.11.2010, 19:17
syberside
сообщение 19.1.2010, 5:30
Из: Новоуральск
Пользователь №: 176 082
Прошивка: ICS 4.0.4
а как свернуть то ситё чудо)
сообщение 19.1.2010, 7:38
Через ZTaskMan
(Свернуть всё на второй вкладке)
Сообщение отредактировал EXL - 19.1.2010, 7:39
syberside
сообщение 19.1.2010, 11:49
Из: Новоуральск
Прошивка: ICS 4.0.4
для этого должно быть включено сворачвание явы? приложения со своим сдл таск мен не сворачивает.
lpmusic
сообщение 19.2.2010, 7:04
Из: {KHABAROVSK}
Пользователь №: 153 740
Модель телефона: Korean Atrix, XT5
Прошивка: Froyo
AtrixMan =)
как его запустить под мпкж боксом? приходиться лезть на флешку скрипт запускать)
сообщение 19.2.2010, 8:21
Странный вопрос. По иконке в Mpkgbox )
Если нет иконки, проверь что папка рокбокса находиться в папке mpkgbox на карте памяти. И в файле *.cfg (называется так же как и папка) , прописан скрипт запуска в строке Exec
Сообщение отредактировал EXL - 19.2.2010, 8:26
lpmusic
сообщение 19.2.2010, 9:43
Из: {KHABAROVSK}
Прошивка: Froyo
AtrixMan =)
где я сказал про иконку?) у меня все отображаеться в мпкж боксе, но через него не запускаеться smile.gif Может из-за того, что у меня не mgx box?
сообщение 19.2.2010, 10:06
Нет разницы
lpmusic
сообщение 19.2.2010, 13:13
Из: {KHABAROVSK}
Прошивка: Froyo
AtrixMan =)
Вот, что в Rockbox.cfg
Name = RockBox
Exec = rockbox.sh
Version = 3.4
Author = Motocaker Team
Comment = Port for ZN5 by Junior Passos. Thanks Ant-ON for SDL.
Да находиться там папка)
Добавлено позже (19.2.2010, 23:19):
исправил строку exec на rockbox-portrait.sh, запустился, но не сворачивается)
JediSamurai
сообщение 23.2.2010, 14:43
Пользователь №: 159 664
Модель телефона: Motozine Zn5
А когда портируют 3,5 версию?
Lunik
сообщение 1.3.2010, 15:00
Пользователь №: 210 670
Модель телефона: ZN5
Прошивка: Symbiosis IV
Всем здрасти. А есть ли исходники этой штуки? Очень хотелось бы поменять алгоритм шафла (думаю, не только мне), могу заняться.
сообщение 1.3.2010, 17:40
RockBox как ни странно открытый проект - значит исходники должны быть
http://www.rockbox.org/ - официальный сайт есть исходники и документация.
Не думаю что скоро
Hitch
сообщение 5.4.2010, 20:31
Вечномолодой
Из: Рая
Пользователь №: 46 265
Прошивка: Bada 1.2
Omygodable :) Это же сам Rockbox. Помню на Е2 он звук знатно улучшал.. до неузнаваемости )
С зайном эта чудо-программулина нормально работает? Все кнопки в адеквате и функции? :)
Ещё бы zMMS к нам.. по-моему так называлась :) То же плеер )
mr.Ozio
сообщение 27.4.2010, 11:36
Из: Київ
Пользователь №: 100 323
Модель телефона: E2,Atrix
Звук становится заметно лучше, особенно порадовали бассы которых больше чем у Е2. Но быстродействие хромает. Какой то он задумчивый и портретный режим не доработаный.
Сообщение отредактировал mr.Ozio - 27.4.2010, 14:43
HePeDoBeH
сообщение 25.6.2010, 6:21
Из: Стара Загора,Болгария
Пользователь №: 45 347
Модель телефона: C350L ->Е398 -> ZN5
Прошивка: Symbiosis V Foto Sp1
Сначало извините меня для моей руский язык, ну я плохо училься в школе. :-)
Если ето не трудно, можно добавить плагин для тексты песни в формате *.lrc ?
В оригинальный rockbox ето возможно с плагином sncviewer, ну я не знаю если вы можете вставить его в портированная версия.Я буду быть очень благодарный для эта дополнительная функция...
Сообщение отредактировал HePeDoBeH - 25.6.2010, 6:32
Hairo Carela
сообщение 25.6.2010, 22:05
From a Distant Land
Из: Dominican Republic
Пользователь №: 204 655
Модель телефона: ZINE Zn5
Прошивка: Qtopia Alpha
i can't istall the rockbox on mem card, i get a error "No rockbox directory, installation incomplete"
any help?
Ded
сообщение 27.8.2010, 19:17
Пользователь №: 38 950
Модель телефона: nokia n8
а поддерживает ли он файлы cue? И возможно ли проигрывать flac и ape файлы?
EXL: Суровый дисковый *.cue поддерживает. Доставляющий *.ape - воспроизводит. Тёплый ламповый *.flac - воспроизводит.
Вот перечень форматов:
MPEG audio layers I—III (MP3/MP2/MP1),
Ogg Vorbis (OGG),
MPEG-4 AAC,
Musepack,
AC3,
WMA,
Speex,
Cook,
ATRAC3,
TTA (True Audio),
FLAC,
WavPack (WV),
Shorten (SHN),
Apple Lossless (ALAC),
APE,
WAV,
Apple AIFF,
ADX,
SID,
NSF,
SAP,
SPC,
MOD.
Сообщение отредактировал EXL - 28.8.2010, 4:36
мистерХ
сообщение 28.8.2010, 3:22
Из: ХАХАБУРГ
Пользователь №: 183 871
Прошивка: серое вещество
Love D2G
flac я слушал
Ded
сообщение 28.8.2010, 9:05
Ogg Vorbis (OGG),
MPEG-4 AAC,
Musepack,
AC3,
WMA,
Speex,
Cook,
ATRAC3,
TTA (True Audio),
FLAC,
WavPack (WV),
Shorten (SHN),
APE,
WAV,
Apple AIFF,
ADX,
SID,
NSF,
SAP,
SPC,
MOD.
А как понять дисковый cue и еще и суровый? ПРосто много mp3 да и флака с куешками.ТО есть проигрываться будет именно как на компе? видеть вместо одного файла уже как бы порезанный потреково? И как тогда пеоемотка именно внутри этих файлов будет идти,ну и вообще переход от песни к песне? Именно как на ББ?
Добавлено позже (28.8.2010, 13:08):
Цитата(мистерХ @ 28.8.2010, 7:22) *
flac я слушал
А куешки с флаком,всё как и положено-потреково воспроизводит?Просто хочется прикупить зину именно как второй тел,и на котором еще и музыку буду слушать
Zorge.R
сообщение 28.8.2010, 9:08
Group Icon
Группа: System Administrators
Из: рук в руки
Пользователь №: 101 800
Прошивка: 1CR
Цитата(Ded @ Сегодня, 13:05)
ПРосто много mp3
использовать cue для mp3, зачем?.
мистерХ
сообщение 28.8.2010, 9:25
Из: ХАХАБУРГ
Love D2G
я в этом не секу закинул альбом во флаке и слушал все попорядку. я не аудиофил
З.Ы, купи себе плеер. рокбокс изнасилует твой аккум и расшибеш зину о стену с криком ноклы дольше держат wink.gif
Ded
сообщение 28.8.2010, 9:26
Много очень сборников(танцевальное направление) с просторов инета и не только, грабятся во всем мире да и у нас в связке mp3+ cue.
Много mp3-я так понимаю что один файл mp3 с куешкой рокбокс тут же разобьет как положено на треки из куе файла и я смогу нормально выбрать трек какой захочу и слушать его? И будет ли работать перемотка внутри трека и можно ли будет потреково перескакивать с песни на песню внутри этого файла?
EXL: Попробовал сейчас cue. Роксбокс разбил трэк как положено, но воспроизводить его что-то не захотел. Причину не знаю, может у меня куе файл не правильный. Если что дай ссылочку на альбом с *.cue, только на небольшой, в пределах 20-30 метров, я проверю
Добавлено позже (28.8.2010, 13:31):
Ну ты альбом закинул во флаке,он был из песен-этот альбом,потреково?Или альбом шел одним треком-от начала до конца,и в папке к альбому шел файл cue, который разбивает один большой трек(сам альбом)-на треки-которые входят в этот альбом
Сообщение отредактировал EXL - 28.8.2010, 9:41
мистерХ
сообщение 28.8.2010, 9:38
Из: ХАХАБУРГ
Love D2G
отдельные трэки)
Ded
сообщение 28.8.2010, 9:44
да на небольшой альбом не получится ссылку дать,они все за 100метров
Добавлено позже (28.8.2010, 13:54):
Давай я попробую сжать до 64kb звук в mp3,размер маленький получится,и залью тебе на файлообменник,на ифолдер например, пойдет?
EXL: Пойдёт
Сообщение отредактировал EXL - 28.8.2010, 11:21
Zorge.R
сообщение 28.8.2010, 10:54
Group Icon
Из: рук в руки
Прошивка: 1CR
открой его блокнотом и исправь путь до исходного файла.
EXL: Да копался сегодня, и путь вставлял, и просто имя. Если, допустим файл 1.mp3 лежит в корне флехи, то путь до него просто /mmc/mmca1/1.mp3 ведь?
Сообщение отредактировал EXL - 28.8.2010, 11:23
Ded
сообщение 28.8.2010, 11:40
Ну вообщето путь моно и не прописывать в куешке
как пример
301_va_-_kontor_top_of_the_clubs_vol._47_cd3_(mixed_by_spencer_and_hill).mp3-это файл
вот что будет в самой куешке(ну это часть конечно)
TITLE "Kontor Top of the Clubs Vol. 47 CD3"
FILE "301_va_-_kontor_top_of_the_clubs_vol._47_cd3_(mixed_by_spencer_and_hill).mp3" MP3
как видим-самое главное-идентичное название файла mp3 и файла куе и еше чтоб в куешке самма мр3 так же называлась
Добавлено позже (28.8.2010, 15:55):
EXL: Пойдёт
http://ifolder.ru/19065434
файлик с куешкой,битрейт 64,только частота 24килогерца,но я думаю это не проблема
EXL: Он части видит, но нифига не воспроизводит
Сообщение отредактировал EXL - 28.8.2010, 14:11
Zorge.R
сообщение 28.8.2010, 12:53
Group Icon
Из: рук в руки
Прошивка: 1CR
Ded, Кеп, ты поражаешь своей гениальностью. путь прописывать вообще не нужно, надо только указать точное имя файла.
нет, просто имя файла.
EXL: Имя файла я попробовал в первую очередь
за снижение ЧД ниже 22 на канал (44.1 на стерео), я готов расстреливать.
Сообщение отредактировал EXL - 28.8.2010, 13:28
сообщение 28.8.2010, 13:36
Ded
сообщение 28.8.2010, 18:52
понизил частоты чтоб сделать маленький размер файлика, и при чем тут частоты,вопрос в том что куе то рокбокс не воспроизводит получается на зине
Добавлено позже (28.8.2010, 22:59):
Цитата(AstaRoth @ 28.8.2010, 17:36) *
матчасть неплохо бы изучать иногда. Cue не только с лосслесом идут.
Zorge.R
сообщение 28.8.2010, 20:04
Group Icon
Из: рук в руки
Прошивка: 1CR
Вот Ты говоришь AstaRoth'у, "матчасть неплохо бы изучать иногда." , а сам то ее учил?
именно за это и готов расстрелять.
понижать надо битрейт (который и отвечает за размер результирующего файла), переводить каналы в моно (при помощи чего можно снизить битрейт в ~2 раза, без относительных потерь качества), но не надо трогать частоту дискретизации (это не влияет на размер, но качество губит беспощадно).
учи он матчасть, не учи, а суть в том нужен ли CUE с куском mp3 в 80 минут на телефоне.
польза от cue для прослушивания рипованных записей, в отсутствии разрывов между концом и началом воспроизведения следующего трека, это актуально только для альбомов где сделан "плавный" (например в альбоме Get Up от 2007 года, от Global Deejay's) либо "неразрывный" переход от одного трека, к другому (например как в альбоме first sound от dj lupin). Во всех других случаях (когда треки отдельные), пользы от куе при прослушивании рипа с диска, никакой нет. отдельные файлы, в разы удобней. (+ к этому, часть плееров уже давно умеет воспроизводить отдельные треки, без пробелов)
а теперь внимание, вопрос: неужели при прослушивании с телефона, пусть даже в hi-end наушниках (омность которых телефон с трудом потянет), так важно отсутсвие разрыва в пол секунды между треками?
Сообщение отредактировал Zorge.R - 28.8.2010, 20:29
Ded
сообщение 29.8.2010, 10:35
файл просили залить не более 30 метров,у меня он ито больше получился,и нужен он был для проверки,будет ли тел читать этот файл с куешкой. Можете и вы проверить,для вас специально залью с нормальной дискредитацией и битрейдом, а вообще какой то флуд пошел уже
Просили файлик поменьше размеров-метров на 30,и в данном случае надо проверить будет ли рокбокс играть этот файл с куешкой
А вот ты не думаешь что просто хренова туча у меня сборников-миксованных,и как ни странно,все они сграблены как положено.Я не хочу лишних телодвижений чтоб нарезать на файлы а потом всё это закидывать в тел,мне хочется как побыстрее и получше(поудобнее).
А теперь вопро-зинка с рокбоксом куе не поддерживают,прав я или нет?
Сообщение отредактировал Ded - 29.8.2010, 10:38
Programmer-tm(Мотофан.)
сообщение 29.8.2010, 10:52
Из: Из мира сего
Пользователь №: 215 291
Модель телефона: Moto X Play
Прошивка: Модифицированная...
Облегченный рокбокс 3.4
Плагины работают, Cue подключаются.
Скин один, шрифт то же.
Portrait мод только оставил. И вообще плеер нужен только для музыки) не более.
Mgx:
Pep:
Сообщение отредактировал Programmer-tm(Мотофан.) - 29.8.2010, 11:02
Zorge.R
сообщение 29.8.2010, 11:57
Group Icon
Из: рук в руки
Прошивка: 1CR
повторяю еще раз, частота дискретизации на размер файла не влияет, размер зависит от битрейта на поток и от количества потоков.
большая часть программ (кодеров) при снижении ЧД, автоматом снижает битрейт (анти избыточное кодировние) и наоборот (именно снижение битрейта приводит к уменьшению размера, а не снижение ЧД)
Ты говоришь что сохранил файлы как
я сказал выше о сведении в моно, Ты это проигнорировал, а зря, потому что переведя поток в моно, Ты мог спокойно сохранить файл в 48 кбит\с и частотой 44.1 кГц, при этом получив меньший размер, но более высокое качество.
не прав.
Сообщение отредактировал Zorge.R - 29.8.2010, 12:12
Ded
сообщение 29.8.2010, 13:50
не прав.
Хорошо,ежели поддерживает зинка cue, то тода если не сложно -проверь и ты этот файлик-будет ли он у тебя играться. Вот ссылка http://ifolder.ru/19065434
могу ежели сжатие не устраивает, скинуть нормально сграбленный файл, в данном случае для меня это не актуально,интересует-сможет ли его моторола при помощи рокбокса проиграть,а не просто вывести список треков
сообщение 29.8.2010, 14:12
Из: Из мира сего
Ded,
Сейчас скачаю и проверю через свою сборку
Добавлено позже (29.8.2010, 18:39):
Ded,
На моей сборке все работает отлично. Музыка играет, cue подключается и все работает.
Сообщение отредактировал Programmer-tm(Мотофан.) - 29.8.2010, 14:47
Ded
сообщение 29.8.2010, 14:41
Цитата(Programmer-tm(Мотофан.) @ 29.8.2010, 18:12) *
Ded,
Ded,
Большое спасибо. Треки перематываются и просто переходят с одного на другой без проблем?
сообщение 29.8.2010, 14:48
Из: Из мира сего
Все работает и перемотка и переходы.
Zorge.R
сообщение 29.8.2010, 15:51
Group Icon
Из: рук в руки
Прошивка: 1CR
в любом рокбоксе
Settings/Playback Settings/Cuesheet Support
ставим YES и перезагружаем рокбокс.
запускаем любой рип, cue подцепляется автоматом, перемотка и листинг треков работают, на отображаемой дорожке, видно деление на треки (возмжно не на всех скинах), я так слушал альбом центра в APE. (т.е. APE тоже нормально воспроизводится)
Сообщение отредактировал Zorge.R - 29.8.2010, 15:53
Ded
сообщение 29.8.2010, 16:02
Цитата(Zorge.R @ 29.8.2010, 19:51) *
в любом рокбоксе
Я так понимаю что и флак тоже без проблем подцепится с куешкой? И еще вопрос-как сильно тормозит сам телефон кода рокбокс включен и намного ли сильнее батарея дохнет?
mr.Ozio
сообщение 29.8.2010, 17:22
Из: Київ
Programmer-tm отличная сборка. Работает быстрее чем родная.
сообщение 29.8.2010, 17:41
Из: Из мира сего
mr.Ozio,
Ну так там только самое необходимое...
[mgx] Rockbox Version 3.4 (100% Functional), Ставим. Обсуждаем. · Motorola ZINE ZN5, ZN5 T-Mobile · Forum
Текстовая версия Сейчас: 1.8.2025, 15:22
