6 страниц V « < 4 5 6 >
[mgx] Rockbox Version 3.4 (100% Functional), Ставим. Обсуждаем.
Offset
сообщение 30.9.2009, 12:05 Закрепленное сообщение!
Leo
Пользователь №: 126 712
RockBox
Hello everybody, I hereby present the official version of the magnificent RockBox.
Some time ago and I adapted the Douglas RockBox Beta (version 3.3) of the Rokr Z6 developed by CepiPeres, was a great application but had some bugs and problems.
Well, then, was recently released on the website of RockBox version 3.4 of this fantastic multimedia center.
Team Motocaker Team took the opportunity to upgrade the family's RockBox MOTOMAGX.
I decided to adapt and adjust to this latest version to our dear ZN5 and the result was amazing. So I'm here to share with you the new version of RockBox.
What's new in this application compared to the Beta:
-Now the application no longer needs to be closed Plugin, just press the power button (red) to close the application.
-Now we can listen to music and continue stirring in the application, we can see photos, play games, use some mini-application, do whatever we want.
-Added the game Doom within the application to play while we hear that favorite song.
-Is it possible to play videos at 25fps in MPEG format.
-Is it possible to play ATRAC3 audio files.
-Is it possible to play audio files AC3.
-Is it possible to play AAC audio files.
-System stabilized and made some adjustments.
Keyboard Configuration:
- Volume Buttons: Controls the volume.
- Smart button: Main Menu.
- Directional Up and Down: Controls the volume and menu controls.
- Directs Right: Next and Select.
- Directional Left: Backwards and Back.
- Center Button: Selects functions.
- Left Softkey: Pause and Play in Playback mode.
- Right Softkey: Stop the music / Exit (when using a plugin or game that does not run correctly).
- Red Button: Close the application.
- Green Button: Capture screen images.
The application has 3 display modes: Portrait, Landscape and Landscape II.
Images of the application:
I recommend installing it on the Memory Card.
Works perfectly in Freedom Evolution Brazil 2.0 by Junior Passos, Evo2 and Evo3 by iLove3d.
Download:
http://www.4shared.com/file/136344685/6e89...Box_ZN5_EN.html
Sorry my English.
Credits:
Motocaker Team (RockBox)
Ant-ON (SDL)
Junior Passos (Ported for ZN5)
Оригинал топик
скачать с сервера mmus СКАЧАТЬ (необходима регистрация)
Скачать с ifolder.ru
Установка RockBox 3.4 (mgx): автор мануала: EXL
1.Скачиваем сам mgx-пакет RockBox, открываем его с помощью архиватора (Я пользуюсь WinRar). Извлекаем папку RockBox в любое доступное место на жестком диске.
2. (Внимание! Телофон должен быть прошит любым пользовательским модом с поддержкой MPKGBOX)!!!
Подключаем телефон в режиме КАРТЫ ПАМЯТИ и кидаем папку RockBox в папку mpkgbox на вашей флешке. Отключаем телефон, заходим в MPKGBOX, вибираем вкладку "карта памяти", запускаем RockBox. Установка завершена!
Общая настройка:
1. Создание главного плейлиста - заходим Playlists, Create Playlist (Создаётся плейлист каталога MMC/Music/).
Просмотр и воспроизведение песен плейлиста - Playlists, View Current Playlist
2. Плеер оснащен очень удобной Базой Данных, в которой музыка из каталога MMC/Music/ сортируется на множество категорий - начиная с Исполнителя, Альбома и заканчивая Годом, Номером трека и даже первой буквой различных категорий! Создать базу можно в меню Database.
3. В плеере есть встроенный Файл-Менеджер (меню - Files), чтобы вызвать контекстное меню в нём, нужно зажать центральную клавишу джойстика.
4. Plugins - здесь сосредоточены игры(присутствует даже Doom), небольшие програмки и визуализация/заставки для плеера. Стоит отметить, что не все плагины работают корректно.
5. System - информация о телефоне и RockBox'e, установка времени сна и др.
Пользовательская настройка: (Пункт Settings)
1. Sound Settings - Здесь можно настроить звучание под себя.
Основные пункты изменяющие звук:
1.1. Stereo Width - рекомендую поставить 250% (Расширение стереобазы)
1.2. Equalizer - Сначала включаем (Enable EQ, Yes), Затем либо настраиваем сами, либо воспользуемся
предустановками (Browse EQ Presets) которые действительно меняют звук!
Совет: 1. Самое качественное звучание - настройка Best Sound Quality (На мой взгляд)
2. Самое громкое Rock Clear + Sound Settings, Limiter Preamp нужно поставить в значение 8.0 db
1.3. Limiter Preamp - Если песня тихая, изменяем значение этого параметра на большее (Например 8.0 db)
2. Playback Settings - Здесь выставляете настройки проигрывания (Повтор, Случайное воспроизведение и др.)
3. General Settings - Общие настройки плеера. Здесь можно выставить русский язык (Language)!
ВНИМАНИЕ! Чтобы русский язык отображался, он должен поддерживаться текущим шрифтом!
4. Theme Settings - Настройка тем.
4.1 Browse Theme Files - Здесь выбираем нужную Вам тему плеера.
4.2 Font - Установка шрифта плеера. (Русский язык отображается например в шрифте unifont)
4.3 While Playing Screen - Установка оболочки самого проигрывателя.
4.4 Show Icons -Настройка показа иконок
5. Manage Settings - Здесь можно сбросить все настройки плеера по дефолту, если вы где-то напортачили. (Reset Settings)
Клавиатура:
Вверх, вниз: громкость в плеере и вверх-вниз в меню.
Вправо: "Следующий трек", Удержание: "Перемотка вперед" - в плеере и выбор в меню.
Влево: "Предыдущий трек", Удержание: "Перемотка назад" - в плеере и назад в меню.
Качелька громкости: управляет громкостью в плеере. Для регулирования необходимо зажать (Длинная шкала)
Центральная кнопка джойстика: Выбор и контекстное меню при зажатии.
Левая софт-клавиша: Пауза и воспроизведение в режиме воспроизведения.
Право софт-клавиша: Стоп/выход (при использовании плагина или игры, которая не работает должным образом).
Красная кнопка: Выход из плеера.
Зеленая кнопка: Скриншот экрана.
Шрифты, поддерживающие русский язык:
11-Nimbus
13-Nimbus
15-Adobe-Helvetica
16-GNU-Unifont
19-Nimbus
cfsj-12pt
Corbel_12
Epsy+asian-12
FZXSQJ-12pt
helvR12
kaiti-14pt
msyh-12pt
msyh-13pt
myfont-12pt
nimbus+uming-14
nimbus-12
nimbus-19
Segoe_UIB_12
shaonv-14pt
simsun_ok
st
STCAIYUN-14pt
unifont
Сменить язык интерфейса в RockBox можно, зайдя в Settings, потом Theme Setings, потом Font устанавливаем - жмем Unifont, возвращаемся назад к пункту General Settings, входим там папка Language.В ней выбираем язык какой хотим.
Еще раз пользуясь случаем благодарим этих камрадов:
Ant-ON (SDL)
Сообщение отредактировал Offset - 12.11.2010, 19:17
сообщение 31.8.2010, 19:29
mr.Ozio,
ясненько. просто вот скачал формулф-1 посмотреть, а времени не было, и что б не конвертировать думал глянуть, а мплеер что то не очень люит формат мпег.
а свои шрифты можно добавлять в плеер
VoiD
сообщение 1.11.2010, 13:16
Пользователь №: 167 152
Модель телефона: EM30
Прошивка: 04.06e
В связи с выходом новой версии RB поднимаю тему, чтобы спросить: возможно ли скомпилировать более свежий билд на наши телефоны?
EXL: Да, но это трудно
Сообщение отредактировал EXL - 1.11.2010, 13:57
D-1c3
сообщение 2.11.2010, 17:16
Пользователь №: 150 086
Прошивка: свежая
со времен первого порта что-нибудь изменилось, или этот рокрокс по-прежнему сжирает всю батарею за несколько часов?
EXL: Он всегда будет сжирать так батарею, т.к сделан через SDL
Сообщение отредактировал EXL - 2.11.2010, 17:19
SanchoNT
сообщение 3.11.2010, 3:41
Из: Нижний Тагил
Пользователь №: 184 870
Прошивка: 4.4.4
но расход батареи при использовании рокбокса это интересная тема, я пока что не знаю адекватных причин большого расхода заряда, ну через SDL и что? хотелось бы по подробней узнать как это может влиять на пожирание заряда, я думал что проц сильно грузит, ограничивал проц до 133 через zCPU при выключенной подсветке - рокбокс играет нормально, батарея жрётся так же, следующее моё предположение было что идёт сильное потребление заряда из-за большой нагрузки на карту памяти, потому что музыка на карте, рокбокс на карте, SDL и свап тоже там же, но пока что не проверял изменится ли что-нибудь если это всё перенести в память телефона
EXL: И, то что мне кажется что это именно из-за этой библиотеки повышенное энергопотребление. Т.к любая игра или приложение с её использованием садит батарею за несколько часов. И кстати да, попробуй как появиться свободное время, проверить изменится ли что-нибудь если рокбокс, свап, музыку перенести в память телефона. Возможно твое предположение правильно
Сообщение отредактировал EXL - 3.11.2010, 8:42
Maxman
сообщение 2.12.2010, 18:47
Пользователь №: 68 054
Народ а у всех рокбокс так безбожно тормозит при регулировке звука или это я такой счастливый?
сообщение 2.12.2010, 19:19
при увилечении и уменьшении? или при редактировании в настройках?
сообщение 2.12.2010, 19:42
он не тормозит просто там диапазон регулировки большой,что то от -70дб до 10 или как то так,но на практике получается что бы увеличить/уменьшить громкость немного нужно делений десять-двадцать перескочить...
Maxman
сообщение 4.12.2010, 0:16
Скажите а в E8 рокбокс как то иначе реализован? всмысле у меня на е8 вроде стоял и батарея особо не дохла
biper
сообщение 6.6.2011, 14:45
Из: Rostov-on-Don
Пользователь №: 219 759
Модель телефона: Motorola ZN5-DEFY+
русский язык не отображает(
igoripp
сообщение 6.6.2011, 15:52
Самый дерзкий
Из: Касимов, Муром
Пользователь №: 215 540
Модель телефона: sony ion
biper, Ты в настройках выбирал русский язык? Если выбрал и появились "квадраты" вместо текста, то выбери другой шрифт smile.gif
biper
сообщение 6.6.2011, 18:07
Из: Rostov-on-Don
вообще ничего не появилось, просто иконки, но я понял о чем ты))спасибо)))
ARomanA
сообщение 6.4.2013, 20:52
Пользователь №: 241 381
Модель телефона: ZN5
Тоесть за собой еще и пару аккумов таскать надо ? =(
Жаль, думал полноценная замена плеера получится, надо было все же Teclast брать походу =(
ARomanA
сообщение 6.7.2013, 8:47
C каким монстром rockbox лучше работает: Simbiosis или Evolution ?
сообщение 6.7.2013, 9:05
одинаково.
VINRARUS
сообщение 6.7.2013, 16:17
Термоядерный
Из: Чорнобиль
Пользователь №: 211 044
Прошивка: 740 MHz: Z6 and ZN5
youtu.be/A_yQLYLiSGQ
Цитата(ARomanA @ Сегодня, 11:47)
* C каким монстром rockbox лучше работает?
Сообщение отредактировал VINRARUS - 6.7.2013, 17:00
Diary of Jane
сообщение 8.7.2013, 2:18
Пользователь №: 238 762
Модель телефона: EDGE+
POEHAVSHII
VINRARUS,
VINRARUS
сообщение 9.7.2013, 13:41
Термоядерный
Из: Чорнобиль
Цитата(Diary of Jane @ Вчера, 5:18)
* с модом симбиоза от Программера так же, как и у тебя
Не правда, ZiniMOD Alfa 2 единственный мод для ZN5 который имеет стабильный разгон до 740 МГц. wink.gif
Цитата(Programmer-tm(Мотофан.) @ 24.1.2012, 17:32)
* -пропатчил apmd (спасибо SanchoNT за разъяснения как это сделать) теперь телефон без стороннего софта разгоняет проц до 532 МГц.
сообщение 9.7.2013, 16:46
Цитата(VINRARUS @ 6.7.2013, 19:17)
* C ZiniMOD Alfa 2 быстрее, там частота больше.
быстрей музыка играет что ли?
ARomanA
сообщение 10.7.2013, 7:52
Просто вроде-кто писал что на Evolution rockbox нормально пашет на частоте 133. У меня на симбиозисе надо 533 ставить, и то немного лагает, причем rockbox упрощенный, а не полный.
сообщение 10.7.2013, 7:58
Из: Из мира сего
Пользователь №: 215 291
Модель телефона: Moto X Play
Прошивка: Модифицированная...
ARomanA,
Может неправильно его юзаешь?) Да и моды тут непричем... Просто надо половину плюшек отключать (неиспользуемых)
Diary of Jane
сообщение 11.7.2013, 3:45
POEHAVSHII
VINRARUS,
мод от Программера идет с разгоном до 636, вообще-то smile.gif а 740, на мой взгляд, этой балалайке ни к чему smile.gif впрочем, мне уже неважно, я ушел на фотон))
сообщение 11.7.2013, 5:24
Из: Из мира сего
Diary of Jane,
А я вернулся на зинку почти) но гоняю с дефаем)
VINRARUS
сообщение 11.7.2013, 19:37
Термоядерный
Из: Чорнобиль
Цитата(Claus398 @ 9.7.2013, 19:46)
* быстрей музыка играет что ли?
Вот тебе лог, там где 133 частота пошла я в рокбоксе вышел из меню трека на главное меню (но музон играет), там где 1й раз 740 МГц было смена трека:
частота > загрузка ЦП в %
По этому если хотите ежедневно пользоваться рокбоксом без розетки - при запуске проигрывания нужно возвратиться к списку меню (в рокбоксе).
Цитата(Diary of Jane @ Сегодня, 6:45)
* мод от Программера идет с разгоном до 636, вообще-то
Я забыл\не внимателен был, но тем не менее ты ошибся:
* а 740, на мой взгляд, этой балалайке ни к чему
В мире ПК когда ЦП устаревает - его разгоняют что бы продлить срок службы.
Сообщение отредактировал VINRARUS - 11.7.2013, 19:39
Diary of Jane
сообщение 12.7.2013, 5:18
POEHAVSHII
подкруткой некоторых настроек в рокбоксе на 636 я добивался полного отсутствия заиканий wink.gif а твой мод у меня несколько раз словил висяк и перезагрузку, поэтому я не остался на нем, увы
сообщение 12.7.2013, 6:46
Из: Из мира сего
Diary of Jane,
типа есть смысл симбиоз попилить?
Diary of Jane
сообщение 12.7.2013, 16:07
POEHAVSHII
Programmer-tm(Мотофан.),
думаю, смысл всегда есть. мне мод очень и очень сильно доставил
сообщение 12.7.2013, 18:37
+ я на август планирую темку новую запилить)
сообщение 13.7.2013, 15:53
Из: Из мира сего
Claus398,
ну мож в августе в отпуске и займусь
сообщение 13.7.2013, 16:42
будет здорово)
сообщение 13.7.2013, 16:47
Из: Из мира сего
Claus398,
скинодел за еду?)
сообщение 13.7.2013, 17:54
в общем то да) ещё за теплую одежду, кров и воду) и за всякие интерессные плюшки) хочется виджетами заняться. нужно програмирование побольше по изучать или с кем то скоопирирыватся.
Serjjio
сообщение 14.12.2014, 16:35
Пользователь №: 247 428
Модель телефона: Zn5
У кого есть RockBox залейте куда нибудь. Пожалуйста!
На ifolder вирусняк
Сообщение отредактировал Serjjio - 14.12.2014, 16:36
Сергей_Motofan
сообщение 25.1.2015, 12:26
Из: г. Оренбург
Пользователь №: 85 146
Прошивка: CM 12.1 5.1.1
..::MotoLife::..
Serjjio,
Держи RockBox ZN5
VINRARUS
сообщение 4.10.2016, 1:06
Термоядерный
Из: Чорнобиль
dark_lord.gif Так, все ссылки поздыхали, хорошо шо у меня валялся полный пакет Rockbox Version 3.4
Исправил несколько нестыковок и сделал автовыбор 3х языков (украинский, росийский, английский) при 1м запуске. А еще пофиксил добавление ярлыка в меню на ZiniMOD.
Сообщение отредактировал VINRARUS - 4.10.2016, 1:10
Прикрепленный файл Rockbox_3.4.pep   ( 18.45 мегабайт ) Кол-во скачиваний: 158
VINRARUS
сообщение 4.10.2016, 11:07
Термоядерный
Из: Чорнобиль
Так, а че со звуком, че он не регулируется, а только циферка меняется?
Хотя еквалайзер паштет.
Unreal_man
сообщение 4.10.2016, 11:32
Из: Другого Края Земли
Пользователь №: 211 211
:-I
Паштет! Хахаха!
По делу: тормозной, недоделанный, с тупым управлением. Выйдя из шелл так и не понял как обратно войти. И еще бекграунд не обрабатывает. Ацтой.
VINRARUS
сообщение 4.10.2016, 11:48
Термоядерный
Из: Чорнобиль
Цитата(Unreal_man @ Сегодня, 14:32)
* И еще бекграунд не обрабатывает.
Для меня рокбокс нужен токо шобы раскачать ЛЮБЫЕ наушники на макс. громкости, благодаря серьезному еквалайзеру.
А вообще сам по себе Rockbox создавался как кастомная прошивка для разных мр3 плееров, и как замена оболочки.
А на линуксе у нас свои скины, свои програмы и игры, по этому Rockbox для motomagx больше игрушка, чем необходимость.
Сообщение отредактировал VINRARUS - 4.10.2016, 11:53
брат82
сообщение 10.1.2017, 13:34
Пользователь №: 251 343
Модель телефона: zn5
Привет! Подскажите, как в рокбоксе нажать на паузу? Вроде бы все привычные кнопки пробовал - результата нет not_i.gif И ещё вопрос - сколько примерно должен держать нормальный аккум в режиме Rockbox? Большое спасибо VINRARUS за pep архив!
Звук по-настоящему классный! После многих лет проигрывания музыки на стандартных проигрывателях разных мобильных устройств - здесь вдруг появилась сценаsmile.gif Никогда не думал, что телефон может так играть.
Сообщение отредактировал брат82 - 10.1.2017, 14:03
сообщение 10.1.2017, 16:29
Из: Из мира сего
брат82,
А ты shell плеер посмотри) Лично от Vinrarus. Вот там то уж музыка такая, какая она есть... На сколько хватает "железа"
Сообщение отредактировал Programmer-tm(Мотофан.) - 10.1.2017, 16:30
брат82
сообщение 10.1.2017, 17:28
Programmer-tm(Мотофан.), Посмотрелsmile.gif Нет, это для вас, программистов. Долго пытался уразуметь, как там вообще в папки заходитьshok.gif shok.gif
Я лучше скажу спасибо VINRARUS за ZiniMOD!! Пылился себе устаревший телефончик в ящике, а тут оказалось, что он ещё 100 очков вперёд даст по некоторым параметрам современным смартфонам. Нужно искать аккумулятор под такое дело dribble.gif Но это уже другая тема.
[mgx] Rockbox Version 3.4 (100% Functional), Ставим. Обсуждаем. · Motorola ZINE ZN5, ZN5 T-Mobile · Forum
Текстовая версия Сейчас: 2.8.2025, 12:36
