6 страниц V « < 5 6
[mgx] Rockbox Version 3.4 (100% Functional), Ставим. Обсуждаем.
Offset
сообщение 30.9.2009, 12:05 Закрепленное сообщение!
Leo
Пользователь №: 126 712
RockBox
Hello everybody, I hereby present the official version of the magnificent RockBox.
Some time ago and I adapted the Douglas RockBox Beta (version 3.3) of the Rokr Z6 developed by CepiPeres, was a great application but had some bugs and problems.
Well, then, was recently released on the website of RockBox version 3.4 of this fantastic multimedia center.
Team Motocaker Team took the opportunity to upgrade the family's RockBox MOTOMAGX.
I decided to adapt and adjust to this latest version to our dear ZN5 and the result was amazing. So I'm here to share with you the new version of RockBox.
What's new in this application compared to the Beta:
-Now the application no longer needs to be closed Plugin, just press the power button (red) to close the application.
-Now we can listen to music and continue stirring in the application, we can see photos, play games, use some mini-application, do whatever we want.
-Added the game Doom within the application to play while we hear that favorite song.
-Is it possible to play videos at 25fps in MPEG format.
-Is it possible to play ATRAC3 audio files.
-Is it possible to play audio files AC3.
-Is it possible to play AAC audio files.
-System stabilized and made some adjustments.
Keyboard Configuration:
- Volume Buttons: Controls the volume.
- Smart button: Main Menu.
- Directional Up and Down: Controls the volume and menu controls.
- Directs Right: Next and Select.
- Directional Left: Backwards and Back.
- Center Button: Selects functions.
- Left Softkey: Pause and Play in Playback mode.
- Right Softkey: Stop the music / Exit (when using a plugin or game that does not run correctly).
- Red Button: Close the application.
- Green Button: Capture screen images.
The application has 3 display modes: Portrait, Landscape and Landscape II.
Images of the application:
I recommend installing it on the Memory Card.
Works perfectly in Freedom Evolution Brazil 2.0 by Junior Passos, Evo2 and Evo3 by iLove3d.
Download:
http://www.4shared.com/file/136344685/6e89...Box_ZN5_EN.html
Sorry my English.
Credits:
Motocaker Team (RockBox)
Ant-ON (SDL)
Junior Passos (Ported for ZN5)
Оригинал топик
скачать с сервера mmus СКАЧАТЬ (необходима регистрация)
Скачать с ifolder.ru
Установка RockBox 3.4 (mgx): автор мануала: EXL
1.Скачиваем сам mgx-пакет RockBox, открываем его с помощью архиватора (Я пользуюсь WinRar). Извлекаем папку RockBox в любое доступное место на жестком диске.
2. (Внимание! Телофон должен быть прошит любым пользовательским модом с поддержкой MPKGBOX)!!!
Подключаем телефон в режиме КАРТЫ ПАМЯТИ и кидаем папку RockBox в папку mpkgbox на вашей флешке. Отключаем телефон, заходим в MPKGBOX, вибираем вкладку "карта памяти", запускаем RockBox. Установка завершена!
Общая настройка:
1. Создание главного плейлиста - заходим Playlists, Create Playlist (Создаётся плейлист каталога MMC/Music/).
Просмотр и воспроизведение песен плейлиста - Playlists, View Current Playlist
2. Плеер оснащен очень удобной Базой Данных, в которой музыка из каталога MMC/Music/ сортируется на множество категорий - начиная с Исполнителя, Альбома и заканчивая Годом, Номером трека и даже первой буквой различных категорий! Создать базу можно в меню Database.
3. В плеере есть встроенный Файл-Менеджер (меню - Files), чтобы вызвать контекстное меню в нём, нужно зажать центральную клавишу джойстика.
4. Plugins - здесь сосредоточены игры(присутствует даже Doom), небольшие програмки и визуализация/заставки для плеера. Стоит отметить, что не все плагины работают корректно.
5. System - информация о телефоне и RockBox'e, установка времени сна и др.
Пользовательская настройка: (Пункт Settings)
1. Sound Settings - Здесь можно настроить звучание под себя.
Основные пункты изменяющие звук:
1.1. Stereo Width - рекомендую поставить 250% (Расширение стереобазы)
1.2. Equalizer - Сначала включаем (Enable EQ, Yes), Затем либо настраиваем сами, либо воспользуемся
предустановками (Browse EQ Presets) которые действительно меняют звук!
Совет: 1. Самое качественное звучание - настройка Best Sound Quality (На мой взгляд)
2. Самое громкое Rock Clear + Sound Settings, Limiter Preamp нужно поставить в значение 8.0 db
1.3. Limiter Preamp - Если песня тихая, изменяем значение этого параметра на большее (Например 8.0 db)
2. Playback Settings - Здесь выставляете настройки проигрывания (Повтор, Случайное воспроизведение и др.)
3. General Settings - Общие настройки плеера. Здесь можно выставить русский язык (Language)!
ВНИМАНИЕ! Чтобы русский язык отображался, он должен поддерживаться текущим шрифтом!
4. Theme Settings - Настройка тем.
4.1 Browse Theme Files - Здесь выбираем нужную Вам тему плеера.
4.2 Font - Установка шрифта плеера. (Русский язык отображается например в шрифте unifont)
4.3 While Playing Screen - Установка оболочки самого проигрывателя.
4.4 Show Icons -Настройка показа иконок
5. Manage Settings - Здесь можно сбросить все настройки плеера по дефолту, если вы где-то напортачили. (Reset Settings)
Клавиатура:
Вверх, вниз: громкость в плеере и вверх-вниз в меню.
Вправо: "Следующий трек", Удержание: "Перемотка вперед" - в плеере и выбор в меню.
Влево: "Предыдущий трек", Удержание: "Перемотка назад" - в плеере и назад в меню.
Качелька громкости: управляет громкостью в плеере. Для регулирования необходимо зажать (Длинная шкала)
Центральная кнопка джойстика: Выбор и контекстное меню при зажатии.
Левая софт-клавиша: Пауза и воспроизведение в режиме воспроизведения.
Право софт-клавиша: Стоп/выход (при использовании плагина или игры, которая не работает должным образом).
Красная кнопка: Выход из плеера.
Зеленая кнопка: Скриншот экрана.
Шрифты, поддерживающие русский язык:
11-Nimbus
13-Nimbus
15-Adobe-Helvetica
16-GNU-Unifont
19-Nimbus
cfsj-12pt
Corbel_12
Epsy+asian-12
FZXSQJ-12pt
helvR12
kaiti-14pt
msyh-12pt
msyh-13pt
myfont-12pt
nimbus+uming-14
nimbus-12
nimbus-19
Segoe_UIB_12
shaonv-14pt
simsun_ok
st
STCAIYUN-14pt
unifont
Сменить язык интерфейса в RockBox можно, зайдя в Settings, потом Theme Setings, потом Font устанавливаем - жмем Unifont, возвращаемся назад к пункту General Settings, входим там папка Language.В ней выбираем язык какой хотим.
Еще раз пользуясь случаем благодарим этих камрадов:
Ant-ON (SDL)
Сообщение отредактировал Offset - 12.11.2010, 19:17
VINRARUS
сообщение 11.1.2017, 0:34
Термоядерный
Из: Чорнобиль
Пользователь №: 211 044
Прошивка: 740 MHz: Z6 and ZN5
youtu.be/A_yQLYLiSGQ
Цитата(брат82 @ Вчера, 19:28)
* Долго пытался уразуметь, как там вообще в папки заходить
* Я лучше скажу спасибо VINRARUS
Сообщение отредактировал VINRARUS - 11.1.2017, 0:34
[mgx] Rockbox Version 3.4 (100% Functional), Ставим. Обсуждаем. · Motorola ZINE ZN5, ZN5 T-Mobile · Forum
6 страниц V « < 5 6
Текстовая версия Сейчас: 2.8.2025, 22:35
