6 страниц V < 1 2 3 4 > »
[mgx] Rockbox Version 3.4 (100% Functional), Ставим. Обсуждаем.
Offset
сообщение 30.9.2009, 12:05 Закрепленное сообщение!
Leo
Пользователь №: 126 712
RockBox
Hello everybody, I hereby present the official version of the magnificent RockBox.
Some time ago and I adapted the Douglas RockBox Beta (version 3.3) of the Rokr Z6 developed by CepiPeres, was a great application but had some bugs and problems.
Well, then, was recently released on the website of RockBox version 3.4 of this fantastic multimedia center.
Team Motocaker Team took the opportunity to upgrade the family's RockBox MOTOMAGX.
I decided to adapt and adjust to this latest version to our dear ZN5 and the result was amazing. So I'm here to share with you the new version of RockBox.
What's new in this application compared to the Beta:
-Now the application no longer needs to be closed Plugin, just press the power button (red) to close the application.
-Now we can listen to music and continue stirring in the application, we can see photos, play games, use some mini-application, do whatever we want.
-Added the game Doom within the application to play while we hear that favorite song.
-Is it possible to play videos at 25fps in MPEG format.
-Is it possible to play ATRAC3 audio files.
-Is it possible to play audio files AC3.
-Is it possible to play AAC audio files.
-System stabilized and made some adjustments.
Keyboard Configuration:
- Volume Buttons: Controls the volume.
- Smart button: Main Menu.
- Directional Up and Down: Controls the volume and menu controls.
- Directs Right: Next and Select.
- Directional Left: Backwards and Back.
- Center Button: Selects functions.
- Left Softkey: Pause and Play in Playback mode.
- Right Softkey: Stop the music / Exit (when using a plugin or game that does not run correctly).
- Red Button: Close the application.
- Green Button: Capture screen images.
The application has 3 display modes: Portrait, Landscape and Landscape II.
Images of the application:
I recommend installing it on the Memory Card.
Works perfectly in Freedom Evolution Brazil 2.0 by Junior Passos, Evo2 and Evo3 by iLove3d.
Download:
http://www.4shared.com/file/136344685/6e89...Box_ZN5_EN.html
Sorry my English.
Credits:
Motocaker Team (RockBox)
Ant-ON (SDL)
Junior Passos (Ported for ZN5)
Оригинал топик
скачать с сервера mmus СКАЧАТЬ (необходима регистрация)
Скачать с ifolder.ru
Установка RockBox 3.4 (mgx): автор мануала: EXL
1.Скачиваем сам mgx-пакет RockBox, открываем его с помощью архиватора (Я пользуюсь WinRar). Извлекаем папку RockBox в любое доступное место на жестком диске.
2. (Внимание! Телофон должен быть прошит любым пользовательским модом с поддержкой MPKGBOX)!!!
Подключаем телефон в режиме КАРТЫ ПАМЯТИ и кидаем папку RockBox в папку mpkgbox на вашей флешке. Отключаем телефон, заходим в MPKGBOX, вибираем вкладку "карта памяти", запускаем RockBox. Установка завершена!
Общая настройка:
1. Создание главного плейлиста - заходим Playlists, Create Playlist (Создаётся плейлист каталога MMC/Music/).
Просмотр и воспроизведение песен плейлиста - Playlists, View Current Playlist
2. Плеер оснащен очень удобной Базой Данных, в которой музыка из каталога MMC/Music/ сортируется на множество категорий - начиная с Исполнителя, Альбома и заканчивая Годом, Номером трека и даже первой буквой различных категорий! Создать базу можно в меню Database.
3. В плеере есть встроенный Файл-Менеджер (меню - Files), чтобы вызвать контекстное меню в нём, нужно зажать центральную клавишу джойстика.
4. Plugins - здесь сосредоточены игры(присутствует даже Doom), небольшие програмки и визуализация/заставки для плеера. Стоит отметить, что не все плагины работают корректно.
5. System - информация о телефоне и RockBox'e, установка времени сна и др.
Пользовательская настройка: (Пункт Settings)
1. Sound Settings - Здесь можно настроить звучание под себя.
Основные пункты изменяющие звук:
1.1. Stereo Width - рекомендую поставить 250% (Расширение стереобазы)
1.2. Equalizer - Сначала включаем (Enable EQ, Yes), Затем либо настраиваем сами, либо воспользуемся
предустановками (Browse EQ Presets) которые действительно меняют звук!
Совет: 1. Самое качественное звучание - настройка Best Sound Quality (На мой взгляд)
2. Самое громкое Rock Clear + Sound Settings, Limiter Preamp нужно поставить в значение 8.0 db
1.3. Limiter Preamp - Если песня тихая, изменяем значение этого параметра на большее (Например 8.0 db)
2. Playback Settings - Здесь выставляете настройки проигрывания (Повтор, Случайное воспроизведение и др.)
3. General Settings - Общие настройки плеера. Здесь можно выставить русский язык (Language)!
ВНИМАНИЕ! Чтобы русский язык отображался, он должен поддерживаться текущим шрифтом!
4. Theme Settings - Настройка тем.
4.1 Browse Theme Files - Здесь выбираем нужную Вам тему плеера.
4.2 Font - Установка шрифта плеера. (Русский язык отображается например в шрифте unifont)
4.3 While Playing Screen - Установка оболочки самого проигрывателя.
4.4 Show Icons -Настройка показа иконок
5. Manage Settings - Здесь можно сбросить все настройки плеера по дефолту, если вы где-то напортачили. (Reset Settings)
Клавиатура:
Вверх, вниз: громкость в плеере и вверх-вниз в меню.
Вправо: "Следующий трек", Удержание: "Перемотка вперед" - в плеере и выбор в меню.
Влево: "Предыдущий трек", Удержание: "Перемотка назад" - в плеере и назад в меню.
Качелька громкости: управляет громкостью в плеере. Для регулирования необходимо зажать (Длинная шкала)
Центральная кнопка джойстика: Выбор и контекстное меню при зажатии.
Левая софт-клавиша: Пауза и воспроизведение в режиме воспроизведения.
Право софт-клавиша: Стоп/выход (при использовании плагина или игры, которая не работает должным образом).
Красная кнопка: Выход из плеера.
Зеленая кнопка: Скриншот экрана.
Шрифты, поддерживающие русский язык:
11-Nimbus
13-Nimbus
15-Adobe-Helvetica
16-GNU-Unifont
19-Nimbus
cfsj-12pt
Corbel_12
Epsy+asian-12
FZXSQJ-12pt
helvR12
kaiti-14pt
msyh-12pt
msyh-13pt
myfont-12pt
nimbus+uming-14
nimbus-12
nimbus-19
Segoe_UIB_12
shaonv-14pt
simsun_ok
st
STCAIYUN-14pt
unifont
Сменить язык интерфейса в RockBox можно, зайдя в Settings, потом Theme Setings, потом Font устанавливаем - жмем Unifont, возвращаемся назад к пункту General Settings, входим там папка Language.В ней выбираем язык какой хотим.
Еще раз пользуясь случаем благодарим этих камрадов:
Ant-ON (SDL)
Сообщение отредактировал Offset - 12.11.2010, 19:17
66_ЛЁХА_99
сообщение 4.10.2009, 9:46
Пользователь №: 108 652
Модель телефона: Motorola ZN5
Прошивка: R6637 G 81 03 0ER
Тоже установил хваленый Рокбокс, в принципе нормально, Русский язык есть, куча настроек и функций.
Минусы - нереально длинная шкала регулировки звука(по-моему вообще бред 79 делений - шутка ли?) и невозможность сворачивать. Глубоко не ковырял, пока, что поверхностное знакомство)
Сообщение отредактировал 66_ЛЁХА_99 - 4.10.2009, 9:46
Mar4elo
сообщение 4.10.2009, 9:52
Пользователь №: 191 089
Модель телефона: ZN5
Прошивка: Symbiosis III
Кстати настройки звука у кого то работают? Я имею виду настройка басов и все остальное, что есть в том меню????
Entom
сообщение 4.10.2009, 10:37
Из: Крыма!
Пользователь №: 159 951
Модель телефона: iPhone 4s
Прошивка: iOS 7
Люблю Apple, уважаю Motorola.
Насчет басов - по моему эти настройки не пашут и то, что сворачивать нельзя это большой минус.
M@t@rol@4k@
сообщение 4.10.2009, 13:34
Из: УкраЇна
Пользователь №: 171 145
Прошивка: Android Pie 9
Monday - Party!
Entom, Mar4elo, Согласен.На 3 разных ушах пробовал игратся с настройками- никакого эффекта.Да и как по мне ROCKBOX играет на 30% тише,чем стандартный плеер.(после использования ROCKBOX громкость в наушниках и динамика падает на теже 30%,помогает перезагрузка.Это проверенно десятками запусков и ребутов.Кстати такое же понижение громкости дает MPlayer.)Зато управление более-менее вырисовалось,хотя пауза и стоп не на самых удобных кнопках(особенно если телефон в кармане куртки и ты на ощупь плеером управляешь).
Сообщение отредактировал M@t@rol@4k@ - 4.10.2009, 15:25
66_ЛЁХА_99
сообщение 4.10.2009, 14:05
Ага, щас проверил тоже, дохрена делений регулировки, а играет совсем тихо smile.gif Те кто его на зину портировали наверно сами не проверяли работоспособность smile.gif
сообщение 4.10.2009, 17:10
Зайдите в предустановленные установки эквалайзера - они работают!!! По крайней мере у меня unsure.gif
holyt
сообщение 4.10.2009, 17:12
Пользователь №: 193 712
Модель телефона: zn5
Эквалайзер сам не мучил, но стандартные готовы настройки значительно изменяют звучание. Так по мне достойное звучание на дефолте и Clear Rock.
Mar4elo
сообщение 4.10.2009, 17:53
Предустановленные настройки эквалайзера действительно работают, но сам настраивать, такие меню как басы, трембл и другие, когда их меняеш не влияют на звук.
Согласен с M@t@rol@4k@, что звук действительно действительно на 30 проц тише играет.
Хотя holyt, подсказал эту фичу и звук вроде бы на том же уровни и играет не плохо.
Ребята проверти на настройках эквалайзера Clear Rock, как вам звук.
сообщение 4.10.2009, 18:36
Mar4elo, влияют! Но как-то не сильно заметно
звук в clear rock отличный!
JediSamurai
сообщение 4.10.2009, 19:56
Пользователь №: 159 664
Модель телефона: Motozine Zn5
Установил плеер и настроил. Плеер ШИКАРЕН. Такого количества настроек звука даже не плеерах нету. Качество звука гораздо выше средненького плеера, тонко настраиваемый эквалайзер, и точно настраиваемая громкость. Плеер ОЧЕНЬ громкий. А если попались тихие треки - в настройках звука есть Preamp, можно добавить до 8 Дб (не считая эквалайзер).
Насчёт сворачиваний - когда я слушаю музыку, я либо еду в автобусе, либо гуляю по городу, и во время этого мне не до прочитывания сообщений или играния в игры (и то в рокбоксе много всякой всячины) так что это не будет мешать.
Насчёт стандартныз эквалайзеров - могу выделить Perfect Bass и Rock Clear. В обоих звучание хорошее, но лучше подстроить "под себя".
Mar4elo
сообщение 4.10.2009, 20:18
JediSamurai, а где там можна настроить под себя?)))
V!iT
сообщение 4.10.2009, 20:35
Из: Украина -> Мелитополь
Пользователь №: 196 457
Прошивка: Symbiosis OER
в эквалайзере - графический эквалайзер!
накручуй как хотишь))
кто знает че такое Фасонирование и Timestretch??? ))
Mar4elo
сообщение 4.10.2009, 20:59
V!iT, JediSamurai спасибо за помощь.
Проигрыватель СУПЕР!!!!!. Это одно из самых лучшие дополнение к телефону которые я видел.
Разработчика низкий поклон.
Timestretch - is the process of changing the speed or duration of an audio signal without affecting its pitch.
Я понял, какой то прикол что изменяет скорость О_0.
А где там есть Фасонирование?))
Сообщение отредактировал Mar4elo - 4.10.2009, 21:04
JediSamurai
сообщение 4.10.2009, 21:20
Насчёт Dithering и Timestretch не знаю - но это врядли полезные функции.
А если настроить Advanced Equalizer - будет почти параметрический эквалайзер. Можно настроить не только громкость по частотам, но и изменить сами частоты.
Mar4elo
сообщение 4.10.2009, 21:28
Dithering Лингво переводить как размывание аудио сигнала (для получения более естественного звучания).О_0
Фрай
сообщение 5.10.2009, 10:16
Из: Казань
Пользователь №: 13 975
Модель телефона: ROKR E2
Прошивка: R564_G_12.05.35P
если не сложно опишите процесс установки. Я распаковал RockBox ZN5 EN.mgx, у меня получилась папка RockBox, какие дальнейшие действия? спасибо
66_ЛЁХА_99
сообщение 5.10.2009, 10:25
Закинь её в папку Mpkgbox на флешке.
M@t@rol@4k@
сообщение 5.10.2009, 13:22
Из: УкраЇна
Monday - Party!
!!!Предлагаю отписыватся о рабочих настройках и т.д. clap.gif Кто что нашел рабочее в плеере!!!Также было бы неплохо написать,что конкретно делают те или иные настройки(фасонирование и т.д.)Считаю,что подобный список действительно можно будет закрепить в первом сообщении, на подобие мини-FAQ thumbsup.gif
Лично я обнаружил,что эквалайзер "Electronic" может и звучит не очень,но громкости предостаточно!Также если при выходе из плеера выставить громкость на максимум ну и применить громкий эквалайзер,то громкость не падает!Если удачно подобрать,то может немного и повысится.Для стандартных ушей довольно неплох эквалайзер "Best Sound Quality".Немного лучше басы звучат да и вообще громкость чуток выше чем на стандартном плеере.
Сообщение отредактировал M@t@rol@4k@ - 5.10.2009, 13:26
lDeNl
сообщение 5.10.2009, 13:31
Zine Master
Пользователь №: 189 506
Модель телефона: Nokia N8
Прошивка: Belle
А может ли кто то сделать мануал как этим плеером пользоваться?
ты вот M@t@rol@4k@, чето вроде этого написал в теме софта но это сообщение снесли, может тут продублируешь? Больше всего меня интересует как там язык поменять... smile.gif
1nTeRacT
сообщение 5.10.2009, 13:34
Пользователь №: 139 825
Модель телефона: MOTOZINE ZN5
Прошивка: G_81.03.0ER
незнаю что вы там про громкость говорите, но у меня он орёт очень даже сильно, чуть громче стандартного! без эквалайзера настраиал в ручную... добавил децебелы по всем частотам и всё!
lDeNl язык меня очень просто, как выше писали уже... заходишь в настройки---->темы--->шрифты, и ставишь шрифт "unifont", после этого в настройках--->главные настройки ----> язык и там ставишь русский !
Сообщение отредактировал 1nTeRacT - 5.10.2009, 13:38
V!iT
сообщение 5.10.2009, 15:22
У кого сколько в режиме слушания музыки в наушниках батарею держит????
У меня за 3 часа в наушниках,полностью села батарея!!Я в шоке!!! sport_boxing.gif
В настройках,поставил батарею на 950м/а,может это влияет?
dark-termit
сообщение 5.10.2009, 15:48
Из: Димитровград, Россия
Пользователь №: 138 157
Прошивка: Android 15
Ясно
А как громкость менять при воспроизведении?
Что-то уныло каждый раз через настройки музыки =\
сообщение 5.10.2009, 16:10
dark-termit,
holyt
сообщение 5.10.2009, 16:24
V!iT,
Частоту процессора до 133 снизь. На воспроизведение в простое частота проца никак не влияет, а вот на батарею влияет еще как.
НО при снижении частоты значительные тормоза при серфинге по меню.
Батарея в рок боксе не корректно работает, можешь на неё забить.
Скандалист
сообщение 6.10.2009, 7:39
Из: Одесса
Пользователь №: 193 051
Модель телефона: Zn5 + K750i + N70
Прошивка: Symbiosis v.3
РокБокс прекрасен!
Но у меня есть с ним небольшая, но неприятная проблема. При попытке выйти из приложения красной кнопкой, РокБокс подвисает. Свернуть Таскманов тоже не получается - телефон начинается адово тормозить и помогает только перезагрузка телефона.
Есть ли в меню Рокбокса программный выход? Или только кнопкой?
1nTeRacT
сообщение 6.10.2009, 7:56
у меня при нажатии на красную кнопку моментально выходит... всё путём... проша Magx Reloaded V1
и вопрос: уже не на одной проше замечено, понижение звука на всём фронте, рокбокс, плеер (стандартный), звонок мелодии и прочее.... раньше я убирал частоту проца и свап и всё помогало, или перезагрузка .... но это не выход.... у кого-нить была похожая проблема?!
Сообщение отредактировал 1nTeRacT - 6.10.2009, 8:01
sim_emrom
сообщение 6.10.2009, 8:25
Из: Ханты-Мансийск
Пользователь №: 195 802
Модель телефона: Spica
Прошивка: a.v.2.1
А мне это "чудо" как раз ничем не понравилось.
При выключении зависает часто, сродни Mplayer'у. Вызвать zTaskMan не получилось ни разу.
Язык переключить на русский можно без всяких Font'ов, так что не понимаю зачем в мануале всё указано на английском.
Простое видео я увидеть в нём так и не смог. Навигация по меню и папкам удобная, а вот управление самим плейером - в гробу я видал несовершенно.
Картинки 320x240 у меня открывались не на весь экран и медленновато, ну а так я не стал разбираться.
MotoDr
сообщение 6.10.2009, 9:11
Пользователь №: 197 783
Модель телефона: Atrix HD
Прошивка: пока что труп
такая ж беда... и непростое, конвертированное для телефона, не смог...
есть кто-нить, кто видео сумел посмотреть на нем ?
без воспроизведения видео как-то сей комбайн теряет привлекательность (на мой взгляд)
JediSamurai
сообщение 6.10.2009, 19:47
А вы на компьютере видео смотрите в винампе, а музыку слушаете в Media Player Classic? Сомневаюсь. Это музыкальный плеер, и настроек для музыки тут предостаточно. Картинки сдесь реализованы просто как добавочная функция (просмотреть обложки).
Какое должно быть управление? Включил выключил, поставил на паузу - снял с неё, поменял громкость качелькой. Едва ли тут могут возникнуть проблемы.
сообщение 7.10.2009, 7:31
Насчет проигрывания видео - сегодня закинул 6 файлов .mpg (25 fps) все с разными характеристиками, кодеками и др.
Ни один нормально не воспроизвелся: то нет звука, то картинка ужасно тормозит! Надо узнать у разроботчиков с какими характеристиками они воспроизводили mpg файлы
Сообщение отредактировал EXL - 7.10.2009, 7:39
66_ЛЁХА_99
сообщение 8.10.2009, 5:59
1nTeRacT,
Есть такое, по всей видимости глюк прошивки 0ER, вряд ли это можно побороть wink.gif На Симбиозисе вроде не замечаю, т.к. много что от 05R взято.
Насчет качества звука, тут все пишут разные настройки эквалайзера, я все послушал и с выключенным эквалайзером мне показалось звук, самый качественный thumbsup.gif Кстати кроме загружаемых настроек там больше ничо не работает, в общем продукт очень сырой, даже если не брать во внимание невозможность сворачивать..
Limiter Preamp ставлю 8 дб, громкость более менее как в стандартном плеере, но все равно можно было и побольше сделать. А кто-то тут сказал, что плеер очень громкий wink.gif
Сообщение отредактировал 66_ЛЁХА_99 - 8.10.2009, 6:21
Скандалист
сообщение 8.10.2009, 6:47
Из: Одесса
Мне тоже больше всего понравился режим без эквалайзеров. Чистый, естественный звук.
У меня, кстати, РоксБокс сворачивается в трей и оттуда играет.
Но зато при выходе красной кнопкой часто подвисает. Капризный продукт, да. Но зато поддержка лосслесов и скорость работы радуютsmile.gif
66_ЛЁХА_99
сообщение 8.10.2009, 6:52
Не понял, вот тут по подробнее. Каким образом он сворачивается у тебя ?
1nTeRacT
сообщение 8.10.2009, 8:45
Цитата(66_ЛЁХА_99 @ 8.10.2009, 9:59) *
1nTeRacT,
это как? я сам эквалайзер настраиваю... по частотам ! и звук у меня громче чем в стандартом плеере - это точно!
66_ЛЁХА_99
сообщение 8.10.2009, 8:58
1nTeRacT, в каком именно меню ? Я пытался настраивать, но изменений никаких, наверно просто не до конца разобрался wink.gif
1nTeRacT
сообщение 8.10.2009, 9:03
настройки-настройки звука-эквалайзер и тут либо в графическом эквалайзере настраивай, либо простые настройки, либо расширенные
я еще в настройках звука поднимаю уровень басов и высоких частот
66_ЛЁХА_99
сообщение 8.10.2009, 9:22
Тут уже писали, что настройки басов и высоких частот не работают. Я чо то не могу понять работает или нет =/ Если в простых настройках поднять громкость всех частот на 10 дб, то изменение практически незаметное, а если поставить 20 к примеру, то громкостть тоже не особо добавляется, зато динамик начинает скрипеть.
Нокиа Н95 к слову в 2 раза громче играет, я имею в виду внешний динамик smile.gif
Аста: к слову- Моторола Е398 дает покурить по громкости всем Нокиям sport_boxing.gif
Сообщение отредактировал AstaRoth - 8.10.2009, 10:07
1nTeRacT
сообщение 8.10.2009, 9:28
нет, не работает... но я так для кучи поднял smile.gifsmile.gif) но настройки в эквалайзере и по частотам 100% работают !!!!!
ну по внешнему я вообще ниче не слушаю и не сравниваю, ибо он говно ! я в наушниках проверял !
Сообщение отредактировал 1nTeRacT - 8.10.2009, 9:29
66_ЛЁХА_99
сообщение 8.10.2009, 9:33
Да в наушниках и так все громко без эквалайзера, я внешний динамик проверял. Убогая регулировка звука, ужас просто =/ Сравнил ещё со стандартным плеером, по громкости примерно одинаково, а по качеству кажется стандартный плеер по лучше звучит. Этот Рокбокс ещё настраивать надо.
Сообщение отредактировал 66_ЛЁХА_99 - 8.10.2009, 9:37
Скандалист
сообщение 8.10.2009, 9:51
Из: Одесса
Плеер сворачивается в трей при входящем звонке. Телефон начинает тормозить, долго соединяет с абонентом, а после завершения звонка воспроизведение возобновляется. К плееру можно вернуться через ТаскМан, либо продолжить копаться в телефоне, мужественно игнорируя тормоза.
В принципе, просто через ТаскМан свернуть РоксБокс тоже КАК БЫ получается. Телефон работает с рабочим столом, но картинка с плеера остается поверх статичных элементов рабочего стола. То есть, выглядит это так:
Сворачиваем приложение. Картинка работающего плеера остается на экране, но уже неработают софтовые клавиши управления плеером. Вызываем меню телефона, открываем книгу контактов - на секунду изображение плеера заменяется на меню или книгу, после чего снова любуемся картинкой плеера. Нажимаем еще что-нибудь - короткая реакция - и снова, здравствуй плеер!
Примечательно, что РокБокс продолжает играть и демонстрировать картинку даже после того как телефон выключился в течении 1-2 секунд.
[mgx] Rockbox Version 3.4 (100% Functional), Ставим. Обсуждаем. · Motorola ZINE ZN5, ZN5 T-Mobile · Forum
Текстовая версия Сейчас: 30.7.2025, 21:52
