6 страниц V « < 2 3 4 5 > »
[mgx] Rockbox Version 3.4 (100% Functional), Ставим. Обсуждаем.
Offset
сообщение 30.9.2009, 12:05 Закрепленное сообщение!
Leo
Пользователь №: 126 712
RockBox
Hello everybody, I hereby present the official version of the magnificent RockBox.
Some time ago and I adapted the Douglas RockBox Beta (version 3.3) of the Rokr Z6 developed by CepiPeres, was a great application but had some bugs and problems.
Well, then, was recently released on the website of RockBox version 3.4 of this fantastic multimedia center.
Team Motocaker Team took the opportunity to upgrade the family's RockBox MOTOMAGX.
I decided to adapt and adjust to this latest version to our dear ZN5 and the result was amazing. So I'm here to share with you the new version of RockBox.
What's new in this application compared to the Beta:
-Now the application no longer needs to be closed Plugin, just press the power button (red) to close the application.
-Now we can listen to music and continue stirring in the application, we can see photos, play games, use some mini-application, do whatever we want.
-Added the game Doom within the application to play while we hear that favorite song.
-Is it possible to play videos at 25fps in MPEG format.
-Is it possible to play ATRAC3 audio files.
-Is it possible to play audio files AC3.
-Is it possible to play AAC audio files.
-System stabilized and made some adjustments.
Keyboard Configuration:
- Volume Buttons: Controls the volume.
- Smart button: Main Menu.
- Directional Up and Down: Controls the volume and menu controls.
- Directs Right: Next and Select.
- Directional Left: Backwards and Back.
- Center Button: Selects functions.
- Left Softkey: Pause and Play in Playback mode.
- Right Softkey: Stop the music / Exit (when using a plugin or game that does not run correctly).
- Red Button: Close the application.
- Green Button: Capture screen images.
The application has 3 display modes: Portrait, Landscape and Landscape II.
Images of the application:
I recommend installing it on the Memory Card.
Works perfectly in Freedom Evolution Brazil 2.0 by Junior Passos, Evo2 and Evo3 by iLove3d.
Download:
http://www.4shared.com/file/136344685/6e89...Box_ZN5_EN.html
Sorry my English.
Credits:
Motocaker Team (RockBox)
Ant-ON (SDL)
Junior Passos (Ported for ZN5)
Оригинал топик
скачать с сервера mmus СКАЧАТЬ (необходима регистрация)
Скачать с ifolder.ru
Установка RockBox 3.4 (mgx): автор мануала: EXL
1.Скачиваем сам mgx-пакет RockBox, открываем его с помощью архиватора (Я пользуюсь WinRar). Извлекаем папку RockBox в любое доступное место на жестком диске.
2. (Внимание! Телофон должен быть прошит любым пользовательским модом с поддержкой MPKGBOX)!!!
Подключаем телефон в режиме КАРТЫ ПАМЯТИ и кидаем папку RockBox в папку mpkgbox на вашей флешке. Отключаем телефон, заходим в MPKGBOX, вибираем вкладку "карта памяти", запускаем RockBox. Установка завершена!
Общая настройка:
1. Создание главного плейлиста - заходим Playlists, Create Playlist (Создаётся плейлист каталога MMC/Music/).
Просмотр и воспроизведение песен плейлиста - Playlists, View Current Playlist
2. Плеер оснащен очень удобной Базой Данных, в которой музыка из каталога MMC/Music/ сортируется на множество категорий - начиная с Исполнителя, Альбома и заканчивая Годом, Номером трека и даже первой буквой различных категорий! Создать базу можно в меню Database.
3. В плеере есть встроенный Файл-Менеджер (меню - Files), чтобы вызвать контекстное меню в нём, нужно зажать центральную клавишу джойстика.
4. Plugins - здесь сосредоточены игры(присутствует даже Doom), небольшие програмки и визуализация/заставки для плеера. Стоит отметить, что не все плагины работают корректно.
5. System - информация о телефоне и RockBox'e, установка времени сна и др.
Пользовательская настройка: (Пункт Settings)
1. Sound Settings - Здесь можно настроить звучание под себя.
Основные пункты изменяющие звук:
1.1. Stereo Width - рекомендую поставить 250% (Расширение стереобазы)
1.2. Equalizer - Сначала включаем (Enable EQ, Yes), Затем либо настраиваем сами, либо воспользуемся
предустановками (Browse EQ Presets) которые действительно меняют звук!
Совет: 1. Самое качественное звучание - настройка Best Sound Quality (На мой взгляд)
2. Самое громкое Rock Clear + Sound Settings, Limiter Preamp нужно поставить в значение 8.0 db
1.3. Limiter Preamp - Если песня тихая, изменяем значение этого параметра на большее (Например 8.0 db)
2. Playback Settings - Здесь выставляете настройки проигрывания (Повтор, Случайное воспроизведение и др.)
3. General Settings - Общие настройки плеера. Здесь можно выставить русский язык (Language)!
ВНИМАНИЕ! Чтобы русский язык отображался, он должен поддерживаться текущим шрифтом!
4. Theme Settings - Настройка тем.
4.1 Browse Theme Files - Здесь выбираем нужную Вам тему плеера.
4.2 Font - Установка шрифта плеера. (Русский язык отображается например в шрифте unifont)
4.3 While Playing Screen - Установка оболочки самого проигрывателя.
4.4 Show Icons -Настройка показа иконок
5. Manage Settings - Здесь можно сбросить все настройки плеера по дефолту, если вы где-то напортачили. (Reset Settings)
Клавиатура:
Вверх, вниз: громкость в плеере и вверх-вниз в меню.
Вправо: "Следующий трек", Удержание: "Перемотка вперед" - в плеере и выбор в меню.
Влево: "Предыдущий трек", Удержание: "Перемотка назад" - в плеере и назад в меню.
Качелька громкости: управляет громкостью в плеере. Для регулирования необходимо зажать (Длинная шкала)
Центральная кнопка джойстика: Выбор и контекстное меню при зажатии.
Левая софт-клавиша: Пауза и воспроизведение в режиме воспроизведения.
Право софт-клавиша: Стоп/выход (при использовании плагина или игры, которая не работает должным образом).
Красная кнопка: Выход из плеера.
Зеленая кнопка: Скриншот экрана.
Шрифты, поддерживающие русский язык:
11-Nimbus
13-Nimbus
15-Adobe-Helvetica
16-GNU-Unifont
19-Nimbus
cfsj-12pt
Corbel_12
Epsy+asian-12
FZXSQJ-12pt
helvR12
kaiti-14pt
msyh-12pt
msyh-13pt
myfont-12pt
nimbus+uming-14
nimbus-12
nimbus-19
Segoe_UIB_12
shaonv-14pt
simsun_ok
st
STCAIYUN-14pt
unifont
Сменить язык интерфейса в RockBox можно, зайдя в Settings, потом Theme Setings, потом Font устанавливаем - жмем Unifont, возвращаемся назад к пункту General Settings, входим там папка Language.В ней выбираем язык какой хотим.
Еще раз пользуясь случаем благодарим этих камрадов:
Ant-ON (SDL)
Сообщение отредактировал Offset - 12.11.2010, 19:17
Mar4elo
сообщение 8.10.2009, 10:49
Пользователь №: 191 089
Модель телефона: ZN5
Прошивка: Symbiosis III
Я вообще не понимаю, разговора, о том как РокБокс воспроизводит музыку через внешний динамик??
Вы музыку через динамик слушаете?????
Я если честно, не проверял, как он там играет. И мне это даже не интересно, так как, внешний динамик у меня работает, только тогда, когда мне кто то звонить. А когда он звонить, то музыка играет замечательно.
Самое главное что РокБокс через наушниках играет ОЧЕНЬ достойно.
Аста: поддерживаю! На внешнем динамике у Зн5 музыку никак не слушают. Это уже обсуждалось. Громкость внешнего динамика вы никак не поднимите.
Сообщение отредактировал AstaRoth - 8.10.2009, 11:16
D-1c3
сообщение 8.10.2009, 18:15
Пользователь №: 150 086
Прошивка: свежая
громкость внешнего динамика- наиважнейший параметр при выбори модели телефона у школоты. нормальным людям громкости хватает- вызов не пропустишь
насчёт рокбокса
кто то орал тут что эквалайзер не сильно влияет на звучание- это не так
кто то орал тут что громкость на 30% ниже стандартного плеера и понижается на те же 30% при выходе из него. отчасти это правда, но
громкость в плеере почти такая же как в стандартном и не может быть ниже чем на 10% по отношению к стандартному. остальные случаи решаются настройкой эквалайзера.
при выходе из рокбокса громкость понижается не на 30%, а в 2-3 раза.
это решается так:
перед выходом ставьте громкость -5 тогда громкость телефона не понизится
проверено
Сообщение отредактировал D-1c3 - 8.10.2009, 18:20
66_ЛЁХА_99
сообщение 8.10.2009, 18:42
Пользователь №: 108 652
Модель телефона: Motorola ZN5
Прошивка: R6637 G 81 03 0ER
У меня Симбиозис 3, ни разу ещё не замечал понижение громкости после выхода из Рокбокса.
Насчет внешнего динамика не надо откровенную чушь писать, он очень тихий, я сравнивал с Sony Ericsson S500i и Nokia N95, зинка тише минимум раза в 2, на улице если шумно его уже не услышишь, а если он ещё в кармане или сумке лежит? По-моему это очевидно.
У меня друг на работе включает иногда музыку со своего S500, или магнитофон тащить или телефон есть разница wink.gif
Сам я с внешнего динамика не слушаю никогда, просто хотел проверить может он вообще громко играть или нет, оказалось, что не может.
И ещё мне кажется, что качество звучания в стандартном плеере лучше чем тут wink.gif
Сообщение отредактировал 66_ЛЁХА_99 - 8.10.2009, 18:46
DeshFXs
сообщение 8.10.2009, 22:15
Из: Жуковский, МО
Пользователь №: 137 130
Модель телефона: Moto X
Прошивка: LiquidSmooth
хммм, как говорите выходить из него?0_о не выходит на красную, тоесть тело выключается (ну система тела) а рок бокс работает XDDDDD
Neomoto
сообщение 9.10.2009, 5:30
Из: Белгород
Пользователь №: 72 604
Модель телефона: MotoZINE ZN5
Прошивка: sym X beta
не надо зажимать. Просто нажать на красную кнопку
Скандалист
сообщение 9.10.2009, 12:37
Из: Одесса
Пользователь №: 193 051
Модель телефона: Zn5 + K750i + N70
Прошивка: Symbiosis v.3
У меня при работающем РокБоксе звонок принимается с такими тормозами, что собеседник не дожидается соединения и кладёт трубку. У всех так?
DeshFXs
сообщение 9.10.2009, 13:05
Из: Жуковский, МО
Скандалист, пока не звонили )
Neomoto, уже все норм, просто при первом запуске он нехотел закрываться ни при нажатии ни при зажатии)
Скандалист
сообщение 9.10.2009, 19:49
Из: Одесса
Пожалуйста, протестируйте кто-нибудь, у кого есть два телефона - как быстро принимается входящий сигнал при работающем РоксБоксе.
сообщение 10.10.2009, 12:08
Скандалист,
Нормально принимается
Junior Passos
сообщение 11.10.2009, 0:34
Пользователь №: 205 960
Модель телефона: Zine ZN5
Onde estão os créditos ?????
http://www.mmus.us/forum/showthread.php?t=10800
Аста:
Credits:
Ant-ON (SDL)
first post - spoiler
На всякий случай еще раз внизу добавлю благодарности!
Сообщение отредактировал AstaRoth - 11.10.2009, 11:08
сообщение 11.10.2009, 9:58
Empréstimos no primeiro post, sob o spoiler! Muitos agradecimentos para a porta no ZN5! Desculpe para o meu Português ruim!
Stray39
сообщение 11.10.2009, 11:25
Пользователь №: 198 407
Модель телефона: MOTOZINE ZN5
Прошивка: пока не определился
установил в рер пакете при попытке запустить пишет codek failure...и тишина... стоит проша Zine Evolution v0.5
Сообщение отредактировал Stray39 - 11.10.2009, 11:41
uzHeR
сообщение 11.10.2009, 12:02
Из: Kuzbass
Пользователь №: 38 217
Прошивка: ZE0.7
у меня на последнем симбиозе тоже рер пакет на ставится
M@t@rol@4k@
сообщение 11.10.2009, 12:42
Из: УкраЇна
Пользователь №: 171 145
Прошивка: Android Pie 9
Monday - Party!
PEP-пакет ставится(по крайней мере тот,что я выкладывал).Я писал,что для того,чтоб появилось приглашение на установку нужно подождать(прилично,все таки телефон медленно такой архив распакует).Если же оно не появляется,то еще пару раз нажать на пакет.Но к сожалению мой пост потерли и этот пакет ко всем остальным присоединили.Все работает.Указанной выше ошибки не наблюдал.Хотя она уже не первый раз всплывает.Эта ошибка никак не связана с .pep или .mgx.Так что это все тут не причем.
Stray39
сообщение 11.10.2009, 16:30
M@t@rol@4k@ ты мог бы свой Рок Бокс выложить... в РЕР ...у меня то он запускается и файлы видит но не проигрывает... у меня тот что в Софте для зн5
Сообщение отредактировал Stray39 - 11.10.2009, 16:31
V!iT
сообщение 11.10.2009, 16:37
Из: Украина -> Мелитополь
Пользователь №: 196 457
Прошивка: Symbiosis OER
мог бы кто подсказать,протестить: сколько рокбокс и стандартный плеер держит часов? буду благодарен!::)
сообщение 11.10.2009, 16:45
V!iT,
RockBox - 3-4 часа беспрырывного проигрывания музыки(max volume),
Стд. плеер - у меня 7-8 часов(max volume)
Mar4elo
сообщение 11.10.2009, 16:47
У меня сегодня 2 часа проиграл и сдох. Ну, мне почему то кажется, что у меня с батарейкой что то.:(
uzHeR
сообщение 11.10.2009, 17:23
Из: Kuzbass
Прошивка: ZE0.7
как вы слушаете на макс громкости? для меня в стандратном плеере больше 2х делений же [вырезан мат] )
Junior Passos
сообщение 12.10.2009, 0:26
Muito obrigado amigo.
Neomoto
сообщение 12.10.2009, 13:24
Из: Белгород
тот что в софте и есть pep пакет от M@t@rol@4k@, читай внимательнее его посты
Entom
сообщение 12.10.2009, 16:04
Из: Крыма!
Пользователь №: 159 951
Модель телефона: iPhone 4s
Прошивка: iOS 7
Люблю Apple, уважаю Motorola.
Мне знакомый сказал, что у него на Е2 тоже после Рокбокса громкость падает: так что это паталогическое или хроническое.:smile.gif)
Аста: может я туплю-но на Е2 у рокбокса не падала громкость. Хотя я узаю eXMMS на е2 - лучше это плейера нет
Сообщение отредактировал AstaRoth - 23.10.2009, 18:05
JediSamurai
сообщение 23.10.2009, 15:05
Пользователь №: 159 664
Модель телефона: Motozine Zn5
В общем такая проблема, если выйти из рокбокса, и опять войти - то его громкость падает примерно на 20 ДБ. Помогает только перезагрузка. Даже если ставить при выходе громкость -5. Возможно ли это вылечить?
Сообщение отредактировал JediSamurai - 23.10.2009, 15:06
syberside
сообщение 23.10.2009, 23:41
Из: Новоуральск
Пользователь №: 176 082
Прошивка: ICS 4.0.4
а у всех плеер подтормаживает? ладно если чуть чуть, но у меня со свапом и на тмоб вообще ужасно работает. unsure.gif tomato.gif
сообщение 24.10.2009, 6:10
Работает отлично, не тормозит!
Пока наверное никак
NiX
сообщение 27.10.2009, 21:30
Пользователь №: 152 211
Модель телефона: e8+milestone+xt5
товарищи, подскажите, выдает ошибку Codec failure. прошивка эво0.5, ставлю через пеп пакет. как вылечить?
ink71
сообщение 30.10.2009, 19:08
Из: Республика Беларусь
Пользователь №: 103 216
Модель телефона: ZN5 t-Mobile
Прошивка: Шустрая ;)
SanchoNT
сообщение 30.10.2009, 19:38
Из: Нижний Тагил
Пользователь №: 184 870
Прошивка: 4.4.4
специально для тех у кого нет кнопки "Поиск" > https://forum.motofan.ru/index.php?act=ST&f=183&t=164808&hl=Codec+failure&view=findpost&p=1361270
читаем в самом конце поста:
Для тех у кого при попытке проиграть файл, пишет: Codec failure
Попробуйте добавить в run.sh следующую строку:
mount -o remount,rw,exec -t jfss2 /dev/mtdblock/user /ezxlocal
потом начинаем потихоньку соображать, добавляем это в run.sh и в run2.sh и какие там ещё скрипты запуска, я не помню щас на память, вобщем надеюсь сообразите
NiX
сообщение 31.10.2009, 0:07
за подсказку спасибо, но нихрена не помогло. а по поводу поиска...
в нашей ветке поиск по codec failure выдает всего две темы, эту и про сдл.
https://forum.motofan.ru/index.php?act=Search&CODE=show&searchid=29ffa1e107455bfa12b53ebf7226c5df&search_in=posts&result_type=topics&highlite=codec+failure
в обоих темах люди задавали подобный же вопрос и вообще не получили ни какого ответа.
[Mgx] RockBox Version 3.4 (100% Functional)
SDL библиотека
так вот, ремаунт в стартовый скрипт не помогает, замена либ не помогает, замена собственно кодеков на кодеки от старой рабочей версии (на всякий случай попробовал) тоже не помогает. вопрос остается открытым - как лечить?
сообщение 28.12.2009, 18:05
Темы для RockBox Портретный режим
Темы для RockBox Горизонтальный режим
Я две проверил. Идут
Как ставить:
Кидаем файлы скина в папки с одинаковыми именами.
Для портретного режима:
Содержимое папок backdrops, themes, wps - заливаем естественно в backdrops.portrait, themes.portrait, wps.portrait
Вообще тут много чего интересного можно найти) http://www.rockbox.org/
Сообщение отредактировал EXL - 28.12.2009, 18:25
Прикрепленный файл arboxWidgets_G.zip   ( 75.01 килобайт ) Кол-во скачиваний: 107
Прикрепленный файл PenPaper_GB.zip   ( 166.3 килобайт ) Кол-во скачиваний: 151
syberside
сообщение 19.1.2010, 5:30
Из: Новоуральск
Прошивка: ICS 4.0.4
а как свернуть то ситё чудо)
сообщение 19.1.2010, 7:38
Через ZTaskMan
(Свернуть всё на второй вкладке)
Сообщение отредактировал EXL - 19.1.2010, 7:39
syberside
сообщение 19.1.2010, 11:49
Из: Новоуральск
Прошивка: ICS 4.0.4
для этого должно быть включено сворачвание явы? приложения со своим сдл таск мен не сворачивает.
lpmusic
сообщение 19.2.2010, 7:04
Из: {KHABAROVSK}
Пользователь №: 153 740
Модель телефона: Korean Atrix, XT5
Прошивка: Froyo
AtrixMan =)
как его запустить под мпкж боксом? приходиться лезть на флешку скрипт запускать)
сообщение 19.2.2010, 8:21
Странный вопрос. По иконке в Mpkgbox )
Если нет иконки, проверь что папка рокбокса находиться в папке mpkgbox на карте памяти. И в файле *.cfg (называется так же как и папка) , прописан скрипт запуска в строке Exec
Сообщение отредактировал EXL - 19.2.2010, 8:26
lpmusic
сообщение 19.2.2010, 9:43
Из: {KHABAROVSK}
Прошивка: Froyo
AtrixMan =)
где я сказал про иконку?) у меня все отображаеться в мпкж боксе, но через него не запускаеться smile.gif Может из-за того, что у меня не mgx box?
сообщение 19.2.2010, 10:06
Нет разницы
lpmusic
сообщение 19.2.2010, 13:13
Из: {KHABAROVSK}
Прошивка: Froyo
AtrixMan =)
Вот, что в Rockbox.cfg
Name = RockBox
Exec = rockbox.sh
Version = 3.4
Author = Motocaker Team
Comment = Port for ZN5 by Junior Passos. Thanks Ant-ON for SDL.
Да находиться там папка)
Добавлено позже (19.2.2010, 23:19):
исправил строку exec на rockbox-portrait.sh, запустился, но не сворачивается)
JediSamurai
сообщение 23.2.2010, 14:43
А когда портируют 3,5 версию?
Lunik
сообщение 1.3.2010, 15:00
Пользователь №: 210 670
Прошивка: Symbiosis IV
Всем здрасти. А есть ли исходники этой штуки? Очень хотелось бы поменять алгоритм шафла (думаю, не только мне), могу заняться.
[mgx] Rockbox Version 3.4 (100% Functional), Ставим. Обсуждаем. · Motorola ZINE ZN5, ZN5 T-Mobile · Forum
Текстовая версия Сейчас: 1.8.2025, 15:24
