20 страниц V  1 2 3 > »
Linux Ming (jffs2 11R - firmware), Прошивка с rw на базе 11R. Версия от 16.12.2009
marcolnx
сообщение 12.11.2009, 17:31 Закрепленное сообщение!
Пользователь №: 201 733
JFFS2 11R (a1200e e a1200r)
English description is under spoiler
First: I wanted to thank tmp_do and tmr for creating a jffs2 firmware (and therefore the possibility of writing the whole system).
Second: I wanted to thank SergGG Provodnik Silent Bob dvrts and all Motofan ru users for sharing informations and help.
Starting from whiteMING2 of tmp_do (thanks to his help and his answers) I have modified and customized the firmware:
- Replaced all libraries SYStapi SYSqtapp SYSjava SYSdb etc. (11R)
- Flip closed options
- Inserted and placed some missing applications or not fully working (BCR - Sync - Standard Viewer - Photo Editor)
- Added binaries (ldd - showQ - ezxpopup - etc.), so bash3 busybox strace ...
- Added ringtones, pictures, skin, mystuff, etc.
- Radio works without headset
- Calendar in the main screen shows the first appointment in 24 hours
- 2 new skins (red and white)
- Pre-installed applications: ekonsole, Assistant of Amin (reboot, pkg installer, screenshot, swap manager, hacker, mystuff, unrar unzip, ecc.), Skin Installer, Backup Restore Now, SysInfo, ZEditor (can see hidden folder and edit hidden files), PicselEdit (there is also the standard)
- 2 java applications: platinumsudoku - ICQ Jimm
- Language: English - Russian - Ukrainian (VR English - Russian)
- Fixed all profile (Silent, Vibrate, ecc.)
- ext2 ext3 support with modules.dep
- Screen3 works
- Support autorun.txt under SD (/mmc/mmca1/)
- Fingerpad white and foxalarm (voice russian)
- added Processor (underclock and overclock at 520)
- added pictures
- added skin blue (Sens theme)
- added, replaced for Camera_R541L7_G_11.10.11R
- added, replaced for libezxmime.so.1.0.0 thanks a lot Silent Bob
- added pftpd (pure-ftpd and pure-ftpwho) thanks a lot fordalulz
- added, replaced ro rw
- added new init script (so also startup1.txt, startup.txt for SD and startup2.txt for phone) and a lot of stuff for mount --bind sounds, animation, volume, font, ecc. without write directly for new user)
p.s.: I have attached folder MCleaner and MotoID, extract and install if you want.
Generally if something does not like (you can write in the whole) you can edit yourself.
Hopefully you'll try it and have fun.
Link:
Link for download
About swap:
If we need 32mb swap just extract the folder .bin from here and put in the root of SD:
http://www.4shared.com/file/84649109/509f6517/Swap_SD.html
You can easy activate - deactivate with Assistant and check with SysInfo or eKonsole
Прикрепленное изображениеПрикрепленное изображение Прикрепленное изображениеПрикрепленное изображение
Перевод на русский dvrts
Прежде всего хотелось бы поблагодарить tmp_do и tmr за создание прошивок на базе jffs2 (и как следствие, возможность модифицирования всей ФС телефона без перепрошивки (read-write:)
Также хотелось бы поблагодарить SergGG, Provodnik, Silent Bob, dvrts и всех пользователей motofan.ru за информацию и помощь
По сравнению с WhiteMING2 (автор tmp_do) прошивка изменена, улучшена и дополнена:
- Заменены все библиотеки SYStapi SYSqtapp SYSjava SYSdb т.д. (11R)
- Расширенное меню при закрытом флипе
- Добавлена и изменены некоторые приложения, отсутствующие или некорректно работающие ( BCR - Синхронизация - Стандартный Viewer - Photo Editor)
- Добавлены бинарники (ldd - showQ - ezxpopup - и т.д.), so, bash3, BusyBox, strace ...
- Добавлены рингтоны, картинки, скины, изменен mystuff и т.д.
- Радио работает без гарнитуры
- Календарь на главном экране отображает первое задание в 24 часа
- 2 скина (красный и белый)
- Предустановленные приложения: ekonsole, Amin Assistant (перезагрузка, установщик pkg, swap, javahacker, mystuff, распаковщики архивов, и т.д.), Skin Installer, Backup Restore, SysInfo, ZEditor (можно увидеть скрытые папки и править скрытые файлы), PicselEdit (есть стандартный)
- Язык: английский - русский - украинский (VR английский - русский)
- Исправлены все звуковые профили (бесшумный, вибро, и т.д.)
- Screen3 работает
- Поддержка autorun.txt (/mmc/mmca1/autorun.txt)
- Фингерпад с кириллицей
- Foxalarm взамен стандартного будульника
- Куча мелких изменений
- Добавлено приложение для разгона процессора (до 520 MHz)
- Добавлены изображения
- Синий скин (Sens)
- Бинарники для камеры от _R541L7_G_11.10.11R
- Изменен libezxmime.so.1.0.0
- Добавлено приложение для ftp
- Изменены бинарники для ro rw
- Дополнен авторан (startup1.txt, startup.txt для карты памяти и startup2.txt для памяти телефона) и дополнительные папки для mount --bind (звуки, анимация, volumetable, шрифты, и т.д. без необходимости переходить в read-write ФС)
Ссылка
Для установки свапа - скачать файл и положить в корень карты памяти
Для изменения режимов ro - rw - в консоли выполнить
CODE
rw
CODE
ro
Сообщение отредактировал marcolnx - 10.1.2010, 9:33
Прикрепленный файл Howto_jffs2_new_firmware_save_data.txt   ( 1.17 килобайт ) Кол-во скачиваний: 948
Прикрепленный файл MCleaner_MotoID.zip   ( 337.61 килобайт ) Кол-во скачиваний: 666
Прикрепленный файл jffs2_kernel_sdhc.zip   ( 3.91 мегабайт ) Кол-во скачиваний: 1308
vitalsh
сообщение 12.11.2009, 19:57
Пользователь №: 204 072
Модель телефона: a1200
есть тут суи ? судя по тому что основа whiteMING2
marcolnx
сообщение 12.11.2009, 22:03
ArD smile.gif thanks a lot.
About SUI no, but you can easy add fingerpad etc. you can write in the whole.
This is just a starting point.
I added now my language, itap, replaced keyboard map about accented, added fingerpad, all directly smile.gif
The firmware it's only AP (my BP it's 13R), I tested in my a1200e and a1200i.
I tested a lot of applications and working fine (also mms and sms about cyrillic).
Thank you dvrts
I entered russian VR and left russian settings for telephone operators.
Soundmanager it's 11R (about late calls), if it works better 14R I will change it (directly).
I have not included fingerpad because he had a different color from the standard keyboard (qwerty or maybe you want a semi-qwerty), but it is very easy to insert it.
Also screen3, applications it's just a starting point, we are so expert and we can change or add.
Сообщение отредактировал dvrts - 17.12.2009, 3:16
dvrts
сообщение 13.11.2009, 11:20
Из: Lviv
Пользователь №: 162 099
marcolnx,
what about Cyrilic SMS? Do they work correctly?
Last FW, what you gave me had incorrect sending of Cyrilic SMS - only
, excluding
абвгд
marcolnx
сообщение 13.11.2009, 12:19
dvrts
sms and mms (send and receive) working fine also for cyrillic (I tested), tapisrv and libs 11R showing correctly cyrillic smile.gif
OFN
сообщение 14.11.2009, 1:07
Из: zp.ua
Пользователь №: 182 112
Модель телефона: XT 1585
Прошивка: 6.0
Вопросы:
1. При откате на 14-ю или на 16-ю- есть ли проблема с аккумом?
2. качество камеры?
3. В аналогичной более рнней прошивке от Марколинкс упоорно не отправляются и не получаются ММСки . А здесь?
4. фингерпад?
5. можно ли восстанавливать контакты от 14-й через MPT ( main. db от 14-й совместима ?)
Сообщение отредактировал OFN - 14.11.2009, 2:16
marcolnx
сообщение 14.11.2009, 8:46
Dvrts
Thank you for your translation (you could place in the first place?). Your help is important. smile.gif
OFN (hi smile.gif )
2- camara and video it's good (silent options, night mode, ecc.)
3- sms and mms (send receive) working fine also for cyrillic (I can show the screenshot of sms mms about my try)
4- Fingerpad not added (I added now in my edit firmware with accented letter). It's easy add (if you wish I can show with images or explain). 2 commands in ekonsol or telnet session.
I maked a backup of original libfingerpad.so.1.0.0 and libnumberboard.so.1.0.0 (/usr/lib/ezx/lib/inputmethods) and replaced. After maked a folder fpad with the files inside (/usr/data_resource/preloadapps/qtapps), reboot smile.gif
5- I restored all my conctacts, sms,mms,calendar event with backuprestorenow (easy and quick), so I think no problem about compatibility.
Firmware keep prolad java: Platinum Sudoku and Jimm-added ICQ
Volume from wm1 (good)
Tested a lot of native applications and java(MotoID works fine).
By
Сообщение отредактировал marcolnx - 14.11.2009, 9:31
Прикрепленный файл 11R_jffs2_fpad.zip   ( 140.97 килобайт ) Кол-во скачиваний: 352
dvrts
сообщение 14.11.2009, 11:09
Из: Lviv
Вопросы:
marcolnx
, are there some troubles with battery in flashing 14r or 16r after your FW?
Добавлено позже (14.11.2009, 13:11):
OFN,
у меня не было (I haven't that)
Miroschnik
сообщение 14.11.2009, 12:08
Пользователь №: 65 070
Модель телефона: Nokia 5800+LGP500
Ребята! Для меня важна работоспособность SoftМanager, FBreader, MCleaner, Foxalarm. Как они ведут себя на этой прошивке?
runtime
сообщение 14.11.2009, 12:32
Из: Омск
Пользователь №: 168 421
Модель телефона: A1200e
Прошивка: JFFS2
У меня воостановление данных не сработало, зато получилось перебросить контакты через Личные данные. Правда сработало не с первого раза.
marcolnx
сообщение 14.11.2009, 12:53
Thank you dvrts for translation.
No problem for the battery.
The firmware will flash only part of the AP.
I tried starting from BP 13R 14R (A1200e) and BP C2 tarck (a1200i). No problem.
Miroschnik
I don't know about these applications (you can easy try preloading and check with strace ldd or just installing before in SD)
runtime
runtime
сообщение 14.11.2009, 13:38
Из: Омск
Прошивка: JFFS2
MPT backup/restore doesn't work, but it is possible to synchronize contacts.
Добавлено позже (14.11.2009, 19:48):
Actually backup worked from the 5 or 6 try...
dvrts
сообщение 14.11.2009, 13:56
Из: Lviv
Miroschnik,
У меня все работает
Добавлено позже (14.11.2009, 16:02):
Да. Между прочим, мне кажется что проша на базе WM1. Ибо АР от 1200 а не 1600
By the way, I think that this FW is WM1-based, not WM2, in cause of AP is from 1200, not from 1600
marcolnx
сообщение 14.11.2009, 14:57
Hi,
I never used MPT.
I do backup backuprestorenow.
Regarding the firmware WM1 problems with modemlauncher (startup) and sending MMS.
I did flash with WM2 and replaced everything (so now AP 11R).
Fanat1k128
сообщение 14.11.2009, 15:21
Пользователь №: 203 967
Excuse for a stupid question but how on this insertion to do autorun?smile.gif write to whom not difficultly please stupidly text, for starmenu, I already all themes about autoruns has see ='(
_____________________________________________________________________
Извините за тупой вопрос, но как на этой прошивке делать авторан?smile.gif напишите кому не трудно пожалуйста тупо сам текст, для старт меню, я уже все темы про автораны просмотрел ='(
Сообщение отредактировал Fanat1k128 - 14.11.2009, 15:21
dvrts
сообщение 14.11.2009, 16:10
Из: Lviv
Авторан классический. В корень карты памяти autorun.txt
Garm
сообщение 14.11.2009, 19:36
Из: Морозовск
Пользователь №: 48 276
Прошивка: Black Ming 3b
Если это 11R... что насчет виджетов?
If this 11R... what about widgets?
dvrts
сообщение 14.11.2009, 21:43
Из: Lviv
Nothing. I dont't think that only platform must support widgets. By the way, it looks like a hybrid, but not a stock platfrorm
Short bugreport:
- swap doesn't work
- McLeaner doesn't block calls, only SMS
Swap trouble has been repaired as
/mmc/mmca1/.bin/swap/
and activation using Assistant
How to solve a problem with McLeaner?
Сообщение отредактировал dvrts - 14.11.2009, 21:57
marcolnx
сообщение 15.11.2009, 20:05
Sorry for the delay but some problems (my wife is expecting a child).
About widgets I've never tried (I think it drains the battery faster).
About MCleaner, I never used but I did quickly pkg (I had the firmware epinter SD)
# tar czvf MClenaer.pkg MCleaner/ (enter)
After I noticed a small problem:
insmod is a link to busybox but we need to change the permissions.
Do exactly this:
insmod download attachment and put it in SD (also added MCleaner.pkg).
Telnet session or ekonsole:
#rw (Enter)
#cd /sbin/ (Enter)
#rm insmod (Enter)
#cp /mmc/mmca1/insmod /sbin/ (Enter)
#chmod u+s insmod (Enter)
#chmod g+s insmod (Enter)
check with ls -l /sbin
insmod need -rwsr-sr-x
Сообщение отредактировал marcolnx - 15.11.2009, 20:32
OFN
сообщение 16.11.2009, 5:19
Из: zp.ua
Прошивка: 6.0
dear Marco!
ie: on top of your firmware you can flash the epinter's patch for sdhc?
PS:good luck!
Сообщение отредактировал OFN - 16.11.2009, 5:20
marcolnx
сообщение 16.11.2009, 6:23
"on top of your firmware you can flash the epinter's patch for sdhc?"
At this time no.
Tmp_do told me that in WM2 kernel and rootfs from qtopia (and read the section tmr U3 Firmware understand).
So far I have never compiled the kernel from source (for A1200).
It would be really nice if they did this tmp_do or advanced users (SDHC support).
Not have much time now (using 2GB SD) but I would be happy to learn. smile.gif
Hanggard
сообщение 16.11.2009, 7:51
Пианист
Из: Riga
Пользователь №: 92 516
Прошивка: iOS 14.1
Прост-рок))
marcolnx,
thanx for you FirmWare, I've been wanting to do the same thing, but was busy...
What about known bugs? Are They in this FW? And what are its main differences from Novin's FW?
marcolnx
сообщение 16.11.2009, 8:55
I have not found any bugs.
Differences with Novin's firmware:
- This is jffs2 firmware and you can change everything (Novin standard firmware)
- Arabic keyboard, picseledit not working for Russian (2 missing files), no completely commands for bash (telnet), lacking Ukrainian, Russian VR lacks, lack screen3, fingerpad not russian, missing important bins (ldd - strace), etc.
In this firmware everything worked well (Russian keyboard, Russian and Ukrainian language, picsel standard and picseledit working for Russian Ukrainian, bash3, busybox, command completion, etc.).
I preinstalled some applications, but you can easily add more.
Just modify 3 files: SysRegistry and SysMenuTree (/usr/data_resource/preloadapps/) UserMenuTree (/ezx_user/download/appwrite/am/) and add the folder with the application in /usr/data_resource/preloadapps/qtapps/
Each user can customize the firmware directly without remaking the flash (add or edit picture, ringtone, keyboard, etc.).
Сообщение отредактировал marcolnx - 16.11.2009, 9:57
Hanggard
сообщение 16.11.2009, 10:32
Пианист
Из: Riga
Прошивка: iOS 14.1
Прост-рок))
marcolnx, ammmm...
How I can setup and up USB-Net? I need samba by usb, but I haven't found any soft for this in your FW.
Добавлено позже (16.11.2009, 17:38):
I have installed some programs, but I didn't find its in menu after reboot!! WTF?
marcolnx
сообщение 16.11.2009, 12:10
Hi Hanggard,
Telnet and Samba start in automatic from modem to usb net (under win telnet 192.168.16.2) (samba win file manager \\192.168.16.2\) you don't need soft for this.
I tested a lot of applications (pkg) also maked myself pkg with mobile starting from a folder (Mcleaner), now also tested lightsensord.pkg
Tell me about the name of .pkg (I will test for you).
p.s.: Try also to rename pkg -> mpkg (firmware has support for mpkg)
Сообщение отредактировал marcolnx - 16.11.2009, 16:14
OFN
сообщение 17.11.2009, 2:36
Из: zp.ua
Прошивка: 6.0
Впечатленя от прошивки за день:
Backup осуществился успешно, восстановились без проблем контакты, СМС, профили интернета, зaкладки браузера, электронная почта. Делал backup Софт Ассистентом русс ( последним билдом с мотофана), а восстанавливал - предустановленным Суперассистентом от Амина.
Без проблем заработали установленные ранее на карту памяти FB Rider, XP Tools,File Explorer( что ОЧЕНЬ обрадовало и очень облегчает жизнь)
Не заработал и отказался устанавливаться по новой Memext ("CВАП- мастер").
( Если часто пользоваться режимом "Карта памяти", он бывает удобен).
Я перепрошивал телефон с предварительно вынутой картой памяти (по аналогии с Ирис smile.gifsmile.gif
Когда вставил флешку обратно и зашел в файловую систему через Файл Эксплорер, оказалось. что у меня есть не только mmca1. но еще и mmca2( пустая и ничего не весящая). ОДНАКО...
Возник вопрос сразу же: что делать с софтом, портированным с E6, где должна находиться здесь библиотека для совместимости?
Когда в первый раз включал и потом выключал Скрин 3, телефон немножечко взбесился - то зависал, то дергался.
Потом успокоился.
Камера радует.
Прошивка оставляет приятные ощущения. Отклик быстрее чем на 14R , удобно расширенное меню при закрытом флипе ( только я не понял, как работает при закрытом флипе пункт меню "контакты"? Нажимаю - ничего не происходит, открываю флип - оказывается, открылся раздел "контакты" вкладка "все". Смысл? )
Но самое неожиданное ( просто надо было предупредить, а то для начинающего это шок):
Кириллической раскладки почему то нет вообще - только английская, цифоровая и рукопись.
Хотел прошиться обратно, но RSD Lite почему то перестал переводить телефон во флеш- мод.
( это не есть проблема, можно и вручную его перевести, но это есть симптом)
Конечно, данную прошивку можно модифицировать вручную, даже без телнет- подключения к компу, тем более раз уж установились и работают File Explorer и XPTools ( кстати: для такой "открытой" прошивки логично предустановить расширенный файл менеджер - тот же File Explorer, надеюсь, у меня это получится. Хотя конечно, настоящему линуксоиду должно хватать консоли smile.gifsmile.gif
Вопрос: как теперь мне дорусифицировать эту прошивку, приделать русские клавиатуру и фингерпад?
И, кстати, все таки: почему прошивка у меня оказалась без русско- украинской клавиатуры?...Библиотеки libezxkeyboard.so ,libezxkeyboard.so.1, libezxkeyboard.so.1.0 ,libezxkeyboard.so.1.0.0 находятся у меня в /usr/lib/ezx/lib/inputmethods . Там же находятся библиотеки libfingerpad.so, libfingerpad.so.1 ,libfingerpad.so.1.0 ,libfingerpad.so.1.0.0. Файл russian.kbd есть и находится в /usr/language/inputmethods . ЧТО НЕ ТАК?
Скачивал я прошивку отсюда, с мотофана.
Может быть, некорректно пошел процесс прошивки? Вроде внешне все было спокойно.
Хотя медленнее чем обычно.
Кто нибудь шил ее поверх 14 R F6, кроме меня?
Сообщение отредактировал OFN - 17.11.2009, 3:06
Hanggard
сообщение 17.11.2009, 3:27
Пианист
Из: Riga
Прошивка: iOS 14.1
Прост-рок))
Клава русская есть, в английской есть русский флажок, его нажимаешь и вот она, русская.
Юзай свап в виде блочного устройства
Это повелось еще со времен Силент-Боба и вайтминга
X3 (хотелось бы знать)
Выбрал при закрытом флипе контакты - нажми кнопочку "-" (ну, которая "сделать тише"). Откроется твой справочник, в нем уже можно выбирать контакт и звонить ему, выбрав номер.
Я шил поверх Сайлент Боба (16R), но до этого у меня была 14R. В принципе разницы нет.
Камера радует.
+1
ОДНАКО...
+1...
marcolnx,
Hallelujah, i made this, yabbadabbadoooo!!:) Thanx for your support smile.gif
This file I can't install: Install error: invalid package (mpkg). If I change extension to pkg - it installs, and ask me "reboot menu?" - I answer - yeah. But after reload menu - program not appears in menu. And CardRegistry file has no mention of just installed program...
(remove .zip extension)
Прикрепленный файл xptools.pkg.zip   ( 485.44 килобайт ) Кол-во скачиваний: 388
Сообщение отредактировал Hanggard - 17.11.2009, 4:16
OFN
сообщение 17.11.2009, 4:26
Из: zp.ua
Прошивка: 6.0
Да в том то и дело, что У МЕНЯ НЕТ ЭТОГО ФЛАЖОЧКА! У меня вместо него "au сдвумя точками сверху. и открывается при нажатии панель всевзможных букв со значками - франко- чешско- турецкая панель какая то mad.gif
обзательно, Просто хочу понять, почему на всех прошивках это нехитрое сооружение работает. а зедсь нет.
Так это же вроде бы и есть некоторым образом вайтминг
Поскольку тут можно ничего не перепрошивать, может быть ее прост положить руками туда, где она лежит в у Сайлент Боба и в Блекдаймнде?
Поупражнялся - таки открваются контакты ( "все").Прикол. Спасибо большое.
Сообщение отредактировал OFN - 17.11.2009, 4:27
runtime
сообщение 17.11.2009, 4:46
Из: Омск
Прошивка: JFFS2
Also couldn't install foxalarm.
Foxalarm
OFN
сообщение 17.11.2009, 4:48
Из: zp.ua
Прошивка: 6.0
Вот именно так у меня и НЕ устанавливался Мemext : Суперассистент писал, что установка прошла успешно, предлагал перезагрузить меню.делал вид. что его перезагружает. но програ не появлялась в меню. в CardRegistry не было никакого упоминания о ней, и обьем занятой памяти тоже не изменялся.
File Explorer и XPTools у меня заработаи только потому, что уже были установлены ранее.
У меня такое впечатление, что предустановленный Суперассистент от Амина просто не работает - в смысле не работает как установщик нативого софта. Бекап он все таки осуществил у меня. Поэтому Софт ассистент рус на флешке я не убираю пока.
Мегаланчер, который был у меня на флешке. кстти- толж заработал: проводник. консоль, системная информация.
Надо проверить Ява хакер.
Тут же можно убрать руками предустановленный Смартассистент и поставить более новый и рабочий.
Толко я не понимаю еще, гд что.
Добавлено позже (17.11.2009, 7:01):
Ура! у меня таки установилась нативная прога - ThemeColor, установилась предустановленным Суперассистентом от Амина.
Чем она отличалась от тех, которые у мня не устанавливались этим "ассистентом"?
На первый взгляд =- тем. что у нее были заполнены поля "Описание", "Поставщик", "версия".
Может, этот Суперасистент ВОТ ТАКОЙ.....
не знаю, извините . Все проги, которые им не устанавливались, на предыдущей прошивке прекрасно усанавливались другими версиями Смарт Асс. С версией Амина я раньше не связывался.
Сообщение отредактировал OFN - 17.11.2009, 5:01
dvrts
сообщение 17.11.2009, 5:45
Из: Lviv
Насчет свапа. Почему проблемы возникают от нежелания читать маны?
В шапке есть ссылка на свап-файл. Файл бросаем в папку .bin в корне карты, идем в Суперассистент и активируем. Всего-то
Hanggard
сообщение 17.11.2009, 5:56
Пианист
Из: Riga
Прошивка: iOS 14.1
Прост-рок))
Caif, less than 1 second
marcolnx, I have old installed (in my mmc) Softmanager program and I like to install soft by this. But it displays a squares instead of an russian text... It is a problem in font?
OFN
сообщение 17.11.2009, 7:04
Из: zp.ua
Прошивка: 6.0
При чем тут чтение или нечтение манов? Читал. Но это другое решение. похожее. но другое. Я часто пользуюсь режимом Масс Сторэдж, и мне приходитс часто отключать свап.
Мемекстендом это делать значительно проще. чем СмартАссистентом версии Амина. Один клик пророще. чем 4.
Второе: при использовании Смартассистента свап файл болтается в корне флешки, вместе со всем остальным "цивильным "контентом, а при испоользовании мемекстенда он спр\ятан от глаз подальше в скрытую папку .system
Это мелочь, но это другая идеология. Как МакОс и Линукс.
Есть разница между использованием свапа как блочного устройства и использованием свапа как файла. Но между разными способами использования свапа как файла разница непринципиальная.
Марко ИМХО предложил именно такой подход- через СмартАссистент просто потому что он привык к СмарАссистенту, Можно у него спросить- и спрошу. smile.gif)
И он не объяснял, почему это принципиально нельзя использовать на его прошивке Мемекстенд.
То же самое. Свап как файл. а не как блочное устройство.
Hanggard
сообщение 17.11.2009, 7:44
Пианист
Из: Riga
Прошивка: iOS 14.1
Прост-рок))
OFN, скажу только одно - свап в виде блочного устройства:
1) Обращение идет через родной драйвер swapfs, а не через fat-driver
2) При подключении в режиме mass storage - свап не теряется, т.к. обращение к нему идет в другой раздел, а /dev/mmca1 будет продолжать успешно монтироваться в режиме флешки.
marcolnx
сообщение 17.11.2009, 10:21
thanks a lot for testing.
About pkg mpkg I'm testing.
There are some setting to do.
I replaced some bin (/bin) like kill, tar, basename, sed (before was link to busybox).
Lightsensord need kill bin.
Now I installed xptools.pkg attached as mpkg and also installed starting from folder xptools and doing a pkg.
Both work.
About language try adding ezx_SoftManage_lang.cfg and also ezx_SysSetup_lang.cfg (thanks a lot Garm). I have not inserted (I did not know what was it).
Please tell me about russian or ukrainian keyboard or about fingerpad (we can replace also iconres.ezx editing with motoskin ezxcodec and replace keyboard map).
I have a A1200e with the original settings and I'm updated with your changes or problems you encounter.
If you want I try to add foxalarm or fingerpad Russian Ukraine.
Let me know and thanks for your work.
When we have fixed all the problems will update the firmware (if you want to do it no problem).
Unfortunately I can not understand Russian, so thanks for the tips.
dvrts
сообщение 17.11.2009, 12:25
Из: Lviv
Who wants english/russian/ukrainian fingerpad on this fw?
I made the next:
1. telnet on 192.168.16.2, then in console
rw
2.
\usr\data_resource\preloadapps\qtapps\
here we put a folder fpad (in attachment fpad from SergGG, great thanks for him)
3.
\usr\lib\ezx\lib\inputmethods\
here we put libraries from attachment
4. reboot
OFN
сообщение 17.11.2009, 12:42
Из: zp.ua
Прошивка: 6.0
ППКС.
Вот,собираюсь себе в ближайшее впемя смонтировать полноценный блочный свап.Одна только проблема -у меня нечем флешку форматнуть под это дело,буду благодарен,если кто поможет с прогой.
ПО ТЕМЕ: слава Богу, после того,как перепрошился по новой той же FW от Марко,все наладилось. Первый раз я просто недопрошился.Перепрошился на другом компе,переставил драйвера,новые.На этот раз все прошло по другому.Телефон пришлось вручную переводить в бут режим,потомна 100%рсд лайт попросил меня вручную включить телефон,сама прошивка проходила более динамично,телефон издавал звуки,как и положено, все было быстрее раза в полтора.Теперь все работает.
есть русская клавтатура тамгде должна быть, нет вылетов при включении скрин 3.Жизнь налаживается.Респект Марко.Носкины я теперь ставить боюсь smile.gif:)
dvrts
сообщение 17.11.2009, 12:53
Из: Lviv
я использую ТОЛЬКО linux дистрибутивы. приложение gparted
Miroschnik
сообщение 17.11.2009, 14:24
Пробум: Paragon particion magik или Acronis disk direktor. За правильность английской транскрипции не ручаюсь
dvrts
сообщение 17.11.2009, 19:29
Из: Lviv
Paragon partition manager
Acronis disk director
Linux Ming (jffs2 11R - firmware), Прошивка с rw на базе 11R. Версия от 16.12.2009 · Motorola ROKR E6, E6e, E6tv, MING A1200, A1200i, A1200e, A1200r, A1200w, A1600 · Forum
Текстовая версия Сейчас: 3.8.2025, 15:54
