Linux Ming (jffs2 11R - firmware), Прошивка с rw на базе 11R. Версия от 16.12.2009
marcolnx
сообщение 12.11.2009, 17:31
Пользователь №: 201 733
Модель телефона: a1200e a1200i
Прошивка: jffs2
JFFS2 11R (a1200e e a1200r)
English description is under spoiler
First: I wanted to thank tmp_do and tmr for creating a jffs2 firmware (and therefore the possibility of writing the whole system).
Second: I wanted to thank SergGG Provodnik Silent Bob dvrts and all Motofan ru users for sharing informations and help.
Starting from whiteMING2 of tmp_do (thanks to his help and his answers) I have modified and customized the firmware:
- Replaced all libraries SYStapi SYSqtapp SYSjava SYSdb etc. (11R)
- Flip closed options
- Inserted and placed some missing applications or not fully working (BCR - Sync - Standard Viewer - Photo Editor)
- Added binaries (ldd - showQ - ezxpopup - etc.), so bash3 busybox strace ...
- Added ringtones, pictures, skin, mystuff, etc.
- Radio works without headset
- Calendar in the main screen shows the first appointment in 24 hours
- 2 new skins (red and white)
- Pre-installed applications: ekonsole, Assistant of Amin (reboot, pkg installer, screenshot, swap manager, hacker, mystuff, unrar unzip, ecc.), Skin Installer, Backup Restore Now, SysInfo, ZEditor (can see hidden folder and edit hidden files), PicselEdit (there is also the standard)
- 2 java applications: platinumsudoku - ICQ Jimm
- Language: English - Russian - Ukrainian (VR English - Russian)
- Fixed all profile (Silent, Vibrate, ecc.)
- ext2 ext3 support with modules.dep
- Screen3 works
- Support autorun.txt under SD (/mmc/mmca1/)
- Fingerpad white and foxalarm (voice russian)
- added Processor (underclock and overclock at 520)
- added pictures
- added skin blue (Sens theme)
- added, replaced for Camera_R541L7_G_11.10.11R
- added, replaced for libezxmime.so.1.0.0 thanks a lot Silent Bob
- added pftpd (pure-ftpd and pure-ftpwho) thanks a lot fordalulz
- added, replaced ro rw
- added new init script (so also startup1.txt, startup.txt for SD and startup2.txt for phone) and a lot of stuff for mount --bind sounds, animation, volume, font, ecc. without write directly for new user)
p.s.: I have attached folder MCleaner and MotoID, extract and install if you want.
Generally if something does not like (you can write in the whole) you can edit yourself.
Hopefully you'll try it and have fun.
Link:
Link for download
About swap:
If we need 32mb swap just extract the folder .bin from here and put in the root of SD:
http://www.4shared.com/file/84649109/509f6517/Swap_SD.html
You can easy activate - deactivate with Assistant and check with SysInfo or eKonsole
Прикрепленное изображениеПрикрепленное изображение Прикрепленное изображениеПрикрепленное изображение
Перевод на русский dvrts
Прежде всего хотелось бы поблагодарить tmp_do и tmr за создание прошивок на базе jffs2 (и как следствие, возможность модифицирования всей ФС телефона без перепрошивки (read-write:)
Также хотелось бы поблагодарить SergGG, Provodnik, Silent Bob, dvrts и всех пользователей motofan.ru за информацию и помощь
По сравнению с WhiteMING2 (автор tmp_do) прошивка изменена, улучшена и дополнена:
- Заменены все библиотеки SYStapi SYSqtapp SYSjava SYSdb т.д. (11R)
- Расширенное меню при закрытом флипе
- Добавлена и изменены некоторые приложения, отсутствующие или некорректно работающие ( BCR - Синхронизация - Стандартный Viewer - Photo Editor)
- Добавлены бинарники (ldd - showQ - ezxpopup - и т.д.), so, bash3, BusyBox, strace ...
- Добавлены рингтоны, картинки, скины, изменен mystuff и т.д.
- Радио работает без гарнитуры
- Календарь на главном экране отображает первое задание в 24 часа
- 2 скина (красный и белый)
- Предустановленные приложения: ekonsole, Amin Assistant (перезагрузка, установщик pkg, swap, javahacker, mystuff, распаковщики архивов, и т.д.), Skin Installer, Backup Restore, SysInfo, ZEditor (можно увидеть скрытые папки и править скрытые файлы), PicselEdit (есть стандартный)
- Язык: английский - русский - украинский (VR английский - русский)
- Исправлены все звуковые профили (бесшумный, вибро, и т.д.)
- Screen3 работает
- Поддержка autorun.txt (/mmc/mmca1/autorun.txt)
- Фингерпад с кириллицей
- Foxalarm взамен стандартного будульника
- Куча мелких изменений
- Добавлено приложение для разгона процессора (до 520 MHz)
- Добавлены изображения
- Синий скин (Sens)
- Бинарники для камеры от _R541L7_G_11.10.11R
- Изменен libezxmime.so.1.0.0
- Добавлено приложение для ftp
- Изменены бинарники для ro rw
- Дополнен авторан (startup1.txt, startup.txt для карты памяти и startup2.txt для памяти телефона) и дополнительные папки для mount --bind (звуки, анимация, volumetable, шрифты, и т.д. без необходимости переходить в read-write ФС)
Ссылка
Для установки свапа - скачать файл и положить в корень карты памяти
Для изменения режимов ro - rw - в консоли выполнить
CODE
rw
CODE
ro
Сообщение отредактировал marcolnx - 10.1.2010, 9:33
Прикрепленный файл Howto_jffs2_new_firmware_save_data.txt   ( 1.17 килобайт ) Кол-во скачиваний: 948
Прикрепленный файл MCleaner_MotoID.zip   ( 337.61 килобайт ) Кол-во скачиваний: 666
Прикрепленный файл jffs2_kernel_sdhc.zip   ( 3.91 мегабайт ) Кол-во скачиваний: 1308
marcolnx   Linux Ming (jffs2 11R - firmware)   12.11.2009, 17:31
vitalsh   есть тут суи ? судя по тому что основа whiteMING...   12.11.2009, 19:57
marcolnx   ArD :) thanks a lot. About SUI no, but you can ea...   12.11.2009, 22:03
dvrts   marcolnx, what about Cyrilic SMS? Do they work ...   13.11.2009, 11:20
marcolnx   dvrts sms and mms (send and receive) working fine ...   13.11.2009, 12:19
OFN   Вопросы: 1. При откате на 14-ю или на 16-ю- есть л...   14.11.2009, 1:07
marcolnx   Dvrts Thank you for your translation (you could pl...   14.11.2009, 8:46
dvrts   marcolnx, are there some troubles with battery i...   14.11.2009, 11:09
Miroschnik   Ребята! Для меня важна работоспособность SoftМ...   14.11.2009, 12:08
runtime   У меня воостановление данных не сработало, зато по...   14.11.2009, 12:32
marcolnx   Thank you dvrts for translation. No problem for th...   14.11.2009, 12:53
runtime   MPT backup/restore doesn't work, but it is pos...   14.11.2009, 13:38
dvrts   Miroschnik, У меня все работает Добавлено позже ...   14.11.2009, 13:56
marcolnx   Hi, I never used MPT. I do backup backuprestoreno...   14.11.2009, 14:57
Fanat1k128   Excuse for a stupid question but how on this inser...   14.11.2009, 15:21
dvrts   Авторан классический. В корень карты памяти autoru...   14.11.2009, 16:10
Garm   Если это 11R... что насчет виджетов? If this 11R....   14.11.2009, 19:36
dvrts   Nothing. I dont't think that only platform mus...   14.11.2009, 21:43
marcolnx   Sorry for the delay but some problems (my wife is ...   15.11.2009, 20:05
OFN   I had the firmware epinter SD dear Marco! i...   16.11.2009, 5:19
marcolnx   Hi dear OFN :) "on top of your firmware you...   16.11.2009, 6:23
Hanggard   marcolnx, thanx for you FirmWare, I've been w...   16.11.2009, 7:51
marcolnx   Hi Hanggard :) I have not found any bugs. Diff...   16.11.2009, 8:55
Hanggard   marcolnx, ammmm... How I can setup and up USB-Net?...   16.11.2009, 10:32
marcolnx   Hi Hanggard, Telnet and Samba start in automatic f...   16.11.2009, 12:10
OFN   Впечатленя от прошивки за день: Backup осуществил...   17.11.2009, 2:36
Hanggard   Клава русская есть, в английской есть русский фла...   17.11.2009, 3:27
OFN   Клава русская есть, в английской есть русский фла...   17.11.2009, 4:26
OFN   This file I can't install: Install error: in...   17.11.2009, 4:48
runtime   Also couldn't install foxalarm. Foxalarm   17.11.2009, 4:46
dvrts   Насчет свапа. Почему проблемы возникают от нежелан...   17.11.2009, 5:45
OFN   Насчет свапа. Почему проблемы возникают от нежела...   17.11.2009, 7:04
Hanggard   Caif, less than 1 second marcolnx, I have old inst...   17.11.2009, 5:56
Hanggard   OFN, скажу только одно - свап в виде блочного устр...   17.11.2009, 7:44
OFN   OFN, скажу только одно - свап в виде блочного уст...   17.11.2009, 12:42
marcolnx   Hi all :) thanks a lot for testing. About pkg mp...   17.11.2009, 10:21
dvrts   Who wants english/russian/ukrainian fingerpad on t...   17.11.2009, 12:25
dvrts   я использую ТОЛЬКО linux дистрибутивы. приложени...   17.11.2009, 12:53
Miroschnik   Пробум: Paragon particion magik или Acronis disk d...   17.11.2009, 14:24
dvrts   Paragon partition manager Acronis disk director   17.11.2009, 19:29
Hanggard   лови http://hanggard.com/ADD.tar.bz2 Если нет кар...   18.11.2009, 2:55
OFN   лови http://hanggard.com/ADD.tar.bz2 Если нет кар...   18.11.2009, 7:17
Hanggard   Это прикол мингов, а не 14R. Просто их венда сорт...   18.11.2009, 7:25
marcolnx   Hi, pkg to work properly, please try substitutes S...   18.11.2009, 11:03
OFN   Please tell me if I need add others things. I wou...   19.11.2009, 6:32
dvrts   it seems, nothing. everything is great!   18.11.2009, 13:14
runtime   it would be great to have foxalarm instead of orig...   18.11.2009, 14:45
Cored   Чем эта прошивка лучше от Silent Bob 2.0?   18.11.2009, 15:31
marcolnx   @runtime I just finished loading the firmware in ...   18.11.2009, 15:58
dvrts   Кому нужен мануал по фоксалалрму - вечером напишу ...   18.11.2009, 16:30
Cored   то есть возможность писать в любые папки,а не тол...   18.11.2009, 17:12
marcolnx   Hi, you can write in the whole. Now I update the f...   18.11.2009, 19:02
Cored   небольшой bug report: Прошился нормально,телефое п...   19.11.2009, 4:52
runtime   @dvrts мануал по фоксаларму - это хорошо   19.11.2009, 5:13
marcolnx   Cored, Sorry but translation problems. Talk about ...   19.11.2009, 6:25
Илья Дорошенко   marcolnx YES. 1) The Motorola Phone Tools not conn...   19.11.2009, 6:37
Hanggard   to Marco: 1) Doesn't work USB Modem Mode - MP...   19.11.2009, 6:43
Hanggard   OFN, вроде бы он файлы переносил. Проверить не мог...   19.11.2009, 7:19
OFN   [b]OFN, sdhc - то ядро. и храниться оно должно в...   19.11.2009, 7:44
*НеХеR*   На всякий перезагрузил телефон еще раз, флешку он ...   19.11.2009, 8:02
SergGG   На всякий перезагрузил телефон еще раз, флешку он...   19.11.2009, 8:12
OFN   Получается, что надо 33-ю кодовыю (ядро) прошить ...   19.11.2009, 8:36
*НеХеR*   epinter_cg33_sdhc_42pL7 не пошло.. вечный ребут, п...   19.11.2009, 8:40
OFN   epinter_cg33_sdhc_42pL7 не пошло.. вечный ребут, ...   19.11.2009, 8:53
SergGG   следовательно, законы природы в Минге соблюдают...   19.11.2009, 9:10
Hanggard   OFN, как патч может быть в jffs2? o_O Просто на фа...   19.11.2009, 9:43
OFN   OFN, как патч может быть в jffs2? o_O Просто на ф...   19.11.2009, 10:11
marcolnx   @runtime now I added, try this :) Foxalarm (also...   19.11.2009, 10:03
marcolnx   @runtime please tell me if ok foxalarm (I took the...   19.11.2009, 12:19
runtime   @marcolnx Thanks a lot for foxalarm manual, though...   19.11.2009, 12:34
marcolnx   Hi runtime, here not master reset (don't make ...   19.11.2009, 12:42
runtime   the problem is that backuprestorenow creates backu...   19.11.2009, 12:46
marcolnx   Hi runtime, just maked a try with backuprestorenow...   19.11.2009, 13:39
runtime   @marcolnx Thanks a LOT! though it was a little...   19.11.2009, 13:45
marcolnx   Yes, it's chmod a+w (I was at works and write ...   19.11.2009, 13:53
runtime   I restored contacts by different ways, but it didn...   19.11.2009, 13:55
ArD.   патч НЕ бинарный, накладывается на исходники ядра...   19.11.2009, 14:21
runtime   I think, i found what the problem was. I think it ...   19.11.2009, 16:19
OFN   I think, i found what the problem was. I think it...   19.11.2009, 22:26
dvrts   directories are the same. either in ming, or on ...   20.11.2009, 0:50
OFN   directories are the same. either in ming, or on d...   20.11.2009, 2:53
Hanggard   Ну не бейте по почкам, я не про конкретно этот па...   20.11.2009, 3:05
bekendorf   Плеер в прошивке с активированым эквалайзером или ...   20.11.2009, 11:38
dvrts   Эквалайзер активирован и работает OFN, точнее, н...   20.11.2009, 12:22
marcolnx   Hi all :) @ OFN Skininstaller occupies only a f...   20.11.2009, 16:46
OFN   Hi Marco! Never modify files directly with a ...   21.11.2009, 0:39
OFN   Доброе время суток! К вопросу о монтировании ...   20.11.2009, 23:15
dvrts   Раздел под swap должен быть swap По крайней мер...   21.11.2009, 0:39
OFN   Раздел под swap должен быть swap По крайней мере...   21.11.2009, 1:00
dvrts   Ну вот и команда для свопа, кто забыл swapon /ezx...   21.11.2009, 0:41
OFN   Ну вот и команда для свопа, кто забыл [code]swap...   21.11.2009, 1:38
dvrts   Ну должен же ж знать. Ибо форматируем не под объ...   21.11.2009, 1:17
dvrts   Есть. Кажется внизу списка реестра а еще мож...   21.11.2009, 1:51
OFN   а что обычно разработчики встраивают в прошивку ...   21.11.2009, 2:51
dvrts   для .mpkg - патчится am для .pkg - ставятся доп...   21.11.2009, 3:11
runtime   Есть пара вопросов: 1. Где в прошивке редактируютс...   21.11.2009, 9:05
W.G. Gates III   /usr/data_resource/alertstyle/   21.11.2009, 9:40
8 страниц V  1 2 3 > »
Linux Ming (jffs2 11R - firmware), Прошивка с rw на базе 11R. Версия от 16.12.2009 · Motorola ROKR E6, E6e, E6tv, MING A1200, A1200i, A1200e, A1200r, A1200w, A1600 · Forum
Текстовая версия Сейчас: 29.7.2025, 13:00
