20 страниц V < 1 2 3 4 > »
Linux Ming (jffs2 11R - firmware), Прошивка с rw на базе 11R. Версия от 16.12.2009
marcolnx
сообщение 12.11.2009, 17:31 Закрепленное сообщение!
Пользователь №: 201 733
JFFS2 11R (a1200e e a1200r)
English description is under spoiler
First: I wanted to thank tmp_do and tmr for creating a jffs2 firmware (and therefore the possibility of writing the whole system).
Second: I wanted to thank SergGG Provodnik Silent Bob dvrts and all Motofan ru users for sharing informations and help.
Starting from whiteMING2 of tmp_do (thanks to his help and his answers) I have modified and customized the firmware:
- Replaced all libraries SYStapi SYSqtapp SYSjava SYSdb etc. (11R)
- Flip closed options
- Inserted and placed some missing applications or not fully working (BCR - Sync - Standard Viewer - Photo Editor)
- Added binaries (ldd - showQ - ezxpopup - etc.), so bash3 busybox strace ...
- Added ringtones, pictures, skin, mystuff, etc.
- Radio works without headset
- Calendar in the main screen shows the first appointment in 24 hours
- 2 new skins (red and white)
- Pre-installed applications: ekonsole, Assistant of Amin (reboot, pkg installer, screenshot, swap manager, hacker, mystuff, unrar unzip, ecc.), Skin Installer, Backup Restore Now, SysInfo, ZEditor (can see hidden folder and edit hidden files), PicselEdit (there is also the standard)
- 2 java applications: platinumsudoku - ICQ Jimm
- Language: English - Russian - Ukrainian (VR English - Russian)
- Fixed all profile (Silent, Vibrate, ecc.)
- ext2 ext3 support with modules.dep
- Screen3 works
- Support autorun.txt under SD (/mmc/mmca1/)
- Fingerpad white and foxalarm (voice russian)
- added Processor (underclock and overclock at 520)
- added pictures
- added skin blue (Sens theme)
- added, replaced for Camera_R541L7_G_11.10.11R
- added, replaced for libezxmime.so.1.0.0 thanks a lot Silent Bob
- added pftpd (pure-ftpd and pure-ftpwho) thanks a lot fordalulz
- added, replaced ro rw
- added new init script (so also startup1.txt, startup.txt for SD and startup2.txt for phone) and a lot of stuff for mount --bind sounds, animation, volume, font, ecc. without write directly for new user)
p.s.: I have attached folder MCleaner and MotoID, extract and install if you want.
Generally if something does not like (you can write in the whole) you can edit yourself.
Hopefully you'll try it and have fun.
Link:
Link for download
About swap:
If we need 32mb swap just extract the folder .bin from here and put in the root of SD:
http://www.4shared.com/file/84649109/509f6517/Swap_SD.html
You can easy activate - deactivate with Assistant and check with SysInfo or eKonsole
Прикрепленное изображениеПрикрепленное изображение Прикрепленное изображениеПрикрепленное изображение
Перевод на русский dvrts
Прежде всего хотелось бы поблагодарить tmp_do и tmr за создание прошивок на базе jffs2 (и как следствие, возможность модифицирования всей ФС телефона без перепрошивки (read-write:)
Также хотелось бы поблагодарить SergGG, Provodnik, Silent Bob, dvrts и всех пользователей motofan.ru за информацию и помощь
По сравнению с WhiteMING2 (автор tmp_do) прошивка изменена, улучшена и дополнена:
- Заменены все библиотеки SYStapi SYSqtapp SYSjava SYSdb т.д. (11R)
- Расширенное меню при закрытом флипе
- Добавлена и изменены некоторые приложения, отсутствующие или некорректно работающие ( BCR - Синхронизация - Стандартный Viewer - Photo Editor)
- Добавлены бинарники (ldd - showQ - ezxpopup - и т.д.), so, bash3, BusyBox, strace ...
- Добавлены рингтоны, картинки, скины, изменен mystuff и т.д.
- Радио работает без гарнитуры
- Календарь на главном экране отображает первое задание в 24 часа
- 2 скина (красный и белый)
- Предустановленные приложения: ekonsole, Amin Assistant (перезагрузка, установщик pkg, swap, javahacker, mystuff, распаковщики архивов, и т.д.), Skin Installer, Backup Restore, SysInfo, ZEditor (можно увидеть скрытые папки и править скрытые файлы), PicselEdit (есть стандартный)
- Язык: английский - русский - украинский (VR английский - русский)
- Исправлены все звуковые профили (бесшумный, вибро, и т.д.)
- Screen3 работает
- Поддержка autorun.txt (/mmc/mmca1/autorun.txt)
- Фингерпад с кириллицей
- Foxalarm взамен стандартного будульника
- Куча мелких изменений
- Добавлено приложение для разгона процессора (до 520 MHz)
- Добавлены изображения
- Синий скин (Sens)
- Бинарники для камеры от _R541L7_G_11.10.11R
- Изменен libezxmime.so.1.0.0
- Добавлено приложение для ftp
- Изменены бинарники для ro rw
- Дополнен авторан (startup1.txt, startup.txt для карты памяти и startup2.txt для памяти телефона) и дополнительные папки для mount --bind (звуки, анимация, volumetable, шрифты, и т.д. без необходимости переходить в read-write ФС)
Ссылка
Для установки свапа - скачать файл и положить в корень карты памяти
Для изменения режимов ro - rw - в консоли выполнить
CODE
rw
CODE
ro
Сообщение отредактировал marcolnx - 10.1.2010, 9:33
Прикрепленный файл Howto_jffs2_new_firmware_save_data.txt   ( 1.17 килобайт ) Кол-во скачиваний: 948
Прикрепленный файл MCleaner_MotoID.zip   ( 337.61 килобайт ) Кол-во скачиваний: 666
Прикрепленный файл jffs2_kernel_sdhc.zip   ( 3.91 мегабайт ) Кол-во скачиваний: 1308
Hanggard
сообщение 18.11.2009, 2:55
Пианист
Из: Riga
Пользователь №: 92 516
Прошивка: iOS 14.1
Прост-рок))
Цитата(OFN @ Вчера, 19:42)
буду благодарен,если кто поможет с прогой.
лови http://hanggard.com/ADD.tar.bz2
Если нет кардридера - у меня прямо через режим MassStorage в мобильнике получилось сделать.
OFN
сообщение 18.11.2009, 7:17
Из: zp.ua
Пользователь №: 182 112
Модель телефона: XT 1585
Прошивка: 6.0
спасибо!
Картридер у меня есть
А то я слышал и про парагон, и про акронис. а найти их в сети не получалось.
Буду делать
Зы: отлкик телефона ИМХО бычтрее ( в сравнении с 14R)
Еще заметил: сохраняется у меня прикол, характерній для 14 R- если подсоединиться в режиме флешки, потом нарушается выставленный ранее порядок ярлыков приложений в разделах.
Сообщение отредактировал OFN - 18.11.2009, 7:18
Hanggard
сообщение 18.11.2009, 7:25
Пианист
Из: Riga
Прошивка: iOS 14.1
Прост-рок))
Это прикол мингов, а не 14R. Просто их венда сортирует потом... Кароче, на 16R так же было.
спасибо!
Всегда рад
+1
marcolnx
сообщение 18.11.2009, 11:03
Hi,
pkg to work properly, please try substitutes SuperAsst the folder with the one attached. (/usr/data_resource/preloadapps/qtapps)
Please translate if work fine, for Russian Ukrainian (mpkg_ru.lng mpkg_ru-ru.lng).
Thanks for your help.
p.s.: also added fingerpad (thanks a lot SergGG and dvrts), added ezx_SoftManage_lang.cfg and ezx_SysSetup_lang.cfg
Please tell me if I need add others things. I would like to upgrade the firmware when you think works well smile.gif
Сообщение отредактировал marcolnx - 18.11.2009, 12:19
dvrts
сообщение 18.11.2009, 13:14
Из: Lviv
Пользователь №: 162 099
it seems, nothing. everything is great!
runtime
сообщение 18.11.2009, 14:45
Из: Омск
Пользователь №: 168 421
Модель телефона: A1200e
Прошивка: JFFS2
it would be great to have foxalarm instead of original alarm.
Cored
сообщение 18.11.2009, 15:31
Из: UA
Пользователь №: 172 163
Прошивка: Silent Bob 2.0
Чем эта прошивка лучше от Silent Bob 2.0?
marcolnx
сообщение 18.11.2009, 15:58
@runtime
http://www.4shared.com/file/154695434/b8ef...US_UA_fpad.html
Updated (added fingerpad, some corrections to the bins, upgraded Assistant ,...) -> save mtd -> new firmware -> tested by the flash.
Now I'm at work, but I think it is very easy to replace the standard alarm with foxalarm (a few commands, if you want I can see, certainly SergGG can help).
By
dvrts
сообщение 18.11.2009, 16:30
Из: Lviv
Кому нужен мануал по фоксалалрму - вечером напишу
Добавлено позже (18.11.2009, 18:37):
Cored,
Для юзера - хоть f6 сойдет. Тут есть rw. Это самое главное
Cored
сообщение 18.11.2009, 17:12
Из: UA
то есть возможность писать в любые папки,а не только ezx_user и ezxlocal?
Пошел прошиваться
marcolnx
сообщение 18.11.2009, 19:02
Hi,
you can write in the whole.
Now I update the firmware for the new users, adding fingerpad, ecc. (you can change) but for sure dvrts and others don't need reflash (they can write an change my settings).
I keep the same firmware with different settings (italian keyboard, fingerpad with accented, ecc.).
In my firmware update I keep also original libs inside the firmware (libfingerpad.so.1.0.0 libnumberboard.so.1.0.0).
Ciao (by)
Cored
сообщение 19.11.2009, 4:52
Из: UA
небольшой bug report:
Прошился нормально,телефое проснулся из флеш мода,включился.Первое впечатление супер-ПО очень шустрое,даже быстрее гизмото,все летает,настроил интернет,орера работает нормально,порадовал встроенный джим(хорошая сборка).С аккумулятором проблем небыло(шился 2 раза)
Теперь о грустном
1.Не работает в режиме USB модема МРТ так и не смог увидеть телефон -не смог восстановить адресную книгу(но это мелочи)
2 При поытке испрльзования как модема через кабель набирается номер и зависает на стадии "проверка имени и пароля"-не коннектится sad.gif почемуто ,встроенная опера ведь нормально работает
На гизмото и сайлент бобе зтих проблем нет.
Вобщем вернулся на сайлент боб, так как использую телефон как модем
Шить 2 раза пробовал
Нельзя ли это поправить-очень прошивка понравилась
Да ,забыл,еще почтовый клиент не запустился
runtime
сообщение 19.11.2009, 5:13
Из: Омск
Прошивка: JFFS2
@dvrts мануал по фоксаларму - это хорошо
marcolnx
сообщение 19.11.2009, 6:25
Cored,
Sorry but translation problems.
Talk about problems connecting via modem to the Internet?
MPT can see my conctact and also modem (I not try connect internet because 1 euro for few minutes...)
Сообщение отредактировал marcolnx - 19.11.2009, 6:38
OFN
сообщение 19.11.2009, 6:32
Из: zp.ua
Прошивка: 6.0
Hi,Marco!
Personally, I'm going to remove one of the skins, some wallpapers and skins installer (to save space) and instead put the File Explorer or XPTools.
On this occasion I have a question.
When we are installing the program handed to the memory card. we record. system -> java-> CardRegistry. I already know where the phone should place the folder with hand-emplaced native programs, and where necessary make a record? (This is a matter of simple user. Which is now thanks to your FW and FW opportunities provided by this will progress much faster biggrin.gif )
PS:and more advisable to place the phone in the file system library for compatibility with programs ported E6
(Although the scripts the vast majority of these programs, have been laid out here, already written library path
given that it is on the memory card
folder. system)
Сообщение отредактировал OFN - 19.11.2009, 6:43
Илья Дорошенко
сообщение 19.11.2009, 6:37
Из: под славным Тольятти
Пользователь №: 149 988
Прошивка: Самопал
Fgfnbz
marcolnx
YES.
1) The Motorola Phone Tools not connect this phone
2) And computer not connecting via modem to the GPRS-Internet
sorry for my English!
Hanggard
сообщение 19.11.2009, 6:43
Пианист
Из: Riga
Прошивка: iOS 14.1
Прост-рок))
to Marco:
1) Doesn't work USB Modem Mode - MPT doesn't see phone
2) In Dial-up connection after dial number on checking login/pass stage session goes into eternal meditation and no connect to Internet
Добавлено позже (19.11.2009, 12:47):
Илья Дорошенко,
у мну точнее:) переводчиков-то развелось, блин:):):)
Сообщение отредактировал Hanggard - 19.11.2009, 6:43
OFN
сообщение 19.11.2009, 7:12
Из: zp.ua
Прошивка: 6.0
Цитата(Hanggard @ 19.11.2009, 9:05) *
*НеХеR*,
it is
Разве?
Ведь, насколько я понял, sdhc - патч -НЕ jffs2 , а cramfs.
То есть он фактически заменит многие из кодовых групп , которые в этой прошивке jffs2 на аналогичные. но уже в ctramfs, и потеряется главное преимущество данной прошивки- rw ?
И тогда эта прошивка станет простот гибридом 11R и того, что у нас стояло до этого ( !4R или 16 R, у кого что было раньше)
Я понимаю. что sdhc- патч затрагивает довольно малое количество кодовых групп, но все таки?
ВОПРОС КО ВСЕ ТЕСТЕРАМ ЭТОЙ ПРОШИВКИ:
каково мнение народа - она лучше работает после 14-й или после 16-й ? ( в данном случае корректнее не "после", а с "остаточными элементами" )
Сообщение отредактировал OFN - 19.11.2009, 7:20
Hanggard
сообщение 19.11.2009, 7:19
Пианист
Из: Riga
Прошивка: iOS 14.1
Прост-рок))
OFN, вроде бы он файлы переносил. Проверить не могу, у меня 2Gb
Добавлено позже (19.11.2009, 13:25):
OFN, sdhc - то ядро. и храниться оно должно в одной папке вроде бы...
OFN
сообщение 19.11.2009, 7:44
Из: zp.ua
Прошивка: 6.0
в какой?
Зы: не все ядро ведь, насколько я понимаю ( а понимаю я еще мало smile.gif)
Ззы: знающие люди. плиз, подскажите: а ГДЕ в самой файловой системе телефона делать запись при ручной установке софта ( пользуясь возможностью, предосавляемой jffs2 форматом ФС телефона)- и ЧТО ПИСАТЬ? Или - бросьте ссылку на ман, если такой есть. Я перечитал тему ув. Проводника и СергГГ Устройство прошивки, но там не описывается. что именно нужно писать в SysRegistry и SysMenuTree. Все таки тема создавалась не для пользователей Вайтминга и модов на его базе - предполагалось, что если человек поставил Вайтминг, он такие вещи знает. Тема ИМХО создавалась из рассчета. что читатель будет собирать себе прошивку в cramfs формате - или из элементов других прошивок, что чаще всего и бываает. но все равно в cramfs формате, с помощью Радиокомма.
А тут благодаря ув. Марко появился очередной мод Вайтминга, но с функционалом, способнім привлечь внимание простого пользователя ( например. с камерой от 11 R, оперой от 11R , пиксельэдитором, соундменеджером от 11 R - и т д ).
ИМХО, в раздел "Устройство прошивки" целесообразно внести внести коррективы, с учетом того, что часть пользователей теперь будут вносить изменения в прошивку не посредством разборки и сборки, а "по ходу жизни" - телнеитом или продивинутым телефонным файл-менеджером+ консоль.
Прошу извинить меня, ну не получается у меня излагать сови мысли короче!
Сообщение отредактировал OFN - 19.11.2009, 8:51
*НеХеR*
сообщение 19.11.2009, 8:02
Пользователь №: 74 787
Прошивка: 2.3.4
На всякий перезагрузил телефон еще раз, флешку он так и не увидел (sdhc 4 gb). Так что не вижу я тут поддержки sdhc (sdhc don't work).
SergGG
сообщение 19.11.2009, 8:12
Мингофан
Из: Дніпро
Пользователь №: 85 418
Модель телефона: Droid Turbo
Прошивка: 6.0
Капітан Збройних сил України
Получается, что надо 33-ю кодовыю (ядро) прошить поверх или добавить в прошивку. Само ядро (не пугайтеcь Е6 в названии, просто Боб перепутал названия) собранное в SBF. Не факт, что оно подойдет, но и проблем больших не будет. Максимум придется перепрошиться снова.
Другая сборка ядра
Сообщение отредактировал SergGG - 19.11.2009, 8:41
OFN
сообщение 19.11.2009, 8:36
Из: zp.ua
Прошивка: 6.0
Цитата(SergGG @ 19.11.2009, 10:12) *
Получается, что надо 33-ю кодовыю (ядро) прошить поверх или добавить в прошивку. Само ядро (не пугайтель наЕ6 в названии, просто Боб перепутал названия) собранное в SBF. Не факт, что оно подойдет, но и проблем больших не будет. Максимум придется перепрошиться снова.
Добавлено позже (19.11.2009, 10:14):
Другая сборка ядра https://forum.motofan.ru/index.php?act=Attach&type=post&id=213197
Я извиняюсь за ламерский: вопрос - а КАК выглядит ядро ( 33 -я КГ) в ФС уже прошитого телефона, когда открываешь его ФС с помощью того же Файл Эксплорера?
В Юникс системах есть соответствующая папка (сорри, директорийsmile.gif:smile.gif) .
А у нас на EZX что является аналогом?
Директория под названием " EZX" у нас нет, но ядро ( бывшая КГ 33 smile.gifsmile.gif где то же находится?
Зы: Я ведь до этого спрашивал здесь Марко, по английски: можно установить поверх Вашей прошивки sdhc патч. хоть от Эпинтера. хоть другой какой?
Он четко ответил: нет, нельзя.
Я перечитал еще раз мои ему вопросы и его ответы.
Я ведь не спрашивал у него: есть ли в этой прошивке поддержка sdhc ? ( с самого начала было понятно, что нет).
Я спросил( по контексту) можно ли чисто технически прошить поверх этой прошивки sdhc патч (пусть и с потерей возможности rw для части ФС)?
Он ответил : нет. Я так понял, "нет" - в смысле - "невозможно".
Наверно, надо уточнить у Марко, что он имел в виду. говоря, что прошить поверх его FW sdhc - патч НЕЛЬЗЯ.
Ззы: Проверять эксперементально не хочется только по одной причине - не хочется лишний раз напрягать аккумулятор.
ТОлько новый поставил, Аваланч. доволен .....
Сообщение отредактировал OFN - 19.11.2009, 8:39
*НеХеR*
сообщение 19.11.2009, 8:40
Прошивка: 2.3.4
epinter_cg33_sdhc_42pL7 не пошло.. вечный ребут, показывает бутскрин и перезагружается. Щас докачаю ядро по первой ссылке, но похоже что наврятли заработает. Походу в нормальной работе с sdhc Silent Bob'a пока никто не поборол smile.gif Телефоном собственно особо уже и не пользуюсь (nokia 1100 в некотором плане для меня выигрывает ), но хочется побороть глюк с батареей после ириски (все время показывает полный заряд, потом пять минут ноль и вырубается, методы описанные на форуме не работают).
З.Ы. Подтверждаю, оба ядра не работают на этой прошивке!
Сообщение отредактировал *НеХеR* - 19.11.2009, 8:45
OFN
сообщение 19.11.2009, 8:53
Из: zp.ua
Прошивка: 6.0
следовательно, законы природы в Минге соблюдаются smile.gif:)
SergGG
сообщение 19.11.2009, 9:10
Мингофан
Из: Дніпро
Прошивка: 6.0
Цитата(OFN @ 19.11.2009, 10:53) *
Резюмируя - надо на то ядро, что используется в данной прошивке накаладывать патч, чтобы появилась поддержка sdhc.
Hanggard
сообщение 19.11.2009, 9:43
Пианист
Из: Riga
Прошивка: iOS 14.1
Прост-рок))
OFN, как патч может быть в jffs2? o_O Просто на файл(ы) ядра накладывается некоторое смещение битов/байтов, а как это происходит - да хоть в хекс-редакторе делайте. Имхо надо Илью Петрова ловить за хвост и еще можно с tmp_do поговорить - все-таки он создатель вайтминга и ядро тоже пересобирал, чтобы выкинуть мусор. (после этого еще он перестал заряжаться в режиме usb-net). А вообще - надо не изобретать велосипед и не шить cramfs-ядро (или какое оно там) на jffs2-прошивку, а то это напоминает мне цитату с баша
только что меня попросили дать линуксовую программу под Windows, как сказали: "а вдруг заработает"
Надо идти двумя путями: либо открыть файл ядра и преобразовать его ФС из cramfs в jffs2, либо наложить патч SDHC на уже имеющееся ядро, что считаю самым разумным, во избежание глюков совместимости.
marcolnx
сообщение 19.11.2009, 10:03
@runtime
Foxalarm (also save original alarm):
download and extract foxalarm folder inside SD
telnet 192.168.16.2
cd /usr/data_resource/preloadapps/qtapps/ (enter)
cp -r /mmc/mmca1/foxalarm/foxalarm/ /usr/data_resource/preloadapps/qtapps/ (enter)
chmod -R a+w foxalarm/ (enter)
cd /usr/setup/ (enter)
rw (enter)
cp /mmc/mmca1/foxalarm/foxalarm.dat /usr/setup/ (enter)
cp /mmc/mmca1/foxalarm/foxapp.cfg /usr/setup/ (enter)
chmod a+w foxa* (enter)
cd /ezx_user/download/appwrite/setup/ (enter)
cp /usr/setup/foxa* /ezx_user/download/appwrite/setup/ (enter)
chown ezx:ezx foxa* (enter)
cd /usr/SYSqtapp/alarmclock/ (enter)
cp alarmclock orig_alarmclock (enter)
chown 1000:1000 orig_alarmclock (enter)
chmod a+w orig_alarmclock (enter)
cp /mmc/mmca1/foxalarm/alarmclock/alarmclock /usr/SYSqtapp/alarmclock/ (enter)
ln -s /usr/data_resource/preloadapps/qtapps/foxalarm/voice voice (enter)
ln -s /ezx_user/download/appwrite/setup/foxalarm.dat foxalarm.dat (enter)
cp /mmc/mmca1/foxalarm/alarmclock/Language.txt /usr/SYSqtapp/alarmclock/ (enter)
cd /usr/lib/ezx/lib/ (enter)
cp libezxalarmclock.so.1.0.0 orig_libezxalarmclock.so.1.0.0 (enter)
chown 1000:1000 orig_libezxalarmclock.so.1.0.0 (enter)
chmod a+w orig_libezxalarmclock.so.1.0.0 (enter)
cp /mmc/mmca1/foxalarm/libezxalarmclock.so.1.0.0 /usr/lib/ezx/lib/ (enter)
reboot (enter)
If problem I will make an update for you
Сообщение отредактировал marcolnx - 19.11.2009, 13:50
OFN
сообщение 19.11.2009, 10:11
Из: zp.ua
Прошивка: 6.0
+1
и я об этом.
Шить поверх ЭТОЙ jffs2 прошивки cramfs ядро ( хоть с поддержкой sdhc, хоть какое угодно) - это та самая цитата из башорга.
"Патч в jffs2"- это я так криво выразился ( тоже - видимо захотел в башорг smile.gifsmile.gif
Я имел в виду. что если нужна поддержка sdhc на ЭТОЙ прошивке. надо патчить ЭТО jffs2-ядро ( то есть фактически ядро от Вайитминга 1).
И насколько я понимаю происходящие здесь движения. ни Илья Петров ни темп_до этим сейчас заниматься не будут.
( рад был бы ошибитьсяsmile.gifsmile.gif - но я не ошибусь в этом)
Если бы я уже эти вещи овоил, я бы это уже сделал сам.
освою - сделаю, если к этому времени еще останется мотивация smile.gifsmile.gif
(Хотя эксперементы с поддержкой sdhc на Минге, произведенные мотосообществом планеты ранее, показывают, что почему то при этом закономерно теряется либо возможность заояжаться от юсб, либо масс сторедж режим. Что то за этим стоит, ИМХО.)
Сейчас мне бы освоить имеющиеся возможности этой прошивки..
Зы: выражение " sdhc- патч" (то есть патч обеспечивающий поддержку sdhc, если им пропатчить ядро) не я здесь на форуме запустил. Я его тут встречал, но раньше не придавал этому значения.
Кто то его выкладывал, вроде бы, кроме уже пропатченного им ядра( или ядер) ?
Я ошибся, говоря, что Эпинтер выкладывал на моторолофансе такой патч, Эпинтер выкладывал всю уже пропатченную 33-ю КГ. то есть - ЯДРО. А кто выкладывал сам патч для поддержки sdhс?
Сообщение отредактировал OFN - 19.11.2009, 10:16
OFN
сообщение 19.11.2009, 10:36
Из: zp.ua
Прошивка: 6.0
Цитата(Hanggard @ 19.11.2009, 12:32) *
OFN, c его же слов "а нафиг насиловать аккумулятор..."
В принципе. да.
Добавлено позже (19.11.2009, 12:49):
Цитата(SergGG @ 19.11.2009, 12:32) *
Тэнка!
я таки правильно запомнил: там не только ядро выложено, но и патч.
Теперь, для тех, кто хочет обеспечить себе поддержку sdhc карточек на этой конкретной прошивке от Марко, кроме этого патча, понадобится ядро от этой прошивки ( вариант :ядро от Вайтминг 1+ подтверждение Марко, что ядро здесь - от вайтминг 1 smile.gifsmile.gif
Плюс - навык и усмение (вариант - желание их преобрестив процессе тренировки)
И опять таки - ответ на вопрос: А СМЫСЛ ?
( с учетом того, что как совершенно справедливо указал ув.Нanggard, ссылаясь на гл.ув. темп_до, в этом случае придется пожертвовать зарядкой от юсб, и быть готовым к тому. что аккумулятор оно будет жрать неслабо, а подзарядиться в процессе заливки новой музыки по быстрому в режиме масс сторедж уже не получится. Да, ауммулятор не будет убиваться вследствие избыточной зарядки, зато при испоользовании минга в качестве юсб модема он будет разряжаться очень быстро, о чем уже здесь было написано).
Зы: а " по будьте любезены" оно таки прикольно.И ,главное - привычнее smile.gif:)
Сообщение отредактировал OFN - 19.11.2009, 10:53
SergGG
сообщение 19.11.2009, 10:55
Мингофан
Из: Дніпро
Прошивка: 6.0
Цитата(OFN @ 19.11.2009, 11:22) *
а все таки - в каких директориях ФС нашего телефона находится ядро ?
В обычной cramfs-прошивке ядро лежит вне файловой системы, в CG33, офвсет 0x800
marcolnx
сообщение 19.11.2009, 12:19
@runtime
please tell me if ok foxalarm (I took the files from firmware SergGG, and thank you so much)
@OFN,
applications you want to add or change?
If you tell me what you want I can do an example (easy)
Sorry if I do not respond to all posts, the Google translation sucks. (also my english).
runtime
сообщение 19.11.2009, 12:34
Из: Омск
Прошивка: JFFS2
@marcolnx Thanks a lot for foxalarm manual, though i didn't try it yet. I'll report as soon as i try your instructions. I try to solve another problem now. All calls displays only in numbers, no names from address book. Neither incoming. nor outgoing calls... I read that master reset could help, but i start this operation about 15 min ago and it still saying "Please wait..." do you know what the problem is?
Может кто в курсе: Входящие и исходящие звонки отображаются исключительно цифрами. Имена из тел. книги не подтягиваются. Почему такое может быть? На других прошивках все в порядке.
Сообщение отредактировал runtime - 19.11.2009, 12:38
marcolnx
сообщение 19.11.2009, 12:42
Hi runtime,
here not master reset (don't make this)
Try copy your conctact in SD and after SD to mobile.
I restored all with backuprestorenow (from 16R), working fine, I can see all conctact calling me.
runtime
сообщение 19.11.2009, 12:46
Из: Омск
Прошивка: JFFS2
the problem is that backuprestorenow creates backup file on SD, but didn't restore contacts to the phone.
And this problem still remains even with new, just created contacts.
@marcolnx Thanks a LOT! though it was a little mistake in commands(chown a+w orig_alarmclock, should be chmod) it worked fine! i got foxalarm working.
Сообщение отредактировал runtime - 19.11.2009, 13:42
marcolnx
сообщение 19.11.2009, 13:39
Hi runtime,
just maked a try with backuprestorenow.
Tap 2 times icon backuprestorenow so inside SD folder /Backup/ PIM1.brn(the old from 16R firmware) and PIM.brn (the new)
I deleted folder restoretmp and open with (2 times) selecting PIM.brn
reboot
All works fine.
About manual restoring contacts try copy your main.db inside /ezx_user/sysDatabase/
p.s.: if you wish, make your try about solving this problem. About foxalarm I can make quickly new firmware update for you with foxalarm already inside.
runtime
сообщение 19.11.2009, 13:45
Из: Омск
Прошивка: JFFS2
marcolnx
сообщение 19.11.2009, 13:53
Yes, it's chmod a+w (I was at works and write quickly), thanks a lot now I correct the post. smile.gif
runtime
сообщение 19.11.2009, 13:55
Из: Омск
Прошивка: JFFS2
I restored contacts by different ways, but it didn't help. All calls still appearing only in numbers... Even with new contacts that i add by hands
Сообщение отредактировал runtime - 19.11.2009, 13:56
ArD.
сообщение 19.11.2009, 14:21
Пользователь №: 202 948
патч НЕ бинарный, накладывается на исходники ядра, затем компилится, нефиг людям мозги пудрить!
з.ы. бинарные патчи(накладывающиеся на готовые, скомпиленные бинарники) делают когда нужно чуток что то изменить(например изменить где нибудь условный переход, чтобы обойти какую нибудь проверку), в данном же случае переписана работа с карточкой т.е. дофига кода.
Сообщение отредактировал ArD. - 19.11.2009, 14:26
Linux Ming (jffs2 11R - firmware), Прошивка с rw на базе 11R. Версия от 16.12.2009 · Motorola ROKR E6, E6e, E6tv, MING A1200, A1200i, A1200e, A1200r, A1200w, A1600 · Forum
Текстовая версия Сейчас: 22.7.2025, 9:59
