20 страниц V < 1 2 3 4 5 > »
Linux Ming (jffs2 11R - firmware), Прошивка с rw на базе 11R. Версия от 16.12.2009
marcolnx
сообщение 12.11.2009, 17:31 Закрепленное сообщение!
Пользователь №: 201 733
JFFS2 11R (a1200e e a1200r)
English description is under spoiler
First: I wanted to thank tmp_do and tmr for creating a jffs2 firmware (and therefore the possibility of writing the whole system).
Second: I wanted to thank SergGG Provodnik Silent Bob dvrts and all Motofan ru users for sharing informations and help.
Starting from whiteMING2 of tmp_do (thanks to his help and his answers) I have modified and customized the firmware:
- Replaced all libraries SYStapi SYSqtapp SYSjava SYSdb etc. (11R)
- Flip closed options
- Inserted and placed some missing applications or not fully working (BCR - Sync - Standard Viewer - Photo Editor)
- Added binaries (ldd - showQ - ezxpopup - etc.), so bash3 busybox strace ...
- Added ringtones, pictures, skin, mystuff, etc.
- Radio works without headset
- Calendar in the main screen shows the first appointment in 24 hours
- 2 new skins (red and white)
- Pre-installed applications: ekonsole, Assistant of Amin (reboot, pkg installer, screenshot, swap manager, hacker, mystuff, unrar unzip, ecc.), Skin Installer, Backup Restore Now, SysInfo, ZEditor (can see hidden folder and edit hidden files), PicselEdit (there is also the standard)
- 2 java applications: platinumsudoku - ICQ Jimm
- Language: English - Russian - Ukrainian (VR English - Russian)
- Fixed all profile (Silent, Vibrate, ecc.)
- ext2 ext3 support with modules.dep
- Screen3 works
- Support autorun.txt under SD (/mmc/mmca1/)
- Fingerpad white and foxalarm (voice russian)
- added Processor (underclock and overclock at 520)
- added pictures
- added skin blue (Sens theme)
- added, replaced for Camera_R541L7_G_11.10.11R
- added, replaced for libezxmime.so.1.0.0 thanks a lot Silent Bob
- added pftpd (pure-ftpd and pure-ftpwho) thanks a lot fordalulz
- added, replaced ro rw
- added new init script (so also startup1.txt, startup.txt for SD and startup2.txt for phone) and a lot of stuff for mount --bind sounds, animation, volume, font, ecc. without write directly for new user)
p.s.: I have attached folder MCleaner and MotoID, extract and install if you want.
Generally if something does not like (you can write in the whole) you can edit yourself.
Hopefully you'll try it and have fun.
Link:
Link for download
About swap:
If we need 32mb swap just extract the folder .bin from here and put in the root of SD:
http://www.4shared.com/file/84649109/509f6517/Swap_SD.html
You can easy activate - deactivate with Assistant and check with SysInfo or eKonsole
Прикрепленное изображениеПрикрепленное изображение Прикрепленное изображениеПрикрепленное изображение
Перевод на русский dvrts
Прежде всего хотелось бы поблагодарить tmp_do и tmr за создание прошивок на базе jffs2 (и как следствие, возможность модифицирования всей ФС телефона без перепрошивки (read-write:)
Также хотелось бы поблагодарить SergGG, Provodnik, Silent Bob, dvrts и всех пользователей motofan.ru за информацию и помощь
По сравнению с WhiteMING2 (автор tmp_do) прошивка изменена, улучшена и дополнена:
- Заменены все библиотеки SYStapi SYSqtapp SYSjava SYSdb т.д. (11R)
- Расширенное меню при закрытом флипе
- Добавлена и изменены некоторые приложения, отсутствующие или некорректно работающие ( BCR - Синхронизация - Стандартный Viewer - Photo Editor)
- Добавлены бинарники (ldd - showQ - ezxpopup - и т.д.), so, bash3, BusyBox, strace ...
- Добавлены рингтоны, картинки, скины, изменен mystuff и т.д.
- Радио работает без гарнитуры
- Календарь на главном экране отображает первое задание в 24 часа
- 2 скина (красный и белый)
- Предустановленные приложения: ekonsole, Amin Assistant (перезагрузка, установщик pkg, swap, javahacker, mystuff, распаковщики архивов, и т.д.), Skin Installer, Backup Restore, SysInfo, ZEditor (можно увидеть скрытые папки и править скрытые файлы), PicselEdit (есть стандартный)
- Язык: английский - русский - украинский (VR английский - русский)
- Исправлены все звуковые профили (бесшумный, вибро, и т.д.)
- Screen3 работает
- Поддержка autorun.txt (/mmc/mmca1/autorun.txt)
- Фингерпад с кириллицей
- Foxalarm взамен стандартного будульника
- Куча мелких изменений
- Добавлено приложение для разгона процессора (до 520 MHz)
- Добавлены изображения
- Синий скин (Sens)
- Бинарники для камеры от _R541L7_G_11.10.11R
- Изменен libezxmime.so.1.0.0
- Добавлено приложение для ftp
- Изменены бинарники для ro rw
- Дополнен авторан (startup1.txt, startup.txt для карты памяти и startup2.txt для памяти телефона) и дополнительные папки для mount --bind (звуки, анимация, volumetable, шрифты, и т.д. без необходимости переходить в read-write ФС)
Ссылка
Для установки свапа - скачать файл и положить в корень карты памяти
Для изменения режимов ro - rw - в консоли выполнить
CODE
rw
CODE
ro
Сообщение отредактировал marcolnx - 10.1.2010, 9:33
Прикрепленный файл Howto_jffs2_new_firmware_save_data.txt   ( 1.17 килобайт ) Кол-во скачиваний: 948
Прикрепленный файл MCleaner_MotoID.zip   ( 337.61 килобайт ) Кол-во скачиваний: 666
Прикрепленный файл jffs2_kernel_sdhc.zip   ( 3.91 мегабайт ) Кол-во скачиваний: 1308
runtime
сообщение 19.11.2009, 16:19
Из: Омск
Пользователь №: 168 421
Модель телефона: A1200e
Прошивка: JFFS2
I think, i found what the problem was. I think it was some kind of conflict between the FW i had before flashing and yours. I tried flashing after 14R and got the problem with showing names from phone-book when receiving or making calls . Then i flashed this FW after 16R and everything was OK.
OFN
сообщение 19.11.2009, 22:26
Из: zp.ua
Пользователь №: 182 112
Модель телефона: XT 1585
Прошивка: 6.0
Я шился после 14 R , но у меня такого не было.
Добавлено позже (20.11.2009, 0:37):
Цитата(SergGG @ 19.11.2009, 12:55) *
В обычной cramfs-прошивке ядро лежит вне файловой системы, в CG33, офвсет 0x800
А в ЭТОЙ jffs2- прошивке?
( пойдешь в root - так практически те же директории, что и раньше)
Добавлено позже (20.11.2009, 1:01):
Цитата(marcolnx @ 19.11.2009, 14:19) *
@OFN,
applications you want to add or change?
If you tell me what you want I can do an example (easy)
Thank you all for your work and patience
I outlined myself, modify your firmware as follows:
1) Keep only one skin, black, and remove most of the wallpapers, leaving only those that you have in the screenshot (IMHO it's the best solution). Option: Replace the skin on my favorite Black Ming, This will free up space for 3). In the skin (though Onyx Black, though Black
Ming) to reduce the transparency to 40% (otherwise the white text poorly visible)
2) remove SkinInstaller (this is my personal decision. I do not like frequent changes in skins. I almost do not change them, the more so, if we put skins then the memory card through a program MotoTheme, it is more economical), it also will free up space for 3). And, finally.
3) FileExplorer, (better - XP Tools, but this program is too large to install the phone).
Well. and fingerpad from SergGG
Of course, I would be glad if you did it smile.gif, but at the same time I want to learn how to do it yourself. I want to develop their skills. That's why I asked for advice on how to manually install the program on the phone, using the opportunities offered by your firmware.
Сообщение отредактировал OFN - 19.11.2009, 23:12
dvrts
сообщение 20.11.2009, 0:50
Из: Lviv
Пользователь №: 162 099
directories are the same. either in ming, or on desktop linux
there've been changed memory blocks (mtd). borders of read-write mtd are changed and now are much more wide.
Doesn't work USB Modem Mode
in econsole, while ming is connected to PC as a modem
/usr/SYSqtapp/modem/modemlauncher &
Добавлено позже (20.11.2009, 3:20):
OFN,
Why you can't do it oneself???
Добавлено позже (20.11.2009, 3:54):
Ok. Non-console (ftp or samba) manual for Foxalarm:
\usr\SYSqtapp\alarmclock\
put here conternts of alarmclock.gz
\usr\lib\ezx\lib\
put here a lib from libezxalarmclock.so.1.0.0.gz
\home\ezx_user\download\appwrite\setup\
put here contents of home.gz
Добавлено позже (20.11.2009, 4:01):
jffs_sdhc kernel. try to use this one (in attachment). some kind of bugs, but SanDisk 8gb works great
Also here is a stock kernel (jffs_wm.sbf.gz)
Сообщение отредактировал dvrts - 20.11.2009, 2:05
Прикрепленный файл jffs_sdhc.sbf.gz   ( 3.89 мегабайт ) Кол-во скачиваний: 193
Прикрепленный файл libezxalarmclock.so.1.0.0.gz   ( 25.42 килобайт ) Кол-во скачиваний: 167
OFN
сообщение 20.11.2009, 2:53
Из: zp.ua
Прошивка: 6.0
такие же, это да.
Просто я есть юзер МакОС , а там есть нюансы, хотя - Юникс, шелл в терминале smile.gif
Это я как раз понимаю. Я читал историю вопроса в ветке, посвященной U - серии прошивок.
Вы уважаемый, описываете суть хака, который в свое время сделал гл.ув. temp_do и благодаря которому прошивку удалось из cramfs перепаковать в jffs2. Это было великое достижение, значение которого непреходяще.
jffs-sdhc kernel. try to use this one (in attachment)
интеоресно.Работает? А откуда оно?
OFN,
Ничего, Учимся потихоньку. учимся. Не хватает конкретных опыта ( приобретаю), навыков ( приобретаю), знаний ( приобретаю). Например: как заполнять SysRegistry, когда ставишь программы вручную в память телефона : так же. как CardRegistry в mmc->mmca1->.system-> Java или как то иначе? Я эти вопросы задавал выше.
Или : в посте №54 Вы приводите коды которые надо ввести в консоли, устанавливая фингерпад .
там rw - просто, без слеша. а у последующего кода везде обратный слеш.
Так надо? Зачеми? ведь обратный слеш используется для экранирования спецсимволов, насколько я помню..
(Извиняюсь за дурацките вопросы: я многое чего знал до этого чисто теориетически, просто смотрел, но не пытался применить. А теперь благодаря Мингу и людям здесь я это делаю сам, стараюсь)
Зы: Напрягать Марко по таким пустякам. когда он спрашивает: "Вы скажите. чего Вам не хватает в прошивке - я сделаю" - у меня и в мыслях не было, ИМХО, это было бы нечестно.
Ззы: пока писал, подошло объяснение... так это не для консоли команды. для телнета....
Сообщение отредактировал OFN - 20.11.2009, 2:55
Hanggard
сообщение 20.11.2009, 3:05
Пианист
Из: Riga
Пользователь №: 92 516
Прошивка: iOS 14.1
Прост-рок))
Цитата(ArD. @ Вчера, 20:21)
патч НЕ бинарный
Ага, спасибо, у меня после смены ядра (экспериментировали с SergGG) ФС покрашилась и телефон не шился, пока я не прошил 14R. Так что когда народ протестит, тогда и я...
bekendorf
сообщение 20.11.2009, 11:38
Пользователь №: 207 686
Плеер в прошивке с активированым эквалайзером или нет?
dvrts
сообщение 20.11.2009, 12:22
Из: Lviv
Эквалайзер активирован и работает
OFN,
точнее, не tmp_do, a tmr
Да, я описал суть rw.
Ядро работает. Есть глюк - сообщение о том, что ФС телефона повреждена и требуется формат. Но sdhc работает. На всякий случай выложил нормальное ядро для возврата
Добавлено позже (20.11.2009, 14:25):
Тут ядро тоже CG33. Офвсет не помню - с телефона пишу
marcolnx
сообщение 20.11.2009, 16:46
@ OFN
Skininstaller occupies only a few kb (17kb) but is very useful.
Try to install the skin attached (with motoskin I also included the keyboard black SergGG) and tell me if it is not useful.
To restore the default theme using the attached file (default1_skin.pskn).
I like this application (I can do tests for keyboard, color, transparency, etc..).
Clearly with this firmware you can always edit it directly.
About adding applications or replace any pre-installed is easy.
Session samba copy SysRegistry and SysMenuTree (/usr/data_resource/preloadapps) and also UserMenuTree (/ezx_user/download/appwrite/am).
Looking at the files you will understand how to easily add or replace (to replace just change the name of the program and then change only SysRegistry).
Never modify files directly with a text editor via samba.
Now open for example a .pkg with 7-Zip and extract the program folder that you want to add.
Put the extracted folder on the SD and in a telnet session:
cp -r /mmc/mmca1/Folder_program/ /usr/data_resource/preloadapps/qtapps/ (Enter)
Now copy the file or files you modified with editor unix compatible:
cp /mmc/mmca1/SysRegistry /usr/data_resource/preloadapps/ (Enter)
If you added applications clearly also SysMenuTree and UserMenuTree.
If you have replaced a pre-installed application delete the folder and files:
rm -r /usr/data_resource/preloadapps/qtapps/Folder_preinstalled/ (Enter)
By
Сообщение отредактировал marcolnx - 20.11.2009, 17:09
OFN
сообщение 20.11.2009, 23:15
Из: zp.ua
Прошивка: 6.0
Доброе время суток!
К вопросу о монтировании свап как блочного устройства конкретно на ЭТОЙ прошивке.
Когда мы монтируем второй раздел карты памяти, мы называем его в коде mmca2.
Но дело в том, что когда на данной прошивке мы подключаем карту памяти к телефону, там уже образуется некий пустой раздел mmca2
( в своем первом bugreport здесь я обращал внимание народа на этот факт. Мне ответил гуру, что это такая особенность WM1, на основе которой сделана прошивка Марко ).
Как в этом случае поступать?
Отформатировать пустую карту памяти, предварительно сделав полный backup данных на ней?
Я так понимаю, при такой ситуации, когда раздел mmca2 уже вроде бы как есть, образовывать раздел под swap за счет свободного пространства (как это предлагает сделать программа Achronis) уже не получиться? То есть - получится, но как тогда назвать вновь образованный раздел в консоли, если одна mmca2 уже есть? smile.gif
Наверно, все таки отформатировать флешку.
И - еще один вопрос:
Раздел под swap должен быть в FAT16 или в ext2?
Сообщение отредактировал OFN - 20.11.2009, 23:15
dvrts
сообщение 21.11.2009, 0:39
Из: Lviv
QUOTE
Раздел под swap должен быть swap
По крайней мере, его так называют более-менее грамотные программы
QUOTE
OFN
Из: zp.ua
Прошивка: 6.0
Hi Marco!
I now almost not using telnet. I use Z Editor with support UTF8, and enter the file system using File Explorer, directly from my phone. . I like that implement serious changes in the phone software can now be the means of the phone software. That's fine.
By
Thanks, Marco. I just do not understand: what changes need to make in Sys Registry and SysMenuTree in the case. when we install in phone memory software, which was not there before?
More question: I have carefully read SysRegistry in my phone after flash your FW, but I have not found a mention of MPKG installer and linLoader. They there?
Сообщение отредактировал OFN - 21.11.2009, 0:41
dvrts
сообщение 21.11.2009, 0:41
Из: Lviv
Ну вот и команда для свопа, кто забыл
CODE
swapon /ezxlocal/dev/mmca2
(21.11.2009, 2:44):
QUOTE
They are as Amin Assistant
Try to check more careful
QUOTE
Hmmmm. What would you like to receive in result?
OFN
сообщение 21.11.2009, 1:00
Из: zp.ua
Прошивка: 6.0
Так сложились звезды. что я буду делать это Акронисом под Виндой. Посмотрим, знает ли он такие слова smile.gif:) как "свап".
Пока что мы с ним на эту тему еше не говорили smile.gif Это я так. заранее уточняю.
Тем не менее Акронис сразу же предложил образовать новый раздел на СВОБОДНОМ пространстве флешки не затрагивая остальное ее пространство. Свободно у меня сейчас 298 Мб, а мне под свап нужно всего 32Мб, ну, максимум 48 Мб. Естественно, он будет форматировать - эти 32 метра. Разве нет? Или он и в этом случае все равно отформатирует мне ВСЮ флешку?
Экий он трудоголик, Акронис
dvrts
сообщение 21.11.2009, 1:17
Из: Lviv
QUOTE
Так сложились звезды. что я буду делать это Акронисом под Виндой. Посмотрим, знает ли он такие слова smile.gif как "свап".
Пока что мы с ним на эту тему еше не говорили Это я так. заранее уточняю.
Ну должен же ж знать. Ибо форматируем не под объем информации (ФС), а под swap. В значении swap. И никак иначе
QUOTE
Не верь ему. Я по крайней мере не верю по одной причине - если меняется разметка носителя, то не может быть затронут не весь носитель. Ну априори.
От формата хуже не станет так точно. Чем закончатся подобные эксперименты - хз, но чую я, что все же полным форматом
OFN
сообщение 21.11.2009, 1:38
Из: zp.ua
Прошивка: 6.0
(21.11.2009, 2:44):
Спасибо. Я об этом и спрашивал: мне предстоит вводить эту команду, после того как я создам соответствующий раздел на флешке, и назвать этот раздел для системы mmca2, а, выходит, mmca2 у меня уже вроде как бы есть уже сейчас. причем образовался он сам собой непонятным образом smile.gifsmile.gif.
Очень интересно. А я его как раз собирался выкинуть и заменить на мотофановский Софт Ассистант Рус от Циника.
Кстати, упоминания о предустановленной Консоли я там в СисРеджистри тоже не увидел, хотя она у меня есть в наличии и работает.
НАверное, потому что читал его хоть и внимательно, но в телефоне, Сейчас извлеку его на десктоп и посмотрю еще лучше. smile.gif
Действительно: я зачем мне знать, как устроено Сисреджистри и что там надо писать в случае ручной установки программы в память телефона. если фактически мне достаточно поменять Ассистант ( а как менять- это и так вроде бы понятно, и Марко доходчиво описал) - а тот один единственный софт, который я собираюсь ставить в память телефона ( ФайлЭксплорер) потом можно поставить с помощью нового Ассистанта ( мотофановский Софт ассистант всегда СПРАШИВАЕТ: А КУДА прикажете установить программу? - в отличие от аминовского. Правда, если ему ответиь: "в память телефона", он вполне может потом выдать: "недостаточно места", хотя место естьsmile.gif
Во- первых: хотелось бы, чтобы Файл Эксплорер стал как бы неотъемлимой частью системы, чтобы, напимер, его нельзя было случайно удалить ( впрочем. для это достаточно c консоли заклеймить его ro)
Во-вторых: интересно, а прочитать негде ( остается читать собственную СисРеджистри и сравнивать ее с КардРеджистри с флешки smile.gif
Добавлено позже (21.11.2009, 3:43):
Абсолютно логично. Но прикалываются же программы над юзерами , однако
Сообщение отредактировал OFN - 21.11.2009, 1:41
dvrts
сообщение 21.11.2009, 1:51
Из: Lviv
QUOTE
Есть. Кажется внизу списка реестра
QUOTE
QUOTE
а еще можно переименовать .pkg в .mpkg
QUOTE
именно так.
QUOTE
OFN
сообщение 21.11.2009, 2:51
Из: zp.ua
Прошивка: 6.0
а что обычно разработчики встраивают в прошивку для установки нативного софта :мmpkg и pkg ?
что, например, встроено у Сайлент Боба ? ( помнится. он как то очень непочтительно отозвался о Смартассистанте) Или- у Проводника в Ириске?
Имеет смысл устроить маленькую инвентаризацию такого рода софта на предмет надежности и эффективности. И именно это рекомендовать желающим ставить сюда.
требования к софту для этой прошивки ИМХО уже другие.
Другая идеология ИМХО.
Сообщение отредактировал OFN - 21.11.2009, 2:59
dvrts
сообщение 21.11.2009, 3:11
Из: Lviv
QUOTE
для .mpkg - патчится am
для .pkg - ставятся доп проги (типа того же ассистента)
runtime
сообщение 21.11.2009, 9:05
Из: Омск
Прошивка: JFFS2
Есть пара вопросов: 1. Где в прошивке редактируются стили звонка? (хочу поправить стиль Вибро). 2. В MCleaner есть такая фишка, при соединении телефон вибрирует, можно ли как то это включить без установки самой программы?
I've got couple of questions: 1. Where in the FW I can edit Alert styles(i want to edit Vibrate style). 2. In MCleaner there is a option that turns on vibrate when the person you are calling picks up the phone. Can i activate it without installing MCleaner?
Добавлено позже (21.11.2009, 15:11):
@OFN Современные программы позволяют изменять размер раздела (а соответственно и разбивать на несколько при наличии свободного места на носителе) без форматирования всего раздела. Т.е. если у тебя есть какая либо инфа на флешке то она сохраниться. Единственное что не забудь, так это то что раздел под swap должен быть тоже Основной(Primary).
Сообщение отредактировал runtime - 21.11.2009, 9:12
W.G. Gates III
сообщение 21.11.2009, 9:40
Из: Псков
Пользователь №: 94 294
Модель телефона: Lumia 920
Прошивка: jffs2
/usr/data_resource/alertstyle/
marcolnx
сообщение 21.11.2009, 10:17
Hi runtime,
I set Vibrate for no click sound and vibrate for missing call.
Silent for no click sound and not sound for missing call.
You can edit with vi editor or copy Silent or Vibrate you wish edit in your desktop -> edit with unix editor and replace (/ezx_user/dowload/appwrite/setup/) Silent.pts Vibrate.pts
EventReminders = 0 (sound) 1 (no sound) 2 (vibration)
About MCleaner I don't know (I installed but I keep unselect Auto Load)
By
Garm
сообщение 21.11.2009, 12:50
Из: Морозовск
Пользователь №: 48 276
Прошивка: Black Ming 3b
Насчет Mcleaner - он подает вибрацию сам, это не телефонная функция, имхо
About MCleaner - he self own make vibration, It is not phone function, imho
Hanggard
сообщение 21.11.2009, 15:15
Пианист
Из: Riga
Прошивка: iOS 14.1
Прост-рок))
Swap
Божэ мой, а понаписали-то, мама дорогая... Акронисом изменяешь раздел (существующий), делая его на 32/64 метра меньше, чем он есть. Далее создаешь новый раздел, форматишь его в Linux Swap, акронис умеет. Последнее - грохай в режиме rw из телефона папку /mmc/mmca2. Остальное - по мануалу.
dvrts
сообщение 21.11.2009, 22:06
Из: Lviv
Hanggard,
ээээ. а кто что не так сказал?
(22.11.2009, 0:09):
В любом случае. В ЛЮБОМ. Считаю. Следует форматить. Такие штуки без формата безнаказанно не проходят
W.G. Gates III
сообщение 22.11.2009, 9:25
Из: Псков
Прошивка: jffs2
это еще почему?
Miroschnik
сообщение 22.11.2009, 13:51
Пользователь №: 65 070
Модель телефона: Nokia 5800+LGP500
Цитата(Miroschnik @ 14.11.2009, 16:08) *
Ребята! Для меня важна работоспособность SoftМanager, FBreader, MCleaner, Foxalarm. Как они ведут себя на этой прошивке?
Цитата(dvrts @ 14.11.2009, 17:56) *
Miroschnik,
У меня все работает
А как заставить работать SoftМanager? Научите?
Eugene398
сообщение 22.11.2009, 14:08
Из: г. Запорожье
Пользователь №: 101 369
Модель телефона: Motorola E398/A1200e
Прошивка: deLuxe/F4_modded
поставь вот ЭТОТ. он работает отлично:)
Miroschnik
сообщение 22.11.2009, 14:20
Цитата(Eugene398 @ 22.11.2009, 18:08) *
Поставил.
Бекап приложения не делает. В автозагрузку приложения не ставит.
И еще
Я сделал как описано эдесь https://forum.motofan.ru/lofiversion/index....151097-150.html
Но не разбирал прошивку. а тупо скопировал нужные файлы по указанным директориям. Foxalarm не работает.
Меню на англицком есть, но будильники и задачи не срабатывают. Подскажите, что и где делал не верно?
Добавлено позже (22.11.2009, 18:53):
Foxalarm победил!!! Всем скопированным файлам дал полные права через FileExp..
Сообщение отредактировал Miroschnik - 22.11.2009, 14:31
marcolnx
сообщение 22.11.2009, 15:21
@Miroschnik
problem with foxalarm?
make like at post #81 (or if problem I add an update)
problem add preload applications?
post#108
here a little example (about adding xptools) look about 8a2b9b37-83e7-a8d9-82cf-000000000008
Also commands inside .bash_history.txt
About swap, ecc. I cannot well translate... sorry
Прикрепленный файл OFN_add_apps.zip   ( 547.5 килобайт ) Кол-во скачиваний: 80
Miroschnik
Облом! Перезагрузился, Fox работать перестал. Кто знает что делать?
Добавлено позже (22.11.2009, 19:45):
Цитата(marcolnx @ 22.11.2009, 19:21) *
@Miroschnik
it all has to be entered via the keyboard? A simpler not?
runtime
сообщение 22.11.2009, 16:08
Из: Омск
Прошивка: JFFS2
@miroschnik Можно команды из 81 поста просто копировать в телнетовскую сессию, а можно скопировать через самбу как описывает dvrts на 11 странице. Только возможно надо будет права добавить для файлов. Я ставил через телнет по 81 посту, у меня все работает. И после перезагрузки тоже.
Если у тебя Foxalarm запускается, но не срабатывает, то скорее всего ты не скопировал libezxalarmclock.so.1.0.0 в /usr/lib/ezx/lib/
Сообщение отредактировал runtime - 22.11.2009, 16:15
OFN
сообщение 22.11.2009, 16:36
Из: zp.ua
Прошивка: 6.0
Hi Marco!
Many thanks for the software.
Thank you also that sent bash_hystory.txt
We discussed the advantages of a swap not as a swap file, but as a swap partition on the memory card, and the technical details of creating this partition of the memory card in the Windows environment via available software
In particular, does before you create a swap partition on the memory card you must format the memory card? (Memory card, users Ming usually contains at least 1 GB of data, preservation and restoration of which is a very complicated process, and if we could do without that, it would be nice, but without it unfortunately can not do). We also talked about how that in the Linux environment partitioning on memory cards is carried out much easier.
Сообщение отредактировал OFN - 22.11.2009, 16:38
Miroschnik
сообщение 22.11.2009, 16:51
Что такое телнет и его сессии для меня ,пока, непостижимо. А чем копирование через самбу отличается от копирования нужных файлов сразу в телефоне?
Я сделал как описывает dvrts на 11 странице, результат тот же!!!
За то время, что я мучаюсь с Фоксом я бы его уже три раза в прошивку установил и прошился! Воистину, клроче тот путь который знаешь!
Во! Еще одна радость! Комп видеть тело перестал видеть в любом режиме! Доторкался! Похоже железо. Другой (тел - 1200) комп видит прекрасно
Сообщение отредактировал Miroschnik - 22.11.2009, 17:02
dvrts
сообщение 22.11.2009, 17:02
Из: Lviv
Вот так он работает без проблем
CODE
Foxalarm (also save original alarm):
download and extract foxalarm folder inside SD
telnet 192.168.16.2
cd /usr/data_resource/preloadapps/qtapps/ (enter)
cp -r /mmc/mmca1/foxalarm/foxalarm/ /usr/data_resource/preloadapps/qtapps/ (enter)
chmod -R a+w foxalarm/ (enter)
cd /usr/setup/ (enter)
rw (enter)
cp /mmc/mmca1/foxalarm/foxalarm.dat /usr/setup/ (enter)
cp /mmc/mmca1/foxalarm/foxapp.cfg /usr/setup/ (enter)
chmod a+w foxa* (enter)
cd /ezx_user/download/appwrite/setup/ (enter)
cp /usr/setup/foxa* /ezx_user/download/appwrite/setup/ (enter)
chown ezx:ezx foxa* (enter)
cd /usr/SYSqtapp/alarmclock/ (enter)
cp alarmclock orig_alarmclock (enter)
chown 1000:1000 orig_alarmclock (enter)
chmod a+w orig_alarmclock (enter)
cp /mmc/mmca1/foxalarm/alarmclock/alarmclock /usr/SYSqtapp/alarmclock/ (enter)
ln -s /usr/data_resource/preloadapps/qtapps/foxalarm/voice voice (enter)
ln -s /ezx_user/download/appwrite/setup/foxalarm.dat foxalarm.dat (enter)
cp /mmc/mmca1/foxalarm/alarmclock/Language.txt /usr/SYSqtapp/alarmclock/ (enter)
cd /usr/lib/ezx/lib/ (enter)
cp libezxalarmclock.so.1.0.0 orig_libezxalarmclock.so.1.0.0 (enter)
chown 1000:1000 orig_libezxalarmclock.so.1.0.0 (enter)
chmod a+w orig_libezxalarmclock.so.1.0.0 (enter)
cp /mmc/mmca1/foxalarm/libezxalarmclock.so.1.0.0 /usr/lib/ezx/lib/ (enter)
reboot (enter)
(22.11.2009, 19:08):
QUOTE
Подключаешь телефон в режиме usb-net к компьютеру, открываешь cmd, пишешь в строке telnet 192.168.16.2
и пишешь необходимые unix-команды
(22.11.2009, 19:10):
QUOTE
И как бы ты это сделал, если не секрет?) Точнее что бы это изменило?
Miroschnik
сообщение 22.11.2009, 17:28
Я, и на Ириске и на Гизмото и на проше от тихого Боба разбирал прошу, заменял файлы, собирал и все работало как часики! А тут ни в какую!!! Взял другой тел, продолжаю мучаться....
Добавлено позже (22.11.2009, 20:34):
Логин root
А пароль?
OFN
сообщение 22.11.2009, 17:54
Из: zp.ua
Прошивка: 6.0
telnet 192.168.16.2
rw (enter)
reboot (enter)
Вариант:
если на флешку предварительно уже установлен расширенный файловый менеджер типа EX Tools или File Explorer,
тогда : в консоли пишем
rw / (enter)
После этого
открываем ФС расширенным файловым менеджером, и перетаскиваем и заменяем файлы и папки с флешки в usr или куда там нам надо точно так же как на любом десктопе с любой операционкой , у которой есть GUI. ( и у файлэксплорера, и у икспитулз есть функция копипаст. После того, как мы разрешаем запись на весь /, то есть - на весь рут, функции копипаст у эксплорера будут работать и в директории usr.)
не Линукс вей, естественно, но в то же самое время и не виндузничество. МакОС вей, ИМХО smile.gif:)
marcolnx
сообщение 22.11.2009, 18:05
Miroschnik
login root (enter)
no password (just enter)
Telnet and eKonsole have completed path (Tab).
I try to write easy.
If you learn few command you can make a lot (top, ps, netstat, free, lsmod, ecc.).
Also maybe learn and make some try with vi editor, ecc.
OFN, about swap I prefear swap file (so I active if I need). I think that activate a swap partition on the external memory (long run) could possibly harm because always active (I can make mistakes).
dvrts
сообщение 22.11.2009, 18:23
Из: Lviv
QUOTE
А я говорииил!
Небось ezxcodec использовал. Так вот. Он для cramFS. A в этой прошивке jffs2. Делай выводы. Твой путь - telnet
Miroschnik
сообщение 22.11.2009, 18:56
Вот и именно то, что в режиме RW, когда есть доступ ко всем файлам Foxalarm работает (кроме почасовой озвучки), но после перезагрузки озвучка работает, а остальные функции нет. Может это последствия Ириски?
Добавлено позже (22.11.2009, 22:10):
Есле быть точным то почасовая озвучка происходит, но не преднвзначенными для этого файлами, а сигналом будильника.
OFN
сообщение 22.11.2009, 19:10
Из: zp.ua
Прошивка: 6.0
In what, in Your opinion, dear Marco, is the threat from the fact that the swap all the time mounted not as a file and a swap partition on the memory card? ?
I understand there may be problems if we try to remove the memory card from the phone, which is included .. but Minge is impossible.
Is it that if violated, contact the memory card as a result of the fall of the phone
unlikely the memory card is mounted very tightly.
Добавлено позже (22.11.2009, 21:30):
ИМХО: сначала убедись для себя, что rw / действует и после перезагрузки.
Поменяй что нибудь в заведомо закрытых до этого разделах. Самый простой тест: зайди с помощью расширенного файлового менеджера в usr/data_resource/picture, сделай cut любую картинку , которую заведомо никогда не используешь в качестве обоев, а потом вставь ее где нибудь на флешке.( если жалко. если не жалко - тогда сделай не cut , а delete smile.gif) . Если команда будет выполнена и картинка исчезнет, значит - с rw все в порядке, а у тебя просто некорректно работает и не приживается фоксаларм. Возможно, виной таки то, что осталось у тебя после перепрошивки от предыдущей Ириски. Фоксаларм - это тот будильник. который звонит из спящего режима телефона, да? А то я редко пользуюсь будильниками и в них не очень разбираюсь smile.gifsmile.gif
Сообщение отредактировал OFN - 22.11.2009, 19:31
Linux Ming (jffs2 11R - firmware), Прошивка с rw на базе 11R. Версия от 16.12.2009 · Motorola ROKR E6, E6e, E6tv, MING A1200, A1200i, A1200e, A1200r, A1200w, A1600 · Forum
Текстовая версия Сейчас: 22.7.2025, 10:00
