2 страниц V  1 2 >
Motorola CLIQ Firmware
Skrilax_CZ
сообщение 17.11.2009, 2:16
Пользователь №: 179 333
Модель телефона: Motorola Miletstone
Прошивка: 2.1 rooted
Скачать официальные прошивки Motorola CLIQ (Dext)
Branding: T-Mobile US
Subsidy Lock: ***UNKNOWN***
Version: 1.1.4
Requires RSD Lite 4.5.7.
Not supported by SBF Recalc.
It is in shx format, to split it:
Plug any Moto phone except CLIQ, then flash the CLIQ firmware on it and let it fail. Open the firmware directory and copy the CG2, RAMDLD and the hmg BEFORE you close the RSD Lite. Now you have the CGs in normal binary format.
http://rapidshare.com/files/308088649/tmo-...stomer.zip.html
Сообщение отредактировал Воха - 28.3.2016, 14:12
Skrilax_CZ
сообщение 29.11.2009, 22:52
I extracted files from the CG2 - system image.
yaffs2 image is located at 0x0178f464 in flashfile CG2. (There is userdata yaffs2 image on 0x094d08cc as well, but that is empty.)
http://rapidshare.com/files/314017775/system.rar
Сообщение отредактировал Skrilax_CZ - 29.11.2009, 22:52
yakk
сообщение 30.11.2009, 5:47
Из: Днепропетровск
Пользователь №: 90 408
Модель телефона: milestone
не нужен..
Skrilax_CZ
I've wrote simple program that extracts all partitions from the cg2.smg file.. shx MUST be splitted with RSD-Lite (all other software doesn't split this shx correctly)..
usage:
cg2 <filename>
Skrilax_CZ
сообщение 30.11.2009, 10:16
Thanks. I wrote one too and new SBF recalc 1.2.9.1 splits it correctly according to my extractings.
I observed:
The "headers" have fixed length 0x308 and then the binary starts. At the offset 0x2E4, there is the length of the binary. Now what are the numbers in the headers at offsets "0x300" and "0x304"? You have any idea? There are some other number, those appear to be constants.
Сообщение отредактировал Skrilax_CZ - 30.11.2009, 10:46
yakk
сообщение 30.11.2009, 10:42
Из: Днепропетровск
не нужен..
Skrilax_CZ
There is partition ID on the 0x2b offset of header.. 0x20 f.e. - partition table, it is used by ramdld.. offset 0x300 - is the checksum of partition - it is calculated as inverted 32bit sum.. value from 0x304 offset seems to be ignored by ramdld..
Added: Value at 0x304 offset is the checksum of header.. 8bit sum of all bytes of header must be equal to 0xFF..
Сообщение отредактировал yakk - 30.11.2009, 11:22
Skrilax_CZ
сообщение 30.11.2009, 13:29
yakk
I see, thanks.
So to sum up what we know about the header:
Size = 0x308
ID - byte at offset 0x2B
Name - string at offset 0xE4
Length - integer 32bit at oggset 0x2E4
Binary checksum - integer 32bit at oggset 0x300, inverted 32bit sum of binary
Header checksum - byte at 0x304, to make the sum of header 0x00 (in 8-bit)
Also I noted that the *hd.mbn files, they seem to be to be some "other headers" for the *sec.mbn files. Their length is always 40 bytes (without the header), so far I just noted that at offset 0x10 in the *hd.mbn there is length of the *sec.mbn binary.
Сообщение отредактировал Skrilax_CZ - 30.11.2009, 13:30
yakk
сообщение 30.11.2009, 14:30
Из: Днепропетровск
не нужен..
Skrilax_CZ
I think that *hd files contain descriptions of the signature of the corresponding *sec file.
Skrilax_CZ
сообщение 30.11.2009, 23:13
yakk
It looks like so, offset 0x14 of the hd.mbn looks like position of the signature (there is magic 30 30 30 35 before the signature).
But amsssec.mbn is probably unsigned (in the amsshd.mbn file the offset 0x14 (length of the *sec) has the same value as 0x10) and I can't find it at the end of the file).
Сообщение отредактировал Skrilax_CZ - 30.11.2009, 23:14
otetznik
сообщение 1.12.2009, 6:33
Из: USA, New-York, Roxbury
Пользователь №: 113 807
Модель телефона: V66i,E398,E2,MB200
Прошивка: Custom
Луди здрасте!!!!:)
А когда на Моторола Кликку будет код разблокирования (T-Mobile) ?
А то купил в США, а он заблакирован только под тамшнего оператора, а мне нуна пользвать все симкартыsmile.gif ph34r.gif
Шо делать? можэт ктото преобрёл это тело?
+Osta
Пиши по-русски
Сообщение отредактировал Osta - 2.12.2009, 14:39
сообщение 1.12.2009, 6:46
будет тогда, когда ты купишь.
Skrilax_CZ
сообщение 2.12.2009, 8:46
There are gzip images in bootsec.mbn and recoverysec.mbn at offsets:
0x47CC
0x1E0800
yakk
сообщение 2.12.2009, 9:13
Из: Днепропетровск
не нужен..
Skrilax_CZ First gzipimages are packed linux kernels.. Second gzip images are ramdisks for android and recovery (it is in gzip cpio format).
Сообщение отредактировал yakk - 2.12.2009, 9:21
Skrilax_CZ
сообщение 2.12.2009, 22:48
yakk
Do you know where / how those two gzip images are addressed?
yakk
сообщение 3.12.2009, 2:30
Из: Днепропетровск
не нужен..
Skrilax_CZ Kernel gzip image isn't adressed - it is located just after gzip unpacker which is always started at 0x800 offset (its size can be different, size of packed kernel+unpacker is stored at 0x08 offset). ramdisk is always located after kernel, it's address is aligned to 2048 bytes..
you can check details of boot and recovery images in adroid sources - http://android.git.kernel.org/?p=platform/...otimg/bootimg.h
Сообщение отредактировал yakk - 3.12.2009, 2:37
otetznik
сообщение 3.12.2009, 23:54
Прошивка: Custom
Телефон превезли позавчера, где этот код достать?
сообщение 4.12.2009, 11:14
otetznik,
здесь почитай человек описывал Motorola CLIQ™ / DEXT
ITMASTER
сообщение 6.12.2009, 11:56
Пользователь №: 43 393
Модель телефона: Motorola CLIQ
У меня друг в штатах он клиент T-Mobile позвпнил кним сказал что хочет код анлока и обешали в теченя 24х часов послат по email потом он перешлет мне и сдeлaю анлок ) отпишусь
Skrilax_CZ
сообщение 6.12.2009, 20:43
yakk
Do you think it correct to flash just one part of the flashfile by simply omitting the others? Or does RAMDLD have some other requirements?
New 1.1.31 firmware:
http://rapidshare.com/files/317230138/tmo-...stomer.zip.html
Сообщение отредактировал Skrilax_CZ - 6.12.2009, 20:57
ITMASTER
сообщение 7.12.2009, 9:29
все код получил :) тепер мой CLIQ unlocked
Добавлено позже (7.12.2009, 13:43):
У меня wi-fi неработает когда делаю scan network ничего не находит может ест какая то тайна что я незнаю?
DeshFXs
сообщение 8.12.2009, 9:02
Из: Жуковский, МО
Пользователь №: 137 130
Модель телефона: Moto X
Прошивка: LiquidSmooth
мне вот интерестно: ведь по идее можно на cliq поставить прошу от droid. Читал что Android 2.0 не очень уж и требовательный к железу, а droid выйдет в россии со всеми вытекающими...
Так вот, ктонибудь может точно сказать - можно ли будет достать прошивки от дроида и обновить с их помощью слик?
defaultlogin_
сообщение 8.12.2009, 9:35
Пользователь №: 210 256
Модель телефона: (M)otorola c350
Прошивка: с j2me
нельзя апараты совершенно разные .
starky
сообщение 8.12.2009, 9:43
Пользователь №: 209 207
Прошивка: 2.1-update1 DACH
wi-fi работает, проверь не скрыт ли SSID у твоего рутера, проверь в других местах где точно есть wifi, попробуй вручную вбить параметры твоей сети wifi (SSID, ключ шифрования и т.д), проверь настройки wifi на самом рутере. Если это не поможет- дефект модуля wifi.
PS: и вообще-то этот вопрос (и пара других) не относится к теме этого обсуждения (Motorola CLIQ Firmware). Давайте не будем ждать пока модеры начнут ругаться.
Сообщение отредактировал starky - 8.12.2009, 9:47
mcandre
сообщение 8.12.2009, 10:32
Пользователь №: 123 452
Модель телефона: Atrix
позитивное!
Кто-то пробовал шить?
Накопал такое: "If you power on the phone with the squares button (menu) held down it will bring up a blue screen at the bottom that says "Bootloader USB Int"."
DeshFXs
сообщение 8.12.2009, 16:24
Из: Жуковский, МО
defaultlogin_, и чем же они, если не сикрет, разные?) железом? производительность железа не влияет, камера там такая же. Единственное, что может вызвать осложнения - кнопки, их назначение и количество, это да. Но больше же ничего!
yakk
сообщение 8.12.2009, 17:20
Из: Днепропетровск
не нужен..
DeshFXs, на дроиде совсем другой проц - от TI, OMAP 3430 вроде.. на клике - от qualcomm - msm7201a..
DeshFXs
сообщение 8.12.2009, 19:37
Из: Жуковский, МО
yakk, какая для андроида разница, ему всеравно куда вставать, если, конечно, драйвера никакие ненадо ставить и тд. Вычитал просто что android 2.0/2.1 не требовательны к железу (последнюю ставят на Hero, и будут с ней выпускать новый трубки)
yakk
сообщение 8.12.2009, 20:41
Из: Днепропетровск
не нужен..
DeshFXs ок, андроид 2.0 или 2.1 или любой другой, если google будет продолжать выкладывать исходники поставить на клик, - не проблема.. Если конечно найдём способ ставить на клик левые прошивки.. но прошивку от дроида в чистом виде поставить не удастся (вроде изначально вопрос был задан именно о возможности установки прошивки дроида на клик)..
зы: драйвера всего внутрипроцового железа будут несовместимы.. в этом плане у прошивки hero гораздо больше шансов установится на клик.
DeshFXs
сообщение 8.12.2009, 23:07
Из: Жуковский, МО
Проблема совместимости - это уже сложнее, но раз уж на Hero c 1.5 можно будет поставить 2.1 то чем Мото хуже?) К тому же, зная Мото, можно предположить, что лазейки будут =)
starky
сообщение 9.12.2009, 8:02
Кроме процессора у Cliq и Droid могут быть разные модули GSM, WiFi и Bluetooth. Так-же скорее всего различное разбивание ROM'a и куча других "мелочей". Так что не думаю что это так уж просто. А насчёт лазеек- подождём...
DeshFXs
сообщение 9.12.2009, 11:29
Из: Жуковский, МО
starky, надо каким-нибудь образом узнать подробнее о железе... Хотя мото никогда не отичалась разной начинкой у своих аппаратов)
Хой
сообщение 9.12.2009, 15:04
Пользователь №: 210 607
Модель телефона: нету
Прошивка: ээ.. что?
DeshFXs, ты зачем с yakk споришь? ему всё таки лучше знать..
Hero - это HTC, они сами выпустят обновление.. тем более в России этот телефон чуть ли не флагман (пока что) поэтому обновления должны быть.. в случае с мото этого скорее всего не будет.. smile.gif
ax192
сообщение 9.12.2009, 19:31
Пользователь №: 169 140
Прошивка: Iris
Найдутся умельцы,и всё будет
DeshFXs
сообщение 11.12.2009, 13:06
Из: Жуковский, МО
Хой, Motorola MILESTONE и что же теперь, мистер "это невозможно", м? wink.gif
сообщение 11.12.2009, 13:41
DeshFXs,
Вы видать читать не умеете, или читаете через строчку. Вам про одно, вы про другое с упорством... Это совершенно разные вещи. Ну будет у вас рут, ну и чё это Вам даст? Возможность запустить прошивку от Дроида на Дексте? Там железо совершенно разное.
DeshFXs
сообщение 11.12.2009, 15:30
Из: Жуковский, МО
stigr, нет нет нет, никто не собирается ставить чистую прошивку с дроида на слик, просто теперь можно вытащить из нее все что нужно, хотябы тот же лэнг, мультитач открыть и тд
defaultlogin
сообщение 11.12.2009, 17:32
Из: /home/
Пользователь №: 197 205
Модель телефона: (M)otorola C350
Прошивка: c j2me
в сотый раз повторяю нельзя отдельно из андроида вытащить ленг и мультитач тоже.
Сообщение отредактировал defaultlogin - 11.12.2009, 20:35
DeshFXs
сообщение 11.12.2009, 23:27
Из: Жуковский, МО
defaultlogin, господи, да чегож вы все такие неверующие, как-будто не на Мотофане находимся, а на Ноклафане, или Яблокофонофане, ейбогу. Тут такое свершалось... А чего китайцы творят? Это же жесть полная=) Андроид - весьма новая платформа, людей которые смогут в ней разобраться - единицы, но все всегда в первый раз. Ты так заявляешь, будто слетал на пару лет в будущее и можешь точно утверждать. Сейчас нельзя, а завтра можно будет. Предлагаю просто подождать, если до лета с андроидом нельзя будет творить что душе угодно - с меня плюс лично тебе(только не забудь напомнить) и признание ошибки =)
defaultlogin
сообщение 12.12.2009, 7:21
Из: /home/
Прошивка: c j2me
DeshFXs
вы от е2 поставите ленг на е8 ?
я лично с платформой больше года знаком.
и знаю .
люди уже сейчас творят на тематических форумах. хотя ждите лета.
Сообщение отредактировал defaultlogin - 12.12.2009, 7:23
DeshFXs
сообщение 12.12.2009, 8:44
Из: Жуковский, МО
defaultlogin, так, раз уже творят, в чем проблема?
Просто понимаешь, мои надежды основаны на том, что на Hero с андроид 1.5 выйдет версия андроида 2.1. Тоесть у версий есть совместимость ведь есть? А раз есть, значит должно быть можно использовать что-то от одной прошивки в другой.
yakk
сообщение 12.12.2009, 8:56
Из: Днепропетровск
не нужен..
DeshFXs, не правильно ты понимаешь - есть андроиды которые можно ставить разные на один и тот же телефон.. и есть разные телефоны - тот же droid(milestone) и cliq(dext) - прошивки между ними будут абсолютно разными, судя по исходникам что выложили на milestone - оно очень похоже на motomagx, а cliq - похоже на hero.. вообще в плане языка это мало что значит, если на cliq получится ставить левые прошивки - будет и русский язык..
Сообщение отредактировал yakk - 12.12.2009, 8:58
2 страниц V  1 2 >
Текстовая версия Сейчас: 15.9.2025, 15:38
