Krm - X Mp For K3, For K3 R261171ld
citroen
сообщение 14.12.2009, 20:15
MotoAuto
Из: Minsk, Belarus
Пользователь №: 95 640
KRM - X MP For K3 R261171LD
KRM - X by King_Rat of MotoXtreme
(новый монстр от зарубежных друзей)
Features:
Dimension X:
Flex Version - KRM - X - V1.0
Technology - KRM: XTRM WIFI
S/W Version - R261171LD-AS_U_99.13.14R
Language List - 0055
Boot Loader - 03.90
Flip Closed Mods...
*Shoot Video (Quality Improved + Unlimited Recording *Approx. 2 Hrs 56 Min for 2GB MicroSD*)
*Take Pics (Quality Improved)
*Initiate Calls
*Conduct Calls via Speaker Phone
*Check Appointments
*Turn Flight Mode On/Off
*Turn BT On/Off
*Lock/Unlock External Keys
*Reject/Divert Incoming Calls
*Power Off Ph
*Change USB Settings
*View Ph Specs
*Change Call Settings
*Play Music (Still Functional)
*Keys Remapped...
#Up Volume - Now Smart Key (+Ph Book if Ph Open)
#Down Volume = Default
#Smart Key - Now Fire Key (Centre Key - D Pad)
#Camera Key - Now Reject/Power Off (if Ph Closed)
#Video Call Key - Now Screen Shots
#Browser Key - Now Short Cuts
Graphics...
*Custom - SU & SD Images (See 1st/Last Image in Montage) [Created by rdwilliamson... and modded by me into below##
*Custom - Boot loader Image (See 1st/Last Image in Montage)##
*Custom - cl.gif & Outer Boot Image (See 1st/Last Image in Montage)##
*Custom - cli_ski
*DRM - New MX Generation - Extensively Modded by me... (Hundreds of .GIF edited/replaced) [Original by Kent_lkc]
*Font - Dekthusian - Created by me (LP0055 - English, Chinese, Italian, German, Vietnamese)
*Skins - Agent - X - Port & Mod by me (Original created by rdwilliamson - MotoXtreme) <== Default Skin **DO NOT DELETE**
Alien - X - Port & Mod be me (Original created by Semseddin - Xibalba)
Bio - X - Port & Mod by me (Original created by rdwilliamson - GoGreen)
Carbon - X - Port & Mod by me (Original created by rdwilliamson - iCarbon)
iHa-[X] - Port & Mod by me (Original created by Woody - iPhone)
*Seamless Graphics Change from Skin to Skin (19x19 .gif fit w/ all Skins + Skins all have the same Status Icons)
*Custom - mma_ucp **DO NOT EDIT** [Menu Items that use .gif from DRM added to Short Cuts & No Longer in Main/Sub Menu(s. Refer - Flip Closed Mods]
*8 Walls/Screen Savers
Audio...
*Ear Piece - Volume + 2
*Custom - Ph Open/Close Sounds
*Custom - Shut Down Audio (Start Up = Vibrate)
*5 Midi Ringtones (To Get You Started)
Fun lights/Ring Light:
*Charging/Charge Complete - All Outer Lights Activate
*Bluetooth - Light Blinks
*Ring Lights - Pulse, Flicker, Rhythmic, Hyperactive
Important Seem/System/Other Edits:
*Unlock Codes **0000** ##000000##
*Camera Quality Improved + Unlimited Video recording
*All Bands in Network Activated
*USB Charging Enabled
*Carrier Modded
*Most Hidden Menu Items Activated
*Message Counter - 450 down
*IM Activated
*Hot Messages
*Google in Ph Book
*Short Cuts Activated
*Menu Items Using DRM .gif in Short Cuts Menu
*Google Maps added to Games
*Custom Menu Titles - Via LP & mma_ucp
*3.5G Instead of H - For Above 3G
*Camera/Video Cam .gif Changed
*EMS/MMS Images
*350 Calls Received etc...
*Not Locked
скачать/download
Сообщение отредактировал citroen - 25.4.2016, 20:02
сообщение 19.5.2010, 6:45
citroen,
спасибо, монстр неплохой, жаль зарубежные друзья не сделали скрины для других скинов(
iDeck
сообщение 15.12.2010, 22:31
Из: Ростов-на-Дону
Пользователь №: 213 912
Модель телефона: XT5
Прошивка: SuperOSR 2.2.0
А 320 к/бит воспроизводит?
citroen
сообщение 17.12.2010, 14:46
MotoAuto
Из: Minsk, Belarus
iDeck,
нет. до 256кб.
iDeck
сообщение 23.1.2011, 14:10
Из: Ростов-на-Дону
Через какую прогу его прошить и если после этого прошить лэнг с русским языком проблем не будет???
citroen
сообщение 25.1.2011, 20:06
MotoAuto
Из: Minsk, Belarus
iDeck,
через RSD или же через FB + сверху ставить надо русский отдельно.
BeePlus
сообщение 31.1.2011, 3:01
Из: Харьков
Пользователь №: 168 992
VE66 :)
Тк новый бут найти не смог, а прошку посмотреть ой как хотелось ... короче прошил отдельно 2 и 15 кодовые группы на стандартную прошу и на 03 бут.
В общем все симпатичненько и работает, ток в меню не заходит по центральной клавише. все остальные клавиши работают. (правил мма, переназначил кнопки ... похоже в симах закопали).
Krm - X Mp For K3, For K3 R261171ld · Кастомные прошивки для Motorola 3G · Forum
Текстовая версия Сейчас: 16.9.2025, 7:04
