2 страниц V  1 2 >
[EM30] MP RevolutionSpeed by elias174
elias174
сообщение 7.2.2012, 0:27
Пользователь №: 219 111
Модель телефона: Motorokr em30
Прошивка: Responsorium 1.1
hi, this is my first monsterpack its based in Responsorium with new apps and new ports wink.gif
*/Source: MotoEvolution.net
*/Autor: elias174
IPB Image
IPB Image IPB Image IPB Image
General Characteristics:
-Based on the Enigmatic Responsorium Monsterpack (motofan.ru) and Imperfect Sandip_2u v10.3 (mmus.us)
-Faster
-Icons for different file types in File Manager
-Running from the file manager, with files lin, sh, txt ..
-MGX-Installation of applications
-Ability to run packages ZPK
-Ability to extract compressed files from the File Manager
-Support for multiple video formats
-Visualization and ttf font settings by FontManager
-Copy/paste
-ZCpuOverclock
-Automatic Installation skins, whether in ext3, mmca1
-ZConfig (already known in Responsorium): possible swap, compcache, sidekey, greenkey, Shortscut
-ZNet (zPand, zUSBNet either unix or windows)
-Modification of internal ui_sounds in memory Phone
-SysRegistry in ezxlocal / download / appwrite / am for free modification
-HSA
-works without a SIM card
-Removed content Stock for faster
-FTP, Samba, webserver, autorun
-Power off and power on gifs mounted mmc / ext
-E8-Libs to run any application
-File Manager Pro preinstalled
-Ability to change Bootlogo, but must name a bmp logo in the following manner, mylogo.bmp.logo run it from the filemanager and apply.
P-ressing backspace in Menu to open MenuEditor
New features:
-CG36 and CG52-systems compiled in cramfs for speed
-ZDeskClock and zDeskLauncher added to zConfig (for proper installation)
-SFileManager new Filemanager-translated into English, the author is Chinese
-Kernel-overclocked to 798mhz (should only be set starting the zCpu to 532MHz)
-Updated zTaskMan version 0.4.5 (798mhz kernel support)
-ZFlashPlayer installed swf file execution from the filemanager (before install the SDL libs)
-ZPart-installed
-GamesBox: New application to organize games apps, to install games to do this:
*With the game or app renowned MGX. Mgx to. Game run from the Filemanager and install
- PicView by Strelok-ported to E8/EM30, to run with any filemanger (except stock) image and select run any app PicView (still with bugs)
-TReader by stelok ported to E8/EM30 to open any textplain or run it from the filemanager and select Treader
-Higher Speed ​​SDL games
-EvolBox contains:
-ZConfig
-SFileManager
-ZFlashplayer
-ZPart
-GamesBox
-MgxBox
-FileManager
-TextEditor
-Java Permissions (added CG44 of Imperfect 10.3)
-New Bootlogo to RevolutionSpeed ​​(thanks daviloco)
Installation Method:
-Make sure you have a no-rsa boot
-Flash FW Stock (if you come from Responsorium not required)
-Flash RevolutionSpeed
-Data-Erase
-Starting and Enjoy
LINK: http://www.4shared.com/archive/vtUBpWuZ/RevolutionSpeed.html
Credits: Julio_MotoMod, Sandip_2u, Zorge, Ant-ON, Pzyduck, Deepak, ilove3d , NestorM, Enigmatic (autor Responsorium), EXL , kno_ocl, MotoEvolution web , Strelok, and others (sorry if i forget you)
PD: Not all scripts and apps are translated into English sad.gif
if you want to continue with the modding of EM30 please Register in MotoEvolution.net , future versions of this Monsterpack and new apps will be published there.
Diag
сообщение 7.2.2012, 3:08
Из: г. Краснодар
Пользователь №: 171 112
Прошивка: R6716_G_71.04.06R_C
Ну что. Сегодня с утра поставил. К вечеру отпишусь. Полет отличный. Частота не сбрасывается. Опера мини работает куда плавнее.
K()t
сообщение 7.2.2012, 6:57
Из: Niko City, Ukraine
Пользователь №: 202 229
Прошивка: CM
Если процессор работает постоянно на 798 он не сильно садит батарею?
Можно попросить Винраруса, он зделает интеллектуальный розгон
Diag
сообщение 7.2.2012, 11:54
Из: г. Краснодар
Ну что могу сказать. С утра на полностью заряженную батарею прошил (только учтем, что батарее уже скоро 3 года) этот мод. Поюзал минут 40-50. Смотрю - одно деление батареи осталось. Минут 20-30 заряжал от компа и поехал на учебу. По пути был запущен рокбокс. Слушал музыку около 30-40 минут. Опять же одно деление. поставил на зарядку на 1 час. На парах пару тройку раз зашел в ОпераМини + опять рокбокс на 40-60 минут. уже оставалось 2 деления. По дороге на работу опять же этот рокбокс на 1 час. Приехал - осталось одно деление. Спустя пару часов снова поставил заряжаться.
Все эти действия проводились с 6-20 до 15-30 по мск. То есть около 9 часов.
Опять же делаю акцент на возраст моей батареи (до этого при аналогичном использовании день (не больше) держала).
Кое-что отметил для себя:
  1. С такой частотой все откликается быстро, аж непривычно как-то.
  2. Из интересностей привлекло внимание ZFlashplayer (который я пока не заюзал) и PicView (работает в
    FileManager и позволяет маштабировать картинку по нажатию клавиш громкости + пару мелочей).
  3. SFileManager - какая-то непонятная альтернатива отечественному zLauncher. Мне он не понравился (SFileManager).
  4. В его пересобранном zTaskMan не работает функция "Убить процесс" по нажатию кнопки "С" (или "Назад")
  5. Непойму теперь смылса нахождения в моде ZCpuOverclock. Ведь частота все равно не сбрасывается.
В основном все тоже, что и в Responsorium.
Данное мнение основано на первых впечатлениях о модификации. В последствии чего сие мнение может поменятся.
Задавайте конкретные вопросы, если не нашли здесь ответ.
Сообщение отредактировал Diag - 9.2.2012, 12:55
Sobol84
сообщение 7.2.2012, 13:16
Пользователь №: 216 330
Модель телефона: Razr M
Прошивка: 4.4.2 (186.46.15)
Что-то я не нашел, как в этом моде сделать дефолтные частоты проца. Отключал zCPUoverclock, ставил вручную частоты через его же, все-равно постоянно 798 Mhz. Эта частота здесь "вшита"?
Сообщение отредактировал Sobol84 - 7.2.2012, 13:16
VINRARUS
сообщение 7.2.2012, 14:17
Термоядерный
Из: Чорнобиль
Пользователь №: 211 044
Прошивка: 740 MHz: Z6 and ZN5
youtu.be/A_yQLYLiSGQ
Цитата(Sobol84 @ Сегодня, 15:16)
* все-равно постоянно 798 Mhz
перезагружать пробовал (частота с 798 не понижается до перезагрузки)? smile.gif
Sobol84
сообщение 7.2.2012, 15:09
Перезагружал не помогает. Частота не понижается вообще никогда (судя по показателям zTaskman).
K()t
сообщение 7.2.2012, 16:26
Прошивка: CM
Попробуйте убить процесс zCPUoverclock, а потом через софт менять частоты, если получиться изменить частоту, то можно использовать способ интеллектуального розгона Винраруса
Sobol84
сообщение 7.2.2012, 16:42
Че за способ, не в курсе, дайте ссылку.
igoripp
сообщение 7.2.2012, 17:15
Самый дерзкий
Из: Касимов, Муром
Пользователь №: 215 540
Модель телефона: sony ion
Sobol84,
forum.motofan.ru/index.php?showtopic=1730557&view=getnewpost
elias174
сообщение 7.2.2012, 18:49
sorry, but i dont speak russian, if all use english, i can understand your questions, please
bagram
сообщение 7.2.2012, 19:13
Пользователь №: 157 041
Модель телефона: EM30
Прошивка: imper_10.3
почему то эта проша у меня не захотела работать нормально, да меню летает, а вот с ext разделами проблема не создаются и существующий не видно. После попытки создать с помощью zpart тело вообще стало виснуть, откатился на Imperfecto 10.3 все нормально что за аномалия... это только у меня так?
igoripp
сообщение 8.2.2012, 5:34
Самый дерзкий
Из: Касимов, Муром
bagram, такие проблемы бывают, когда частота большая(
K()t
сообщение 8.2.2012, 6:55
Прошивка: CM
нужно спросить у автора, включил ли он автомонтирование
Diag
сообщение 8.2.2012, 8:29
Из: г. Краснодар
В английском не шарю, но спрошу автора...
(Google в помощь)
elias174, it is possible to lower the CPU frequency?
elias174
сообщение 8.2.2012, 11:38
sure this made possible with zcpuoverclock with frecuencys in 133, 266; 399 , but i cant understand the because of this the ussage of the batery its the same with 532
Diag
сообщение 8.2.2012, 11:49
Из: г. Краснодар
But I have the CPU frequency does not change
OlegST
сообщение 8.2.2012, 16:35
Пользователь №: 210 367
Прошивка: Imperfecto v10.3 rus
не у тебя одного частота не сбрасываеться
OlegST
сообщение 8.2.2012, 19:37
bagram
сообщение 8.2.2012, 20:37
В таком случае зачем ее повышать? (и касательно zpart на других монстрах у меня тоже были проблемы). Думаю это не из за частоты, потому что тормоза начинаются после попытки форматнуть (разбить флешку на разделы). На флешке уже были разделы, тел. их не увидел (созданы - disk editor в Imperfecto 10.3)
Сообщение отредактировал bagram - 8.2.2012, 20:49
OlegST
сообщение 8.2.2012, 21:29
у Imperfecto другая структура флешки,вернее порядок расположения разделов
SergerDest
сообщение 9.2.2012, 12:46
Пользователь №: 231 041
Прошивка: MP RevolutionSpeed
Есть хочу...
А как прошить этот мод?
p.s. Сорри за идиотский вопрос...
VINRARUS
сообщение 9.2.2012, 15:13
Термоядерный
Из: Чорнобиль
Цитата(SergerDest @ Сегодня, 14:46)
* А как прошить этот мод?
p.s. вопрос...
SergerDest
сообщение 10.2.2012, 8:05
Есть хочу...
Блиин, у меня 7z файл не принимается РСДлайтом (((
может его как-нибудь переименовать надо?
Diag
сообщение 10.2.2012, 8:09
Из: г. Краснодар
Может его нужно сначала распаковать?
Блин, автор собирается исправлять понижение частоты? А то надоело по 2 раза на день заряжать телефон.
K()t
сообщение 10.2.2012, 10:51
Прошивка: CM
Поставь армд с другой прошивки
Добавлено позже (10.2.2012, 12:54):
Попробуйте патч с этой темы поставить
OlegST
сообщение 10.2.2012, 11:05
не работает
Diag
сообщение 10.2.2012, 11:29
Из: г. Краснодар
Этот патч на ем30 работать не собирается. При тестировании, Ant-ON так и не узнал, в чем проблема работы этого патча на ем30.
SergerDest
сообщение 10.2.2012, 12:39
Есть хочу...
Я разобрался уже. Просто Гугл хром сказал, что файл скачан, а на самом деле оказался недокачан...
p.s. I am noob ))
OlegST
сообщение 10.2.2012, 17:59
так зачем на него ссылки давать?или поглумиться?
igoripp
сообщение 10.2.2012, 18:17
Самый дерзкий
Из: Касимов, Муром
OlegST,
Цитата(OlegST @ Сегодня, 20:59)
* Попробуйте
Вот ключевое слово) А вось, что то и получилось бы. K()t не клоун, что б народ развлекать. Плюс того армд в том, что по первому требованию частота поднимается до максимальной. Установите этот патч, и замените в том zpk армд на свой, посмотрите что получится)
K()t
сообщение 10.2.2012, 20:09
Прошивка: CM
В точку!
Сообщение отредактировал K()t - 10.2.2012, 20:11
SergerDest
сообщение 13.2.2012, 7:44
Есть хочу...
a какой ленг можно поставить, чтобы без итапа было?
igoripp
сообщение 13.2.2012, 11:59
Самый дерзкий
Из: Касимов, Муром
SergerDest, а чем он, собственно, мешает? Возьми да и выключи в настойках ввода)
SergerDest
сообщение 13.2.2012, 12:47
Есть хочу...
Есть ли для DeskLauncher'а оболочки, как у часов?
Diag
сообщение 13.2.2012, 12:56
Из: г. Краснодар
Нет. можно менять только фон (по умолчанию его нет), т.е. подложку под иконки. Посмотри в теме Приложений, там есть описание этого плагина.
SergerDest
сообщение 13.2.2012, 15:13
Есть хочу...
спасибо ))
boytoy
сообщение 21.2.2012, 18:46
Из: Владимир
Пользователь №: 190 405
Модель телефона: ZN5 EM30 Milestone
Прошивка: магазинная
Отлично, поражен скоростью работы. Теперь в автобусе достаю из кармана не веху,а Ем30, чтоб послушать музыку smile.gif , наконец то плеер работает с адекватной скоростью, в плане запуска, листания треков и т.д.
SanchoNT
сообщение 24.2.2012, 5:57
Из: Нижний Тагил
Пользователь №: 184 870
Прошивка: 4.4.4
Дело не в apmd. Полюбому разгон сделан через ядро, тем методом который публиковал EXL в ветке ZN5. Но исправить одно значение в ядре - этого мало, нужно исправлять модули ядра и я думаю что ещё и патчить системные файлы.
В EM30 наверняка стоит тот же процессор что и в ZN5, поэтому я бы не рекомендовал шить этот мод, ведь рекомендуемая максимальная частота этого процессора 512 Mhz (да, почему-то именно 512 а не 532 указано в тех. данных процессора на разных сайтах). А если верить Википедии, то процессор можно использовать максимум на частоте 665 Mhz, потому что там так указаны частоты работы этого проца: 532-665 Mhz.
Сообщение отредактировал SanchoNT - 24.2.2012, 5:58
Тоха52
сообщение 27.2.2012, 15:08
Пользователь №: 169 807
Модель телефона: RoKr E6
Прошивка: Vacum 1.2
Настроение в формате жесткого похмелья.
залейте пожалуйста на другой хостинг с этого скачать не могу helpsmilie.gif helpsmilie.gif helpsmilie.gif
[EM30] MP RevolutionSpeed by elias174 · Motorola ROKR E8, EM30 · Forum
2 страниц V  1 2 >
Текстовая версия Сейчас: 5.8.2025, 20:44
