5 страниц V « < 3 4 5
[Moto E] Обзор и обсуждение Мото Е XT1022 - конкурент Moto G, прошивки, разлочка, Unlock, русский, инструкции, файлы, программы, игр
sidr
сообщение 22.6.2014, 13:11 Закрепленное сообщение!
Из: Бреста
Пользователь №: 168 840
Moto E (XT1021, XT1022, XT1025)
Техническое описание
Operating system - Android™ 4.4, KitKat®
Processor - Qualcomm® Snapdragon™ 200 with 1.2GHz dual-core A7 CPU
Adreno 302 400MHz single-core GPU
Capacity - 4GB standard MicroSD slot supports up to 32GB expandable memory 1GB RAM
Dimensions and weight - Height: 124.8mm
Width: 64.8mm
Depth: 12.3mm
Weight: 142g
Display - 4.3 inches 540 x 960 qHD, 256ppi Features anti-smudge coating and Corning Gorilla Glass 3
Connectivity - MicroUSB, supports USB 2.0 3.5 mm headset jack Micro SIM
Battery - Built-in rechargeable lithium-ion, 1980mAh Mixed usage up to 24 hours
Rear camera - 5 MP
Networks - US GSM Model:
GSM/GPRS/EDGE (850, 900, 1800, 1900 MHz)
UMTS/HSPA+ up to 21 Mbps (850, 1700 (AWS), 1900 MHz)
Requires a microSIM card (not included)
Global GSM Model:
UMTS/HSPA+ up to 21 Mbps (850, 900, 1900, 2100 MHz)
CDMA Model Coming Soon!
CDMA/EVDO Rev A (850, 1900 MHz)
Bluetooth® Technology - Version 4.0 LE
Wi-Fi - 802.11 b/g/n, 2.4GHz
Фото MOTO E
Видео
[video]https://www.youtube.com/watch?v=Cs6tV1Di3-8[/video]
Видео Moto E vs Moto G
[video]https://www.youtube.com/watch?v=rVKQJp21r9Q[/video]
ОФ прошивки для MOTO E
Инструкция по прошивки с hda
a) Download and install Motorola Moto EDrivers
b) Download and extract the stock Firmware of your choosing
c) If the firmware file you downloaded is a .xml.zip file then download Motorola Fastboot Attachment 2427667 (attached to this post) and extract the .exe into the same folder as the stock firmware files (the same folder as the .bin and .img files). If your firmware is a .tar.gz file then skip this step.
d) Get ADB (if you don't already have this, I suggest downloading and installing Minimal ADB and Fastboot by shimp208:
Direct Download
Disclaimer:
Follow these instructions at your own risk. If something goes wrong don't blame me!
These are the original stock signed image files from Motorola it should work on all Moto E Variants.
Steps to restore stock firmware:
1) Reboot the phone into bootloader mode. There are 2 ways to do this.
I) The 'hardware' way.
a) Unplug the USB cable and power off the phone.
b) Press and hold 'Volume down' then power on the phone.
c) Connect USB cable to your computer.
II) The 'software' way.
a) Enable developer mode on the Moto E (Settings-> 'About Phone'. Tap 7 times on 'Build Number')
b) Enable USB debugging. (Settings -> 'Developer options' -> 'USB Debugging' -> check)
c) Connect phone to computer via USB, you should see a new ADB device detected and drivers installed.
d) Open "Minimal ADB and Fastboot". Type:
Code:
adb reboot-bootloader
You should see the Moto E bootloader screen with the following options:
Code:
Normal Powerup
Recovery
Factory
Switch Console [NULL: null]
Barcodes
BP Tools
2) Open a command prompt / terminal (Start -> cmd.exe in Win7) and browse to the folder with the extracted firmware.
In my case:
Code:
cd c:\falcon_retgb_user_4.3_14.10.0Q3.X-76-LGG-8_54_release-keys-cid7-Retail_GB
3)
Flash each of the partitions in sequence using mfastboot, you need to enter the following commands one-by-one checking that each one returns an [OKAY]
Code:
mfastboot flash partition gpt.bin
mfastboot flash motoboot motoboot.img
mfastboot flash logo logo.bin
mfastboot flash boot boot.img
mfastboot flash recovery recovery.img
mfastboot flash system system.img_sparsechunk1
mfastboot flash system system.img_sparsechunk2
mfastboot flash system system.img_sparsechunk3
mfastboot flash modem NON-HLOS.bin
mfastboot erase modemst1
mfastboot erase modemst2
mfastboot flash fsg fsg.mbn
mfastboot erase cache
mfastboot erase userdata
mfastboot reboot
Downgrading:
4) Wait, you should now be rebooted into a fully stock Moto E firmware.
Драйвера
Где купить:
EBAY
AMAZON
Фото разобранного телефона
Сообщение отредактировал Воха - 20.12.2015, 19:28
Воха
сообщение 21.11.2015, 23:10
Сектант Xiaomi
Из: Дніпро 🇺🇦
Пользователь №: 145 492
Прошивка: Android 12-13
Норм
А после обновлений разве они не займут столько же? Или андроид при КАЖДОМ обновлении делает резервную копию?
сообщение 21.11.2015, 23:34
Воха,
вот честно не скажу как сейчас, но на старых версиях, находил до 5 версий жмаила и других прог. как на 5 андроиде не скажу, но удаление и установка с нуля гугл прог мне помогала.
captan2
сообщение 22.11.2015, 13:51
Из: Воронежская область
Пользователь №: 163 860
Модель телефона: z3 - xt5 - E - G3
Цитата(stigr @ 22.11.2015, 2:59) *
не то вы господа удаляете. Снеси все обновления системных приложений и заново их обнови. Андроид зачем то резервирует старые версии системных прог, что приводит к засорению системной памяти, а не той которую вы чистите.
И как это сделать? я ж писал, что в этих вещах вещах я туп...
Добавлено позже (22.11.2015, 17:57):
Цитата(Воха @ 22.11.2015, 0:18) *
А сам телефон в статус строке пишет о нехватке памяти?
Да, пишет
Сообщение отредактировал captan2 - 22.11.2015, 13:51
Воха
сообщение 22.11.2015, 14:00
Сектант Xiaomi
Из: Дніпро 🇺🇦
Норм
Цитата(captan2 @ Сегодня, 15:51)
* И как это сделать?
Меню>Настройки>Приложения>вкладка "Все", проходишся по всем приложениям и те у кого есть кнопка "Удалить обновления"- жмёшь её и соглашаешся на удаление обновлений
captan2
сообщение 24.11.2015, 5:26
Попробовал. Сделал. Поудалял некоторое количество обновлений гугловских приложений. Уведомление из строки уведомлений исчезло. Обновилось одно приложение и при попытке обновиться второму пишет что нет места. Но уведомления в строке пока нет
Воха
сообщение 24.11.2015, 5:41
Сектант Xiaomi
Из: Дніпро 🇺🇦
Норм
Есть возможность получить Root?
captan2
сообщение 24.11.2015, 7:35
Не, у меня и руки не оттуда растут, да и умом не вышел. Гуманитарий я...
Воха
сообщение 24.11.2015, 7:39
Сектант Xiaomi
Из: Дніпро 🇺🇦
Норм
Тогда бэкап всего нужного, и общий сброс с очисткой- и можно не ломать голову с обновлениями и т.д.
captan2
сообщение 24.11.2015, 7:49
Так я только недавно такое делал. А он откат сделает к времени покупки или просто к чистому телефону с операционкой?
Воха
сообщение 24.11.2015, 8:05
Сектант Xiaomi
Из: Дніпро 🇺🇦
Норм
Тогда чистая прошивка через RSD lite: я предполагаю, похоже при обновлении в системе осталась старая прошивка pardon.gif
captan2
сообщение 24.11.2015, 9:03
Воха, честно сказать не особо понял как.. То есть я понимаю. что это программа для прошивки, но тогда получится. что я не официальную ОС установлю?
Воха
сообщение 24.11.2015, 9:48
Сектант Xiaomi
Из: Дніпро 🇺🇦
Норм
Официальную, нужно лишь найти твою версию, сделай скрины "о телефоне"- давай поищем
captan2
сообщение 6.12.2015, 21:19
Прошу прощения, что выпал. мало того что проблемы с памятью аппарата, так он начал отключаться и появляется такой экран как на фото. Первый раз я был в шоке. Но путо тыкая и выбирая варианты дальнейших действий, он всё же заработал. До компа добрался только сейчас и к тому времени сегодня он таким образом уже четвёртый раз выдаёт фокус. Что ж мне с ним делать-то.. ( Изображение
Воха
сообщение 7.12.2015, 11:58
Сектант Xiaomi
Из: Дніпро 🇺🇦
Норм
Шить через RSD
captan2
сообщение 7.12.2015, 19:24
Всё это китайская грамота для меня(((
Воха
сообщение 7.12.2015, 19:56
Сектант Xiaomi
Из: Дніпро 🇺🇦
Норм
ПК с интернетом есть?
captan2
сообщение 8.12.2015, 5:36
Конечно))
Воха
сообщение 8.12.2015, 6:49
Сектант Xiaomi
Из: Дніпро 🇺🇦
Норм
Сделай скриншот "о телефоне", там где версия прошивки (в самом низу) и т.д.
captan2
сообщение 8.12.2015, 18:53
Вот как-то так...Изображение
Воха
сообщение 9.12.2015, 6:40
Сектант Xiaomi
Из: Дніпро 🇺🇦
Норм
Модель XT1022 ?
captan2
сообщение 9.12.2015, 17:02
XT1021
mardariy
сообщение 10.12.2015, 13:53
Пользователь №: 22 440
RsdLite http://rsdlite.en.lo4d.com/
Драйвера - http://www.motorola.com/getmdmwin
Прошивка https://www.androidfilehost.com/?fid=24052804347843430
Инструкция - http://devfaq.ru/ru/q/14178
Собственно вся инструкция - установить драйвера, зайти в fastboot, запустить RsdLite, открыть файл , нажать кнопку.
Только нужные данные все сохраните перед этим, сотрется всё.
Сообщение отредактировал mardariy - 10.12.2015, 14:44
i-text
сообщение 27.4.2016, 10:02
Пользователь №: 206 974
Модель телефона: Moto RAZR 5G
А у кого-нибудь этот телефон "просто так" зависал? Есть какие-нибудь распространенные проблемы? Отправил знакомой телефон, который сам около недели тестировал и проблем не видел, а у нее вдруг начали проявляться. Далее, описываю "со слов" так как телефон не у меня.
Первая: телефон начал плохо откликался на сенсер, загрузочное лого Мото с земным шаром сменялось рабочим столом. В первый раз странность появилась во время зарядки телефона от сети, повторно - сама по себе. Проблему решили хард резетом, с полным сбросом до заводских настроек через меню восстановления.
2 дня полет был нормальным.
Сегодня, зайдя в галерею просмотреть снятое видео телефон завис, экран погас. Телефон не откликался ни на кнопку включения, ни на сочетания кнопок. Включился сам через полчаса. Сейчас работает стабильно.
Из подробностей установлена самсунговская 16 гб sd карта - осталась еще от старого штатовского владельца.
Из программ (все свежие версии): мемори бустер лайт, ес-проводник, мото камера, галерея, асист, гугл поиск, вибер, яндекс браузер, т.е. никаких игр, ничего подозрительного...
Есть идеи? СД карта может так вредить? Первый раз когда жестко завис. Карту вынимали, перезагружали, но проблема не исчезла... Хотя, может все это друг с другом не связано.
Модель xt1021 (отвязанная от Cricket)
Сообщение отредактировал i-text - 27.4.2016, 10:07
сообщение 27.4.2016, 16:40
i-text,
нужно посмотреть, что барышня ставила на телефон. может там вирусов полным полно. насчет карты памяти, если карта медленная, забитая или поврежденная, то может тупить. нужно без карты попробовать попользоваться.
Цитата(i-text @ Сегодня, 13:02)
* мемори бустер лайт
вот кстати первый "вирус"
* Из программ (все свежие версии)
свежие, не означает, что хорошие. у меня на стоке 4.4.2 гугл поиск есть. если его не обновлять, запрос вводится почти мгновенно или 1-1,5 секунды. стоит обновить, секунды 3 не меньше, ещё и клавиатура жестко тупит при наборе. так что старые версии получше будут.
i-text
сообщение 27.4.2016, 18:53
В том то и дело, что ничего не ставила.
Бустером сам второй год пользуюсь... Т.е программа не из плохих.
Да я и не спорю, что свежие не значит хорошие. Но в новых много все улучшено, например в мотороловских приложениях. Сам факт такого жесткого зависа подозрителен. Может что-то аппаратное? Хотя почему хард резет помог...
Сам с таким не встречался...
сообщение 27.4.2016, 19:58
Цитата(i-text @ Сегодня, 21:53)
* Бустером сам второй год пользуюсь... Т.е программа не из плохих.
реклама в ней есть? не вижу смысла закрывать то, что потом снова откроется. лучше убрать лишнее, тоесть удалить.
* Хотя почему хард резет помог...
что то поставила из прог лишних? пусть скачает касперского или др веба и прогонит на вирусы. и список приложений пусть соскринит и отправит. а то так можно гадать очень долго.
i-text
сообщение 28.4.2016, 19:36
На вирус похоже. Поставил на moto g те же самые обои. - Зависание повторилось. Вопрос, как зайти во внутреннюю память из fastboota для удаления файла обоев
сообщение 28.4.2016, 20:55
i-text,
безопасный режим?
i-text
сообщение 29.4.2016, 21:53
Сделал хардрезет. Нужно было что то за ночь придумать. Способов увидеть внутренний каталог телефона без загрузки андройда не нашел.
Сообщение отредактировал i-text - 29.4.2016, 21:53
сообщение 30.4.2016, 10:51
i-text,
а с безопасного режима удалить не получилось? или ты не понял как туда войти?
в любом случае, почисти флешку ещё и предупреди барышню, что бы не ставила из маркета что попало. у нас на форуме я выложил кучу картинок для рабочего стола, позднее ещё добавлю.
lcrmslcrms
сообщение 30.4.2016, 11:18
Пользователь №: 191 309
Прошивка: 42r/wm6.1/wm5.0
i-text, поставь cwm если это возможно дальше прошей файлик смонтируй нужные разделы загрузится файловый менеджер потом удалишь ненужные файлы
[Electrify 2] - Обсуждение Motorola XT881
Сообщение отредактировал lcrmslcrms - 30.4.2016, 11:21
Воха
сообщение 30.4.2016, 14:05
Сектант Xiaomi
Из: Дніпро 🇺🇦
Норм
https://twrp.me/devices/motorolamotoe.html
i-text
сообщение 1.5.2016, 15:05
Claus398,
Зайти то зашел, но телефон перезагружался все равно. .т.е. появлялась надпись безопасного режима, а потом сразу перезагрузка.
Не знаю как, но у меня получилось один раз зайти в телефон без срабатывания перезагрузки. Сделал это через режим отладки. Удалил файл обоев. Скопировал что нужно было на облако, выключил телефон, думая, что все в порядке и... Опять все по новой. Без проблем больше загрузиться не получилось. Циклическая перезагрузка останавливалась только в меню восстановления. Вайп кэша не помог. Так что я до сих пор не понимаю что это было.
lcrmslcrms,
Воха,
Видимо плохо искал. Запомню на будущее. Спасибо за советы
Сообщение отредактировал i-text - 1.5.2016, 15:11
[Moto E] Обзор и обсуждение Мото Е XT1022 - конкурент Moto G, прошивки, разлочка, Unlock, русский, инструкции, файлы, программы, игр · Motorola на Android OS · Forum
Текстовая версия Сейчас: 6.9.2025, 8:16
