5 страниц V < 1 2 3 4 > »
[Moto E] Обзор и обсуждение Мото Е XT1022 - конкурент Moto G, прошивки, разлочка, Unlock, русский, инструкции, файлы, программы, игр
sidr
сообщение 22.6.2014, 13:11 Закрепленное сообщение!
Из: Бреста
Пользователь №: 168 840
Moto E (XT1021, XT1022, XT1025)
Техническое описание
Operating system - Android™ 4.4, KitKat®
Processor - Qualcomm® Snapdragon™ 200 with 1.2GHz dual-core A7 CPU
Adreno 302 400MHz single-core GPU
Capacity - 4GB standard MicroSD slot supports up to 32GB expandable memory 1GB RAM
Dimensions and weight - Height: 124.8mm
Width: 64.8mm
Depth: 12.3mm
Weight: 142g
Display - 4.3 inches 540 x 960 qHD, 256ppi Features anti-smudge coating and Corning Gorilla Glass 3
Connectivity - MicroUSB, supports USB 2.0 3.5 mm headset jack Micro SIM
Battery - Built-in rechargeable lithium-ion, 1980mAh Mixed usage up to 24 hours
Rear camera - 5 MP
Networks - US GSM Model:
GSM/GPRS/EDGE (850, 900, 1800, 1900 MHz)
UMTS/HSPA+ up to 21 Mbps (850, 1700 (AWS), 1900 MHz)
Requires a microSIM card (not included)
Global GSM Model:
UMTS/HSPA+ up to 21 Mbps (850, 900, 1900, 2100 MHz)
CDMA Model Coming Soon!
CDMA/EVDO Rev A (850, 1900 MHz)
Bluetooth® Technology - Version 4.0 LE
Wi-Fi - 802.11 b/g/n, 2.4GHz
Фото MOTO E
Видео
[video]https://www.youtube.com/watch?v=Cs6tV1Di3-8[/video]
Видео Moto E vs Moto G
[video]https://www.youtube.com/watch?v=rVKQJp21r9Q[/video]
ОФ прошивки для MOTO E
Инструкция по прошивки с hda
a) Download and install Motorola Moto EDrivers
b) Download and extract the stock Firmware of your choosing
c) If the firmware file you downloaded is a .xml.zip file then download Motorola Fastboot Attachment 2427667 (attached to this post) and extract the .exe into the same folder as the stock firmware files (the same folder as the .bin and .img files). If your firmware is a .tar.gz file then skip this step.
d) Get ADB (if you don't already have this, I suggest downloading and installing Minimal ADB and Fastboot by shimp208:
Direct Download
Disclaimer:
Follow these instructions at your own risk. If something goes wrong don't blame me!
These are the original stock signed image files from Motorola it should work on all Moto E Variants.
Steps to restore stock firmware:
1) Reboot the phone into bootloader mode. There are 2 ways to do this.
I) The 'hardware' way.
a) Unplug the USB cable and power off the phone.
b) Press and hold 'Volume down' then power on the phone.
c) Connect USB cable to your computer.
II) The 'software' way.
a) Enable developer mode on the Moto E (Settings-> 'About Phone'. Tap 7 times on 'Build Number')
b) Enable USB debugging. (Settings -> 'Developer options' -> 'USB Debugging' -> check)
c) Connect phone to computer via USB, you should see a new ADB device detected and drivers installed.
d) Open "Minimal ADB and Fastboot". Type:
Code:
adb reboot-bootloader
You should see the Moto E bootloader screen with the following options:
Code:
Normal Powerup
Recovery
Factory
Switch Console [NULL: null]
Barcodes
BP Tools
2) Open a command prompt / terminal (Start -> cmd.exe in Win7) and browse to the folder with the extracted firmware.
In my case:
Code:
cd c:\falcon_retgb_user_4.3_14.10.0Q3.X-76-LGG-8_54_release-keys-cid7-Retail_GB
3)
Flash each of the partitions in sequence using mfastboot, you need to enter the following commands one-by-one checking that each one returns an [OKAY]
Code:
mfastboot flash partition gpt.bin
mfastboot flash motoboot motoboot.img
mfastboot flash logo logo.bin
mfastboot flash boot boot.img
mfastboot flash recovery recovery.img
mfastboot flash system system.img_sparsechunk1
mfastboot flash system system.img_sparsechunk2
mfastboot flash system system.img_sparsechunk3
mfastboot flash modem NON-HLOS.bin
mfastboot erase modemst1
mfastboot erase modemst2
mfastboot flash fsg fsg.mbn
mfastboot erase cache
mfastboot erase userdata
mfastboot reboot
Downgrading:
4) Wait, you should now be rebooted into a fully stock Moto E firmware.
Драйвера
Где купить:
EBAY
AMAZON
Фото разобранного телефона
Сообщение отредактировал Воха - 20.12.2015, 19:28
сообщение 11.7.2014, 6:00
Claus398,
Цитата(BeePlus @ 4.7.2014, 2:21)
* Юзаю Moto e XT1022 (dual) русский с коробки. (4.4.2)
BeePlus
сообщение 11.7.2014, 23:31
Из: Харьков
Пользователь №: 168 992
VE66 :)
Цитата(Claus398 @ 11.7.2014, 8:38) *
Цитата(BeePlus @ 6.7.2014, 12:11)
* тк леново запарил ауканием и переспрашиваниями
а какая модель если не секрет?
BeePlus,
кстати правда что русский по умолчанию есть в системе?
любая на мтк.
а вообще на P780 например. Я торгую брендовыми китайскими поделками (и разумеется у нас есть свой сервис)
А насчет мото е, так тут чистый андроид , 99.8 процентов тут на русском.
сообщение 12.7.2014, 8:41
тогда покупка леново отпадает. вот и думаю что выбрать для девушки moto E, Razr M, Razr HD, ценник почти везде одинаковый. а вот если с индии можно будет заказать мото е до 150 баков с доставкой, то возьму его.
lcrmslcrms
сообщение 12.7.2014, 10:45
Пользователь №: 191 309
Прошивка: 42r/wm6.1/wm5.0
Claus398,
Moto e будет куда призентабильней и русский, взял и пользуешься .
сообщение 12.7.2014, 15:50
lcrmslcrms,
если с индии, особенно если и 2 симки, то покупаю не думая, даже не смотря на отсутствие фронтальной камеры.
BeePlus
сообщение 12.7.2014, 23:15
Из: Харьков
VE66 :)
Похоже на 4.4.4 стал еще дольше держать аккум.
Проверю в ближайшей командировке.
Проблемка сменить внутреннюю память на флеху ... не переписывается и через модуль xposed не меняется путь.
Баг с голосовым поиском и после неработающим плеером остался.
Все остальное супер.
BeePlus
сообщение 14.7.2014, 21:32
Из: Харьков
VE66 :)
Довольно юзабельный циан, причем стабильный.
Косяк с инетом (ток на первой симке), а так приятно все.
Поиграюсь пару суток.
сообщение 15.7.2014, 5:13
BeePlus,
а баг, тот что ты описывал на стоке, пропал на циане?
BeePlus
сообщение 15.7.2014, 23:10
Из: Харьков
VE66 :)
Цитата(stigr @ 15.7.2014, 8:13) *
BeePlus,
короче остался баг, но я посносил кучу стоковых прог ( в тч и поиск и голос), поэтому он исчез.
Очень сильно подчистил сток от гугла, думаю деодекс сделать.
сообщение 16.7.2014, 8:43
http://www.flipkart.com/moto-e/p/itmdvuwsy...=ts_motoe_black вот тут нашел по неплохой цене телефон, вопрос пришлют ли в украину? и не прокидают ли?
или похоже они отправляют только по индии(((
Сообщение отредактировал Claus398 - 16.7.2014, 8:46
TWIX11
сообщение 16.7.2014, 14:59
Из: Индия
Пользователь №: 82 679
Модель телефона: slvr L7; Defi+; Мото-Е
в Индии распродали 1 миллион MOTO-X, MOTO-G, MOTO-E
Самолично купил Moto-E одним из первых покупателей, так как проживаю в Индии. Хорошо что не поддался эмоциям многообещающего MOTO-G и спонтанно выждал "тёмную лошадку", чему несказанно рад!
Юзаю его пару месяцев и ни одного нарекания в работе железа! Неделю назад вышло обновление КитКат с версии 4.4.2 до 4.4.4 и легко установилось после скачки.
Парни, ну что ещё говорить?! MOTO-E это убийца смартфонов своего уровня наповал . Очень досадно что в России перестали продавать Мото... Я так же прикупил этот аппарат для своей девушки и ещё отправлю маме в Россию.
Добавлено позже (16.7.2014, 19:47):
а по моему камера отличная!
максимальное разрешение:
съемка ночью при уличном освещении без вспышки , которой и нету и не нужна!
вот видео https://www.youtube.com/watch?v=dZaIT147wvo
сообщение 16.7.2014, 17:07
TWIX11,
а что по ценам на него? есть ли нам возможность как то купить?
TWIX11
сообщение 16.7.2014, 18:01
Из: Индия
Цитата(Claus398 @ 16.7.2014, 21:07) *
TWIX11,
на сайте специальная низкая цена для Индии 120$ (Мото очень любит индусов)
А купить для вас можно только через посредника!
сообщение 16.7.2014, 18:05
TWIX11,
кст, да
У нас на форуме уже был прецедент где мотофан живущий в экзотической стране, организовал что то типа канторы посредника по доставки специфических товаров из Бразилии (восновном телефонов Мото, нои не только)
Может Вы тоже, за не большое вознаграждение, поможете местным жаждущим МотоФанам? От нас респект, а Вам небольшая прибыль. Уверен что найдется не один десяток желающих, а при правильном подходе с организацией продвижения и расширения списка товаров, думаю можно и полноценный бизнес открыть.
TWIX11
сообщение 16.7.2014, 18:20
Из: Индия
stigr,
Ну может так и сделаю. Да, я сострадаю Российским мотофанам чесно. Я сам фанатею от мото давно и готов помочь нуждающимся )) За очень скромную комиссию 30$ с посылки. И уже имею опыт отправки разных дешёвых индийских товаров.
сообщение 16.7.2014, 19:55
TWIX11,
создайте темку в Купле продаже, опишите что да как все тонкости с оплатой и доставкой, думаю клиентура появится.
Хотя с ценообразованием Вам стоит поработать. Фиксированная цена за посылку имеет смысл только тогда когда стоимость товара большая. Не уверен что она применима к телефонону стоимостью около 150 баксов, но как говорится на каждый товар есть свой покупатель, Вам виднее.
BeePlus
сообщение 16.7.2014, 22:03
Из: Харьков
VE66 :)
Кстати согласен что выбор верный сделал и не взял мото G.
Реально сбалансированный смартик получился.
Добавлено позже (17.7.2014, 1:05):
Claus398, данный линк у нас давно, но нужен посредник.
Кстати 30 уе за посредника это хорошая цена, самая низкая получается.
TWIX11
сообщение 17.7.2014, 6:00
Из: Индия
stigr,
спасибо вам за совет про темку!
BeePlus, (клёвый ник)
высокая цена за посылку из Индии считается 50 у.е. , так что вы правильно сделали вывод!
наверно не стоит оффтопить больше тут ))
сообщение 17.7.2014, 6:09
TWIX11,
создай тогда тему, опиши сколько будет чего стоить, какие гарантии и тд.
TWIX11
сообщение 17.7.2014, 6:12
Из: Индия
Claus398,
Ок, только через недельку примерно создам, когда вернусь в Индию. Я щас в Шри-ланке нахожусь.
BeePlus
сообщение 20.7.2014, 7:57
Из: Харьков
VE66 :)
сообщение 20.7.2014, 15:42
BeePlus,
зачем ешку разбирал? Шото случилось или так спортивный интерес?
tuco
сообщение 20.7.2014, 16:05
Из: киров
Пользователь №: 220 793
Модель телефона: pixel 6a
30 баксов с телефона стоимостью 120? спасибо. в хендтеке он 4500 без доставки
сообщение 20.7.2014, 16:58
tuco,
ну на хендетке односимчный вариант, а тут двух.
BeePlus
сообщение 21.7.2014, 9:06
Из: Харьков
VE66 :)
Цитата(stigr @ 20.7.2014, 18:42) *
BeePlus,
Нет нигде фоток разобранного дуоса, вот и заполнил нишу.
Самому всегда интересно что и как (и тепер понимаю как его герметичным полностью сделать, хотя действительно он дождя защищен.
сообщение 21.7.2014, 9:56
BeePlus,
а случайно, фотки процесса разборки не делал?
Цитата(BeePlus @ Сегодня, 12:06)
* и тепер понимаю как его герметичным полностью сделать
ну и нам расскажи))
BeePlus
сообщение 22.7.2014, 21:10
Из: Харьков
VE66 :)
А что рассказывать ? Если крышка не люфтит, то можно вообще не париться. А так скотчем (наверное изолентой) залепить сзади прорези под аккум и вибрик ...
Со стороны 3.5 и USB стоит резина по периметру.
Сами панельки (верх и низ) с 2х бортиков и даже нет смысла между ними (было желание) прокладывать полоску резинки.
Короче, почти герметичен он. Уже столько раз пивом заливал, для демонстрации. grin.gif
captan2
сообщение 26.7.2014, 15:06
Из: Воронежская область
Пользователь №: 163 860
Модель телефона: z3 - xt5 - E - G3
Народ, выручайте. Сегодня прилетел в Рим, нашёл магазин с Моторолой. Там были 4 модели. Одна вылитая Е за которой я и пришёл, но на этикетке написано MOTO ME4K. в описании написано что это вообще MotoG. Спросил, весьма не приветливую продавщицу про Е. Она говорит вот Джи. А Е нету. Попробовал поиск в гугле. Пусто. Но по внешнему виду это Е, его двумя колонками. Что делать?
сообщение 26.7.2014, 15:31
captan2,
включи тел и посмотри название в настройках.
captan2
сообщение 26.7.2014, 15:53
Без знания языка и с приветливостью той мадам, я буду долго это делать))) поищу другой филиал этой сети, может там будет проще завтра)))
сообщение 26.7.2014, 18:38
captan2,
я с китайского языка на русский меню интерфейса в настройках перевел, а ты с итальянского не сможешь? там иконки есть для навигации, искать слово "Lingua" или что то в этом роде. удачи
Сообщение отредактировал Claus398 - 26.7.2014, 18:41
BeePlus
сообщение 27.7.2014, 21:35
Из: Харьков
VE66 :)
Цитата(captan2 @ 26.7.2014, 18:06)
* MOTO ME4K
сними заднюю крышку и если слот под 2 сим, то все ок.
а вообще продается только в Индия и Бразилия
Сообщение отредактировал BeePlus - 27.7.2014, 22:32
lcrmslcrms
сообщение 27.7.2014, 22:17
Captan2 .вот про me4k , обзор http://gambarhandphone.com/videos/motorola...o-e-unboxing-4k ,вроде киткат из коробки и кто мото джи на одну сим эго обзор по ссылке выше
Сообщение отредактировал lcrmslcrms - 27.7.2014, 22:40
captan2
сообщение 28.7.2014, 6:54
Не много, конечно, понял из видео) но спасибо. Так как других вариантов нет, пойду сегодня возьму, а там уж будете дальше помогать, надеюсь))
Добавлено позже (28.7.2014, 13:00):
Я сделал это))) я его купил. Правда на цвет не посмотрел. Тут не принято вроде как открывать в магазине. На ветрине был черный, ну я и думал по умолчанию и у меня тот же. Пришел в отель. А на коробочке написано белый))) какая прелесть. Гламур. Страшно коробочку открывать. Продавец был другой и на просьбу продать Моторолу он сразу спросил Мото джи или мото е.Парень в теме. Так же на коробке вычитал что модельХТ1021. И он сразу сказал что там нет зарядки, только USB кабель. Сейчас наверное буду открывать.
Добавлено позже (28.7.2014, 13:05):
Аааа! Там есть русский! Всё остальное всё равно ! Моторола, моя любовь!!!!!)
lcrmslcrms
сообщение 28.7.2014, 13:11
captan2,
Напиши пожалуйста цену в рознице .
Сообщение отредактировал lcrmslcrms - 28.7.2014, 13:18
BeePlus
сообщение 28.7.2014, 13:33
Из: Харьков
VE66 :)
captan2
сообщение 28.7.2014, 17:22
Стоимость 129 евро. Ну а мне и одной симки хватит)))
lcrmslcrms
сообщение 28.7.2014, 18:32
Спецификация на мото g /e http://www.devicespecifications.com/ru/comparison/a1883cf9
captan2
сообщение 4.8.2014, 19:26
Итак, я добрался до дома. Поменял сим-карту на микро и сижу балуюсь. Устанавливаю приложения, обновление ПО и так далее. Конечно телефон прелесть. Хотя сравнивать особо не с чем. Ну уж что есть. Но вот какая потеха. Как я и писал ранее зарядки как таковой нет. Только кабель USB. Батарея подразрядилась, я подключил к компьютеру и решил отвлечься от всех этих посыпавшихся сообщений в Вайбере. Отключаю телефон... а он включается... Повтор дал тот же результат. Незнаю как и думать.
сообщение 4.8.2014, 21:28
captan2,
заряди телефон зарядкой скажем от самсунга или аштиси, благо в каждом магазине продают такие, не советую заряжать от компа и использовать дешевые китайские зарядки.
[Moto E] Обзор и обсуждение Мото Е XT1022 - конкурент Moto G, прошивки, разлочка, Unlock, русский, инструкции, файлы, программы, игр · Motorola на Android OS · Forum
Текстовая версия Сейчас: 6.9.2025, 8:18
