5 страниц V < 1 2 3 4 5 >
[Moto E] Обзор и обсуждение Мото Е XT1022 - конкурент Moto G, прошивки, разлочка, Unlock, русский, инструкции, файлы, программы, игр
sidr
сообщение 22.6.2014, 13:11 Закрепленное сообщение!
Из: Бреста
Пользователь №: 168 840
Moto E (XT1021, XT1022, XT1025)
Техническое описание
Operating system - Android™ 4.4, KitKat®
Processor - Qualcomm® Snapdragon™ 200 with 1.2GHz dual-core A7 CPU
Adreno 302 400MHz single-core GPU
Capacity - 4GB standard MicroSD slot supports up to 32GB expandable memory 1GB RAM
Dimensions and weight - Height: 124.8mm
Width: 64.8mm
Depth: 12.3mm
Weight: 142g
Display - 4.3 inches 540 x 960 qHD, 256ppi Features anti-smudge coating and Corning Gorilla Glass 3
Connectivity - MicroUSB, supports USB 2.0 3.5 mm headset jack Micro SIM
Battery - Built-in rechargeable lithium-ion, 1980mAh Mixed usage up to 24 hours
Rear camera - 5 MP
Networks - US GSM Model:
GSM/GPRS/EDGE (850, 900, 1800, 1900 MHz)
UMTS/HSPA+ up to 21 Mbps (850, 1700 (AWS), 1900 MHz)
Requires a microSIM card (not included)
Global GSM Model:
UMTS/HSPA+ up to 21 Mbps (850, 900, 1900, 2100 MHz)
CDMA Model Coming Soon!
CDMA/EVDO Rev A (850, 1900 MHz)
Bluetooth® Technology - Version 4.0 LE
Wi-Fi - 802.11 b/g/n, 2.4GHz
Фото MOTO E
Видео
[video]https://www.youtube.com/watch?v=Cs6tV1Di3-8[/video]
Видео Moto E vs Moto G
[video]https://www.youtube.com/watch?v=rVKQJp21r9Q[/video]
ОФ прошивки для MOTO E
Инструкция по прошивки с hda
a) Download and install Motorola Moto EDrivers
b) Download and extract the stock Firmware of your choosing
c) If the firmware file you downloaded is a .xml.zip file then download Motorola Fastboot Attachment 2427667 (attached to this post) and extract the .exe into the same folder as the stock firmware files (the same folder as the .bin and .img files). If your firmware is a .tar.gz file then skip this step.
d) Get ADB (if you don't already have this, I suggest downloading and installing Minimal ADB and Fastboot by shimp208:
Direct Download
Disclaimer:
Follow these instructions at your own risk. If something goes wrong don't blame me!
These are the original stock signed image files from Motorola it should work on all Moto E Variants.
Steps to restore stock firmware:
1) Reboot the phone into bootloader mode. There are 2 ways to do this.
I) The 'hardware' way.
a) Unplug the USB cable and power off the phone.
b) Press and hold 'Volume down' then power on the phone.
c) Connect USB cable to your computer.
II) The 'software' way.
a) Enable developer mode on the Moto E (Settings-> 'About Phone'. Tap 7 times on 'Build Number')
b) Enable USB debugging. (Settings -> 'Developer options' -> 'USB Debugging' -> check)
c) Connect phone to computer via USB, you should see a new ADB device detected and drivers installed.
d) Open "Minimal ADB and Fastboot". Type:
Code:
adb reboot-bootloader
You should see the Moto E bootloader screen with the following options:
Code:
Normal Powerup
Recovery
Factory
Switch Console [NULL: null]
Barcodes
BP Tools
2) Open a command prompt / terminal (Start -> cmd.exe in Win7) and browse to the folder with the extracted firmware.
In my case:
Code:
cd c:\falcon_retgb_user_4.3_14.10.0Q3.X-76-LGG-8_54_release-keys-cid7-Retail_GB
3)
Flash each of the partitions in sequence using mfastboot, you need to enter the following commands one-by-one checking that each one returns an [OKAY]
Code:
mfastboot flash partition gpt.bin
mfastboot flash motoboot motoboot.img
mfastboot flash logo logo.bin
mfastboot flash boot boot.img
mfastboot flash recovery recovery.img
mfastboot flash system system.img_sparsechunk1
mfastboot flash system system.img_sparsechunk2
mfastboot flash system system.img_sparsechunk3
mfastboot flash modem NON-HLOS.bin
mfastboot erase modemst1
mfastboot erase modemst2
mfastboot flash fsg fsg.mbn
mfastboot erase cache
mfastboot erase userdata
mfastboot reboot
Downgrading:
4) Wait, you should now be rebooted into a fully stock Moto E firmware.
Драйвера
Где купить:
EBAY
AMAZON
Фото разобранного телефона
Сообщение отредактировал Воха - 20.12.2015, 19:28
i-text
сообщение 4.8.2014, 22:19
Пользователь №: 206 974
Модель телефона: Moto RAZR 5G
captan2, Не понимаю, а почему вы предпочли именно moto e ?
У мото g и вспышка (читай: фонарик) есть и фронт камера, да и стоит он не намного дороже. smile.gif
сообщение 5.8.2014, 6:21
Цитата(stigr @ Сегодня, 0:28)
* и использовать дешевые китайские зарядки.
и дешевые китайские юсб кабеля тоже.
сообщение 5.8.2014, 7:48
Claus398,
у него родной кабель из комплекта, мото никогда дешевку в комплект не ложила.
captan2
сообщение 5.8.2014, 9:45
Из: Воронежская область
Пользователь №: 163 860
Модель телефона: z3 - xt5 - E - G3
НУ почему Е сам ответить вам не смогу. Во-первых, на тот момент это была и новинка и отзывы были хорошие и шансы получить русский язык выше. Да, фронтальной камеры не хватает, но это не смертельно. Вот с зарядкой проблема, конечно. НУ продавец сразу предупредил меня, так что всё честно. Я вот думаю. К предыдущему квенчу родная зарядка сдохла и я покупал какую-то в Связном. Конечно, не родную (где ж я её найду). Может её использовать?
И не подскажите, никто не встречал в продаже в сети уже к Е сменные панели и чехлы?
Сообщение отредактировал captan2 - 5.8.2014, 11:21
BeePlus
сообщение 6.8.2014, 0:12
Из: Харьков
Пользователь №: 168 992
VE66 :)
Цитата(captan2 @ 4.8.2014, 22:26) *
Отключаю телефон... а он включается... Повтор дал тот же результат. Незнаю как и думать.
А зарядка, так это вообще рай (для меня) тк стандартная на 550 ма !!! И мотя официально писала заряжать током от 450 ма до 1.5 а
я и 2а заряжаю и с Motorola V8 , короче, все ок.
TWIX11
сообщение 9.8.2014, 4:09
Из: Индия
Пользователь №: 82 679
Модель телефона: slvr L7; Defi+; Мото-Е
Создал тему Спец продажа новых Moto-E (Dual sim)
Если какие вопросы - отвечу непременно!
сообщение 9.8.2014, 7:32
точно в ваших есть слот под карты памяти? рельное б фото..
TWIX11
сообщение 9.8.2014, 11:36
Из: Индия
точнее не бывает)
при подключении к компу выводит следущее окно :
сообщение 9.8.2014, 13:45
TWIX11
сообщение 9.8.2014, 14:05
Из: Индия
Цитата(Osta @ 9.8.2014, 17:45) *
именно так. Задняя крышка снимается ногтем и меняется и симки и флешка тоже ногтем ))
И кстати в коробке идёт зарядка под российские розетки, но она не usb-шная.
Click
сообщение 9.8.2014, 20:28
Из: г. Ростов-на-Дону
Пользователь №: 148 599
Модель телефона: Z2Play(xt1710-09)
Прошивка: 8.0
а какая она?? зарядка?
Сообщение отредактировал Click - 9.8.2014, 20:29
сообщение 9.8.2014, 20:32
Click,
ну видать TWIX11 имел ввиду что не такая зарядка как в последних мотоандроидах, где зарядка комплектуется отделяющимся юсб кабелем, а обыкновенная зарядка с встроенным проводом как было раньше.
TWIX11
сообщение 10.8.2014, 4:55
Из: Индия
stigr,
да. Для соединения с компом я пользуюсь юсб-кабелем от прошлой Мото defy+
А китайский дешовый юсб-кабель я тоже не рекомендую.
captan2
сообщение 18.9.2014, 10:35
Сегодня на почте получил заднюю крышку из Великобритании для Е. Оперативненько так... Теперь будет чем заменить мой белый задник)))
Voxa
сообщение 26.12.2014, 19:19
(M)otoVoxa
Из: г.Ставрополь
Пользователь №: 20 908
Модель телефона: Apple iPhone 6s 32Gb
А скажите что это за Moto E xt830c?
сообщение 26.12.2014, 19:26
Voxa,
это такой себе бюджетный аппарат от мото. стоит 2х ядерный снапдрагон 200, гиг оперативки, флешка, 4 гб собственной памяти. гарантировано выйдет андроид 5.0. 5 иегов камера. есть версии на 2 симки.
сообщение 26.12.2014, 20:37
Voxa,
а фиг его знает что за чудо, раньше буква С в конце обычно обозначала сдма телефон, наверно и тут так же. Но я не встречал ешки под сдма видать решили выпустить.
Добавлено позже (26.12.2014, 22:41):
Да точно, ультра бюджетник для компании Веризон, работает на стандарте сдма. Вроде жсм не работает.
Добавлено позже (26.12.2014, 22:43):
Claus398,
где ты вычитал что том есть две симки, вроде их там совсем нет?
сообщение 27.12.2014, 8:17
Цитата(stigr @ Вчера, 22:37)
* где ты вычитал что том есть две симки, вроде их там совсем нет?
http://www.gsmarena.com/motorola_moto_e_dual_sim-6323.php
Voxa
сообщение 27.12.2014, 9:35
(M)otoVoxa
Из: г.Ставрополь
А ну теперь понятно, а то просто смотрю xt830c стоит в два раза дешевле чем другие версии мото Е.
сообщение 27.12.2014, 15:08
Claus398,
ну и где ты вычитал что там написано про тот телефон что спрашивал Voxa.
Там стандартная ешка и ешка бразильская (XT1022 и XT1025), а тебя спросили именно о телефоне с определенным индексом (xt830c), читай вопрос внимательно. wink.gif
Voxa,
Странно что вообще сотку запросили. Хотя если это без привязки к контракту то супер, видать с контрактом совсем бесплатно отдадут. У веризона всегда в магазинах есть аппараты которые бесплатно дают с контрактом. Для Украины (Казахстана) годный тел. Главное что бы не было траблов с прошивкой сдма части.
сообщение 16.2.2015, 22:18
Сегодня тел неожиданно отрубился, на кнопки не реагировал при подключении к зарядке был вот такой скрин
Потом шото случилось и тел наконец загрузился. Батарея была шо до инцидента шо после почти полная. Кто с таким сталкивался, и вообще шо за скрин и шо за фигня была?
TWIX11
сообщение 21.2.2015, 22:47
Из: Индия
Было разок такое, сам удивлялся. Но ничо страшного так то.
На днях кстати поставил на него СМ11. Есть нарекания блин(( Виснет когда долго стоит на зарядке. Иконки приложений исчезают с раб.стола! Кароче еще недельку поезжу и скорей всего верну китКат.
captan2
сообщение 12.3.2015, 12:47
Доброго времени суток! Требуется ваша помощь))) (ну как всегда)) Наконец-то сестра собралась покупать новый телефон. Естественно это должна Моторола))) Про другой я бы и не разговаривал)) Но, так как обещанные официальные поставки в Россию так и не начались пока, один выход это ebay. Но там у меня опыта по сути нет. В теории всё понятно, а вот на практике как выбрать нужный товар - это проблема. Покупал бы себе, то риск был бы минимален так как всё прекрасно понимаю, а тут не себе, так что не хотелось бы лопухнуться. Понимаю что не совсем в тему пишу, но может поможете тыкнуть в нужный товар, так чтобы и цена была адекватной и телефон новый на 2 сим-карты, ну и всё как полагается. Очень буду благодарен. smile.gif
Тут залез на этот ebay а там уже в продаже односимочный второго поколения продают...
i-text
сообщение 12.3.2015, 13:06
Вот с доставкой в Россию: http://ebay.com/itm/251873229920
С доставкой 9300 обойдется.
Ох уж зтот доллар...
P.S. Еще рекомендую заказать чехол http://www.ebay.com/itm/S-line-Skin-f-Moto...=item4ad9105c89
77 рублей стоит. Продавец из Китая. Доставка в Россию бесплатная
Сообщение отредактировал i-text - 12.3.2015, 15:58
captan2
сообщение 19.3.2015, 18:36
Заказал. буду ждать. Надеюсь будет так же всё удачно как и с моим телефоном)))
madangelua
сообщение 21.6.2015, 19:36
Пользователь №: 248 203
Модель телефона: Droid 2 a955
Прошивка: 4.0.4
плохое
попался такой апарат цдма стандарта залоченый спц под оператора (Tracfone)Кто нибудь помочь его разлочить может? по мануалу с офф сайта говорит что не возможно
tima_02
сообщение 1.8.2015, 5:59
Пользователь №: 243 189
Модель телефона: Droid Razr HD XT926
Добрый день!
Имеется CDMA версия moto e XT1019, оператор US Cellular. Нужен spc\msl код для вшития номера intertelecom. Бут разлочен, рут есть. Возможно ли считать spc?
lcrmslcrms
сообщение 1.8.2015, 10:58
Пользователь №: 191 309
Прошивка: 42r/wm6.1/wm5.0
Цитата(tima_02 @ 1.8.2015, 8:59) *
Добрый день!
Вы пробовали те способы что я вам дал ?
tima_02
сообщение 1.8.2015, 13:52
Добрый день!
Да, пробовал. Через dfs не считывает. Есть еще варианты?
lcrmslcrms
сообщение 1.8.2015, 14:03
Добрый день!
по мануалу черtp hex редактор
lcrmslcrms
сообщение 2.8.2015, 14:34
Вот еще нашол сайт. https://dev.webb.so/msl/
tima_02
сообщение 3.8.2015, 12:36
Уже пробовал этот сайт, генерирует пароль 198000, так же как и в dfs справа внизу spc calculator, но не подходит, пишет BAD_SPC.
dfs
На телефонах moto x можно считать код через прогу spcutility если понизить версию прошивки и радио до 4.4.2. На XT1019 самая ранняя версия 4.4.4 и эта утилита не работает. В gsm версии moto e, например XT1021, есть прошивка 4.4.2, прошивая ее не подходит радио модуль, соответственно считать тоже не получается. Вопрос, с какого телефона можно попробовать зашить радио версии не старше 4.4.2?
lcrmslcrms
сообщение 3.8.2015, 12:54
tima_02,
если есть слот под руим то пробуйте с запустить сеть от интертелекома ,есть вероятность того что радиомодуль нельзя перевести в режим nv_only ,также попробуйте просто вполе сpc в бить 000000 .http://forum.xda-developers.com/showthread.php?p=47580651#post47580651
также янашол о том что Motorola Moto X U.S. Cellular - XT1055 (работает ТОЛЬКО с RUIM картой)
Сообщение отредактировал lcrmslcrms - 3.8.2015, 13:32
tima_02
сообщение 3.8.2015, 13:41
Цитата(lcrmslcrms @ 3.8.2015, 15:54) *
tima_02,
Пробовал 000000 и 198000, не записывает данные.
Слот физически отсутствует.
lcrmslcrms
сообщение 3.8.2015, 13:51
tima_02,
а вокршопом пробовали читать код ?
вот что я нашёл https://www.youtube.com/watch?v=51EXOg80QAo
Сообщение отредактировал lcrmslcrms - 3.8.2015, 13:54
tima_02
сообщение 3.8.2015, 14:01
tima_02,
Завтра попробую. А в сообщении с xda, в посте выше, я так и не понял что там делать. Сможете написать порядок действий. Спасибо
lcrmslcrms
сообщение 3.8.2015, 14:19
tima_02,
делайте по видео
1.перводим в режим bp tools =>грузимся в систему=> подключяемся к dfs => набираем ##626=> вводим 000000=> жмакаем veryfic => вкладка general => spc жмакаем кнопку read = получаем код .
по ссылке то для самсунга
вроде скачивайте бантик ищите adb отладчик
чтоб работал MSL Reader dhjlb,s нужна флешка так как код пишется на флешку
Сообщение отредактировал lcrmslcrms - 3.8.2015, 14:41
captan2
сообщение 16.9.2015, 6:48
Глупейший вопрос, наверное, но всё же. Андроид на этом телефоне обновляется или нет? И до какого? У меня стоит 4.4.4, хотя везде уже анонсируют шестой.
сообщение 16.9.2015, 20:34
captan2,
обещали до 5.0 обновить.
вообще как то быстро они 6й рекламируют, тогда на 5.1 толком ещё не обновились. если гугля будет столько обнов пилить, то их можно будет видеть только в новых телефонах.
captan2
сообщение 18.9.2015, 8:22
То есть просто сидеть и ждать?))
[Moto E] Обзор и обсуждение Мото Е XT1022 - конкурент Moto G, прошивки, разлочка, Unlock, русский, инструкции, файлы, программы, игр · Motorola на Android OS · Forum
Текстовая версия Сейчас: 6.9.2025, 8:18
