[Moto E] Обзор и обсуждение Мото Е XT1022 - конкурент Moto G, прошивки, разлочка, Unlock, русский, инструкции, файлы, программы, игр
sidr
сообщение 22.6.2014, 13:11 Закрепленное сообщение!
Из: Бреста
Пользователь №: 168 840
Moto E (XT1021, XT1022, XT1025)
Техническое описание
Operating system - Android™ 4.4, KitKat®
Processor - Qualcomm® Snapdragon™ 200 with 1.2GHz dual-core A7 CPU
Adreno 302 400MHz single-core GPU
Capacity - 4GB standard MicroSD slot supports up to 32GB expandable memory 1GB RAM
Dimensions and weight - Height: 124.8mm
Width: 64.8mm
Depth: 12.3mm
Weight: 142g
Display - 4.3 inches 540 x 960 qHD, 256ppi Features anti-smudge coating and Corning Gorilla Glass 3
Connectivity - MicroUSB, supports USB 2.0 3.5 mm headset jack Micro SIM
Battery - Built-in rechargeable lithium-ion, 1980mAh Mixed usage up to 24 hours
Rear camera - 5 MP
Networks - US GSM Model:
GSM/GPRS/EDGE (850, 900, 1800, 1900 MHz)
UMTS/HSPA+ up to 21 Mbps (850, 1700 (AWS), 1900 MHz)
Requires a microSIM card (not included)
Global GSM Model:
UMTS/HSPA+ up to 21 Mbps (850, 900, 1900, 2100 MHz)
CDMA Model Coming Soon!
CDMA/EVDO Rev A (850, 1900 MHz)
Bluetooth® Technology - Version 4.0 LE
Wi-Fi - 802.11 b/g/n, 2.4GHz
Фото MOTO E
Видео
[video]https://www.youtube.com/watch?v=Cs6tV1Di3-8[/video]
Видео Moto E vs Moto G
[video]https://www.youtube.com/watch?v=rVKQJp21r9Q[/video]
ОФ прошивки для MOTO E
Инструкция по прошивки с hda
a) Download and install Motorola Moto EDrivers
b) Download and extract the stock Firmware of your choosing
c) If the firmware file you downloaded is a .xml.zip file then download Motorola Fastboot Attachment 2427667 (attached to this post) and extract the .exe into the same folder as the stock firmware files (the same folder as the .bin and .img files). If your firmware is a .tar.gz file then skip this step.
d) Get ADB (if you don't already have this, I suggest downloading and installing Minimal ADB and Fastboot by shimp208:
Direct Download
Disclaimer:
Follow these instructions at your own risk. If something goes wrong don't blame me!
These are the original stock signed image files from Motorola it should work on all Moto E Variants.
Steps to restore stock firmware:
1) Reboot the phone into bootloader mode. There are 2 ways to do this.
I) The 'hardware' way.
a) Unplug the USB cable and power off the phone.
b) Press and hold 'Volume down' then power on the phone.
c) Connect USB cable to your computer.
II) The 'software' way.
a) Enable developer mode on the Moto E (Settings-> 'About Phone'. Tap 7 times on 'Build Number')
b) Enable USB debugging. (Settings -> 'Developer options' -> 'USB Debugging' -> check)
c) Connect phone to computer via USB, you should see a new ADB device detected and drivers installed.
d) Open "Minimal ADB and Fastboot". Type:
Code:
adb reboot-bootloader
You should see the Moto E bootloader screen with the following options:
Code:
Normal Powerup
Recovery
Factory
Switch Console [NULL: null]
Barcodes
BP Tools
2) Open a command prompt / terminal (Start -> cmd.exe in Win7) and browse to the folder with the extracted firmware.
In my case:
Code:
cd c:\falcon_retgb_user_4.3_14.10.0Q3.X-76-LGG-8_54_release-keys-cid7-Retail_GB
3)
Flash each of the partitions in sequence using mfastboot, you need to enter the following commands one-by-one checking that each one returns an [OKAY]
Code:
mfastboot flash partition gpt.bin
mfastboot flash motoboot motoboot.img
mfastboot flash logo logo.bin
mfastboot flash boot boot.img
mfastboot flash recovery recovery.img
mfastboot flash system system.img_sparsechunk1
mfastboot flash system system.img_sparsechunk2
mfastboot flash system system.img_sparsechunk3
mfastboot flash modem NON-HLOS.bin
mfastboot erase modemst1
mfastboot erase modemst2
mfastboot flash fsg fsg.mbn
mfastboot erase cache
mfastboot erase userdata
mfastboot reboot
Downgrading:
4) Wait, you should now be rebooted into a fully stock Moto E firmware.
Драйвера
Где купить:
EBAY
AMAZON
Фото разобранного телефона
Сообщение отредактировал Воха - 20.12.2015, 19:28
captan2
сообщение 29.5.2014, 15:01
Из: Воронежская область
Пользователь №: 163 860
Модель телефона: z3 - xt5 - E - G3
Так как моя нынешняя моторолка попрощалась со мной, то встал вопрос покупки новой. Через интернет присмотрел в Италии, куда поеду летом, модель Moto E. Но здесь на форуме совсем никак не могу найти темы с обсуждением данной модели. Тыкните мне, пожалуйста, если таковые есть что бы прочитать. Спасибо
5 страниц V  1 2 3 > »
Ответов(1 - 39)
сообщение 29.5.2014, 15:51
captan2,
пока информации мало. Новость анонса можно прочесть тут
На мой взгляд достойный девайс, хотя не без минусов. Например как по мне минус это отсутствие фронтальной камеры для видео связи, ну и вспышки (хотя это и не столь важно).
Но и есть отличный плюс в виде наличия слота карты памяти. На моем джи его явно не хватает.
-RPG-
сообщение 29.5.2014, 15:53
Пользователь №: 126 829
Модель телефона: куча разных
Прошивка: нестандарт
captan2, телефон совсем новый, еще ни у кого на руках скорее всего нет.
сообщение 29.5.2014, 18:08
по моему его даже в продаже пока нету. так что ждем появления в продаже.
сообщение 29.5.2014, 19:09
Claus398,
ошибаешься, в индии 120 000 ешек в онлайне распродали за пару часов.
сообщение 29.5.2014, 19:47
stigr,
а по чем продавали?
нашел вот http://www.ebay.com/itm/NEW-Motorola-Moto-...=item2ed24f787f 170 баксов, барыга продает, дороговато конечно. блин плохо что с офф сайта не отправляют по всему миру DHL'ом
captan2
сообщение 29.5.2014, 19:48
Claus398,
ну я практически наугад через официальный сайт вышел на региональный итальянский сайт и там есть ссылки на сайты магазинов типа Евроникс. И у них они стоят по 129 евро. Хотя немецкий сайт предлагает по 109, но под заказ. А доставка, как я прочитал здесь долгая и не дешёвая. Так что даже если так, то к концу июля уж они будут в продаже)) Иначе я без моторолки заскучаю совсем, хотя мой пенсионер Z3 сейчас выручает, но уже привык к смартфону(((
сообщение 29.5.2014, 20:01
Цитата(Claus398 @ Сегодня, 22:47)
* а по чем продавали?
129 баксов (но в рупиях). Так как мото и объявляла. Но я так и не понял продавалась двух симочная версия или простая. Новость видел в твиттере.
Добавлено позже (29.5.2014, 23:11):
Кст вот обзор от энгаджета. Будущим владельцам познавательно прочесть http://www.engadget.com/2014/05/26/moto-e-review/
captan2
сообщение 29.5.2014, 20:19
Я так понял продают односимочную http://www.euronics.it/acquistaonline/tele...=eProd142008979
За обзор спасибо, но с английским труба)))
сообщение 30.5.2014, 5:45
captan2,
в двух словах, они его хвалят. Минуса и плюсы они дают примерно теже. Плюс хвалят дисплей.
captan2
сообщение 30.5.2014, 6:49
Цитата(stigr @ 30.5.2014, 9:45) *
captan2,
Значит будем брать smile.gif через пару месяцев. Главное потом разобраться с языком))
сообщение 30.5.2014, 7:27
Цитата(captan2 @ Сегодня, 9:49)
* Главное потом разобраться с языком))
если с разлочкой бута не будет траблов, то и с русским не должно быть проблем. Ну если будут то прейдется ждать рут когда взломают.
captan2
сообщение 30.5.2014, 12:08
Ну вот тут я точно спешить не буду, со всякими там рутами. Не умею я этого))
Потому буду напрягать свой скромный английский))
сообщение 30.5.2014, 13:12
Цитата(captan2 @ Вчера, 22:48)
* ну я практически наугад через официальный сайт вышел на региональный итальянский сайт и там есть ссылки на сайты магазинов типа Евроникс. И у них они стоят по 129 евро. Хотя немецкий сайт предлагает по 109, но под заказ. А доставка, как я прочитал здесь долгая и не дешёвая.
за 150 евро с доставкой например, для меня уже пропадает интерес. так как за такие деньги можно купить и М и бритву шд(((
Цитата(stigr @ Вчера, 23:01)
* Кст вот обзор от энгаджета. Будущим владельцам познавательно прочесть http://www.engadget.com/2014/05/26/moto-e-review/
запись видео слабенькая конечно( я думал хоть шд будет. на камеру уклон не идет.
сообщение 30.5.2014, 13:33
Цитата(captan2 @ Сегодня, 15:08)
* Ну вот тут я точно спешить не буду, со всякими там рутами. Не умею я этого))
та ладно, если все будет так как на джи то в принципе не так и сложно, мануалы быстро появятся.
JUK1
сообщение 31.5.2014, 14:37
Из: Украина г.Кропивницкий
Пользователь №: 210 269
Модель телефона: MOTO Z PLAY XT1635-02
Прошивка: 8.0
Появился в продаже в Украине,в интернет магазине с наложенным платежом ссылка http://mbrand.com.ua/product_info.php?prod...62295ec3756bfc4 Там же есть много других Мото,покупал жене Moto g
Сообщение отредактировал JUK1 - 31.5.2014, 14:39
сообщение 1.6.2014, 6:47
JUK1,
цены конечно у них не ахти, за ту цену что они 8 гиговый односимочник джи продают купил в Украине 16 гигов дуал сим. Я уже не говорю что курс бакса у больше чем курс евро. Если пересчитать по нормальному курсу ешка у них будет стоить на сто баксов дороже чем продают официально, то есть больше 230 баксов. А теперь скажи кто в здравом уме купит у них его?
Через недельку обсуждение магазинов, покупки и прочие рассуждения вынесу в отдельную тему место которой в ветке Покупаем Motorola. Делимся опытом и помогаем!
сообщение 14.6.2014, 7:39
Простенький Видео обзорчик
[video]https://www.youtube.com/watch?v=GGx2qA0b7DE[/video]
XclusR
сообщение 19.6.2014, 20:33
Из: Н.Новгород
Пользователь №: 82 974
Модель телефона: Moto X Play
Прошивка: MPD24.107-52
Продается на амазоне:
http://www.amazon.com/Motorola-Moto-Global...keywords=moto+e
Кстати, в видеообзоре - присутствует русский язык. Он там изначально, или - пришел с обновлением до 4.4.3?
captan2
сообщение 20.6.2014, 17:46
Ага, вот меня тоже как "полиглота" интересует данный вопрос)))
Voxa
сообщение 22.6.2014, 11:39
(M)otoVoxa
Из: г.Ставрополь
Пользователь №: 20 908
Модель телефона: Apple iPhone 6s 32Gb
Я написал одному продавцу с ибея который продаёт moto E, он сказал что русского языка нету.
сообщение 27.6.2014, 7:09
На странице Motorola Германия в социальной сети Facebook появилось объявление об обновлении смартфонов Moto G и X до Android L. Что касается самого дешёвого смартфона компании, Moto E, то представитель Motorola дал крайне неоднозначный ответ: "Мы в настоящее время по-прежнему не знаем, имеет ли апдейт до Android 5.0 смысл, если его не будет, смартфон определённо получит обновление до Android One OS для маломощных устройств" (представитель Motorola говорил именно "Android 5.0" и "Android One OS").
Сайт
Volchik777
сообщение 28.6.2014, 14:10
Пользователь №: 114 628
Модель телефона: MG
Прошивка: -
Русский язык интерфейса присутствует на данном девайсе?
sidr
сообщение 28.6.2014, 14:58
Из: Бреста
Volchik777,
Русского нет это ответили в техпотдержке моторолы
BeePlus
сообщение 3.7.2014, 23:21
Из: Харьков
Пользователь №: 168 992
VE66 :)
Юзаю Moto e XT1022 (dual) русский с коробки. (4.4.2)
BeePlus
сообщение 4.7.2014, 8:19
Из: Харьков
VE66 :)
Анлочится через сайт Моторолы, далее через фастбут подкидываем кастом рекавери (TWRP) и с флешки устанавливаем SuperSU.
Пол часа делов и можно накатывать 11 циан (или остальные кастомы)
Мото как всегда мото, камера отстой и задняя крышка люфтит.
сообщение 4.7.2014, 9:14
Цитата(BeePlus @ Сегодня, 11:19)
* камера отстой
сама камера не ахти или её работа на 4.4?
BeePlus
сообщение 4.7.2014, 10:23
Из: Харьков
VE66 :)
* камера отстой
Сам модуль конечно.
нет автофокуса.
программно даже hdr есть, а снимки ...
Девайс супер, ожидал худшего (особенно видя какое железо), а так, нереально доволен.
Экран ... разрешение возможно не ахти, но картинка и качество .
Связь ... да что тут говорить.
И микрофон и динамики , а в наушниках звук
батарейка!!! (охотно верю что хватит на 24 часа)
киткат с коробки и есть апдейт на новые версии ...
Дорого правда для такого железа, но последняя истинная моторолка, можно и купить blind.gif
Кстати, обновилось бутлого , теперь все в символике чемпионата по футболу в Бразилии laugh.gif
Сообщение отредактировал BeePlus - 4.7.2014, 15:13
сообщение 4.7.2014, 17:24
Цитата(BeePlus @ Сегодня, 13:23)
* Девайс супер, ожидал худшего (особенно видя какое железо)
я електрофай 2 немного использовал, то на старом омапе 4 довольно таки и нормально. такого железа вполне хватит, если не игроман конечно.
BeePlus
сообщение 4.7.2014, 17:57
Из: Харьков
VE66 :)
я тоже омап люблю, главное что тут не МТК.
МТК такая лажа ... я леново приторговываю, наигрался.
Да и в дроид D3 тоже хватило на МТК
даже электричка вторая у друга (свою пристроил) , но тут квалком экономичнее получился.
С м-кой сравнить и то дольше тянет. Звук в разговорном динамике лучше м-ки.
брал для работы, понимаю восторг индусов.
Сообщение отредактировал BeePlus - 4.7.2014, 20:53
сообщение 4.7.2014, 18:08
BeePlus,
крышка люфтит сильно?
кроме крышки претензии к сборке и к материалам есть?
BeePlus
сообщение 4.7.2014, 20:49
Из: Харьков
VE66 :)
Цитата(stigr @ 4.7.2014, 21:08) *
BeePlus,
не, при надавливании. не сильно.
о, сборка ... сказка.
уже пивом и водой заливал дисплей, вода вообще скатывается и не остается на поверхности, капельками.
Кирпичик такой увесистый получился (мне вес нравится) и 14 винтами крепится задняя часть.
сообщение 4.7.2014, 20:56
Цитата(BeePlus @ Сегодня, 23:49)
* не, при надавливании. не сильно.
ааа, ну тогда на джи таже песня, но она у меня не была из коробки, появилась после не сильно аккуратного открывания крышки. Вставлял дополнительную крышку (белую) что у меня шла в комплекте на ней такого не было. Сейчас юзаю флип шел вместо задней крышки, он тоже поскрипывает при нажатии в области динамика.
Меня сборка в последних моторах очень радует.
Ну и не мало важный вопрос. Где брал и по чем с доставкой обошелся?
BeePlus
сообщение 5.7.2014, 23:24
Из: Харьков
VE66 :)
брал у перекупов, обошелся относительно дорого. (что по сути не важно , думал разочаруюсь)
в Индии продают по 117 уе.
Качество ... блин, да я уже запарился всем показывать и заливать дисплей пивом, а позже смывать водой smile.gif и столько винтиков на задней части корпуса crazy.gif
фотки с девайса.
Сообщение отредактировал BeePlus - 5.7.2014, 23:28
сообщение 6.7.2014, 6:49
фотки конечно не ах ти, но для освещенной местности и для ультра бюджетника сносные.
BeePlus
сообщение 6.7.2014, 9:11
Из: Харьков
VE66 :)
Я его брал для звонков (хочу нормально качество голоса и связи от моторолы, тк леново запарил ауканием и переспрашиваниями, особенно при движении в машине), работы (серфинг, мессенждеры, работа с базой и почтой), поиграться как всегда прошивками (знал что загрузчик анлочится и что апдеты будут от самой мото) и по той причине что последняя Моторола.
Про камеру знал.
конечно ожидал худшего если честно (за проц боялся, тк 45нм это типа раритет) за автономность (особенно после похожих аналогов), но реально как бюджетник ...
короче думаю как в индии самому (без прокладок) заказать беленький, для супруги. laugh.gif
Сообщение отредактировал BeePlus - 6.7.2014, 9:13
XclusR
сообщение 6.7.2014, 18:05
Из: Н.Новгород
BeePlus, если получится заказать в индии без посредников - будет очень интересно описание опыта.
Двухсимочная Мото Е - то, что я ищу ))
BeePlus
сообщение 11.7.2014, 0:28
Из: Харьков
VE66 :)
Ну что, единственный баг это плеер не включается после использования голосового управления (или набора голосом)
Приходится ребутить.
А так , прилетел апдейт до 4.4.4 (официалка) и к счастью обновили эту дурную звонилку (стоковый диалер китката, такой неудобный), улучшили камеру и скорость интерфейса.
Правда пришлось повозиться и вернуть все приложения в папку систем апп, тк апдейт не ставился (убив рут и накатав стоковый рекавери).
сообщение 11.7.2014, 5:38
Цитата(BeePlus @ 6.7.2014, 12:11)
* тк леново запарил ауканием и переспрашиваниями
а какая модель если не секрет?
Цитата(XclusR @ 6.7.2014, 21:05)
* если получится заказать в индии без посредников - будет очень интересно описание опыта.
вот вот, я бы и сам заказал бы с удовольствием, ещё бы и обзор подробный мог бы написать.
BeePlus,
кстати правда что русский по умолчанию есть в системе?
[Moto E] Обзор и обсуждение Мото Е XT1022 - конкурент Moto G, прошивки, разлочка, Unlock, русский, инструкции, файлы, программы, игр · Motorola на Android OS · Forum
Текстовая версия Сейчас: 23.7.2025, 9:26
