A3100 dead, how to resurrect?
Ruth511
сообщение 4.11.2020, 15:42
Пользователь №: 253 410
Модель телефона: Rizr Z8
I'm sorry for writing in English, and also for the noob questions.
I have an A3100. When I was using the Ghost tool to restore a bin file, the phone suddenly turned off. Maybe the battery ran out. I could not turn on the phone (battery was fully charge). When it is connected to PC, the port COM does not appear.
Was the power source IC dead? Is there any way to resurrect it?
Thanks!!!!
Воха
сообщение 5.11.2020, 2:44
Сектант Xiaomi
Из: Дніпро 🇺🇦
Пользователь №: 145 492
Прошивка: Android 12-13
Норм
Have You tried this "Инструкция по прошивке:" [A3100] Прошивка ?
Сообщение отредактировал Воха - 5.11.2020, 2:46
Ruth511
сообщение 6.11.2020, 13:48
The "Attila port" does not appear, now. Battery was fully charged. If the PC does not show the port, I cannot flash the firmware.
Воха
сообщение 6.11.2020, 14:52
Сектант Xiaomi
Из: Дніпро 🇺🇦
Норм
But the instructions say that you need to connect the phone to the computer without a battery.
сообщение 6.11.2020, 17:52
Ruth511,
What version of Windows are you using? Newer versions of Windows such as Windows 10 don't work well with old Motorola smartphones. Use Windows 7 or even Windows XP instead.
ps.gif You can run old Windows inside a virtual machine like Oracle VM VirtualBox or VMWare Workstation Player if you don't have hardware with it.
USB and COM ports can be forwarded into these virtual machines from your host quite easily.
Воха
сообщение 6.11.2020, 18:26
Сектант Xiaomi
Из: Дніпро 🇺🇦
Норм
He needs to make sure that a device with the required VID and PID appears in the Windows device manager, and only after that he can install programs, drivers and virtual machines wink.gif
Ruth511
сообщение 7.11.2020, 9:05
Thanks, guys.
I've tried both ways: with and without battery. But after the sudden turn off, it cannot be turned on.
I'm using Win8 and Win10, now. I will try Win7, then.
Воха
сообщение 7.11.2020, 10:03
Сектант Xiaomi
Из: Дніпро 🇺🇦
Норм
Цитата(Ruth511 @ Сегодня, 11:05)
* But after the sudden turn off, it cannot be turned on.
First - check Your cable with other phones
* I'm using Win8 and Win10, now. I will try Win7, then.
No no no. You do not understand, the installed system does not affect in any way whether the PC will see your phone))
You should have a clear understanding of how Windows Device Manager works. Open the Windows device manager and try to connect and disconnect different devices, you will see that the list is updated with each event, the same update should be done when the A3100 is connected, if this does not happen, then even windows 3.1 will not fix the situation grin.gif
Ruth511
сообщение 7.11.2020, 16:03
When the phone dead, I had taken an all-night charge. In the morning, the battery was warm, therefore, the battery was not the problemi I aslo have 2 more BT-60. When I connects it to the PC, Windows Device Management show no changes. I have 2 cables, both do not work then.
The phone dead when the restoring process (ghost) was not incompleted (more than 50%). So, I think some electronic components were dead by shock.
Воха
сообщение 7.11.2020, 16:24
Сектант Xiaomi
Из: Дніпро 🇺🇦
Норм
Цитата(Ruth511 @ Сегодня, 18:03)
* Windows Device Management show no changes
Well, while the Windows device manager does not display changes when the phone is connected, you should only look for the problem in the phone or cable
Ruth511
сообщение 10.11.2020, 15:22
I think it's not cable or battery.
Before it dead, I could not enter Download mode without battery.
I've changed the cable and the battery, but it could not be turned on.
I'm now looking for the way to activate the connection to PC. It may be the test point method or qualcomm hardware connection.
Текстовая версия Сейчас: 14.9.2025, 6:10
