croccio
сообщение 4.7.2010, 22:52
Пользователь №: 161 521
Модель телефона: L7 Slvr, c350
how can i open menu from shell??? i try so
CODE
/usr/SYSqtapp/xe/faultline view:flows/mainmenu/Mainmenu.xml 3
but it doesn't work =(
Pyth_ON!
сообщение 5.7.2010, 10:30
MOTOMAGXX0r
Пользователь №: 198 680
Модель телефона: ROKR EM30/PEARL VE66
Прошивка: R6716_G_71.01.02R_B
if you want to open the menu, the output process flowplayer to the fore ;/
croccio
сообщение 5.7.2010, 10:52
can u write the code please? i don't understand
(5.7.2010, 11:05):
i try so but in telnet it says that it couldn't search cmd flow player
CODE
./flowplayer -b -X -x
and try so
CODE
it doesn't work
(5.7.2010, 11:51):
i would open a preview menu.. so i mount file, then i would opn menu.. after menu close there wil be the umount of file.. see the code..
CODE
#!/bin/sh
mypath=${0%/*}
mount -o bind $mypath/1/main_view.svg /usr/SYSqtapp/xe/resource/skins/default/view/main_view.svg
kill `pidof flowplayer`
umount /usr/SYSqtapp/xe/resource/skins/default/view/main_view.svg
menu doesn't open
Pyth_ON!
сообщение 5.7.2010, 14:42
MOTOMAGXX0r
Judging by your first post you want from the console to open the menu, I understood correctly? smile.gif
If so, then you have to move the process forward flowplayer using, for example, zTaskManMini (he is in the topic of native programs).
zTaskManMini `pidof flowplayer`
and try so
it doesn't work
What do you think should happen after that?
#!/bin/sh
mypath=${0%/*}
menu doesn't open
on a plan of the script itself should open a menu?
croccio
сообщение 5.7.2010, 21:30
the menu doesn't open!
(5.7.2010, 21:38):
doesn't work
CODE
K()t
сообщение 5.7.2010, 22:34
Из: Niko City, Ukraine
Пользователь №: 202 229
Прошивка: CM
croccio,
It works, I'll check!
#!/bin/sh
mypath=${0%/*}
$mypath/zTaskManMini `pidof flowplayer`
Сообщение отредактировал K()t - 5.7.2010, 22:35
Прикрепленный файл zTaskManMini.rar   ( 4.04 килобайт ) Кол-во скачиваний: 73
croccio
сообщение 6.7.2010, 11:35
bro i do this
CODE
#!/bin/sh
mypath=${0%/*}
# mount file mainview.svg
# kill process flowplayerto refresh menu with the mount file
# re-open the process flowplayer
# move menu on the top
# mount the file to finish the preview
mount -o bind /mmc/movinand1/.Anim/images/main_view.svg /usr/SYSqtapp/xe/resource/skins/default/view/main_view.svg
mount -o bind /mmc/movinand1/.Anim/images/main_view.svg $CurrentSkin/svg/main_view.svg
this lock app and i kill the process to unlock my phone.. where is the poblem?? sorry but i'm new to this "world"
K()t
сообщение 6.7.2010, 16:11
Прошивка: CM
croccio, What is your code should do?
croccio
сообщение 6.7.2010, 16:52
a preview of menu..
K()t
сообщение 6.7.2010, 17:00
Прошивка: CM
croccio,
#!/bin/sh
mypath=${0%/*}
showQ "Анимация" "Вы хотите применить анимацию "Рыбки"?" 1
if [ "0" = "$?" ]
then
exit 0
fi
THEMECFG="/ezxlocal/download/appwrite/setup/ezx_theme.cfg"
CurrentSkin=`grep "^CurrentSkin = " "$THEMECFG" | sed "s/CurrentSkin = //"`
main_view=$CurrentSkin/svg/main_view.svg
mount -o bind $main_view /usr/SYSqtapp/xe/resource/skins/default/view/main_view.svg
-rf /mmc/movinand1/.Anim mkdir /mmc/movinand1/.Anim/
mkdir /mmc/movinand1/.Anim/images/
cp $mypath/file/1/*.* /mmc/movinand1/.Anim/images/
cp $mypath/file/S02_Anim /mmc/movinand1/unKnown/
/usr/SYSqtapp/phone/vibrateprocess
showQ "Анимация" "Успешно установленна, посмотреть что получилось" 1
if [ "0" = "$?" ]
then
exit 0
fi
/usr/SYSqtapp/xe/faultline view:flows/mainmenu/Mainmenu.xml 3 &
sleep 3
Сообщение отредактировал K()t - 6.7.2010, 21:24
Open Menu · Motorola ROKR E8, EM30 · Forum
Текстовая версия Сейчас: 11.8.2025, 15:08
Форум живёт: 8110 дней
