[Milestone] Cyanogenmod, Порт от Nadlabak'a
iBarS
сообщение 17.9.2010, 15:27
Из: Кемерово
Пользователь №: 64 876
Прошивка: 2.2
Home page: http://android.doshaska.net/cm6
Статус: первый публичный альфа релиз CyanogenMod 6 for Milestone (nandroid backup)
Что работает: надеюсь все (GSM, WiFi, BlueTooth, GPS, camera & focus, video & audio recording & playback, app2sd, Adobe flash)
Custom additions to CM6: several additional dictionaries for keyboard
Update: 22.9.2010 0.01c
- includes the previously released hot fixes for APN/GPS (i5) and unwanted boot during charge only mode (i10)
- temporarily used usb_mass_storage_fix script (borrowed from Dext3r) is gone. Motorola's proprietary usbd is back accompanied with Usb.apk (re-engineered to reflect changes in 2.2 os classes and to disable the unavailable options). StorageNotifications.java (part of services.jar) adjusted to not duplicate the notifications from Usb.apk. Usb.apk together with usbd allows to suspend the usb kernel driver and the phone can enter the suspend mode now. Hopefully, the battery life will be better.
- several adjustments in init scripts (includes the check for fighting adbd sometimes launched from the first init instance)
- QuickOffice.apk included
- Street.apk removed, so you can download and install the updated version from the market
- audioflinger recompiled to not include one unnecessary static lib
Note: when adb is enabled and usb connected during boot, you will have to disconnect and reconnect the usb cable before you can mount the SD card to a computer. chmod 644 /system/etc/init.d/02adb_during_boot will disable the early adb mode and the mount will be possible immediately. Early adb is enabled by default (well, it's alpha, right?).
Only system.img has been changed and there should be no need to wipe data when you update from 0.01/0.01b, but I highly recommend to delete cache and dalvik-cache. Use OpenRecovery 1.37 or newer. Don't forget to backup your customized /system/etc/init.d/10overclock first .
Main obstacles encountered:
missing new 2.2 functions in the proprietary audio driver library libaudio taken from 2.1 system, solved by modifications to AudioFlinger.cpp (getInputFramesLost and getRenderPosition).
Известные проблемы:
- intermittent chaotic touch screen responses when connected to USB
- system will reboot when sh.bin used to run the second instance of init or the 2nd init instance itself is killed, because the original init instance will suddenly try continue the deliberately frozen init process on an already running system
To do:
- prepare and release the source for custom building (=> installation via update.zip in the future)
- clean up the mess in init scripts
- invent some better init hijack
- make some non polling usb fix (for now it's using the Dext3r's script - thanks)
- etc.
Примечания:
- the main init scripts are located in /system/etc/rootfs
- clocking options (frequency table, vsel table and governors) can be set in /system/etc/init.d/10overclock
- google apps are already included in this one, I will change that in the future releases
- included BPSW and boot are from the 2.36 RTEU release - radio will work on European frequencies
Установка:
- use OpenRecovery to restore the downloaded system image on your phone
- if you are using Motorola's 2.1-update1 fix update, you do not need to restore the boot and BPSW, restore only the system
- data wipe/factory reset is highly recommended
Ссылки:
http://rapidshare.com/files/419591971/MM1_...alpha_0.01b.zip
http://rapidshare.com/files/420601255/MM1_...alpha_0.01c.zip
Сообщение отредактировал iBarS - 23.9.2010, 13:36
iBarS   [Milestone] Cyanogenmod   17.9.2010, 15:27
Alex469   Добавлю от себя. Только что поставил. Это андроид ...   17.9.2010, 15:54
iBarS   У меня почему-то на нем не работает тач, верх экра...   18.9.2010, 3:58
Ratmagor   Обманули бутлоадер? Или оно работает на старом ядр...   18.9.2010, 18:55
Silent_Bob   На старом ...   18.9.2010, 19:36
Vinndimon   А для русской клавы RU-keyboard используется? Приб...   19.9.2010, 9:33
Илья Дорошенко   я делал так: шьешь рекавери, он начинает загружать...   19.9.2010, 12:33
serzh44   я делал так: шьешь рекавери, он начинает загружат...   19.9.2010, 15:39
serzh44   ruKeyboard разве предназначена для офф. русских ап...   20.9.2010, 11:55
Silent_Bob   Там всё настраивается ... :ps: Настройки под РСТ M...   20.9.2010, 14:18
DeshFXs   скажите лучше про быстродействе, есть тот самый пр...   20.9.2010, 15:45
Илья Дорошенко   по меню анимация подтормаживает. но игры заходили ...   20.9.2010, 16:57
Ratmagor   Спасибо за помощь. Поставил - настроил - работает ...   20.9.2010, 17:02
serzh44   Я прироста в скорости не заметил. Может только сле...   20.9.2010, 21:09
Илья Дорошенко   Я прироста в скорости не заметил. Может только сл...   21.9.2010, 18:06
Ratmagor   По 4му пункту: запятая ставится через alt+. Кстат...   21.9.2010, 5:23
Alex469   По 4му пункту: запятая ставится через alt+. Это ...   21.9.2010, 5:42
iBarS   Обновился мод. Обновил 1й пост..   23.9.2010, 13:37
64kbiT   вообще perfect. но с батареей и правда беда, и зам...   24.9.2010, 17:07
Илья Дорошенко   хм... в новой версии батарейку скушал за ночь на 1...   25.9.2010, 3:28
64kbiT   хм... пользуюсь сим модом 2 день, перестали ставит...   25.9.2010, 8:25
Ratmagor   хм... пользуюсь сим модом 2 день, перестали стави...   25.9.2010, 18:11
sals999   app2sd не хочет работать на С версии, у кого ещё и...   25.9.2010, 14:20
64kbiT   sals999, в вечный ребут уходит? тут же 2.2 можно ...   25.9.2010, 15:50
sals999   64kbiT, не, не уходит, просто тел загружается а н...   25.9.2010, 17:38
64kbiT   Поддерживаю. свайп с рукейбордом не дружит ниразу...   25.9.2010, 18:25
iBarS   Update: 29.9.2010 0.02 This release is not much ab...   30.9.2010, 14:47
64kbiT   понял только то, что не особо фиксит баги. так соб...   30.9.2010, 16:07
Ratmagor   понял только то, что не особо фиксит баги. так со...   1.10.2010, 8:01
John-1994   Извиняюсь , сколько я раз уже видел эту тему , но ...   1.10.2010, 9:08
Ratmagor   Извиняюсь , сколько я раз уже видел эту тему , но...   1.10.2010, 9:46
XVilka   Да, кстати добавлю, что cyanogen и koush отказалис...   1.10.2010, 22:13
John-1994   Ratmagor , спасибо за ответ . Однако после него у ...   2.10.2010, 10:48
64kbiT   лично я цианоген поставил только ради переноса при...   2.10.2010, 13:49
John-1994   64kbit , на SIM-карте можно хранить контакты , по ...   2.10.2010, 14:23
64kbiT   John-1994, читай внимательнее. импортирую с симк...   2.10.2010, 16:39
John-1994   Аххх !!! :crazy: В общем установил я ...   2.10.2010, 16:57
64kbiT   Каким местом ты ставил мод?   2.10.2010, 17:28
John-1994   По моему правильным , закидывал в папку Update , п...   2.10.2010, 17:32
64kbiT   в названии "update" случайно не было? ст...   2.10.2010, 17:35
John-1994   Сейчас опробуем ... P.S. На нынешней кондиции ещё...   2.10.2010, 18:13
64kbiT   Нее, такого не замечал. у меня вечные ребуты при п...   2.10.2010, 18:25
John-1994   В общем установил я эту недоAlpha более приличным ...   3.10.2010, 10:26
64kbiT   флеш есть. его надо с маркета ставить сначала.   3.10.2010, 11:21
Ratmagor   Пользуюсь уже третью неделю cyanogenmod'ом. Из...   4.10.2010, 10:29
John-1994   Близко , но нет , у меня с Wi-Fi проблемы заключал...   4.10.2010, 11:47
64kbiT   уфффф, при подключении юсб для передачи данных ухо...   4.10.2010, 18:26
XVilka   Вот тут можно высказать пожелания и обратную связь...   5.10.2010, 6:16
64kbiT   поставил клавы, которые выложил боб, на цианоген. ...   5.10.2010, 8:15
iBarS   Update: 06.10.2010 0.02-10.10.06 - media playback ...   9.10.2010, 5:30
John-1994   Парни , пользователи Сайонджена , очень прошу выдр...   10.10.2010, 21:03
iBarS   Update: 11.10.2010 0.02-10.10.11 - tcmd replaced w...   11.10.2010, 11:52
iBarS   Он просто написал, что тестит см6 на 32 ядре (froy...   16.10.2010, 2:00
M.org   Гм, а как же "невозможность изменить ядро...   17.10.2010, 8:47
iBarS   Гм, а как же "невозможность изменить ядро...   17.10.2010, 10:04
Илья Дорошенко   народ уже давно юзает альфа версию фройо от моторо...   18.10.2010, 11:54
Илья Дорошенко   ГОТ нее склепал сборку!!! они только д...   20.10.2010, 7:05
John-1994   Кстати , а никто не сталкивался с проблемой того ,...   14.11.2010, 14:55
Ratmagor   Кстати , а никто не сталкивался с проблемой того ...   17.11.2010, 22:35
Asmodey777   а у кого сколько показывает Linpack на 1000Мгц? GO...   19.11.2010, 9:29
John-1994   Я использую Quadrant Benchmark , и общий показател...   19.11.2010, 13:09
lelvisl   Народ, у кого есть клава русская под свежий цианог...   20.11.2010, 22:28
Ratmagor   Cyanogenmod4Milestone. Домашняя страница Google Co...   21.11.2010, 10:50
disparo   Я поставил, через полдня откатился обратно на сток...   26.11.2010, 14:20
Ratmagor   Я поставил, через полдня откатился обратно на сто...   26.11.2010, 14:30
disparo   Свежий патсн под хардклаву: http://4pda.ru/forum/...   30.11.2010, 15:05
John-1994   Disparo , не знаешь как убить значок на панели уве...   2.12.2010, 12:59
disparo   Disparo , не знаешь как убить значок на панели ув...   6.12.2010, 8:30
Ratmagor   Самое главное - не забывать перегружаться после за...   4.12.2010, 1:21
John-1994   Значок патча для клавиатуры с предыдущей страницы ...   7.12.2010, 17:54
Ratmagor   Значок патча для клавиатуры с предыдущей страницы...   8.12.2010, 20:04
sibkor   Поставил циан,перестал работать 3g и edge,перепрош...   10.12.2010, 7:03
Ratmagor   Поставил циан,перестал работать 3g и edge,перепро...   10.12.2010, 11:19
sibkor   Поставил циан,перестал работать 3g и edge,перепр...   10.12.2010, 21:30
John-1994   APN настроен ?   10.12.2010, 21:55
sibkor   APN настроен ? Да настроен Добавлено позже (11....   11.12.2010, 8:43
Vinndimon   Ссылка на OpenRecovery не работает.   12.12.2010, 10:13
Ratmagor   Обновил закрепленный пост. Вышла новая версия циан...   12.12.2010, 15:13
Asmodey777   Я чёта туплю, для чего нужен второй раздел на флеш...   14.12.2010, 12:00
Ratmagor   Я чёта туплю, для чего нужен второй раздел на фле...   14.12.2010, 19:32
Asmodey777   Спасиб! а как настроить по пунктам app2ext? по...   15.12.2010, 10:38
Ratmagor   Спасиб! а как настроить по пунктам app2ext? п...   15.12.2010, 20:54
UserRokr   выложите русификатор хардклавы плз..   16.12.2010, 17:14
Shellton   Подскажите какую сборку циана лучше всего зас став...   18.12.2010, 15:37
Ratmagor   Подскажите какую сборку циана лучше всего зас ста...   18.12.2010, 18:37
Shellton   А как узнать какя последняя? Где ее скачать?   18.12.2010, 18:50
Ratmagor   А как узнать какя последняя? Где ее скачать? Как...   18.12.2010, 20:13
Shellton   Там же как я понимаю только апдейт. Покрайней мере...   18.12.2010, 20:52
John-1994   Это апдейт , ставится он тоже как апдейт , на инст...   18.12.2010, 22:17
Shellton   Все установилось поверх стоковой 2.1 Косяк был в т...   18.12.2010, 22:35
DeBasser   Добавлено позже (18.12.2010, 22:40): а расскажит...   18.12.2010, 23:10
MKRIK   думал дождаться офф, но что-то руки уж больно чешу...   20.12.2010, 18:37
Ratmagor   думал дождаться офф, но что-то руки уж больно чеш...   20.12.2010, 20:24
John-1994   Уже 9 дней нет обновления Циана , у меня уже начин...   20.12.2010, 22:26
Shellton   MKRIK, Когда я шил я сначала пробывал через ГОТ и...   21.12.2010, 0:15
MKRIK   прошил модом на основе последней сборки Циана, в ц...   21.12.2010, 10:20
rausNT   app2ext создает ссылку на директорию в фс телефо...   22.12.2010, 17:52
Ratmagor   app2ext создает ссылку на директорию в фс телеф...   22.12.2010, 21:20
4 страниц V  1 2 3 > »
[Milestone] Cyanogenmod, Порт от Nadlabak'a · Прошивки для телефонов на Android OS · Forum
Текстовая версия Сейчас: 10.8.2025, 21:28
