[Milestone] Cyanogenmod, Порт от Nadlabak'a
iBarS
сообщение 17.9.2010, 15:27
Из: Кемерово
Пользователь №: 64 876
Прошивка: 2.2
Home page: http://android.doshaska.net/cm6
Статус: первый публичный альфа релиз CyanogenMod 6 for Milestone (nandroid backup)
Что работает: надеюсь все (GSM, WiFi, BlueTooth, GPS, camera & focus, video & audio recording & playback, app2sd, Adobe flash)
Custom additions to CM6: several additional dictionaries for keyboard
Update: 22.9.2010 0.01c
- includes the previously released hot fixes for APN/GPS (i5) and unwanted boot during charge only mode (i10)
- temporarily used usb_mass_storage_fix script (borrowed from Dext3r) is gone. Motorola's proprietary usbd is back accompanied with Usb.apk (re-engineered to reflect changes in 2.2 os classes and to disable the unavailable options). StorageNotifications.java (part of services.jar) adjusted to not duplicate the notifications from Usb.apk. Usb.apk together with usbd allows to suspend the usb kernel driver and the phone can enter the suspend mode now. Hopefully, the battery life will be better.
- several adjustments in init scripts (includes the check for fighting adbd sometimes launched from the first init instance)
- QuickOffice.apk included
- Street.apk removed, so you can download and install the updated version from the market
- audioflinger recompiled to not include one unnecessary static lib
Note: when adb is enabled and usb connected during boot, you will have to disconnect and reconnect the usb cable before you can mount the SD card to a computer. chmod 644 /system/etc/init.d/02adb_during_boot will disable the early adb mode and the mount will be possible immediately. Early adb is enabled by default (well, it's alpha, right?).
Only system.img has been changed and there should be no need to wipe data when you update from 0.01/0.01b, but I highly recommend to delete cache and dalvik-cache. Use OpenRecovery 1.37 or newer. Don't forget to backup your customized /system/etc/init.d/10overclock first .
Main obstacles encountered:
missing new 2.2 functions in the proprietary audio driver library libaudio taken from 2.1 system, solved by modifications to AudioFlinger.cpp (getInputFramesLost and getRenderPosition).
Известные проблемы:
- intermittent chaotic touch screen responses when connected to USB
- system will reboot when sh.bin used to run the second instance of init or the 2nd init instance itself is killed, because the original init instance will suddenly try continue the deliberately frozen init process on an already running system
To do:
- prepare and release the source for custom building (=> installation via update.zip in the future)
- clean up the mess in init scripts
- invent some better init hijack
- make some non polling usb fix (for now it's using the Dext3r's script - thanks)
- etc.
Примечания:
- the main init scripts are located in /system/etc/rootfs
- clocking options (frequency table, vsel table and governors) can be set in /system/etc/init.d/10overclock
- google apps are already included in this one, I will change that in the future releases
- included BPSW and boot are from the 2.36 RTEU release - radio will work on European frequencies
Установка:
- use OpenRecovery to restore the downloaded system image on your phone
- if you are using Motorola's 2.1-update1 fix update, you do not need to restore the boot and BPSW, restore only the system
- data wipe/factory reset is highly recommended
Ссылки:
http://rapidshare.com/files/419591971/MM1_...alpha_0.01b.zip
http://rapidshare.com/files/420601255/MM1_...alpha_0.01c.zip
Сообщение отредактировал iBarS - 23.9.2010, 13:36
iBarS   [Milestone] Cyanogenmod   17.9.2010, 15:27
eNin   Йухуху! Полтора часа мучений (как всегда, всё ...   23.12.2010, 4:21
eNin   Что-то после его установки словно в акб дырка появ...   23.12.2010, 20:19
Ratmagor   Теперь такой вопрос, который мучает меня пол вчер...   24.12.2010, 14:55
eNin   Я пробовал то же самое делать в Рут Експлорере - п...   25.12.2010, 15:19
Ratmagor   Обновлен CM6, по идее должно увеличиться время жиз...   29.12.2010, 15:00
Hich   Доброй ночи! После установки циана,не могу под...   7.1.2011, 0:09
Hich   Блин вообще косяк,поставил гот,наверх циан,все про...   7.1.2011, 8:20
64kbiT   Postavil 27.12 batareya tak silno raduet P.s perez...   9.1.2011, 17:10
Ratmagor   Пока все ждут 2.2 в соседней ветке, нас обрадовали...   11.1.2011, 13:15
Varrkan   где ? какой шапке? Добавлено позже (11.1.2011, 17...   11.1.2011, 14:49
Ratmagor   где ? какой шапке? [i]Добавлено позже (11.1.2011...   11.1.2011, 16:54
John-1994   Чудненько , пока через пару месяцев 2.2 выйдет , м...   11.1.2011, 16:04
Respect_ff   что-то я порядком подзадолбался =\ не хочет у...   11.1.2011, 20:10
virp50   на этой проше работает синхронизация facebook ?   11.1.2011, 21:03
Trollbob   Стоит последний циан на androidiani recovery. unde...   13.1.2011, 11:22
John-1994   Respect_ff , ставить Сайнож. крайне просто : 1. Пр...   13.1.2011, 14:56
Ratmagor   Respect_ff , ставить Сайнож. крайне просто : 1. П...   13.1.2011, 23:23
John-1994   Но в противном случае же прошивка будет работать н...   14.1.2011, 10:34
Respect_ff   так делал все. как только начинаю шить,он бац и с...   14.1.2011, 14:28
John-1994   Шить на 2.2 от GOT или апдейтить ?   14.1.2011, 14:48
Respect_ff   Шить на 2.2 от GOT или апдейтить ? апдейтить, на...   16.1.2011, 15:06
Shellton   А как обновить версию цианоена на более новую, что...   14.1.2011, 17:17
John-1994   Просто обновить без вайпов , может ?   14.1.2011, 20:20
Jaykop   Здравствуйте а не подскажете где можно взять темы,...   15.1.2011, 8:58
John-1994   Подойдут любые , устанавливаемые апдейтом темы для...   15.1.2011, 10:13
Ratmagor   Подойдут любые , устанавливаемые апдейтом темы дл...   15.1.2011, 12:08
Trollbob   Подойдут любые , устанавливаемые апдейтом темы д...   16.1.2011, 18:50
Jaykop   Ratmagor, Хорошо спасибо!А то перепробовал уж...   15.1.2011, 12:42
eNin   А что, я правильно понял, что баг с утеканием заря...   15.1.2011, 13:28
portalxxl   Поставил последнюю версию. Это просто супер. И рус...   15.1.2011, 19:45
John-1994   Решил проблему со сваливанием браузера при воспрои...   15.1.2011, 22:08
Ratmagor   А что, я правильно понял, что баг с утеканием зар...   16.1.2011, 12:35
eNin   Это уже на том самом бразильском ядре? Камера на ...   16.1.2011, 14:02
JungleBrother   скажите, вайп удаляет данные с сд карты? а сейвы к...   16.1.2011, 14:21
Ratmagor   скажите, вайп удаляет данные с сд карты? а сейвы ...   16.1.2011, 20:15
eNin   Камера, вроде, и раньше не глючила. Поставил пос...   16.1.2011, 22:14
Ratmagor   [quote name='Ratmagor' post='1564659' date='16.1....   16.1.2011, 22:42
eNin   su rm /mnt/secure/asec/smdl2tmp1.asec Попробуй по...   17.1.2011, 5:38
Ratmagor   [quote name='Ratmagor' post='1564714' date='16.1....   17.1.2011, 11:48
Wedmed5   Если сделают с новым ядром, то наверное и я прошью...   17.1.2011, 2:27
CycJIuK   Привет всем. Установил последнюю версию данного мо...   21.1.2011, 9:55
Ratmagor   Привет всем. Установил последнюю версию данного м...   21.1.2011, 12:45
CycJIuK   Его нет, и скорее всего не будет. Так как это проп...   21.1.2011, 13:21
Ratmagor   ИЙЕС! nadlabak и Skrilax_CZ домучили модуль ex...   21.1.2011, 19:42
John-1994   Это ведь означает , что мы теперь можем запустить ...   21.1.2011, 21:59
Trollbob   Это ведь означает , что мы теперь можем запустить...   23.1.2011, 11:28
Ratmagor   [quote name='John-1994' post='1566348' date=...   23.1.2011, 18:07
John-1994   Ну , была где-то на "4пда.ру" программа ...   23.1.2011, 18:02
John-1994   Это очень старый мануал по установке Debian , из-з...   23.1.2011, 19:03
Ratmagor   Новая версия CM, ядро и бинарники от 19.01.   29.1.2011, 12:24
John-1994   Надеюсь такого количества багов , как это было с в...   29.1.2011, 12:59
Ratmagor   Надеюсь такого количества багов , как это было с ...   29.1.2011, 22:41
Bell071   [b][color=#009900]Прошивка в картинках. на примере...   31.1.2011, 2:40
Varrkan   Спасибо за инструкцию. Многие просили, и вот нашла...   31.1.2011, 5:14
azyra   Добрый день. Помогите разобраться: стоит версия 0,...   2.2.2011, 9:31
Bell071   Други, у меня к вам просьба. Попробуйте отключить ...   2.2.2011, 12:29
DeshFXs   Bell071, с включенным JIT бенчмарки выдают 1200+ о...   2.2.2011, 12:38
Bell071   Bell071, с включенным JIT бенчмарки выдают 1200+ ...   2.2.2011, 15:14
Vinndimon   Подскажите, а у циана с ревкцией на тач как дела о...   2.2.2011, 21:08
azyra   Подскажите, а у циана с ревкцией на тач как дела ...   3.2.2011, 6:54
Vinndimon   Подскажите, а у циана с ревкцией на тач как дела...   3.2.2011, 7:57
Bell071   бывает зависание на мертво(приходится дергать АК...   3.2.2011, 8:48
azyra   бывает зависание на мертво(приходится дергать А...   3.2.2011, 10:09
Vinndimon   И да... Реакция на тач у циана ничуть не лучше, че...   3.2.2011, 9:38
azyra   И да... Реакция на тач у циана ничуть не лучше, ч...   3.2.2011, 14:06
Vinndimon   И да... Реакция на тач у циана ничуть не лучше, ...   3.2.2011, 20:10
azyra   [quote name='azyra' post='1570777' date='3.2.2011...   3.2.2011, 21:15
Vinndimon   [quote name='azyra' post='1570777' date='3.2.201...   3.2.2011, 22:31
azyra   [quote name='azyra' post='1570938' date='3.2.2011...   4.2.2011, 5:29
Vinndimon   [quote name='azyra' post='1570938' date='3.2.201...   4.2.2011, 8:15
DeshFXs   И отключайте джут, если не попугаи а многозадачно...   3.2.2011, 10:50
64kbiT   чтото странное стало происходить последне время......   3.2.2011, 13:12
John-1994   To 64KBit : Трындец жесть , похоже вообще на то , ...   3.2.2011, 18:18
64kbiT   Ребят, аппарат на гарантии. Такая ерунда появляетс...   3.2.2011, 21:59
Илья Дорошенко   Ребят, аппарат на гарантии. Такая ерунда появляет...   4.2.2011, 5:38
DeshFXs   Для справки: походил без JIT день. Батарейки меньш...   3.2.2011, 22:01
Dart Plegas   Привет! Кто-нибудь поставил Cyanogenmod 7 хот...   4.2.2011, 5:33
azyra   Привет! Кто-нибудь поставил Cyanogenmod 7 хо...   4.2.2011, 6:34
DeshFXs   Dart Plegas, эм, и он даже для Milestone? 0_o   4.2.2011, 7:18
azyra   Dart Plegas, эм, и он даже для Milestone? 0_o ...   4.2.2011, 8:02
64kbiT   Поставил циан 7 на своего кашлеющего и хромого мон...   4.2.2011, 8:08
azyra   ого-го... ждем с нетерпением релиза. похоже гредет...   4.2.2011, 8:52
Ratmagor   как и ожидалось, несколько часов назад nadlabak вы...   4.2.2011, 11:52
Vinndimon   А где сии конфиги лежат?   4.2.2011, 20:43
Ratmagor   А где сии конфиги лежат? /system/build.prop По...   4.2.2011, 21:41
Jip   Пользуюсь CM7 два дня (билд от 6 февраля), всё про...   8.2.2011, 6:48
motoroller635   а навител на нем пробовали??? когда его в горизонт...   8.2.2011, 6:51
Varrkan   Навител не искажается уже даже в прошивке 2.1. Вер...   8.2.2011, 6:57
Jip   Выявил особенность: то ли дело в настройках телефо...   8.2.2011, 21:26
agronomchek   а на сколько кривой патч на клаву к циану 7му? мож...   12.2.2011, 13:04
Vinndimon   а на сколько кривой патч на клаву к циану 7му? мо...   12.2.2011, 15:14
Ratmagor   [quote name='agronomchek' post='1573876' date='12...   12.2.2011, 20:00
agronomchek   Премного благодарен)   13.2.2011, 9:39
Ratmagor   сборка с русской клавой циана от 14го февраля.   15.2.2011, 16:50
motoroller635   http://ge.tt/40FirFe сборка с русской клавой циан...   16.2.2011, 13:14
Ratmagor   [quote name='Ratmagor' post='1574971' date='15.2....   16.2.2011, 16:56
Bell071   Найдено приемлемое решение убогой циановской много...   16.2.2011, 19:52
agronomchek   Товарищи, подскажите в чем фишка. На сайте циана, ...   20.2.2011, 10:30
DeshFXs   появится =)   20.2.2011, 15:34
Ratmagor   Обновил ссылки в шапке, выложена свежая сборка с р...   21.2.2011, 14:08
4 страниц V < 1 2 3 4 >
[Milestone] Cyanogenmod, Порт от Nadlabak'a · Прошивки для телефонов на Android OS · Forum
Текстовая версия Сейчас: 10.8.2025, 21:29
