[Milestone] Cyanogenmod, Порт от Nadlabak'a
iBarS
сообщение 17.9.2010, 15:27
Из: Кемерово
Пользователь №: 64 876
Прошивка: 2.2
Home page: http://android.doshaska.net/cm6
Статус: первый публичный альфа релиз CyanogenMod 6 for Milestone (nandroid backup)
Что работает: надеюсь все (GSM, WiFi, BlueTooth, GPS, camera & focus, video & audio recording & playback, app2sd, Adobe flash)
Custom additions to CM6: several additional dictionaries for keyboard
Update: 22.9.2010 0.01c
- includes the previously released hot fixes for APN/GPS (i5) and unwanted boot during charge only mode (i10)
- temporarily used usb_mass_storage_fix script (borrowed from Dext3r) is gone. Motorola's proprietary usbd is back accompanied with Usb.apk (re-engineered to reflect changes in 2.2 os classes and to disable the unavailable options). StorageNotifications.java (part of services.jar) adjusted to not duplicate the notifications from Usb.apk. Usb.apk together with usbd allows to suspend the usb kernel driver and the phone can enter the suspend mode now. Hopefully, the battery life will be better.
- several adjustments in init scripts (includes the check for fighting adbd sometimes launched from the first init instance)
- QuickOffice.apk included
- Street.apk removed, so you can download and install the updated version from the market
- audioflinger recompiled to not include one unnecessary static lib
Note: when adb is enabled and usb connected during boot, you will have to disconnect and reconnect the usb cable before you can mount the SD card to a computer. chmod 644 /system/etc/init.d/02adb_during_boot will disable the early adb mode and the mount will be possible immediately. Early adb is enabled by default (well, it's alpha, right?).
Only system.img has been changed and there should be no need to wipe data when you update from 0.01/0.01b, but I highly recommend to delete cache and dalvik-cache. Use OpenRecovery 1.37 or newer. Don't forget to backup your customized /system/etc/init.d/10overclock first .
Main obstacles encountered:
missing new 2.2 functions in the proprietary audio driver library libaudio taken from 2.1 system, solved by modifications to AudioFlinger.cpp (getInputFramesLost and getRenderPosition).
Известные проблемы:
- intermittent chaotic touch screen responses when connected to USB
- system will reboot when sh.bin used to run the second instance of init or the 2nd init instance itself is killed, because the original init instance will suddenly try continue the deliberately frozen init process on an already running system
To do:
- prepare and release the source for custom building (=> installation via update.zip in the future)
- clean up the mess in init scripts
- invent some better init hijack
- make some non polling usb fix (for now it's using the Dext3r's script - thanks)
- etc.
Примечания:
- the main init scripts are located in /system/etc/rootfs
- clocking options (frequency table, vsel table and governors) can be set in /system/etc/init.d/10overclock
- google apps are already included in this one, I will change that in the future releases
- included BPSW and boot are from the 2.36 RTEU release - radio will work on European frequencies
Установка:
- use OpenRecovery to restore the downloaded system image on your phone
- if you are using Motorola's 2.1-update1 fix update, you do not need to restore the boot and BPSW, restore only the system
- data wipe/factory reset is highly recommended
Ссылки:
http://rapidshare.com/files/419591971/MM1_...alpha_0.01b.zip
http://rapidshare.com/files/420601255/MM1_...alpha_0.01c.zip
Сообщение отредактировал iBarS - 23.9.2010, 13:36
iBarS   [Milestone] Cyanogenmod   17.9.2010, 15:27
artanto   свежая сборка CM7 от goodwin_c, теперь циан RC4.1 ...   11.4.2011, 14:20
dark-termit   свежая сборка CM7 от goodwin_c, теперь циан RC4.1...   12.4.2011, 11:18
Ratmagor   свежая сборка CM7 от goodwin_c, теперь циан RC4....   12.4.2011, 17:52
dark-termit   Перед установкой чистим раздел system, делаем все...   13.4.2011, 13:22
Ratmagor   [quote name='Ratmagor' post='1589529' date='12.4....   13.4.2011, 16:36
dark-termit   [quote name='Ratmagor' post='1589529' date='12.4...   13.4.2011, 19:17
Ratmagor   Новая сборка от f_pasha. На соседнем ресурсе, чье ...   16.4.2011, 16:21
Alex Rokr   Новая сборка от f_pasha. На соседнем ресурсе, чье...   17.4.2011, 20:09
Bell071   Можно ее как-то отключить? Официальная раскладка ...   17.4.2011, 21:55
artanto   Dот и дождались мы релиза 7-го циана. Теперь от go...   20.4.2011, 6:56
Ratmagor   Обновление.   26.4.2011, 14:34
artanto   Обновление от goodwin_c на основе CM 7.1.0 RC0 (2....   4.5.2011, 6:40
JE5TER   Обновление от goodwin_c на основе CM 7.1.0 RC0 (2...   8.5.2011, 10:43
artanto   Сборка на основе CM7.1 RC1 от roadracer: update-RU...   11.5.2011, 12:31
Vinndimon   Народ, у меня последняя сборка CM7 от Паши и телеф...   12.5.2011, 21:06
Vinndimon   Народ, у меня последняя сборка CM7 от Паши и теле...   16.5.2011, 20:38
Ratmagor   Поменял свой майлстоун на desire hd. Если есть жел...   14.5.2011, 4:25
Eugene.E   Стоит ли GO SMS Pro у кого-нибудь на CM7? У меня о...   19.5.2011, 13:51
borisovam   У меня вообще странная "не дружба" субжа...   26.5.2011, 6:40
Vinndimon   У меня вообще странная "не дружба" субж...   26.5.2011, 8:47
grblmm   не качаются сборки f_pasha и goodwin перезалейте ...   28.5.2011, 13:34
grblmm   а как у кого с потребление ? что то очень быстро б...   30.5.2011, 10:32
Demm   Новая версия update-cm-7.1.0-RC11-11.07.10 Change ...   11.7.2011, 8:43
grblmm   Новая версия update-cm-7.1.0-RC11-11.07.10 а ка...   13.7.2011, 18:49
Alek1989   Ребят, после того как применил 7 мод,телефон заход...   12.7.2011, 21:47
SergGG   Ребят, после того как применил 7 мод,телефон захо...   13.7.2011, 6:27
Alek1989   Проблема решена, всем спасибо.   13.7.2011, 7:26
artanto   последние обновления циана: cyanogen.ru или cyanog...   25.8.2011, 8:49
ryst7777   стоит см7 0,0rc3 не вполне доволен оперативка зави...   4.11.2011, 14:19
NixCore   Ссылки на CM в закреплённом сообщении не работают ...   13.11.2011, 21:52
ryst7777   накатил см7,1,0,2 стало намного лучше все работает...   14.11.2011, 5:09
ryst7777   ссылки на прошивки на прочтите правила форума M...   14.11.2011, 9:08
ryst7777   поставил последнюю сборку от паши http://cyanogen...   21.11.2011, 18:23
Martyr   поставил последнюю сборку от паши http://cyanoge...   11.12.2011, 11:34
ryst7777   батарейка держит столько же сколько на официале за...   11.12.2011, 16:15
skorpionik82   народ такая проблема. шил Моторку с 2.1 офф в СМ п...   30.12.2011, 15:07
ryst7777   я чуть выше ссылочку давал дуй туда и делай все ...   30.12.2011, 15:39
skorpionik82   я чуть выше ссылочку давал дуй туда и делай все ...   1.1.2012, 11:10
DOMAN   еще вчера выщел первый CM9 для нашей модели :) ht...   6.1.2012, 4:38
Mоторчег   а можно поподробнее, обзорчик так сказать. и что з...   7.1.2012, 10:59
julixaeron   Ребята! Обновите пожалуйста шапку до актуально...   12.1.2012, 7:35
Ilya_GC   Согласен с julixaeron, тема актуальна. У кого уже ...   13.1.2012, 13:35
ryst7777   читай выше я писал про 2,3,7 пробовал разные остан...   14.1.2012, 6:23
DOMAN   не знаю то за сборка и кто автор. но Apps2ext, каж...   14.1.2012, 10:00
ryst7777   читал отзывы о сей сборке /К чёрту шашечки, тот мо...   14.1.2012, 12:04
R.U.S.H.A.N.   DOMAN, еще не проверил? :) как там режим модема...   15.1.2012, 11:26
DOMAN   проверил. не заню именно это не проверял, но чет м...   17.1.2012, 16:16
Martyr   Все-таки у меня наверное руки не из того места. Из...   30.1.2012, 0:50
Ilya_GC   Martyr, на флешке папка OpenRecovery случайно не л...   30.1.2012, 19:11
Martyr   Martyr, на флешке папка OpenRecovery случайно не ...   30.1.2012, 22:15
Ilya_GC   Может что-то с рекавери не так, повредилось. Попро...   30.1.2012, 22:44
Martyr   Может что-то с рекавери не так, повредилось. Попр...   31.1.2012, 5:33
Destinychild   1) после установки цианогена стало неправильно ото...   15.2.2012, 11:45
Kostyan43   Господа HELP!!!! Перепрошил тел 72...   17.2.2012, 12:43
stigr   я как понял у вас веха 720 а это прошивка для про...   17.2.2012, 15:06
Kostyan43   Веха 720-это чё? Я лузер в этом. У меня без клавы ...   20.2.2012, 9:12
stigr   Kostyan43, ну дак эта прошивка не для вашего теле...   20.2.2012, 10:26
Desmaster   Тело покупалось в английском магазине, было перепр...   26.2.2012, 7:55
Makaka-91   дошли руки установить мод, ставил 7.2.0 RC0a и в о...   15.3.2012, 18:49
Xalvat   Вопрос такой: на др ресурсах есть инфа, мол, Cyano...   16.3.2012, 4:37
Programmer-tm(Мотофан.)   Xalvat, Не знаю как Milestone, но на Defy+ ничего...   16.3.2012, 4:46
DeshFXs   Xalvat, тач убивает не CM, а влага, жара и песок))   20.3.2012, 8:42
noph8   но не Defy странности с тачем на CM есть. При поп...   20.3.2012, 11:16
TiM_22R   Крайняя наработка от nadlabak'a - CM7.2.4 с по...   4.11.2012, 10:46
ryst7777   был на пда читал тему прошил последний циан.через ...   5.11.2012, 13:01
TiM_22R   был на пда читал тему прошил последний циан.через...   6.11.2012, 12:50
ryst7777   недопонял как не разбивать,я без разбива флехи пер...   6.11.2012, 16:29
TiM_22R   Поставил подправленную см10 сборку от 28.11, подкл...   29.11.2012, 5:29
TiM_22R   Почему-то определяет как xt720... и да, результаты...   21.12.2012, 6:26
Stillpz   Хз, где написать, но так и не смог найти и понять ...   18.2.2013, 8:34
ULumia   Последний CyanogenMod 6 для Motorola Milestone на ...   25.10.2022, 13:00
Воха   Добавьте ссылки на другие версии, или свяжитесь со...   4.12.2022, 22:15
EXL   ULumia, Кстати, последний доступный CyanogenMod 7...   27.1.2023, 3:52
4 страниц V « < 2 3 4
[Milestone] Cyanogenmod, Порт от Nadlabak'a · Прошивки для телефонов на Android OS · Forum
Текстовая версия Сейчас: 10.8.2025, 21:28
