Help With Segmentation Fault
elias174
сообщение 22.10.2010, 11:23
Пользователь №: 219 111
Модель телефона: Motorokr em30
Прошивка: Responsorium 1.1
hi, I compile an application for e8/em30, I compile without problems but when I run telnet I get segmentation fault error, I did the debugging with gdb, and get this
CODE
(gdb) run zConverter
Starting program: /mmc/mmca1/zConverter zConverter
BFD: /lib/ld-linux.so.3: warning: sh_link not set for section `.ARM.exidx'
BFD: /lib/libc.so.6: warning: sh_link not set for section `.ARM.exidx'
BFD: /lib/libpthread.so.0: warning: sh_link not set for section `.ARM.exidx'
BFD: /usr/lib/libstdc++.so.6: warning: sh_link not set for section `.ARM.exidx'
BFD: /lib/libgcc_s.so.1: warning: sh_link not set for section `.ARM.exidx'
BFD: /usr/lib/libmedl.so: warning: sh_link not set for section `.ARM.exidx'
BFD: /usr/lib/libezxflex.so: warning: sh_link not set for section `.ARM.exidx'
BFD: /usr/lib/libvkm.so: warning: sh_link not set for section `.ARM.exidx'
BFD: /lib/librt.so.1: warning: sh_link not set for section `.ARM.exidx'
BFD: /usr/lib/ezx/lib/libconfigmanager.so: warning: sh_link not set for section
`.ARM.exidx'
BFD: /usr/lib/libconfigmanager.so: warning: sh_link not set for section `.ARM.ex
idx'
No such file or directory: No such file or directory
[*]QWidget::setMorphMode() is called. WinId=00000943, newMode=-1
[*]Old mode = 2
[*]this->isActiveWidow() is FALSE
[*]Morphing Mode of TLW 00000943 will be set to -1
[*]QWidget::setMorphMode() is called. WinId=00000945, newMode=-1
[*]Old mode = 2
[*]Morphing Mode of TLW 00000945 will be set to -1
Program received signal SIGSEGV, Segmentation fault.
0x41b47e48 in ZWidget::setAutoAdjustWidthInPanel ()
   from /usr/lib/libezxappbase.so.1
i need help with this, thanks in advance
Сообщение отредактировал elias174 - 22.10.2010, 11:23
elias174
сообщение 27.10.2010, 11:52
please i need your help
Ant-ON
сообщение 27.10.2010, 15:03
Пользователь №: 49 304
Прошивка: CM12 / CM10 / PM2
Need see sourcode code. So to say something hard. Add log into the program. Better through cout. To find the crash site in the code.
elias174
сообщение 27.10.2010, 20:58
i copy de source of my mmc (in the same routes) and i give the sames results, which is the command that I write? thanks bro
elias174
сообщение 13.11.2010, 16:38
please i need your help ant-on
Help With Segmentation Fault · Motorola ROKR E8, EM30 · Forum
Текстовая версия Сейчас: 12.9.2025, 9:04
