3 страниц V « < 2 3
E8_silence-7, Мод на основе 13r_e (обновление от 26.02.13)
smaylik
сообщение 15.11.2010, 18:37 Закрепленное сообщение!
Пользователь №: 173 531
E8_Silence-7
Autor: D-Boy
Based on: R6718_G_71.10.13R_E
Описание
Originally Posted by D-Boy
E8_Silence-7_Magicbox/ProcessMgr_13R_FW, I'm back...
Make sure that non-modded phones first be flashed with the correct version of noRSA bootloader!
When flashing is done, it's best to do master clear (Delete All Data) to achieve the best operating results!
Master Clear (Delete All Data):
Menu - Settings - Phone settings - Reset - Delete all data (Password: 000000)
Built-in input reason, the main clearance time is longer, about two minutes, please be patient!
I am the Lord because there is no clear result of the use of the obligation is not answered!!
I will begin by thanking those who contribute to the development of E8: ilove3D,龙 猪,泪,蜜蜂,maybeloveu,爱因,无印,Ro1ne, too many of them, endless lists, in short, thank you very much!
Thanks to ilove3D for the Magicbox, very powerful Task Manager, to 泪 for mgxInstaller, Rokr Mgr, Rokr tools and maybeloveu for the ProcessMgr.
Brush Pack is based on the ilove3D's Pro3 changes.
In accordance with their own ideas to add something.
I modified the package has always been the pursuit of speed and stability, unnecessary little things to add.
Divided into two versions, Magicbox version and ProcessMgr + Mpkgbox2.0 version.
Magicbox need to register, see the specific registration www.magxcn.com
for the free version, available to Friends of the machine is not up.
To maintain system stability, I do not like the built-in switch programs directly, so we only choose to forward to. CG36, CG46, CG52 components are used in cramfs format, improve system speed.
Brush Pack main features are as follows:
Both versions have built-in tears mgxInstaller, can choose to install into the menu or mpkgbox mgx or magicbox.
set which adds tears Rokr Mgr.
Built-in input methods. But need to manually import the theme and character input method.
After completion of the main brush clearance, the MarsInput folder into the phone memory unKnown can be.
\ MarsInput \ db may be replaced by your own font.
\ MarsInput \ theme can put themselves under the subject input method.
To keep the system speed at highest possible, sub-menu icons are disabled, you can enable them by yourself.
Sub.mgx
Also provides us with tears of gratitude to remove the installation tool in the menu mgx Mpkg Mgr, Thank you very much!
mpkg_mgr.mgx
For memory card partitioning you can use ilove3d's partitioner.
e8_parter_fixed.mgx
Other specific plug-it:
Note: This package in addition to built a music radar, but not built, or any other mgx java software, all software installed machine of their choice friends.
Set according to capture breath after running, choose to start automatically, after each boot can be automatically run.
If you press the music button after power is not exhaled, more like twice. After the first breath, after press time will be able to exhale.
the outgoing speed is fast.!
I thank those who have supported Friends of the machine, very grateful!
Скрины
E8_silence-7_Mod_ver_1.1
Перепакованная мной версия мода, пока тестовая.
Особенности:
- добавлен русский язык
- libezxappbase.so.1.0.0 заменена на патченую
- убраны китайские твики
- MagicBox заменен на MgxBox
- переработано меню
- авторан свапа на 3ий раздел флэш карты
- поддержка ext3 и ext2 разделов
- добавлен zCpuOverclock
- zTaskMan на зеленой кнопке
- Активировано HSA
- в файловом менеджере пункты ext и root
- EasyTheme как в zMod'e
- и по мелочам всякое
Если есть какие-либо пожелания или найдете баги пишите.
Известные БАГи сборки на данный момент( в следующей версии постараюсь устранить)
- не работает кнопка "нотка"
Установка
-Удалить все автораны с телефона и карты памяти, шрифты и прочую ерунду.
-переключиться на стандартный скин.
-Прошейте No_RSA_boot (если у вас его нет)
-Настройки\Настройки телефона\сброс\"Удалить все данные"
-прошейте монстр.
-если телефон не загружается, прошейте CG31 для своего бута.
-подождали 10 минут, после включения телефона и Настройки\Настройки телефона\сброс\"Удалить все данные" (Может показаться,что тел завис, это не так)
-после включения ждите 10 минут... перезагрузите телефон вручную.
-после включения ждите 10 минут. Телефон готов к использованию.
Скачать
E8_Silence-7_ProcessMgr_13R_FW.rar - http://u.115.com/file/t1bd5b56a9
E8_Silence-7_MagicBox_13R_FW.rar - http://u.115.com/file/t166a2a594
E8_Silence-7_Mod_ver_1.1 - http://depositfiles.com/files/x6mbu9djz
Версия 1.3.1 от J()KER'a
Описание
Скачать
Сообщение отредактировал Sereg_K - 4.3.2013, 8:47
aalleexxnn
сообщение 6.6.2013, 16:45
Пользователь №: 225 705
Модель телефона: ищу E8
однако совсем не принимает СМС. Накололся сегодня - хотел по интернету покупку совершить, СМС от сбера не дошла. Отправил СМС с другого телефона - не дошла. Переткнул симку в в другой телефон - СМС принимает, значит симка и МТС не виноваты. Сделал сброс настроек - все равно не принимает.
Капец.
DaNTaLiaN™
сообщение 6.6.2013, 17:05
Из: СПб
Пользователь №: 210 392
Модель телефона: Motorola
aalleexxnn,
версия от J()KERа?
aalleexxnn
сообщение 7.6.2013, 2:00
Цитата(DaNTaLiaN™ @ 6.6.2013, 23:05) *
aalleexxnn,
версия от J()KERа?
да, версия от J()KERа
но по-моему, я где-то давно в обсуждениях встречал какие-то траблы с СМС у "первоисточника" (71.10.13R), правда чем закончилось - не помню совершенно.
ps. только что перепрошился на сток 14CR, пришли все вчерашние СМС
Сообщение отредактировал aalleexxnn - 7.6.2013, 3:09
сообщение 8.6.2013, 19:51
Цитата(aalleexxnn @ 6.6.2013, 19:45)
* однако совсем не принимает СМС. Накололся сегодня - хотел по интернету покупку совершить, СМС от сбера не дошла. Отправил СМС с другого телефона - не дошла. Переткнул симку в в другой телефон - СМС принимает, значит симка и МТС не виноваты. Сделал сброс настроек - все равно не принимает.
Капец.
xз, в последне время активно юзал е8, часто звонил, писал\принимал смски, все приходило, ниразу никаких глюков не ловил, может оператор балуется?
Dfast
сообщение 9.6.2013, 15:03
Пользователь №: 216 506
Модель телефона: ROKR E1
Прошивка: 49r
Всем привет
Поставил вашу прошивку, версия 1.3.1 от джокера
Отличная прошивка, все устраивает, работает без нареканий, но есть вопросы по проигрывателю...все делал правильно, синхронизировал телефон с Windows Media, пробовал заливать музыку через него (нужно скинуть порядком 440 песен весом в 4гб (флешка стоит на 8гб)) закидываю песни в окошко синхронизации, жду пока обработаются, нажимаю синхронизировать, и как-то быстро проходит синхронизация, скидывается где-то на 300-400мб песен.пробовал много раз, резулитат одинаковый. Попробовал скидывать в реиме синхронизации песни не через ВМ, а просто в папку Music, скинул 50-70 песен, все было нормально, продолжил по 1 папке докидывать остальные песни, вышло порядком 200 песен, скинул, перезагрузил телефон, захожу в проигрыватель, а там пишет пусто! второй раз перезагрузил, на несколько секунд появился список песен, и сразу `пусто` Еще раз перезагрузил, захожу в плеер, выдает ошибку `Unknown ErrorOn`
1. Что я делаю не так?
2. Плеер потянет более 400 песен?
3. И вообще существют кастомные плееры, или кастомные прошивки с плеером, с которыми плясать с бубном не нужно?
Помогите пожалуйста, ибо без плеера на музыкальном телефоне, плоховато...
e8_silence-7 mod joker 1.3.1 / boot 06_AC (NoRSA)
сообщение 9.6.2013, 15:15
Dfast,
у меня было порядка 500 песен, все было норм, кроме первого запуса плеера (секунд 10 первый раз заходил в плейлист). Я бы посоветовал скинуть всю музыку сразу в корень папки Music, тоесть без подпапок, чтобы абослютна вся музыка сразу лежала в music и после того как скинешь музыку, удали все файлы которые начинаются с точки с корня флешки и памяти телефона, перезагрузи телефон и подожди минут 10
VINRARUS
сообщение 9.6.2013, 15:24
Термоядерный
Из: Чорнобиль
Пользователь №: 211 044
Прошивка: 740 MHz: Z6 and ZN5
youtu.be/A_yQLYLiSGQ
Цитата(Dfast @ Сегодня, 18:03)
* И вообще существют кастомные плееры
Да. Например этот справится с любым количеством музыки, годится для ежедневного прослушивания: Shell Player 2.0
Поддерживает как автоматическое так и ручное обновление базы песен.
Сообщение отредактировал VINRARUS - 9.6.2013, 15:25
сообщение 9.6.2013, 15:49
Цитата(VINRARUS @ Сегодня, 18:24)
* Shell Player 2.0
не умеет нормально интергрироваться в mediafinder
играет втрое тише чем стандартный
не сильно удобен в использовании
VINRARUS
сообщение 9.6.2013, 16:45
Термоядерный
Из: Чорнобиль
Цитата(J()KER @ Сегодня, 18:49)
* не умеет нормально интергрироваться в mediafinder
По моему я это реализовал.
* играет втрое тише чем стандартный
Не правда, я сделал решение.
* не сильно удобен в использовании
Смотря какие требования. Мне например стандартный не удобен был.
сообщение 9.6.2013, 17:23
Цитата(VINRARUS @ Сегодня, 19:45)
* По моему я это реализовал.
ты реализовал замену медиафайндера а не интеграцию
* Не правда, я сделал решение.
костыль, помимо поднятия громкости плеера, еще и системные звуки орать начинают
* Смотря какие требования. Мне например стандартный не удобен был.
на вкус и цвет, к тому же ты не пользовался плеером е8, а я не пользовался плеером зины\з6, так что xз как на них, но на е8 вполне сносный плеер (не без изъянов конечно)
VINRARUS
сообщение 9.6.2013, 17:30
Термоядерный
Из: Чорнобиль
aalleexxnn
сообщение 6.8.2013, 3:23
Капец.
разобрался. если на silence-7 вернуть забэкапленные SMS от прошивки на базе 14CR (файл messaging.db), то SMS не доходят. Или доходят в смысле принимаются, но не пишутся в базу и потом не оповещаются. Если "удалить все данные" то этот файл "обнуляется" и SMS принимаются. Видимо, какое-то несоответствие форматов. Хотя с прошивкой на базе 14CR все нормально.
сообщение 7.8.2013, 9:09
DOMAN
сообщение 4.11.2013, 4:35
Из: солнечная адыгея, майкоп.
Пользователь №: 199 932
Модель телефона: defy pro
как установить rockbox.pep на прошивке? известный способ не помог
E8_silence-7, Мод на основе 13r_e (обновление от 26.02.13) · Motorola ROKR E8, EM30 · Forum
3 страниц V « < 2 3
Текстовая версия Сейчас: 10.9.2025, 18:25
