3 страниц V < 1 2 3 >
E8_silence-7, Мод на основе 13r_e (обновление от 26.02.13)
smaylik
сообщение 15.11.2010, 18:37 Закрепленное сообщение!
Пользователь №: 173 531
E8_Silence-7
Autor: D-Boy
Based on: R6718_G_71.10.13R_E
Описание
Originally Posted by D-Boy
E8_Silence-7_Magicbox/ProcessMgr_13R_FW, I'm back...
Make sure that non-modded phones first be flashed with the correct version of noRSA bootloader!
When flashing is done, it's best to do master clear (Delete All Data) to achieve the best operating results!
Master Clear (Delete All Data):
Menu - Settings - Phone settings - Reset - Delete all data (Password: 000000)
Built-in input reason, the main clearance time is longer, about two minutes, please be patient!
I am the Lord because there is no clear result of the use of the obligation is not answered!!
I will begin by thanking those who contribute to the development of E8: ilove3D,龙 猪,泪,蜜蜂,maybeloveu,爱因,无印,Ro1ne, too many of them, endless lists, in short, thank you very much!
Thanks to ilove3D for the Magicbox, very powerful Task Manager, to 泪 for mgxInstaller, Rokr Mgr, Rokr tools and maybeloveu for the ProcessMgr.
Brush Pack is based on the ilove3D's Pro3 changes.
In accordance with their own ideas to add something.
I modified the package has always been the pursuit of speed and stability, unnecessary little things to add.
Divided into two versions, Magicbox version and ProcessMgr + Mpkgbox2.0 version.
Magicbox need to register, see the specific registration www.magxcn.com
for the free version, available to Friends of the machine is not up.
To maintain system stability, I do not like the built-in switch programs directly, so we only choose to forward to. CG36, CG46, CG52 components are used in cramfs format, improve system speed.
Brush Pack main features are as follows:
Both versions have built-in tears mgxInstaller, can choose to install into the menu or mpkgbox mgx or magicbox.
set which adds tears Rokr Mgr.
Built-in input methods. But need to manually import the theme and character input method.
After completion of the main brush clearance, the MarsInput folder into the phone memory unKnown can be.
\ MarsInput \ db may be replaced by your own font.
\ MarsInput \ theme can put themselves under the subject input method.
To keep the system speed at highest possible, sub-menu icons are disabled, you can enable them by yourself.
Sub.mgx
Also provides us with tears of gratitude to remove the installation tool in the menu mgx Mpkg Mgr, Thank you very much!
mpkg_mgr.mgx
For memory card partitioning you can use ilove3d's partitioner.
e8_parter_fixed.mgx
Other specific plug-it:
Note: This package in addition to built a music radar, but not built, or any other mgx java software, all software installed machine of their choice friends.
Set according to capture breath after running, choose to start automatically, after each boot can be automatically run.
If you press the music button after power is not exhaled, more like twice. After the first breath, after press time will be able to exhale.
the outgoing speed is fast.!
I thank those who have supported Friends of the machine, very grateful!
Скрины
E8_silence-7_Mod_ver_1.1
Перепакованная мной версия мода, пока тестовая.
Особенности:
- добавлен русский язык
- libezxappbase.so.1.0.0 заменена на патченую
- убраны китайские твики
- MagicBox заменен на MgxBox
- переработано меню
- авторан свапа на 3ий раздел флэш карты
- поддержка ext3 и ext2 разделов
- добавлен zCpuOverclock
- zTaskMan на зеленой кнопке
- Активировано HSA
- в файловом менеджере пункты ext и root
- EasyTheme как в zMod'e
- и по мелочам всякое
Если есть какие-либо пожелания или найдете баги пишите.
Известные БАГи сборки на данный момент( в следующей версии постараюсь устранить)
- не работает кнопка "нотка"
Установка
-Удалить все автораны с телефона и карты памяти, шрифты и прочую ерунду.
-переключиться на стандартный скин.
-Прошейте No_RSA_boot (если у вас его нет)
-Настройки\Настройки телефона\сброс\"Удалить все данные"
-прошейте монстр.
-если телефон не загружается, прошейте CG31 для своего бута.
-подождали 10 минут, после включения телефона и Настройки\Настройки телефона\сброс\"Удалить все данные" (Может показаться,что тел завис, это не так)
-после включения ждите 10 минут... перезагрузите телефон вручную.
-после включения ждите 10 минут. Телефон готов к использованию.
Скачать
E8_Silence-7_ProcessMgr_13R_FW.rar - http://u.115.com/file/t1bd5b56a9
E8_Silence-7_MagicBox_13R_FW.rar - http://u.115.com/file/t166a2a594
E8_Silence-7_Mod_ver_1.1 - http://depositfiles.com/files/x6mbu9djz
Версия 1.3.1 от J()KER'a
Описание
Скачать
Сообщение отредактировал Sereg_K - 4.3.2013, 8:47
igoripp
сообщение 4.7.2011, 5:40
Самый дерзкий
Из: Касимов, Муром
Пользователь №: 215 540
Модель телефона: sony ion
aalleexxnn, если я тебе сказал, что ссылка рабочая, значит так оно и ЕСТЬ. Что мешает нажать кнопку скачать, под той "лабудой" которую ты процитировал?! Или, все же, тебе РЕЛИГИЯ не позволяет это сделать!? Еще раз пишу: БУДЬ ВНИМАТЕЛЕН!!!
Еще в этой проше есть минус - не работает многопоточная ява, пришлось через натив организовать) Визуально, еще поставил скин стоковый ccmc, батарея стала дольше держать)
PS^Прикрепил мануал для "особо одаренных"
Сообщение отредактировал igoripp - 4.7.2011, 10:46
VINRARUS
сообщение 4.7.2011, 6:52
Термоядерный
Из: Чорнобиль
Пользователь №: 211 044
Прошивка: 740 MHz: Z6 and ZN5
youtu.be/A_yQLYLiSGQ
Цитата(igoripp @ Сегодня, 8:40)
* не работает многопоточная ява, пришлось через натив организовать
Может я не в свое дело лезу, но насколько я знаю файл из /usr/SYSjava/kvm это ява машына, когда из менюшки запускается ява прога, то на ява машыну передаеться всеголиш подобная команда "-launch 20000", а вот система следит чтобы если запущенная из меню /usr/SYSjava/kvm не закрыта (то есть ява в фоне), то не дает запустить другую ява прогу. И для обхода этой лабуды всего лиш нужно ява машынку перенести в другую папку, а по старому пути положыть скрипт.
Например если ява машынка лежыт в /usr/vin/kvm, то скрипт будет выглядеть так:
#!/bin/sh
/usr/vin/kvm $@ &
И таким образом будет достигнуто как правильное отображение явы в таске, так и мультиява с возможностью запуска до сотни ява прог одновременно. clapping.gif
Ну в моде для Z6 "Project Evolution 4' я так и сделал, и все работает.
igoripp
сообщение 4.7.2011, 8:00
Самый дерзкий
Из: Касимов, Муром
VINRARUS,
да, давно уже реализовано. Просто, по умолчанию этого нет. Решается это через натив. Через зквм. Достаточно один раз активировать и все)
smaylik
сообщение 4.7.2011, 11:31
Да когда я собирал про мульти яву просто забыл. ps я ей не пользуюсь)
zcpuoverclock выключается после перезагрузки.
igoripp
сообщение 4.7.2011, 12:30
Самый дерзкий
Из: Касимов, Муром
smaylik,
Не обрабатываются прикосновения к лицевому сенсору, омега же - работает. На счет лицевой панели сенсора не знаю, плюс это или минус...
Зачем так сделали?
y=$(showTextEntry "меню" "введите число2:" "")
Криво обрабатывает переменную y. На zMod все в порядке, получается, "косяк" прошивки
smaylik
сообщение 4.7.2011, 16:21
igoripp, не ко мне эти вопросы. Сенсор особенность .13R
igoripp
сообщение 10.7.2011, 11:25
Самый дерзкий
Из: Касимов, Муром
smaylik, к тебе пару вопросов.
1. Как понять "собирал"?
2. Разве ты автор прошивки?
3. Может это ты "накосячил" и из за тебя мои проблемы?
И чем чревато установить этот же монстр с сайта mmus.us
Сообщение отредактировал igoripp - 10.7.2011, 12:38
smaylik
сообщение 10.7.2011, 19:09
Я перепаковывал этот мод (silence_mod1.1\1.2), список изменений в шапке. Ничего серьезного не делал, только проверенные методы, поэтому ошибки которые у тебя выскакивают не моих рук дело. Хотя, если хочешь можешь поставить с mmus оригинал, и сам проверить. Чем это чревато, да ничем. Просто у тебя будет зашита быстрая китайская прошивка, без русского ленга.
Autor E8_silence-7: D-Boy
Сообщение отредактировал smaylik - 10.7.2011, 19:11
xf∞
сообщение 12.2.2012, 13:25
Пользователь №: 170 513
Модель телефона: Moto G2 (XT1068)
Прошивка: Чупа-чупс 5.0.2
Если вдруг на айфолдере истечёт срок годности, можете мне написать. я перезалью.
josi
сообщение 18.6.2012, 8:49
Из: Донецк
Пользователь №: 229 247
Модель телефона: Motorola ХТ 910
Она будет работать одекватно если я прошьюсь поверх з-мода??
igoripp
сообщение 18.6.2012, 9:50
Самый дерзкий
Из: Касимов, Муром
josi, да. Только не забудь с з-мод удалить автораны. А что мешает поверх стандартной, на которой базируется з-мод поставить? Так уж на верняка.
josi
сообщение 18.6.2012, 10:47
Из: Донецк
но у меня уже стоит з-мод на данный момент! или будет лучше прошить чистую R6713_G_71.14.1CR_A_, а потом уже этот мод??
igoripp
сообщение 18.6.2012, 10:52
Самый дерзкий
Из: Касимов, Муром
josi, будет лучше прошить, и после этого сделать общую очистку, а затем уже и шить силенс. Хотя повторюсь, разницы не должно быть.
smaylik
сообщение 19.6.2012, 11:11
тогда уж шей чистую R6718_G_71.10.13R_E
да, если ссылки умерли скажи перезалью
Сообщение отредактировал smaylik - 19.6.2012, 11:12
aalleexxnn
сообщение 19.6.2012, 11:59
Пользователь №: 225 705
Модель телефона: ищу E8
слегка не в тему, но близко:
никак не могу понять, что свежее?
71.10.13R или 71.14.1CR ? или просто 2 ветки расползлись в разные стороны...
igoripp
сообщение 19.6.2012, 14:34
Самый дерзкий
Из: Касимов, Муром
aalleexxnn, 14 как бы самая новая, для всех, кроме китая. 13 выпустили через какое-то время, после 14, специально для китайского рынка.
smaylik, перезалей, пожалуйста. А то, она уже как больше года мертвая.
smaylik
сообщение 20.6.2012, 19:22
E8_Silence-7_Mod_v.1.2.rar
igoripp
сообщение 21.6.2012, 7:51
Самый дерзкий
Из: Касимов, Муром
smaylik, а оригинальной 13ой нету?
smaylik
сообщение 21.6.2012, 18:27
нет
Makaka-91
сообщение 21.6.2012, 19:10
Из: Чебоксары
Пользователь №: 119 662
Модель телефона: V3, E8, V3x
вот - CMCC_E8_R6718_G_71.10.13R_E
igoripp
сообщение 21.6.2012, 19:48
Самый дерзкий
Из: Касимов, Муром
Makaka-91, ты реально мужик!!! Я ее найти нигде не мог nea.gif. Уже шил ее? Случаем не лоченая?
Попроси стигра ее на сайт загрузить, а потом, в теме прошивок для е8, дать на нее рабочую ссылку.
josi
сообщение 26.6.2012, 11:44
Из: Донецк
а что из этих двух надо шить?
E8_R6718_G_71.10.13R_E_GSXELBAM0APCNCMNSL009_PDS001_LP0615_GSXELBAMAPCNCMNSL_S008_E001_R001_G001_WIG124190_1FF.sbf
или
R6718_G_71.10.13R_E_elba_mol_Bootloader_consumer_replacer.shx
smaylik
сообщение 26.6.2012, 15:12
смотря что ты хочешь
первая - стоковая 13r
josi
сообщение 27.6.2012, 5:10
Из: Донецк
Прошился, вроде не че так шустрая, только вот не обновляет базы с телефона, почему? и можно ли добавить как нить копи/паст ??
igoripp
сообщение 27.6.2012, 6:57
Самый дерзкий
Из: Касимов, Муром
josi, какие базы? Если медиа, то удали все файлы(!) начинающиеся с точки, которые лежат в корне флеш-карты и памяти телефона.
josi
сообщение 27.6.2012, 8:29
Из: Донецк
а как мне открыть zpk, он почему-то отображается как неизвестный здесь. Тоесть можно ли зделать при нажатии на архив чтоб выскакивало уведомления об установки как в з-мод?
И плиз помогите с копи/паст, он ну очень нужен!!
Сообщение отредактировал josi - 27.6.2012, 9:23
smaylik
сообщение 27.6.2012, 9:33
zpk - чисто zmod фишка
копи-паста нет и не будет
этот мод собран, не чтобы тягаться с монстрами типа zmod. главная мысль была собрать быстрый мод, поэтому здесь имеется только минимально необходимый функционал. копи-паст несколько тормозил запуск некоторых приложений, из-за этого не присутствует.
да в монстре есть несколько косяков, есть что добавить, но времени заниматься им у меня нет+в планах сменить телефон. если кто-то хочет заняться развитием этой прошивки я буду только рад, если что-то будет нужно или непонятно,то помогу.
K()t
сообщение 29.6.2012, 21:38
Из: Niko City, Ukraine
Пользователь №: 202 229
Прошивка: CM
zpk сожно через скриптовую программу запускать, прикрутить копи паст дело 10 минут, я даже для этого патч делал
v1rtuzzz
сообщение 10.9.2012, 8:20
Пользователь №: 235 273
Модель телефона: moto
прошился этим модом. как убрать в настройках главного экрана настройки мусульманской "молитвы" ???
сообщение 18.2.2013, 15:50
Народ, ни у кого не осталось этой прошивки, smaylikом пересобранной?
и оригинальной 13R?
aalleexxnn
сообщение 18.2.2013, 16:50
и оригинальной 13R?
куда залить? есть обе
сообщение 18.2.2013, 16:58
aalleexxnn, отписал в личку
aalleexxnn
сообщение 18.2.2013, 17:15
CMCC_E8_R6718_G_71.10.13R_E.rar
http://gfile.ru/ajv0
E8_Silence-7_Mod_v.1.2.zip 85.58MB
http://gfile.ru/ajf2
Сообщение отредактировал aalleexxnn - 18.2.2013, 17:33
сообщение 25.2.2013, 13:35
Чуть обновил прошивку до версии 1.3.1
- Теперь жители Украины могут записывать 10значные номера в телефонный справочник и в списке вызовов они будут отображаться
- Добавил MuPDF и ассоциации на него (SDL установите сами)
Ссыль: http://yadi.sk/d/KXoZFUh531KZt
Старая версия (1.3)
Вот, пересобрал на досуге прошивку, будем считать что это версия 1.3 smile.gif
Изменений не много, но для меня это было критично, может еще кому пригодится
- Папки skins и mpkgbox перекочевали из файлового менеджера в .system с глаз долой
- Также убрал папки ext и root из файлового менеджера
- Собрал ядро с авторазгоном до 740 мгц (По умолчанию стоит стандартная 399, но если хотите увеличить до 740 или 636 то скачиваем jCPU и выбираем нужное, также можно разогнать до 532 через zCpuOverclock, который находится в настройках
- Переписал запуск zCpuOverclock (автор слишком экстравагантно его запускал, даже немного через заднюю чакру smile.gif )
- Удалил CG31
- Добавил мультияву
- Поправил конфиги (добавил поиск устройств блютуз в функции на главном экране, убрал значек активной линии из статус бара и еще может что-то, что не вспомнил)
- Добавил защиту от дурака: чтобы нельзя было одновременно запускать jCPU и zCpu
Ссылка для скачивания
http://yadi.sk/d/oyKW8mrX2sGLw
Ставить так:
-прошейте монстр.
Я бы еще посоветовал перед тем как производить вышеописанные операции прошить стандартную 13R, а потом ставить этот монстр.
В итоге вы получите, шуструю прошивку, без лишнего функционала.
____________________
А вот моя простенькая самопальная програмка: все просто до безобразия - устанавливаем, запускаем и выбираем нужную частоту, после обязательно перезагружаем телефон. Если выбрано Disable то разгонять можно как обычно через zCpuOverclock
Сообщение отредактировал J()KER - 3.3.2013, 22:49
are_ed
сообщение 25.2.2013, 16:17
Пользователь №: 164 538
how about battery use it drain battery or not
сообщение 25.2.2013, 17:09
are_ed, as well as on stock firmware if you will use 399mhz. On 740 battery will drain little more.
igoripp
сообщение 25.2.2013, 19:28
Самый дерзкий
Из: Касимов, Муром
J()KER, вот это ты молодец. Данная прошивка и вправду заслуживает внимания, но мне она не нравится из-за одного момента: лицевая панель не реагирует на прикосновения( Кстати, заметил изменения в радио?
сообщение 25.2.2013, 20:06
Цитата(igoripp @ Сегодня, 21:28)
* лицевая панель не реагирует на прикосновения(
у меня лицевая панель не первой свежести (хочу поменять корпус, как лишние деньги появятся) и у нее много ложных прикосновений, особенно в опере мини, особенно в полноэкранном наборе текста, поэтому для меня это плюс, по крайней мере с этой панелью
* Кстати, заметил изменения в радио?
в радио всмысле в fm или радиочасти телефона?
если fm то я им не пользуюсь, а связь еще не успел как следует протестировать, времени не было, нужен был смарт как основной телефон
____________
Если есть какие предложения - пишите, если что интересное, то может смогу прикрутить
aalleexxnn
сообщение 26.2.2013, 16:48
дешевые корпуса $3.5
http://cnn.cn/shop/rokr-c-501.html
я в интернете покупать не умею, мне отсюда доча купила и потом привезла
к плохому корпусу обязательно надо брать battery tray, именно там защелки ломучие.
извините, что не в тему.
Сообщение отредактировал aalleexxnn - 26.2.2013, 16:51
Sereg_K
сообщение 27.2.2013, 8:01
Мотоснайпер
Из: Жемчужина у моря
Пользователь №: 60 316
Модель телефона: ROKR E8
Прошивка: Z-Mod E8
Добавил в первый пост и закрепил его
Можешь с кратким описанием добавить ее в тему Приложения
E8_silence-7, Мод на основе 13r_e (обновление от 26.02.13) · Motorola ROKR E8, EM30 · Forum
Текстовая версия Сейчас: 5.8.2025, 9:29
