3 страниц V < 1 2 3 >
E8_silence-7, Мод на основе 13r_e (обновление от 26.02.13)
smaylik
сообщение 15.11.2010, 18:37 Закрепленное сообщение!
Пользователь №: 173 531
E8_Silence-7
Autor: D-Boy
Based on: R6718_G_71.10.13R_E
Описание
Originally Posted by D-Boy
E8_Silence-7_Magicbox/ProcessMgr_13R_FW, I'm back...
Make sure that non-modded phones first be flashed with the correct version of noRSA bootloader!
When flashing is done, it's best to do master clear (Delete All Data) to achieve the best operating results!
Master Clear (Delete All Data):
Menu - Settings - Phone settings - Reset - Delete all data (Password: 000000)
Built-in input reason, the main clearance time is longer, about two minutes, please be patient!
I am the Lord because there is no clear result of the use of the obligation is not answered!!
I will begin by thanking those who contribute to the development of E8: ilove3D,龙 猪,泪,蜜蜂,maybeloveu,爱因,无印,Ro1ne, too many of them, endless lists, in short, thank you very much!
Thanks to ilove3D for the Magicbox, very powerful Task Manager, to 泪 for mgxInstaller, Rokr Mgr, Rokr tools and maybeloveu for the ProcessMgr.
Brush Pack is based on the ilove3D's Pro3 changes.
In accordance with their own ideas to add something.
I modified the package has always been the pursuit of speed and stability, unnecessary little things to add.
Divided into two versions, Magicbox version and ProcessMgr + Mpkgbox2.0 version.
Magicbox need to register, see the specific registration www.magxcn.com
for the free version, available to Friends of the machine is not up.
To maintain system stability, I do not like the built-in switch programs directly, so we only choose to forward to. CG36, CG46, CG52 components are used in cramfs format, improve system speed.
Brush Pack main features are as follows:
Both versions have built-in tears mgxInstaller, can choose to install into the menu or mpkgbox mgx or magicbox.
set which adds tears Rokr Mgr.
Built-in input methods. But need to manually import the theme and character input method.
After completion of the main brush clearance, the MarsInput folder into the phone memory unKnown can be.
\ MarsInput \ db may be replaced by your own font.
\ MarsInput \ theme can put themselves under the subject input method.
To keep the system speed at highest possible, sub-menu icons are disabled, you can enable them by yourself.
Sub.mgx
Also provides us with tears of gratitude to remove the installation tool in the menu mgx Mpkg Mgr, Thank you very much!
mpkg_mgr.mgx
For memory card partitioning you can use ilove3d's partitioner.
e8_parter_fixed.mgx
Other specific plug-it:
Note: This package in addition to built a music radar, but not built, or any other mgx java software, all software installed machine of their choice friends.
Set according to capture breath after running, choose to start automatically, after each boot can be automatically run.
If you press the music button after power is not exhaled, more like twice. After the first breath, after press time will be able to exhale.
the outgoing speed is fast.!
I thank those who have supported Friends of the machine, very grateful!
Скрины
E8_silence-7_Mod_ver_1.1
Перепакованная мной версия мода, пока тестовая.
Особенности:
- добавлен русский язык
- libezxappbase.so.1.0.0 заменена на патченую
- убраны китайские твики
- MagicBox заменен на MgxBox
- переработано меню
- авторан свапа на 3ий раздел флэш карты
- поддержка ext3 и ext2 разделов
- добавлен zCpuOverclock
- zTaskMan на зеленой кнопке
- Активировано HSA
- в файловом менеджере пункты ext и root
- EasyTheme как в zMod'e
- и по мелочам всякое
Если есть какие-либо пожелания или найдете баги пишите.
Известные БАГи сборки на данный момент( в следующей версии постараюсь устранить)
- не работает кнопка "нотка"
Установка
-Удалить все автораны с телефона и карты памяти, шрифты и прочую ерунду.
-переключиться на стандартный скин.
-Прошейте No_RSA_boot (если у вас его нет)
-Настройки\Настройки телефона\сброс\"Удалить все данные"
-прошейте монстр.
-если телефон не загружается, прошейте CG31 для своего бута.
-подождали 10 минут, после включения телефона и Настройки\Настройки телефона\сброс\"Удалить все данные" (Может показаться,что тел завис, это не так)
-после включения ждите 10 минут... перезагрузите телефон вручную.
-после включения ждите 10 минут. Телефон готов к использованию.
Скачать
E8_Silence-7_ProcessMgr_13R_FW.rar - http://u.115.com/file/t1bd5b56a9
E8_Silence-7_MagicBox_13R_FW.rar - http://u.115.com/file/t166a2a594
E8_Silence-7_Mod_ver_1.1 - http://depositfiles.com/files/x6mbu9djz
Версия 1.3.1 от J()KER'a
Описание
Скачать
Сообщение отредактировал Sereg_K - 4.3.2013, 8:47
igoripp
сообщение 21.6.2012, 19:48
Самый дерзкий
Из: Касимов, Муром
Пользователь №: 215 540
Модель телефона: sony ion
Makaka-91, ты реально мужик!!! Я ее найти нигде не мог nea.gif. Уже шил ее? Случаем не лоченая?
Попроси стигра ее на сайт загрузить, а потом, в теме прошивок для е8, дать на нее рабочую ссылку.
josi
сообщение 26.6.2012, 11:44
Из: Донецк
Пользователь №: 229 247
Модель телефона: Motorola ХТ 910
а что из этих двух надо шить?
E8_R6718_G_71.10.13R_E_GSXELBAM0APCNCMNSL009_PDS001_LP0615_GSXELBAMAPCNCMNSL_S008_E001_R001_G001_WIG124190_1FF.sbf
или
R6718_G_71.10.13R_E_elba_mol_Bootloader_consumer_replacer.shx
smaylik
сообщение 26.6.2012, 15:12
смотря что ты хочешь
первая - стоковая 13r
josi
сообщение 27.6.2012, 5:10
Из: Донецк
Прошился, вроде не че так шустрая, только вот не обновляет базы с телефона, почему? и можно ли добавить как нить копи/паст ??
igoripp
сообщение 27.6.2012, 6:57
Самый дерзкий
Из: Касимов, Муром
josi, какие базы? Если медиа, то удали все файлы(!) начинающиеся с точки, которые лежат в корне флеш-карты и памяти телефона.
josi
сообщение 27.6.2012, 8:29
Из: Донецк
а как мне открыть zpk, он почему-то отображается как неизвестный здесь. Тоесть можно ли зделать при нажатии на архив чтоб выскакивало уведомления об установки как в з-мод?
И плиз помогите с копи/паст, он ну очень нужен!!
Сообщение отредактировал josi - 27.6.2012, 9:23
smaylik
сообщение 27.6.2012, 9:33
zpk - чисто zmod фишка
копи-паста нет и не будет
этот мод собран, не чтобы тягаться с монстрами типа zmod. главная мысль была собрать быстрый мод, поэтому здесь имеется только минимально необходимый функционал. копи-паст несколько тормозил запуск некоторых приложений, из-за этого не присутствует.
да в монстре есть несколько косяков, есть что добавить, но времени заниматься им у меня нет+в планах сменить телефон. если кто-то хочет заняться развитием этой прошивки я буду только рад, если что-то будет нужно или непонятно,то помогу.
K()t
сообщение 29.6.2012, 21:38
Из: Niko City, Ukraine
Пользователь №: 202 229
Прошивка: CM
zpk сожно через скриптовую программу запускать, прикрутить копи паст дело 10 минут, я даже для этого патч делал
v1rtuzzz
сообщение 10.9.2012, 8:20
Пользователь №: 235 273
Модель телефона: moto
прошился этим модом. как убрать в настройках главного экрана настройки мусульманской "молитвы" ???
сообщение 18.2.2013, 15:50
Народ, ни у кого не осталось этой прошивки, smaylikом пересобранной?
и оригинальной 13R?
aalleexxnn
сообщение 18.2.2013, 16:50
Пользователь №: 225 705
Модель телефона: ищу E8
и оригинальной 13R?
куда залить? есть обе
сообщение 18.2.2013, 16:58
aalleexxnn, отписал в личку
aalleexxnn
сообщение 18.2.2013, 17:15
CMCC_E8_R6718_G_71.10.13R_E.rar
http://gfile.ru/ajv0
E8_Silence-7_Mod_v.1.2.zip 85.58MB
http://gfile.ru/ajf2
Сообщение отредактировал aalleexxnn - 18.2.2013, 17:33
сообщение 25.2.2013, 13:35
Чуть обновил прошивку до версии 1.3.1
- Теперь жители Украины могут записывать 10значные номера в телефонный справочник и в списке вызовов они будут отображаться
- Добавил MuPDF и ассоциации на него (SDL установите сами)
Ссыль: http://yadi.sk/d/KXoZFUh531KZt
Старая версия (1.3)
Вот, пересобрал на досуге прошивку, будем считать что это версия 1.3 smile.gif
Изменений не много, но для меня это было критично, может еще кому пригодится
- Папки skins и mpkgbox перекочевали из файлового менеджера в .system с глаз долой
- Также убрал папки ext и root из файлового менеджера
- Собрал ядро с авторазгоном до 740 мгц (По умолчанию стоит стандартная 399, но если хотите увеличить до 740 или 636 то скачиваем jCPU и выбираем нужное, также можно разогнать до 532 через zCpuOverclock, который находится в настройках
- Переписал запуск zCpuOverclock (автор слишком экстравагантно его запускал, даже немного через заднюю чакру smile.gif )
- Удалил CG31
- Добавил мультияву
- Поправил конфиги (добавил поиск устройств блютуз в функции на главном экране, убрал значек активной линии из статус бара и еще может что-то, что не вспомнил)
- Добавил защиту от дурака: чтобы нельзя было одновременно запускать jCPU и zCpu
Ссылка для скачивания
http://yadi.sk/d/oyKW8mrX2sGLw
Ставить так:
-прошейте монстр.
Я бы еще посоветовал перед тем как производить вышеописанные операции прошить стандартную 13R, а потом ставить этот монстр.
В итоге вы получите, шуструю прошивку, без лишнего функционала.
____________________
А вот моя простенькая самопальная програмка: все просто до безобразия - устанавливаем, запускаем и выбираем нужную частоту, после обязательно перезагружаем телефон. Если выбрано Disable то разгонять можно как обычно через zCpuOverclock
Сообщение отредактировал J()KER - 3.3.2013, 22:49
are_ed
сообщение 25.2.2013, 16:17
Пользователь №: 164 538
how about battery use it drain battery or not
сообщение 25.2.2013, 17:09
are_ed, as well as on stock firmware if you will use 399mhz. On 740 battery will drain little more.
igoripp
сообщение 25.2.2013, 19:28
Самый дерзкий
Из: Касимов, Муром
J()KER, вот это ты молодец. Данная прошивка и вправду заслуживает внимания, но мне она не нравится из-за одного момента: лицевая панель не реагирует на прикосновения( Кстати, заметил изменения в радио?
сообщение 25.2.2013, 20:06
Цитата(igoripp @ Сегодня, 21:28)
* лицевая панель не реагирует на прикосновения(
у меня лицевая панель не первой свежести (хочу поменять корпус, как лишние деньги появятся) и у нее много ложных прикосновений, особенно в опере мини, особенно в полноэкранном наборе текста, поэтому для меня это плюс, по крайней мере с этой панелью
* Кстати, заметил изменения в радио?
в радио всмысле в fm или радиочасти телефона?
если fm то я им не пользуюсь, а связь еще не успел как следует протестировать, времени не было, нужен был смарт как основной телефон
____________
Если есть какие предложения - пишите, если что интересное, то может смогу прикрутить
aalleexxnn
сообщение 26.2.2013, 16:48
дешевые корпуса $3.5
http://cnn.cn/shop/rokr-c-501.html
я в интернете покупать не умею, мне отсюда доча купила и потом привезла
к плохому корпусу обязательно надо брать battery tray, именно там защелки ломучие.
извините, что не в тему.
Сообщение отредактировал aalleexxnn - 26.2.2013, 16:51
Sereg_K
сообщение 27.2.2013, 8:01
Мотоснайпер
Из: Жемчужина у моря
Пользователь №: 60 316
Модель телефона: ROKR E8
Прошивка: Z-Mod E8
Добавил в первый пост и закрепил его
Можешь с кратким описанием добавить ее в тему Приложения
сообщение 27.2.2013, 12:00
Цитата(Sereg_K @ Сегодня, 10:01)
* Добавил в первый пост и закрепил его
Спасибо)
Sereg_K, так она бесполезна на других прошивках, она всего навсего копирует патченую либу и добавляет ее в автозагрузку, без патченого ядра работать не будет.
Сообщение отредактировал J()KER - 27.2.2013, 12:02
igoripp
сообщение 27.2.2013, 14:02
Самый дерзкий
Из: Касимов, Муром
Цитата(J()KER @ Вчера, 0:06)
* в радио всмысле в fm или радиочасти телефона?
FM smile.gif Оно красивше стало...
сообщение 27.2.2013, 16:02
Цитата(igoripp @ Сегодня, 16:02)
* FM Оно красивше стало...
да я старое и не видел даже)) не запускал ни разу)
сообщение 3.3.2013, 22:23
aalleexxnn
сообщение 4.3.2013, 15:43
в общем, не повезло.
за несколько дней до того, как прошить v1.3, для "чистоты эксперимента" прошил типа исходную CMCC_E8_R6718_G_71.10.13R_E , которую сам же и выкладывал. Поигрался, потом смотрю - чего это там еще в архиве лежит - R6718_G_71.10.13R_E_elba_mol_Bootloader_consumer_replacer.shx
Прошил. Ну дурила же.В общем похоже, что сам не заметил, как поднял версию бута с исходной 06.a3 до 06.аа.
сижу шью V1.3. параллельно зашел на сайт - а уже есть 1.3.1. Скачал. версия 1.3 зашилась. Подождал 10 минут. Не делая сброса перешил на версию 1.3.1. подождал 10 минут. Сделал сброс. Телефон погрузился в ступор на очень долго. В общем, вытащил батарейку. Телефон не грузится - слегка подсвечивается экран на несколько секунд, тухнет, через несколько секунд опять подсвечивается, тухнет и так до бесконечности. Прошит стоковую 1CR, сбросился, перезагрузился, еще раз прошил v1.3.1. Та же песня.
Ну, думаю, что-то с загрузчикам - смотрю - а у него версия поднялась.
Ну, думаю, надо вернуть. И это была роковая ошибка. Главное, в глубине мозга помнил, что нельзя понижать бут, но вот руки шаловливые.
Теперь буду замыкание тестпоинт осваивать.
одно радует - это резервный е8 для экспериментов, основной е8 жив-здоров!
Сообщение отредактировал aalleexxnn - 4.3.2013, 15:47
сообщение 4.3.2013, 17:11
Цитата(aalleexxnn @ Сегодня, 17:43)
* Теперь буду замыкание тестпоинт осваивать.
главное не передержи, ато хоронить прийдется
Добавлено позже (4.3.2013, 19:12):
На будущее: эта шутка
* R6718_G_71.10.13R_E_elba_mol_Bootloader_consumer_replacer.shx
шьется только если после прошития прошивка не грузится (показывает что в буте ошибки появились) и то лучше ее вообще не шить
Сообщение отредактировал J()KER - 4.3.2013, 17:14
Chepurnoff
сообщение 24.3.2013, 12:37
Из: Тюмень - Пенза - Саратов
Пользователь №: 157 192
Прошивка: zMod
Ту бир ор нот ту бир?
Дошли руки и прошил версию 1.3.1
Посравнению с бывшей прошивкой что стояла на моем Е8 (помоему Z-mod) - очень шустрая, приятно пользоваться стало телефоном.
P/S - заметил, что звук в разговорном динамике стал громче. Может раньше у меня что-то с конфигами не то было, незнаю, но звук тоже радует)
Сообщение отредактировал Chepurnoff - 24.3.2013, 12:46
сообщение 24.3.2013, 23:41
Chepurnoff, спасибо smile.gif Никаких багов не заметил?
v1rtuzzz
сообщение 2.4.2013, 12:05
доброго дня, обьясните мне дураку по4ему в плеер не добавилась музыка закинутая в память телефона в папку Music ? после прошивки скинул песни на флешку и в память, музыку с флешки видит нормально! 4то делать? спасибо
сообщение 2.4.2013, 14:31
v1rtuzzz,
удалите файлы начинающиеся с точки из корня встроенной памяти и флешки и перезагрузите тел
Сообщение отредактировал J()KER - 2.4.2013, 14:32
v1rtuzzz
сообщение 3.4.2013, 12:41
удалил файлы с то4кой в на4але, перезагрузил, подождал 10 минут=не помогло sad.gif
Добавлено позже (3.4.2013, 13:33):
я уже флешку вытянул, перезалил музыку в память телефона=результата 0, музыки не видно
сообщение 3.4.2013, 15:34
v1rtuzzz, гляну у себя как будет время, а тебе пока посоветую попробовать залить музыку через синхронизацию Windows Media Player
Сообщение отредактировал J()KER - 3.4.2013, 15:34
v1rtuzzz
сообщение 3.4.2013, 22:03
поменял музыку местами с памяти на флешку, нашло и добавило в проигрыватель...
а как не шаманил и сброс делал, и ставил приложение для о4истки баз музыки не помогло
Chepurnoff
сообщение 9.4.2013, 20:22
Прошивка: zMod
J()KER,
Багов не заметил.
Только вот мусульманский календарь удивил. Первый раз такое вижу)
сообщение 9.4.2013, 20:23
Цитата(Chepurnoff @ Сегодня, 23:22)
* Только вот мусульманский календарь удивил. Первый раз такое вижу)
так я ж его выпилил в 1.3.1 О_о
сообщение 1.5.2013, 19:19
Цитата(v1rtuzzz @ 3.4.2013, 15:41)
* я уже флешку вытянул, перезалил музыку в память телефона=результата 0, музыки не видно
забыл написать: проверил у себя - телефон нормально видит музыку как с флешки так и с памяти телефона, единственное что, так это желательно удалять файлы с точкой с корня флешки и телефона после добавления новой музыки и перезагружать телефон
Сообщение отредактировал J()KER - 1.5.2013, 19:19
crazy SaZoN
сообщение 24.5.2013, 8:39
Пользователь №: 115 873
Модель телефона: RokR E1, E8
Прошивка: мотозверь
Товарищи, а для сохранения смс с прошивки zMod простого бекапа main.db достаточно? А то я помню проблемы какие-то были, что не подцепливался файл.
сообщение 24.5.2013, 11:20
crazy SaZoN, не знаю, не пробовал
crazy SaZoN
сообщение 24.5.2013, 12:39
Прошивка: мотозверь
VINRARUS
сообщение 24.5.2013, 14:39
Термоядерный
Из: Чорнобиль
Пользователь №: 211 044
Прошивка: 740 MHz: Z6 and ZN5
youtu.be/A_yQLYLiSGQ
Цитата(crazy SaZoN @ Сегодня, 11:39)
* а для сохранения смс с прошивки zMod простого бекапа main.db достаточно?
Нужно сохранить папку /ezxlocal/sysDatabase целиком, по крайней мере у меня с 1 main.db были проблемы, а с обома файлами в папке - нет.
А так этот бекап должен подойти для всех модов Е8, если не ошибаюсь. smile.gif
E8_silence-7, Мод на основе 13r_e (обновление от 26.02.13) · Motorola ROKR E8, EM30 · Forum
Текстовая версия Сейчас: 10.9.2025, 15:39
