3 страниц V < 1 2 3
E8_silence-7, Мод на основе 13r_e (обновление от 26.02.13)
smaylik
сообщение 15.11.2010, 18:37 Закрепленное сообщение!
Пользователь №: 173 531
E8_Silence-7
Autor: D-Boy
Based on: R6718_G_71.10.13R_E
Описание
Originally Posted by D-Boy
E8_Silence-7_Magicbox/ProcessMgr_13R_FW, I'm back...
Make sure that non-modded phones first be flashed with the correct version of noRSA bootloader!
When flashing is done, it's best to do master clear (Delete All Data) to achieve the best operating results!
Master Clear (Delete All Data):
Menu - Settings - Phone settings - Reset - Delete all data (Password: 000000)
Built-in input reason, the main clearance time is longer, about two minutes, please be patient!
I am the Lord because there is no clear result of the use of the obligation is not answered!!
I will begin by thanking those who contribute to the development of E8: ilove3D,龙 猪,泪,蜜蜂,maybeloveu,爱因,无印,Ro1ne, too many of them, endless lists, in short, thank you very much!
Thanks to ilove3D for the Magicbox, very powerful Task Manager, to 泪 for mgxInstaller, Rokr Mgr, Rokr tools and maybeloveu for the ProcessMgr.
Brush Pack is based on the ilove3D's Pro3 changes.
In accordance with their own ideas to add something.
I modified the package has always been the pursuit of speed and stability, unnecessary little things to add.
Divided into two versions, Magicbox version and ProcessMgr + Mpkgbox2.0 version.
Magicbox need to register, see the specific registration www.magxcn.com
for the free version, available to Friends of the machine is not up.
To maintain system stability, I do not like the built-in switch programs directly, so we only choose to forward to. CG36, CG46, CG52 components are used in cramfs format, improve system speed.
Brush Pack main features are as follows:
Both versions have built-in tears mgxInstaller, can choose to install into the menu or mpkgbox mgx or magicbox.
set which adds tears Rokr Mgr.
Built-in input methods. But need to manually import the theme and character input method.
After completion of the main brush clearance, the MarsInput folder into the phone memory unKnown can be.
\ MarsInput \ db may be replaced by your own font.
\ MarsInput \ theme can put themselves under the subject input method.
To keep the system speed at highest possible, sub-menu icons are disabled, you can enable them by yourself.
Sub.mgx
Also provides us with tears of gratitude to remove the installation tool in the menu mgx Mpkg Mgr, Thank you very much!
mpkg_mgr.mgx
For memory card partitioning you can use ilove3d's partitioner.
e8_parter_fixed.mgx
Other specific plug-it:
Note: This package in addition to built a music radar, but not built, or any other mgx java software, all software installed machine of their choice friends.
Set according to capture breath after running, choose to start automatically, after each boot can be automatically run.
If you press the music button after power is not exhaled, more like twice. After the first breath, after press time will be able to exhale.
the outgoing speed is fast.!
I thank those who have supported Friends of the machine, very grateful!
Скрины
E8_silence-7_Mod_ver_1.1
Перепакованная мной версия мода, пока тестовая.
Особенности:
- добавлен русский язык
- libezxappbase.so.1.0.0 заменена на патченую
- убраны китайские твики
- MagicBox заменен на MgxBox
- переработано меню
- авторан свапа на 3ий раздел флэш карты
- поддержка ext3 и ext2 разделов
- добавлен zCpuOverclock
- zTaskMan на зеленой кнопке
- Активировано HSA
- в файловом менеджере пункты ext и root
- EasyTheme как в zMod'e
- и по мелочам всякое
Если есть какие-либо пожелания или найдете баги пишите.
Известные БАГи сборки на данный момент( в следующей версии постараюсь устранить)
- не работает кнопка "нотка"
Установка
-Удалить все автораны с телефона и карты памяти, шрифты и прочую ерунду.
-переключиться на стандартный скин.
-Прошейте No_RSA_boot (если у вас его нет)
-Настройки\Настройки телефона\сброс\"Удалить все данные"
-прошейте монстр.
-если телефон не загружается, прошейте CG31 для своего бута.
-подождали 10 минут, после включения телефона и Настройки\Настройки телефона\сброс\"Удалить все данные" (Может показаться,что тел завис, это не так)
-после включения ждите 10 минут... перезагрузите телефон вручную.
-после включения ждите 10 минут. Телефон готов к использованию.
Скачать
E8_Silence-7_ProcessMgr_13R_FW.rar - http://u.115.com/file/t1bd5b56a9
E8_Silence-7_MagicBox_13R_FW.rar - http://u.115.com/file/t166a2a594
E8_Silence-7_Mod_ver_1.1 - http://depositfiles.com/files/x6mbu9djz
Версия 1.3.1 от J()KER'a
Описание
Скачать
Сообщение отредактировал Sereg_K - 4.3.2013, 8:47
сообщение 27.2.2013, 12:00
Цитата(Sereg_K @ Сегодня, 10:01)
* Добавил в первый пост и закрепил его
Спасибо)
Sereg_K, так она бесполезна на других прошивках, она всего навсего копирует патченую либу и добавляет ее в автозагрузку, без патченого ядра работать не будет.
Сообщение отредактировал J()KER - 27.2.2013, 12:02
igoripp
сообщение 27.2.2013, 14:02
Самый дерзкий
Из: Касимов, Муром
Пользователь №: 215 540
Модель телефона: sony ion
Цитата(J()KER @ Вчера, 0:06)
* в радио всмысле в fm или радиочасти телефона?
FM smile.gif Оно красивше стало...
сообщение 27.2.2013, 16:02
Цитата(igoripp @ Сегодня, 16:02)
* FM Оно красивше стало...
да я старое и не видел даже)) не запускал ни разу)
сообщение 3.3.2013, 22:23
aalleexxnn
сообщение 4.3.2013, 15:43
Пользователь №: 225 705
Модель телефона: ищу E8
в общем, не повезло.
за несколько дней до того, как прошить v1.3, для "чистоты эксперимента" прошил типа исходную CMCC_E8_R6718_G_71.10.13R_E , которую сам же и выкладывал. Поигрался, потом смотрю - чего это там еще в архиве лежит - R6718_G_71.10.13R_E_elba_mol_Bootloader_consumer_replacer.shx
Прошил. Ну дурила же.В общем похоже, что сам не заметил, как поднял версию бута с исходной 06.a3 до 06.аа.
сижу шью V1.3. параллельно зашел на сайт - а уже есть 1.3.1. Скачал. версия 1.3 зашилась. Подождал 10 минут. Не делая сброса перешил на версию 1.3.1. подождал 10 минут. Сделал сброс. Телефон погрузился в ступор на очень долго. В общем, вытащил батарейку. Телефон не грузится - слегка подсвечивается экран на несколько секунд, тухнет, через несколько секунд опять подсвечивается, тухнет и так до бесконечности. Прошит стоковую 1CR, сбросился, перезагрузился, еще раз прошил v1.3.1. Та же песня.
Ну, думаю, что-то с загрузчикам - смотрю - а у него версия поднялась.
Ну, думаю, надо вернуть. И это была роковая ошибка. Главное, в глубине мозга помнил, что нельзя понижать бут, но вот руки шаловливые.
Теперь буду замыкание тестпоинт осваивать.
одно радует - это резервный е8 для экспериментов, основной е8 жив-здоров!
Сообщение отредактировал aalleexxnn - 4.3.2013, 15:47
сообщение 4.3.2013, 17:11
Цитата(aalleexxnn @ Сегодня, 17:43)
* Теперь буду замыкание тестпоинт осваивать.
главное не передержи, ато хоронить прийдется
Добавлено позже (4.3.2013, 19:12):
На будущее: эта шутка
* R6718_G_71.10.13R_E_elba_mol_Bootloader_consumer_replacer.shx
шьется только если после прошития прошивка не грузится (показывает что в буте ошибки появились) и то лучше ее вообще не шить
Сообщение отредактировал J()KER - 4.3.2013, 17:14
Chepurnoff
сообщение 24.3.2013, 12:37
Из: Тюмень - Пенза - Саратов
Пользователь №: 157 192
Прошивка: zMod
Ту бир ор нот ту бир?
Дошли руки и прошил версию 1.3.1
Посравнению с бывшей прошивкой что стояла на моем Е8 (помоему Z-mod) - очень шустрая, приятно пользоваться стало телефоном.
P/S - заметил, что звук в разговорном динамике стал громче. Может раньше у меня что-то с конфигами не то было, незнаю, но звук тоже радует)
Сообщение отредактировал Chepurnoff - 24.3.2013, 12:46
сообщение 24.3.2013, 23:41
Chepurnoff, спасибо smile.gif Никаких багов не заметил?
v1rtuzzz
сообщение 2.4.2013, 12:05
Пользователь №: 235 273
Модель телефона: moto
доброго дня, обьясните мне дураку по4ему в плеер не добавилась музыка закинутая в память телефона в папку Music ? после прошивки скинул песни на флешку и в память, музыку с флешки видит нормально! 4то делать? спасибо
сообщение 2.4.2013, 14:31
v1rtuzzz,
удалите файлы начинающиеся с точки из корня встроенной памяти и флешки и перезагрузите тел
Сообщение отредактировал J()KER - 2.4.2013, 14:32
v1rtuzzz
сообщение 3.4.2013, 12:41
удалил файлы с то4кой в на4але, перезагрузил, подождал 10 минут=не помогло sad.gif
Добавлено позже (3.4.2013, 13:33):
я уже флешку вытянул, перезалил музыку в память телефона=результата 0, музыки не видно
сообщение 3.4.2013, 15:34
v1rtuzzz, гляну у себя как будет время, а тебе пока посоветую попробовать залить музыку через синхронизацию Windows Media Player
Сообщение отредактировал J()KER - 3.4.2013, 15:34
v1rtuzzz
сообщение 3.4.2013, 22:03
поменял музыку местами с памяти на флешку, нашло и добавило в проигрыватель...
а как не шаманил и сброс делал, и ставил приложение для о4истки баз музыки не помогло
Chepurnoff
сообщение 9.4.2013, 20:22
Прошивка: zMod
J()KER,
Багов не заметил.
Только вот мусульманский календарь удивил. Первый раз такое вижу)
сообщение 9.4.2013, 20:23
Цитата(Chepurnoff @ Сегодня, 23:22)
* Только вот мусульманский календарь удивил. Первый раз такое вижу)
так я ж его выпилил в 1.3.1 О_о
сообщение 1.5.2013, 19:19
Цитата(v1rtuzzz @ 3.4.2013, 15:41)
* я уже флешку вытянул, перезалил музыку в память телефона=результата 0, музыки не видно
забыл написать: проверил у себя - телефон нормально видит музыку как с флешки так и с памяти телефона, единственное что, так это желательно удалять файлы с точкой с корня флешки и телефона после добавления новой музыки и перезагружать телефон
Сообщение отредактировал J()KER - 1.5.2013, 19:19
crazy SaZoN
сообщение 24.5.2013, 8:39
Пользователь №: 115 873
Модель телефона: RokR E1, E8
Прошивка: мотозверь
Товарищи, а для сохранения смс с прошивки zMod простого бекапа main.db достаточно? А то я помню проблемы какие-то были, что не подцепливался файл.
сообщение 24.5.2013, 11:20
crazy SaZoN, не знаю, не пробовал
crazy SaZoN
сообщение 24.5.2013, 12:39
Прошивка: мотозверь
VINRARUS
сообщение 24.5.2013, 14:39
Термоядерный
Из: Чорнобиль
Пользователь №: 211 044
Прошивка: 740 MHz: Z6 and ZN5
youtu.be/A_yQLYLiSGQ
Цитата(crazy SaZoN @ Сегодня, 11:39)
* а для сохранения смс с прошивки zMod простого бекапа main.db достаточно?
Нужно сохранить папку /ezxlocal/sysDatabase целиком, по крайней мере у меня с 1 main.db были проблемы, а с обома файлами в папке - нет.
А так этот бекап должен подойти для всех модов Е8, если не ошибаюсь. smile.gif
aalleexxnn
сообщение 6.6.2013, 16:45
однако совсем не принимает СМС. Накололся сегодня - хотел по интернету покупку совершить, СМС от сбера не дошла. Отправил СМС с другого телефона - не дошла. Переткнул симку в в другой телефон - СМС принимает, значит симка и МТС не виноваты. Сделал сброс настроек - все равно не принимает.
Капец.
DaNTaLiaN™
сообщение 6.6.2013, 17:05
Из: СПб
Пользователь №: 210 392
Модель телефона: Motorola
aalleexxnn,
версия от J()KERа?
aalleexxnn
сообщение 7.6.2013, 2:00
Цитата(DaNTaLiaN™ @ 6.6.2013, 23:05) *
aalleexxnn,
версия от J()KERа?
да, версия от J()KERа
но по-моему, я где-то давно в обсуждениях встречал какие-то траблы с СМС у "первоисточника" (71.10.13R), правда чем закончилось - не помню совершенно.
ps. только что перепрошился на сток 14CR, пришли все вчерашние СМС
Сообщение отредактировал aalleexxnn - 7.6.2013, 3:09
сообщение 8.6.2013, 19:51
Цитата(aalleexxnn @ 6.6.2013, 19:45)
* однако совсем не принимает СМС. Накололся сегодня - хотел по интернету покупку совершить, СМС от сбера не дошла. Отправил СМС с другого телефона - не дошла. Переткнул симку в в другой телефон - СМС принимает, значит симка и МТС не виноваты. Сделал сброс настроек - все равно не принимает.
Капец.
xз, в последне время активно юзал е8, часто звонил, писал\принимал смски, все приходило, ниразу никаких глюков не ловил, может оператор балуется?
Dfast
сообщение 9.6.2013, 15:03
Пользователь №: 216 506
Модель телефона: ROKR E1
Прошивка: 49r
Всем привет
Поставил вашу прошивку, версия 1.3.1 от джокера
Отличная прошивка, все устраивает, работает без нареканий, но есть вопросы по проигрывателю...все делал правильно, синхронизировал телефон с Windows Media, пробовал заливать музыку через него (нужно скинуть порядком 440 песен весом в 4гб (флешка стоит на 8гб)) закидываю песни в окошко синхронизации, жду пока обработаются, нажимаю синхронизировать, и как-то быстро проходит синхронизация, скидывается где-то на 300-400мб песен.пробовал много раз, резулитат одинаковый. Попробовал скидывать в реиме синхронизации песни не через ВМ, а просто в папку Music, скинул 50-70 песен, все было нормально, продолжил по 1 папке докидывать остальные песни, вышло порядком 200 песен, скинул, перезагрузил телефон, захожу в проигрыватель, а там пишет пусто! второй раз перезагрузил, на несколько секунд появился список песен, и сразу `пусто` Еще раз перезагрузил, захожу в плеер, выдает ошибку `Unknown ErrorOn`
1. Что я делаю не так?
2. Плеер потянет более 400 песен?
3. И вообще существют кастомные плееры, или кастомные прошивки с плеером, с которыми плясать с бубном не нужно?
Помогите пожалуйста, ибо без плеера на музыкальном телефоне, плоховато...
e8_silence-7 mod joker 1.3.1 / boot 06_AC (NoRSA)
сообщение 9.6.2013, 15:15
Dfast,
у меня было порядка 500 песен, все было норм, кроме первого запуса плеера (секунд 10 первый раз заходил в плейлист). Я бы посоветовал скинуть всю музыку сразу в корень папки Music, тоесть без подпапок, чтобы абослютна вся музыка сразу лежала в music и после того как скинешь музыку, удали все файлы которые начинаются с точки с корня флешки и памяти телефона, перезагрузи телефон и подожди минут 10
VINRARUS
сообщение 9.6.2013, 15:24
Термоядерный
Из: Чорнобиль
Цитата(Dfast @ Сегодня, 18:03)
* И вообще существют кастомные плееры
Да. Например этот справится с любым количеством музыки, годится для ежедневного прослушивания: Shell Player 2.0
Поддерживает как автоматическое так и ручное обновление базы песен.
Сообщение отредактировал VINRARUS - 9.6.2013, 15:25
сообщение 9.6.2013, 15:49
Цитата(VINRARUS @ Сегодня, 18:24)
* Shell Player 2.0
не умеет нормально интергрироваться в mediafinder
играет втрое тише чем стандартный
не сильно удобен в использовании
VINRARUS
сообщение 9.6.2013, 16:45
Термоядерный
Из: Чорнобиль
Цитата(J()KER @ Сегодня, 18:49)
* не умеет нормально интергрироваться в mediafinder
По моему я это реализовал.
* играет втрое тише чем стандартный
Не правда, я сделал решение.
* не сильно удобен в использовании
Смотря какие требования. Мне например стандартный не удобен был.
сообщение 9.6.2013, 17:23
Цитата(VINRARUS @ Сегодня, 19:45)
* По моему я это реализовал.
ты реализовал замену медиафайндера а не интеграцию
* Не правда, я сделал решение.
костыль, помимо поднятия громкости плеера, еще и системные звуки орать начинают
* Смотря какие требования. Мне например стандартный не удобен был.
на вкус и цвет, к тому же ты не пользовался плеером е8, а я не пользовался плеером зины\з6, так что xз как на них, но на е8 вполне сносный плеер (не без изъянов конечно)
VINRARUS
сообщение 9.6.2013, 17:30
Термоядерный
Из: Чорнобиль
aalleexxnn
сообщение 6.8.2013, 3:23
Капец.
разобрался. если на silence-7 вернуть забэкапленные SMS от прошивки на базе 14CR (файл messaging.db), то SMS не доходят. Или доходят в смысле принимаются, но не пишутся в базу и потом не оповещаются. Если "удалить все данные" то этот файл "обнуляется" и SMS принимаются. Видимо, какое-то несоответствие форматов. Хотя с прошивкой на базе 14CR все нормально.
сообщение 7.8.2013, 9:09
DOMAN
сообщение 4.11.2013, 4:35
Из: солнечная адыгея, майкоп.
Пользователь №: 199 932
Модель телефона: defy pro
как установить rockbox.pep на прошивке? известный способ не помог
E8_silence-7, Мод на основе 13r_e (обновление от 26.02.13) · Motorola ROKR E8, EM30 · Forum
3 страниц V < 1 2 3
Текстовая версия Сейчас: 4.8.2025, 5:45
