Final Myth SP1 with 2 version: N & E, Новый монстр! 2 версии!
en5er
сообщение 8.3.2011, 8:03
Из: Оренбург sity
Пользователь №: 68 455
ждёмс...
Источник
Описание без перевода:
As I promised, I will make update version for FInal Myth to fix bugs and update new funtions. Now I will introduce: there are 2 versions of Final Myth SP1: N (normal) and E (Extended)
What's news?
- New Mgx Apps added: Java Adapter, Flash Player, Funlight, cSubicon, Rokrdesk with weather (beta version), ztaskman (add in mpkgbox)
- New Java Apps: Baomoi, Albite Reader (epub reader)
- Fix all bugs from previous mp
- Increase speed, stablility.
- and many others . (you can find more by yourself)
What's differences between 2 versions?
* Normal version:
- skin: Win7 Aero edition - edited by Devilsking
- Use original structure of filemanager
* Extended version:
- skin: BuufCoffee by Jacek95 - edited some points by Devilsking smile.gif)
- Use new structure of filemanager for icons - idea from Jacek95. That's new evolution but when you use this version, remember that old skins may be not compatible with this version (some icons). See more about this change which made by jacek95:
Trích dẫn
http://mobile.livemo...s-and-skinners/
How to install this mp?
1. Be sure that you have noRSA for your bootloader
2. Delete all data in your "unknown" folder
3. Use RSD to flash this mp
4. After flashing, reboot 1 more time.
5. Enjoy it
Hướng dẫn flash mp:
1. Hãy chắc chắn bạn đã flash noRSA tương ứng cho bootloader của bạn
2. Xóa thư mục Unknown trong bộ nhớ máy (bằng máy tính hoặc bằng filemanager - tùy bạn)
3. FLash mp
4. Sau khi flash hãy khởi động lại thêm 1 lần nữa
5 Tận hưởng thôi :P
Hướng dẫn sử dụng tính năng thời tiết:
1. Mở RokrDesk (với E version) hoặc WeatherDesk (với N version)
2. Mở tab 2 bấm Tùy chọn
3. Chọn Change city, kéo xuống dưới chọn Hanoi
4. Bấm tùy chọn > Update weather[/code]
Краткий перевод от @SEM*:
Как я обещал я обновил версию "FInal Myth" исправляя ошибки и добавляя новые функции. Сейчас я реализовал: 2 версии FInal Myth SP (сервис пак, типа глобальное обновление): N (нормальное, обычное) и E (расширенная)
Что нового?
- Добавлены новые *mgx приложения: Java Adapter, Flash Player, Funдight, cSubicon, Rokrdesk with weather (бета версия), ztaskman (встроен в mpkgbox)
- Новые ява приложения: Baomoi, Albite Reader (epub reader)
- пофиксены все проблемы предыдущей версии
- Увелична скорость и стабильность
- и много чего ещё (можете найти больше самостоятельно)
Различия двух версий:
* Обычная версия:
- скин: Win7 Aero edition - редактировал Devilsking
- используется оригинальная структура файлового менеджера.\
* Расширенная версия:
- скин: BuufCoffee by Jacek95 - Devilsking отредактировал некоторые детали
- Использована новая структура икононок в файловом менеджере - идея Jacek95. Это новый этап развития, но используя эту версию следует помнить что старые скины могут не поддерживаться в этой версии (некоторые иконки). Смотрите более подробно об изменениях которые сделал jacek95 (дальше походу ссылка на эти изменения, но не проверял):
Trнch dẫn
Как установить эту прошивку:
1. Вы должны быть уверенны что у вас стоит noRSA бут (или так: noRSA для вашего бутлоадера)
2. Удалите все файлы с папки "unknown" (ну это походу имеется ввиду удалить все автораны, а они могут быть у вас не только в этой папке, см. список папок авторанов в описании вашей прошивки).
3. Используйте RSD (RSD lite наверно имел ввиду) для того чтобы прошить этот монстр
4. Перезагрузитесь ещё раз
5. Наслаждайтесь
СКАЧАТЬ
Сообщение отредактировал en5er - 9.3.2011, 6:28
zerooo
сообщение 8.3.2011, 15:23
Из: Рязань
Пользователь №: 202 070
Модель телефона: c380l7l9em30zn5e8
Прошивка: разные
Добавлено позже (8.3.2011, 19:26):
извините увидел ночью обязательно поставлю
en5er
сообщение 8.3.2011, 19:46
Из: Оренбург sity
ждёмс...
Различия между 2 версиями?
* Обычная версия:
- скин: Win7 Aero издание - редакция Devilsking
- Использована оригинальная структура файл менеджера
- скин: BuufCoffee от Jacek95 - редакция Devilsking
- Использована новая структура файл менеджера для значков - идея Jacek95. Это новый способ, но когда вы используете эту версию, помните, что старые скины могут быть не совместимы с этой версией (некоторые значки)
@SEM*
сообщение 8.3.2011, 21:29
(M)LuckyMan
Из: Earth
Пользователь №: 126 920
Прошивка: Android 11 & 14
What's news?
* Normal version:
* Extended version:
Trнch dẫn
5. Enjoy it
Краткий перевод:
Что нового?
* Обычная версия:
Trнch dẫn
5. Наслаждайтесь
Сообщение отредактировал @SEM* - 8.3.2011, 21:30
moto_chainik
сообщение 9.3.2011, 11:55
Пользователь №: 164 287
Модель телефона: E398,E8,v3i,zn5,defy+
Русский и Украинский присутствуют? Кто ставил как впечатление? Спасибо clapping.gif
smaylik
сообщение 9.3.2011, 13:06
Пользователь №: 173 531
Модель телефона: Atrix 2
Прошивка: CM 10.1
Поставил, посмотрел, снес. Много чего можно настроить, но скоростью работы не блещет. zmod побыстрее будет, к тому же все настройки можно осуществить через mgxbox.
Русского\украинского нет.
Все выше перечисленное это мое личное мнение , мб этот монстр кому-нибудь и понравится.
Danil_KA
сообщение 12.3.2011, 19:13
Пользователь №: 98 770
Модель телефона: Motorola Moto G
Прошивка: 4.4.2
Сидел на прошлой версии этого монстра. Вполне хорошая прошивка.
Сообщение отредактировал Danil_KA - 15.3.2011, 6:31
parkhomenko
сообщение 14.3.2011, 10:05
Пользователь №: 225 021
Модель телефона: motorola e8
Прошивка: 1cr
отличное настроение
помогите пожалуста! я прошылся етой прошывкой и тепер не работает mpgx box, плеер станд. и телефон не читает архивы. с прошой прошывкой архивы тоже не читал, хотя раньше все было нормально.
smaylik
сообщение 15.3.2011, 4:41
Прошивка: CM 10.1
Надо сделать очистку данных, когда тел включится перезагрузись.
parkhomenko
сообщение 15.3.2011, 18:03
Прошивка: 1cr
отличное настроение
Сделал полную очистку - все равно не помогло
are_ed
сообщение 15.3.2011, 18:27
Пользователь №: 164 538
bugs in bluetooth file transfer...incorrect permission??
Final Myth SP1 with 2 version: N & E, Новый монстр! 2 версии! · Motorola ROKR E8, EM30 · Forum
Текстовая версия Сейчас: 14.9.2025, 4:55
