Vietnamese Need Your Help...., In order to make LP0021(R373)
MicMeo
сообщение 23.10.2005, 16:39
Пользователь №: 55 578
Dear Random and others profess member...
On behalf of Vietnam Motorola Community(_www.motofunvn.com) I post this thread…
We need your help to completed our Vietnamese Language Pack LP0021(LP0021) for i398. R373
I’ve tried to use all your SHXCodec version to Extract LP0021 form original mobilephone E398 and
Combine it into new R373 LP…
The following is my full details of what I’ve done to make LP0021 R373
1.Open I398-1ER-Itunes English_Portugues_Cheat -LP03 only-PCMMod.shx
And extract English Language Strings from that LP
Directly translate it into Vietnamese and put in a txt file.
2.Open R372_G_0E[1][1].20.95R_lang0021_reflash.shx and extract Language Pack
Here’s picture:
http://www.k45mt.net/e398/SHXCodec/2.JPG
3. ReOpen I398-1ER-Itunes English_Portugues_Cheat -LP03 only-PCMMod.shx
And add Vietnamese Language File I’ve just Extract from R372
http://www.k45mt.net/e398/SHXCodec/3.JPG
4.Parse Language then it displays like this:
http://www.k45mt.net/e398/SHXCodec/4.JPG
5. Load the file contains translated Vietnamese language I’ve done from English(r373)
Then pack it
http://www.k45mt.net/e398/SHXCodec/5.JPG
But when I parsed it again. I had full of blank.
http://www.k45mt.net/e398/SHXCodec/6.JPG
2 days after I was lookin’ for another way to Loadstring in to the OLD R372 Vietnamese Language but I couldn’t
Then I found that you had a program name Font Editor. I was tried to explore Vietnamese LP(R372) and I found that inside the Language file
There’re Vietnamese font. I think can make a font map for that File using ISE 1.0 or such things like that… But What for??
So! I ask for your help.
1.Do you know details, structure of an SMG CG4 language file? If you do, please help me!
2.How can you read strings in a language file? Where is located, how it was packed?
3.Could I use HEX Workshop to Edit String that hide in Language File???
We’re all Vietnamese Moto lover, but we only have Vietnamese Language for original E398 please help us!
Thanks in advance!
Sincerely yours!
Random
сообщение 24.10.2005, 6:03
Музыкант
Пользователь №: 36 054
Модель телефона: iPhone 4S
Hello.
As I know, there is no structural differences in R372 and R373 langpacks.
Have you tried to flash youe 0021 R372 LP to R373 platform directly, without any operations?
Здравствуйте.
Насколько я знаю, между ленгами для R372 и R373 отличий в структуре нет.
Пробовали ли вы просто прошивать на R373 нужный языковой пакет от платформы R372, без редактирования?
MicMeo
сообщение 24.10.2005, 11:21
It is possible to extract CG4 from R372 and combine with R373( Only take Ramloader) then Flash it
I did it from the very first time... but there're so many diffirent between R373 and R372
I've just make a simple comparision to show you those diffirents
Then this picture show that r372 is missing so many Language string ID
and they DO not MATCH with R373
If you want to see Vietnam R373 txt strings, EN R373 txt String and Vietnam R372 txt strings please tell me!
Random
сообщение 24.10.2005, 15:24
Музыкант
Curently there is no way to modify font layout in langpack, because it is not discovered yet.
You can chage original English fonts, but how about SMS, that you will receive?
So the best way is - use English, or wait original Motorola LP.
Of course, you can edit R372 strings in SHX CoDec, to make it work with R373.
Random
сообщение 24.10.2005, 16:50
Музыкант
CODER,
Товарищ хочет сделять вьетнамский ленгпак для R373 плтформы.
Проблема в том, что ID строк в ленгах 372 и 373 не совпадают.
А нужного языка в известных ленгпаках для 373 нет.
MicMeo
сообщение 24.10.2005, 18:20
Thanks so much for your reply but it'd better for me if you write it in English because http://babelfish.altavista.com[TRANSLATOR] always return HARD TO UNDERSTAND translation.
and I think if there's a way to mannually edit the R372 Language Pack???
I was tried like this
But this message appears:
Then I asked you how can you extract Strings in a language pack?Where its addresses?
Thanks!
Random
сообщение 24.10.2005, 19:36
Музыкант
MicMeo,
Strings in LP are packed, so the best way to view/edit them - use SHX CoDec, that have such function.
MicMeo
сообщение 24.10.2005, 19:40
But I did it, then I see that error! How can I do???
BTW would you please talk with me via Yahoo IM or MSN
Here mine:
micmeo@hotmail.com
micmeo82@yahoo.com
Thanks in advance!
Vilko
сообщение 24.10.2005, 21:08
Мотокодер
Пользователь №: 71
Random,
may be it's time to publish LP's pack/unpack algorithm here? ;)
Random
сообщение 25.10.2005, 15:16
Музыкант
Vilko,
Of course you can.
It is will be great.
But for MicMeo, if he's not a programmer, it is useless information.
Maybe this error occurs, because of SHX CoDec doesn't support Unicode symbols...
puper must look at this.
Vilko
сообщение 25.10.2005, 15:23
Мотокодер
Пользователь №: 71
Random,
sources of pack/unpack - Puper's task :)
i have only unpack, and my source is asm, hard to understand...
MicMeo
сообщение 25.10.2005, 17:43
Цитата(Random @ Вторник, 25 Октября 2005, 23:16)
Vilko,
Of course you can.
"SHX CoDec doesn't support Unicode symbols..." <-- You said that, then how you can make Russian languagepack for E398 R373?
Anyway I've tried to contact with puper but it seems he does not have time to take an attention...
,please tell me the way to contact him.
Thanks alot!
puper
сообщение 25.10.2005, 20:35
MotoSHXCoder
Из: Брест
Пользователь №: 38 940
Модель телефона: nokia :)
MicMeo, try to use new version and answer for me how it works.
MicMeo
сообщение 26.10.2005, 2:17
Puper,
Using your new SHXCoDec 2.6, I open the old R372 Vietnamese lang pack
And parse Language ID: 0C(Vietnamese)
DO NOTHING
Pack strings 2 times
Then this old message appears
It seems SHXCoDec can not work with Codepage 1258 [ANSI/OEM Vietnam]
Сообщение отредактировал Vilko - 26.10.2005, 13:54
Random
сообщение 26.10.2005, 16:10
Музыкант
MicMeo,
As I thnk, puper do not use Unicode when displaying strings, he use Russian/English codepage.
Better he answer :)
MicMeo
сообщение 26.10.2005, 18:42
Probaly he's doing another project and don't have time to look after SHXCoDec when he's just release ver. 2.60 of SHXCoDec...
We look forward to hear from him, about brand new SHXCoDec, with CP 1258[Vietnamese]
Thanks alot!
puper
сообщение 26.10.2005, 20:55
MotoSHXCoder
Из: Брест
Random, ты не прав, в лэнгпаке сами данные в юникоде, поэтому юникод поддерживается по определению...без него никак.
Тут проблема м.б. в самом DBGrid, его надо на вьетнамский настроить.. (какой он вообще - иероглифы/клинопись?)
Или может быть вьетнамских вариантов тоже уйма.
Та надпись, которая у него показалась, возникает в случае - если в строке встречается символ, котрого нет в "оригинальной языковой матрице". Для примера, в англ. лэнгпаке попрбуйте собрать слово с русской Ы например или Ё, Щ, Ъ. Хотя некоторые символы там есть (например в англ.матрице встречаются буквы от слов Русский, Украiньска и т.д). Может он недопустимые иероглифы пишет? которых нет в наборе - или из какого другого набора.....
Моих знаний англ. не хватит ему всё это объянить :)
Vilko
сообщение 26.10.2005, 22:42
Мотокодер
Пользователь №: 71
puper,
тебе надо просто отображение само в юникоде делать. т.е. заставит DBGrid понимать юникод. или выводить в виндовый ListView32 - он понимает...
Random
сообщение 27.10.2005, 10:28
Музыкант
puper,
Так вот об этом я и говорил :)
Поянтно, что в файле Unicode, Но все стандартные компоненты Delphi не поддерживают его нормальным образом.
Могу посоветовать Tnt Delphi Unicode Controls http://tnt.ccci.org/delphi_unicode_controls - там практически все компоненты передаланы под Юникод, в т.ч. и DbGrid
kenshin1101
сообщение 10.11.2005, 5:32
Пользователь №: 57 700
Модель телефона: kenshin
Vilko : sources of pack/unpack please. I think puper should give source code of shxcodec. (i'm vietnamese too :) )
just change string -> WideString !!!
i have test shxcodec 2.60 , i know it written in delphi.Why shxCodec doesn't support unicode ?
Vietnamese Need Your Help...., In order to make LP0021(R373) · Ломаем и строим! · Forum
Текстовая версия Сейчас: 12.9.2025, 10:32
