Help About Firmware, in enlglish please
TiDAniUM
сообщение 2.1.2006, 19:11
Пользователь №: 58 524
i had r365_g_0b.d2.27r on my c650 then i installed this version R368_G_0B.A0.11R but now i want
to install back my old version ..how i do this ?
answer in english please cuz my russian is bad ..
aligatro
сообщение 2.1.2006, 23:51
Мотоблуджекер
Пользователь №: 40 684
Модель телефона: Нокиа
ok
1. Download this program Repstudio Download
2. Press *#and power button on your cellphone. Open repstudio Choose your cellphone in list (c650) and press "Repair" button *Note there should be a sign that phone is connected.After program is finished with the process you can close it.
3. Now download FlashBackup by Random Download
4. Download this file R365_G_0B.D2.23R_C650 then download this file R365_G_0B.D2.27R_B_reflashLink is dead
Unpack those files to the desktop The link for reflash file is dead :( But you can use R365_G_0B.D2.23R
5.Open Flash Backup then look on the tab menu and click on "Flasher".
6.Then click on the the sqare button with three dots on it.
7. Then select this file "R365_G_0B.D2.23R_PDS004_LP002E_DRM0001_JPJAVA_G_0B_C650_06_05_54R_SE8402BXXU1117_1FF.shx" that is on desktop
and click on "Flash" button. *Note Look if Cellphone is connected if everything is right the process will begin. Do not disconnect during flashing.
8. Without disconnecting your cellphone click on the power button (on the cellphone) If everything is alright then open Flashbackup program once again and repeating steps 5,6,7 exept in step 7 select different file (R365_G_0B.D2.27R_B_reflash)
9. Flash it and You will have the firmware version that you wanted.
The one that is in red you don't have to follow yet. until you find reflash or fullflash of r365_g_0b.d2.27r
Manual was based on this manual
TiDAniUM
сообщение 3.1.2006, 16:46
when i flashed the phone it suddenly shuted down so i turned the power on
and now the phone isnt working ...
the phone is like this :
when i turn it on it's showing me the Hellomoto and then every thing going black and then phone turning off
it self and then the black screen again and then again if turning off again , in this situation i cant turn off the
phone myself unless i taking out the battery ..so can anyone help me plz ..?
i cant go to my provider and tell him that i downloaded a firmware cuz he wont fix my phone :(
TiDAniUM
сообщение 3.1.2006, 19:13
i figured up how to fix this ...i only needed to press * and # to boot load ...
Help About Firmware, in enlglish please · For English speaking members · Forum
Текстовая версия Сейчас: 29.7.2025, 19:26
