Slvr L7 - Мр3 Звук, МР3 ЗВУК
(l)user
сообщение 29.5.2006, 6:40
Пользователь №: 85 204
Модель телефона: SLVR L7
Sorry for writing in English. My Russian is pretty good but I just can't type using a standard QWERTY keyboard.
Anyways, I have SLVR L7 V8 w/ itunes and can't figure out how to INCREASE volume on WIRED HEADPHONES when playing AAC and MP3 files... I tried P2KAE (excellent soft!) changing Gain Table setting to no avail....
Anyone figured that part out?
Thanks so much and again sorry for using English here in this forum. You can answer in Russian I understand (almost) everything.
Пока!
Сообщение отредактировал (l)user - 31.5.2006, 17:56
Dj demon
сообщение 30.5.2006, 20:02
Пользователь №: 74 082
Модель телефона: Motorola L7
Прошивка: L7 Imonster Black
Try to use P2ktools and you must change the volume to 1 in Tools-Change Volume
Supshow
сообщение 31.5.2006, 4:33
RAZRовед
Пользователь №: 14 647
Прошивка: оптимальная
(l)user
Are you talkiing about wired headset volume? If so and when the max volume does no good, you have to manually edit the gain_table.bin file which is located on disc /a/ of your phone. After downloading the file from phone, open it with a hex editor (for instance, xvi32), locate offset 1BD and set the value to either 03 or 04 (initially you'll have 01 there). Save changes, upload the file back to your phone, restart, and you're all set.
Should you have trouble editing the file, you may post it here and I'll edit it for ya. Good luck!
(l)user
сообщение 31.5.2006, 18:54
Supshow,
Worked like a charm:) 4 gave my headphones a little overdrive and 3 was just right.
It's great there are no checksums and control codes... Easy modding, like on my old Siemens.
cпосиба,
(l)user
BTW. Is there a web site with all the gain table settings/offsets explained (can be in Russian)? Motomodders.com have it all wrong.... How about param_table.bin - anything interesting there? :)
Supshow
сообщение 1.6.2006, 6:37
RAZRовед
(l)user
Anytime! :)
The most complete description of gains and seem edits is here: http://xlr8.us/hofo/map.txt
Make sure to check this map from time to time. It's being regularly updated as soon as there are some new mods available.
Not sure about the param_table.bin - people tried to dig up something useful there. Try serching this and other similar sites.
Should you have any other questions/queries, pls feel free to contact me.
Dj demon
сообщение 2.6.2006, 7:31
Скачал прошивку от V360 и не знаю можно ли её ставить на L7. Вроде бы аппараты одинаковые!
Откликнитесь кто-нибудь,помогите PLS!!! :(
snaketk
сообщение 2.6.2006, 7:52
Пользователь №: 68 056
Модель телефона: MPx220
Прошивка: 1.47
Dj demon,
нельзя. у тебя кирпич, а там раскладной. тело умрёт=)
Dj demon
сообщение 2.6.2006, 19:29
Пасиба за подсказку!!!
St-Blade
сообщение 2.6.2006, 21:13
Из: Белгород
Пользователь №: 32 176
Модель телефона: Nokia e66
Прошивка: ...хз...
Тогда такой пример! Раньше скрещивали монстр от в3 с прошивкой от 398 и все работало после небольшой правки
bas005
сообщение 2.6.2006, 21:54
Пользователь №: 67 316
Модель телефона: C650+E2
я думаю что всё-иаки можно, если ставить на л7 то всё будет работать, а если с л7 на в360, то не будет работать внешний экран и быстрое меню (хотя эти новые модели могут и вообще не работать после такого) вот на с650можно ставить любую прошивку от d'irb (180,188,220)
LCF
сообщение 3.6.2006, 17:10
Из: Мурманск
Пользователь №: 52 465
Значится так. Пока никто этого не делал. И пока не сделает - эта тема - просто флейм. Пока кто-нибудь не прошьет - мы ничего не узнаем.
lucrece
сообщение 3.6.2006, 20:06
Moto®Head
Из: Кировская область
Пользователь №: 62 616
Модель телефона: V3xx
Прошивка: R26111LD_U_96.A0.0ER
Ну почему же не ставили? Ставили, только наоборот, от L7 на V360(см. стр. 18 темы Прошивки и флексы для V360). Неудачно: тел не включается.
(l)user
сообщение 5.6.2006, 4:41
Supshow,
Once more question: Is there any way to make the ringtone loop with no gap inbetween?
My SLVR pauses to approx. 1 sec before repeating a ringtone...
MOoOotoOoOo
сообщение 5.6.2006, 5:08
Из: Баку
Пользователь №: 86 225
Прошивка: L7 iMonster Black
Конкретные цифры можете сказать? Чтоб звучало чисто и громко (без каких-либо хрипов).
В данном случае говорится об L7
Supshow
сообщение 5.6.2006, 7:52
RAZRовед
(l)user
I have no clue... This 1 sec gap never seemed 2 b a problem 4 me.
MOoOotoOoOo
Ты про какую громкость говоришь? Рингтонов? Тогда 01. На 02 уже идут хрипы.
Yura.yo
сообщение 5.6.2006, 13:04
Пользователь №: 83 680
Прошивка: r4513_g_08.b7.dcr_rb
где я могу достать Hex editor? ;)
Alex133
сообщение 5.6.2006, 13:38
Заслуженный МотоФанец
Пользователь №: 6 566
Модель телефона: V500, S700
Прошивка: 4FR
Yura.yo,
http://www.datacord.ru/content/art-3.html
Читай вот тут все про редактирование симов в хексе и все ссылки.
MOoOotoOoOo
сообщение 5.6.2006, 19:32
Из: Баку
Да уж… При "Внутренний динамик - 2" хрипит зараза! Пришлось понизить громкость
P2KTools:
Громкая связь – 2
Клавиатура – 2
Внутренний динамик – 1
Звуки/Видео – 5
Системные звуки – 5
Нормуль?
P2K Advanced Editor:
SKINED
сообщение 5.6.2006, 23:59
Overclocker
Из: Чёрная дыра
Пользователь №: 42 866
Модель телефона: C113/V500/V3/L7/V360
Прошивка: все хорошие
Вы мне можете объяснить, а зачем это нужно???
Val_1111
сообщение 6.6.2006, 4:36
Пользователь №: 86 398
Очень нужен таймер. Никому не встречался для Л7 или может другой какой подойдет?
St-Blade
сообщение 6.6.2006, 6:12
Из: Белгород
Прошивка: ...хз...
SKINED, например, программная активация ежа
Alex133
сообщение 6.6.2006, 6:59
Прошивка: 4FR
Val_1111,
Ты хоть объясни, что этот таймер должен делать-то. По телефону звонить в заданное время - это вряд ли получится.
(l)user
сообщение 7.6.2006, 4:03
Цитата(Supshow @ Monday, 5 June 2006, 2:52)
(l)user
It's not a problem other thna the gap defeats a purpose of creating a looped ringtone...
I wonder if you can eliminate the gap...
Also, I have done something that made my built in speaker cracle when playing itunes, ringtones and speakerphone are no afected. It sound like it is teribly overdriven.... Any help here?
Supshow
сообщение 7.6.2006, 5:33
RAZRовед
(l)user
The only thing I could recommend with looped ringtone is to make a longer mp3 (more than 30 seconds).
You must've altered your gain_table.bin in some improper way. Try restoring your unedited file and then do gain edits again.
Текстовая версия Сейчас: 14.9.2025, 8:38
