Flash Checksum, Uploading a modified flash to RAZR
WhileTrue
сообщение 30.8.2006, 13:02
Пользователь №: 95 739
Модель телефона: Man
Прошивка: Hegazy
Hello experts..
Is there any check sum I need to update to have a modified flash file working propably on RAZR?
Many thanks in advance...
FlashTato
сообщение 30.8.2006, 18:16
Пользователь №: 90 457
Модель телефона: ciao
Прошивка: ciao
Yes, if you edit a Codegroup in SMG/BIN you need ricalculating the Checksum (16Bit) in the Header :).
You can do it with a HEX Editor (preferably HEX Workshop).
And after you need editing Header and writing the Checksum in Little Endian an Example:
If the checksum is E0 1C
You will write 1C E0
But you need knowing the Offset of the Checksum of the Modded Codegroup :D
But if you use the Replace Feature of SHX CoDec you can do it in automatic!!! :)
But unfortunately SHX CoDec doesn't work with SLVR L7,V3i,V3x,E1070/V1075........ full-flash :( so if you made a SW for these Handle you need working in HEX :P
WhileTrue
сообщение 31.8.2006, 8:30
Прошивка: Hegazy
Ok gurus,
I managed to bypass the checksum error, now the modified flash is uploading quite well.. Now the device is comming up with a new error, it says "phone code sig error:35:02:". What now guys? is there a signiture I need to change too to have the modified flash working?!?!!? blink.gif
Any help will be apreciated!
blackbox
сообщение 2.9.2006, 17:51
Control Freak
Пользователь №: 52 431
Модель телефона: iPhone
Прошивка: 2.2.1
Firmware is protected by digital signature (RSA with 1024 bit key).
To sign your modified firmware you'll need Motorola's private key :)
However, on some old models sig check can be bypassed with a patch. This method is widely used to flash E1 ROKR firmware into E398.
I don't know if this works on V3 RAZR, but definitely it doesn't on V3i and V3x.
FlashBackup 3 can be used for removing sig check, or you can find manual method.
Just don't forget to back up your original firmware before you kill your phone :)
WhileTrue
сообщение 5.9.2006, 7:39
Прошивка: Hegazy
Thanks man,
I tired FlashBackup 3.0.53 with RAZR v3i+itune and it failed to disable RSA check. What other methods I can try?
WhileTrue
сообщение 7.9.2006, 15:08
Прошивка: Hegazy
blackbox, I think ROKR is lynux not p2k... Is there any other p2k device I can disable the RSA protection on it?
Flash Checksum, Uploading a modified flash to RAZR · For English speaking members · Forum
Текстовая версия Сейчас: 30.7.2025, 9:49
