Problem With Backuping V3r...
cichy202
сообщение 20.9.2006, 19:30
Пользователь №: 99 913
Модель телефона: MOtorola V3r
Hi!
I just bought Motorola V3 but it turned out that it's V3R... <_< Before I start playin' with it (flashing etc.) I want to back it up. I heard that random's F&B is best, so i downloaded it but there's no profile for V3r... I read that it's possible to add 2 files to directories (Loaders & Profiles) and it works perfectly (fullflash without PDS). I found only for bootloader 0A.50. Please help me :)
My phone:
Boot Loader
0A.30
SW Version:
R4515_G_08.BD.43R
Help me plz :) I speak only English and Polish.
EDIT:
I'm also looking for Langpack LP0037 (with polish iTAP!) for V3r...
Random
сообщение 22.9.2006, 18:27
Музыкант
Пользователь №: 36 054
Модель телефона: iPhone 4S
cichy202,
Hello.
If you have the fullflash (monsterpack) for your phone, please decompile it to the binary files and post here the "RAMDLD" file from that fullflash.
I will try to add the V3r support.
cichy202
сообщение 23.9.2006, 8:32
I don'y know what exactly you mean but i used SHXCODEC and as a result i got this file.... I found found monsterpack on Matrax.net forum, but noone have checked it yet. If i placed wrong file, here is link for whole MP:
>> Monster Pack <<
>> RAMDLD <<
It's my first Motorola and i've it for 3 weeks so be patient ;) This file isn't exactly the same as my phone: i have diferent flex version, LP0037 (i have 0039).
Random
сообщение 24.9.2006, 21:05
Музыкант
cichy202,
1. Unrar this test profile to your Flash&Backup3 folder.
2. Restart F&B3
3. In profile box select R4515_V3r
4. Try to make backup
Please, write here does it work or not.
Прикрепленный файл v3r_testprofile.rar   ( 24.43 килобайт ) Кол-во скачиваний: 740
cichy202
сообщение 25.9.2006, 13:50
@Random:
I've backuped my V3R succesfully :) Tanks a lot !!!!!!
Can I flash V3R now?
Idon't know why but it have only 17MB.... Format: FB3 (cab-zip).
Random
сообщение 25.9.2006, 16:02
Музыкант
cichy202,
FB3 is compressed format, and 17 MB normal for 32 MB backup.
If you are want to check it - change extension to ".CAB" and unpack file.
Yes, but beware of locked firmwares! For your model unlocking in F&B3 is impossible.
cichy202
сообщение 25.9.2006, 18:17
I've got one more question: Can I unpack LP0037 from moster pack and add it to my phone without flashing whole phone?
Random
сообщение 25.9.2006, 18:56
Музыкант
cichy202,
When you flashing with the F&B3 you can select which code groups do you want to flash.
So, if you want to flash just langpack, select only CG4.
Or if you want to flash in other program, delete all other code groups and save new SHX.
cichy202
сообщение 25.9.2006, 19:08
Thanks a lot for help :D I don't know what i'll do wthout your help ;)
Random
сообщение 25.9.2006, 19:35
Музыкант
cichy202,
Not at all :)
Diom
сообщение 26.9.2006, 7:35
Из: Запорожье
Пользователь №: 51 972
Модель телефона: V3r>l7>V3i>Z6>V8>E8
Random,
Создание корректного профиля под эту подлую платформу (R4515), ИМХО - дело архиважное, так как растёт число несчастных владельцев V3r, обделённых возможностью безопасно модить тело!
Огромный респект Великому Гуру, за решение для нас убогих этого вопроса!
Вставлю свои 5 копеек. На www.motox.info товарищ WhoAmI предлагает буквально следующее:
The first one V3r_0A50.ldr is from a standard R4515 monsterpack, it allows to read everything except PDS, and to write back the main codegroups (naturally except BOOT and PDS). Just put it in "loaders" of FB3; also put the associated profile in "profiles", see above.
The other one R4513_08D0_image.ldr allows to read everything, including PDS, but cannot be used for writing anything back. Just for those curious to see what's in their PDS...
Есть ли тут рациональное зерно, и что за буты такие левые? Особо впечатлило "allows to read everything, including PDS" Выложу их здесь - авось будут Вам полезны!
И ещё как быть с RSA на этих телах, можно ли шить хотя-бы отдельные CG?
Random
сообщение 26.9.2006, 16:05
Музыкант
diom,
Все правильно, с такими же проблемами и я сталкивался.
Но новых моделях загрузчики либо не сливают PDS, либо сливают, но он пустой. А если же они его корректно сливают - то обратно никак не восстановить. Тоже самое и с bootloader-ом.
Поэтому в итоге я просто закоментировал бут и ПДС в файле профиля. Хоть они для некоторых моделей и работают - но только в одну сторону.
Отдельные CG шить можно, но только не забывая о их взаимосвязи.
Т.е. возможно разделять таким образом
1. CG1+CG3+CG18 (+CG7 если есть)
2. CG2
3. CG4
4. CG15
Diom
сообщение 27.9.2006, 7:38
Из: Запорожье
Random,
Большое спасибо за консультацию!
SkyP_81
сообщение 6.11.2006, 15:04
Пользователь №: 106 028
Модель телефона: What is this
Hi Random!
I have an originally unlocked V3r with bootloader 0A52 and I want to change DRM and fonts on it. So I wondered if the latest version of Flash&Backup3 supported with 0A52? I just only need change DRM and maybe the fonts, nothing unlocking procrdure!
Please help me in English rolleyes.gif !
Random
сообщение 6.11.2006, 16:09
Музыкант
SkyP_81,
I think yes!
Try to backup your DRM. Even if it will fail nothing will be happened with phone.
Diom
сообщение 8.11.2006, 9:30
Из: Запорожье
Random,
Добавлю к вашему сообщению обстоятельство из опыта неоднократного шитья V3r.
CG для редактирования сохранять убирая пустоту в конце кодовых групп, иначе
редактируя к примеру DRM, его размер увеличивается (при замене иконок на более обьёмные).
И прошивая такой кодовой группой получаем трупик, так как конечный адрес группы залазит в область следующей. ИМХО.
SkyP_81
сообщение 8.11.2006, 12:25
Thanks MR.Random! I've done it, and the flashing works perfectly too! clap;applo clap;applo clap;applo
Flash&Backup3 works perfectly! It's indispensable! :)
LAkate
сообщение 13.11.2006, 12:12
Пользователь №: 104 790
Модель телефона: RAZR V3r
мужики помогите!!!!
я попытался по вышеописанной инструкции залить в V3r ленгпак
.lang.from.mpx398.fsw
закончилась вроде без ошибок сия процедура.
телефон перезагрузился и потом стал моргать редко экраном как будто перезагружаться сразу и подсветка клавы гаснет то опять горит.
попробовал залить родной backup CG4.smg но после его успешной вроде бы заливки ничего не поменялось....
НЕЛП ПЛИЗ!!! :( :( :( :( :( :( :(
Цитата(diom @ Среда, 8 Ноября 2006, 12:30)
Random,
у меня стоит галочка на "убирать пустоту в конце кодовых групп"
Problem With Backuping V3r... · Random's Developments · Forum
Текстовая версия Сейчас: 12.9.2025, 8:14
