I know that this repeats the last one theme but this is for V series and i have 2 texts of my provider.If someone knows how to erase them please Help
![]() Remove provider text in V series |
VenoMan |
Новичок ![]() Группа: Пользователи Сообщений: 11 Регистрация: 16.1.2005 Пользователь №: 34 479 Модель телефона: Motorola v525 Рейтинг: 0 ![]() |
ZeatooL |
![]() МотоЧиститель ![]() ![]() ![]() ![]() ![]() Группа: Почётные мотофаны Сообщений: 680 Регистрация: 15.1.2005 Из: Красноярск :-p Пользователь №: 34 239 Модель телефона: C650/Nokia 6170 Прошивка: R365_G_0B.D3.06R/ХЗ Рейтинг: 213.1 ![]() |
With similar to you to a problem time only not on V lines already collided.
First go in the menu opcode,To go in the menu opcode press quickly keys of the menu 048263* Then: Enter values: 1th Stage: Opcode "47" "OK" Field 1 "50" "OK" Field 2 "1" "OK" Field 3 "116" "OK" Field 4 "1" "OK" Field 5 (D) "016" "OK" Return: Field 5 (D) "000" "OK" Results F1 : 0 stage 2: Opcode "47" "OK" Field 1 "50" "OK" Field 2 "1" "OK" Field 3 "75" "OK" Field 4 "1" "OK" Field 5 (D) "255" "OK" Return: Field 5 (D) "191" "OK" Results F1 : 0 Should work. P.S. Excuse me, for that that I badly know English |
kyfranck |
Новичок ![]() Группа: Пользователи Сообщений: 10 Регистрация: 24.3.2005 Пользователь №: 39 455 Модель телефона: kyfranck Рейтинг: 0 ![]() |
Цитата(zeatool @ Воскресенье, 13 Марта 2005, 17:17) With similar to you to a problem time only not on V lines already collided. First go in the menu opcode,To go in the menu opcode press quickly keys of the menu 048263* Then: Enter values: 1th Stage: Opcode "47" "OK" Field 1 "50" "OK" Field 2 "1" "OK" Field 3 "116" "OK" Field 4 "1" "OK" Field 5 (D) "016" "OK" Return: Field 5 (D) "000" "OK" Results F1 : 0 stage 2: Opcode "47" "OK" Field 1 "50" "OK" Field 2 "1" "OK" Field 3 "75" "OK" Field 4 "1" "OK" Field 5 (D) "255" "OK" Return: Field 5 (D) "191" "OK" Results F1 : 0 Should work. P.S. Excuse me, for that that I badly know English That's work on motorola razor V3 ? |
dj sky |
Научный сотрудник ![]() ![]() ![]() ![]() ![]() Группа: Пользователи Сообщений: 401 Регистрация: 14.7.2004 Из: Иваново Пользователь №: 7 882 Модель телефона: V535/C650 Прошивка: 0BR/2FR Рейтинг: 26.5 ![]() |
kyfranck, I think it will work on V3, bcse it works on triplets (as zeatool said, i think he said truth :) )
kyfranck |
dj sky |
kyfranck, operator's logo can be removed by MotoSkin program.
All you've to do is: 1) download *ski file from phone; 2) open this file in MotoSkin; 3) edit operator logo and save file; 4) upload changed ski-file back to phone; 5) change attribute of this file to "system' (by p2ktools) 6) restart phone & enjoy |
kyfranck |
Цитата(dj sky @ Воскресенье, 27 Марта 2005, 17:01) kyfranck, operator's logo can be removed by MotoSkin program. All you've to do is: 1) download *ski file from phone; 2) open this file in MotoSkin; 3) edit operator logo and save file; 4) upload changed ski-file back to phone; 5) change attribute of this file to "system' (by p2ktools) 6) restart phone & enjoy can you tell me more please ? i don't understand the complete procedure. |
Dyze |
Новичок ![]() Группа: Пользователи Сообщений: 3 Регистрация: 27.3.2005 Пользователь №: 39 664 Модель телефона: V300 Рейтинг: 0 ![]() |
wat about if I want to put back my carrier provider text on the phone... because the phone i had modified was my brother's now he is willing to kill me.
dj sky |
kyfranck, first you must download P2kTools, you can transfer files to/from phone with this program.
Part 1. P2k mode connection setup: Connect phone via cable, windows will find it. When it will ask you for drivers, press "install from disk" and select driver from P2kTools/drv/ folder. Run P2kTools, press "Switch to..." button and choose "P2k Mode". Then press "Connect" button. Widnows will find some new devices & will ask for drivers again, you'll have to select P2kTools/drv/ folder again. Sure that your OS is win2000/XP/ and later. Part2. Downloading files: Press "Refresh" button on "Explorer" tab in P2kTools. Program will show phone's filesystem tree and files like in windows explorer. Go to /a/mobile/skins/ folder and download ski-file from folder named as skin which you want to be used without Operator logo (for example, if you want to erase operator logo in "Techno" skin, you've to download and modify /a/mobile/skins/Techno/Techno.ski file) If you want to do some operations with another content of skin (e.g. change icons, background pics etc.), you also must download *.dat files from skin folder. Part3. Modifying Data Logo: It's the most simple and interesting part :) Just run MotoSkin and open downloaded ski-file, choose "Operator text" tree item and change "Opacity" value between 0 and 255 (0-absolutely untransparent, 255- absolutely transparent text). Then save the file (File->Save /or ->SaveAs...) Part 4. Uploading modified ski-file Just start p2ktools, press "connect" and "refresh" button, select /a/mobile/skins/SkinName/ folder and press "Upload" button. Thats all :) It's recommended to set attributes of downloaded system files to "system", it will prevent erasing of this files after master clearing. To change attributes, use button with same name in P2kTools. After attribute changing, just press "restart" button. Thats ALL :) I hope this info will make yor life some better ;) Good Luck! Dyze, if you used opcodes from zeatool's post, just do backstep - enter same opcodes but in field 5: Цитата Return: Field 5 (D) "191" "OK" P. S. Sorry for my english |
kyfranck |
Цитата(dj sky @ Понедельник, 28 Марта 2005, 20:27) kyfranck, first you must download P2kTools, you can transfer files to/from phone with this program. Part 1. P2k mode connection setup: Connect phone via cable, windows will find it. When it will ask you for drivers, press "install from disk" and select driver from P2kTools/drv/ folder. Run P2kTools, press "Switch to..." button and choose "P2k Mode". Then press "Connect" button. Widnows will find some new devices & will ask for drivers again, you'll have to select P2kTools/drv/ folder again. Sure that your OS is win2000/XP/ and later. Part2. Downloading files: Press "Refresh" button on "Explorer" tab in P2kTools. Program will show phone's filesystem tree and files like in windows explorer. Go to /a/mobile/skins/ folder and download ski-file from folder named as skin which you want to be used without Operator logo (for example, if you want to erase operator logo in "Techno" skin, you've to download and modify /a/mobile/skins/Techno/Techno.ski file) If you want to do some operations with another content of skin (e.g. change icons, background pics etc.), you also must download *.dat files from skin folder. Part3. Modifying Data Logo: It's the most simple and interesting part :) Just run MotoSkin and open downloaded ski-file, choose "Operator text" tree item and change "Opacity" value between 0 and 15 (0-absolutely untransparent, 15- absolutely transparent text). Then save the file (File->Save /or ->SaveAs...) Part 4. Uploading modified ski-file Just start p2ktools, press "connect" and "refresh" button, select /a/mobile/skins/SkinName/ folder and press "Upload" button. Thats all :) It's recommended to set attributes of downloaded system files to "system", it will prevent erasing of this files after master clearing. To change attributes, use button with same name in P2kTools. After attribute changing, just press "restart" button. Thats ALL :) I hope this info will make yor life some better ;) Good Luck! Dyze, if you used opcodes from zeatool's post, just do backstep - enter same opcodes but in field 5: P. S. Sorry for my english Thanks a lot. ps : I'm french and U ? |
Dyze |
igght thanks man.. i had all back to normal already.. but thanks ....
I used MotoKit to have it back on.. and change de Outer LCD display ma name.. "Dyze" lol. |
dj sky |
Текстовая версия | Сейчас: 28.7.2025, 1:57 |
