Своя Заставка На Вкл/выкл В Е2
hobbit19
сообщение 27.10.2006, 19:22
квант истории
Из: Рязань
Пользователь №: 39 980
Модель телефона: (M)oTorola
Прошивка: testing/unstable
вот нарыл у китайцев
0. Prepare two GIF animation files with 240x320 resolution, and put them in your memory card. One is for startup animation, the other one is for shutdown animation.
For example, I use two files : tux_on.gif and tux_off.gif, and put them in a folder called 'MyGIFs' in my memory card.
(Images are taken from "Clean-series" theme for E680i. Credit goes to Blackhawk of Motorolafans for such a beautiful yet efficient theme.)
1. Telnet to your E2 (telnet 192.168.16.2).
2. Go to /ezx_user/download/appwrite/setup/theme directory
cd /ezx_user/download/appwrite/setup/theme
3. Find 2 files : "themefiles.cfg" and "User_0.chm" (ls).
4. Create backups of those files, just in case.
cp themefiles.cfg themefiles.cfg.bak
cp User_0.chm User_0.chm.bak
4. Copy those files to your memory card.
cp themefiles.cfg /mmc/mmca1/themefiles.cfg
cp User_0.chm /mmc/mmca1/User_0.chm
5. Reconnect your E2 to your PC as Memory Card.
6. Edit the two files you copied using WinXP's WordPad or any Linux/UNIX-compatible text editor. Don't use Notepad.
6a. Edit "themefiles.cfg"
Change this :
[/usr/data_resource/poweroff/splash_powerdown_ani_full.gif]
MotoTheme = 0
MotoTheme(Modified) = 1
[/usr/data_resource/poweron/splash_powerup_ani_full.gif]
MotoTheme = 0
Into this (depends on file path and names of your GIF animation) :
[/mmc/mmca1/MyGIFs/tux_off.gif]
MotoTheme = 0
[/mmc/mmca1/MyGIFs/tux_on.gif]
MotoTheme = 0
Save and close the file.
6b. Edit "User_0.chm"
Change this :
PowerOffScreen = /usr/data_resource/poweroff/splash_powerdown_ani_full.gif
PowerOnScreen = /usr/data_resource/poweron/splash_powerup_ani_full.gif
PowerOffScreen = /mmc/mmca1/MyGIFs/tux_off.gif
PowerOnScreen = /mmc/mmca1/MyGIFs/tux_on.gif
7. Next step is to copy the files back to the /ezx_user/download/appwrite/setup/theme directory. Telnet again to your phone.
8. Copy the files back to the original directory.
cp /mmc/mmca1/themefiles.cfg /ezx_user/download/appwrite/setup/theme/themefiles.cfg
cp /mmc/mmca1/User_0.chm /ezx_user/download/appwrite/setup/theme/User_0.chm
9. Exit telnet, disconnect, and restart your phone.
10. Enjoy the new startup and shutdown animations.
GrAnd_
сообщение 27.10.2006, 19:31
Из: Королев/Москва
Пользователь №: 43 782
Модель телефона: Atrix
Вроде ж уже кто-то из своих менял!?
ztrewq
сообщение 27.10.2006, 19:51
Из: Kiev, Ukraine
Пользователь №: 53 648
Модель телефона: E2, e1070, Qtek 9000
Я делал, только вообще тему, а не на заставку, под рукой была от а1200, поэтому получилось ОЧЕНЬ криво. Черный шрифт на темном фоне и т.д....
hobbit19
сообщение 27.10.2006, 19:58
квант истории
Из: Рязань
какая тему ? выложи и опиши что делал )
и скрины интересна глянуть что и где крива
мож сам поговыряюсь на выходных
whitemoto
сообщение 27.10.2006, 20:01
Пользователь №: 63 052
Прошивка: pre
В 43p заставку на вкл/выкл. можно в настройках тем в телефоне менять ;)
ztrewq
сообщение 27.10.2006, 21:48
Из: Kiev, Ukraine
В теме "Ковыряем Фс"
ссылка
Xaker753
сообщение 28.10.2006, 2:09
Пользователь №: 100 614
Модель телефона: Motorola ROKR E6!
да на 43р это доступно все ))))) народ не отставайте ))))
Своя Заставка На Вкл/выкл В Е2 · Motorola ROKR E2, A910, A910i, E895 · Forum
Текстовая версия Сейчас: 3.8.2025, 22:13
