Elektro255 V0.3 (based On 49r) - Can't Make A Call, phone hangs when trying make a call
SkW4R4
сообщение 11.12.2006, 21:26
Пользователь №: 110 970
Hi, this is my first post - sorry that in english but I don't speak/write in Russian :/
I've already posted my problem on motomodders.net no one there could help me :/
So here is a description of my problem....
I've downloaded v0.3 based on 49R by elektro255 (elektro255.ovh.org), flashed my phone, and everything seem to be fine except the fact I can not make a call, I mean... When I dial a number and press a Green-Phone Button my phone hangs (the only way to use phone again is to remove battery) :/
It also hangs when I type *5 (shortcut to open main menu - ie. when you don't have your sim card in the phone) or when I use a number (it doesnt matter if a number is from a phone book or from a txt msg).
But when set "Disconnect Network" to "ON" '*5' works fine and dialing a number results in appearing of "Action not Allowed" message. I reflashed v0.3 with R373_G_0E.30.49R (downloaded from e398.com) and now I can make a call but it doesn't make any sense, coz I've lost all features that 0.3 provides.
This is What I have in "Panics":
Num: 0001
Ver: 0e.30
TIME: 00:30:10 12-09
LENGTH: 0209
4900 0000 0000 0c2e 1610
c201 0060 0000 3310 0900
0000 0000 0003 fd9a c810
2330 3900 0000 0100 0000
0812 79c2 f012 7e50 0403
fd56!
I don't know if it matters but I found that CG1 from elektro is 12MiB while from R73_G_0E.30.49R is 5MiB
plus R73_G_0E.30.49R contains CG7 which is not present in elektro's
I tried to reflash this CG7 over elektro's but it doesn't help,
Maybe I am doing something wrong ?
To get this I already did:
1) Went back to my provider's soft
2) Flashed with 42_for_all_MP
3) Flashed with elektro's v0.3 49R mod
Result: can't make a call
Another Way:
3) Flashed with Starter XP (46R) - making calls works
4) Flashed with elektro's v0.3 49R mod -> making calls Doesnt work
Yet Another Way
3) Flashed with R73_G_0E.30.49R
Yet Another Way #2
5) Flashed back with R73_G_0E.30.49R -> making calls works
"Went back to my provider's soft" = Restoring PDS and FULL BuckUp.
I tried other MPs based on elektro255 - none of them let me make a call :/
Hope this helps to find a solution to my problem.
elektro255 doesn't respond on IM :/
All help appreciated
P.S.
If it's not a problem please respond in english.
~Best Regards
Active
сообщение 11.12.2006, 22:25
Из: Зеленоград
Пользователь №: 104 027
Прошивка: Mpx398 DeLuxe
Type your message here Rokr E1 Sw Modfore398 By Elektro255 V0.3 (46r,49r)
SkW4R4
сообщение 11.12.2006, 22:59
ok, so I would like to ask any one who can do this, to join my topic to the one mentioned by Active (https://motofan.ru/board/index.php?showtopic=77295)
Active
сообщение 11.12.2006, 23:22
Из: Зеленоград
SkW4R4,
I copy your post #1 into the topic Rokr E1 Sw Modfore398 By Elektro255 V0.3 (46r,49r)
If anyone could help, I type his messege here.
SkW4R4
сообщение 12.12.2006, 12:09
Great!
If you could also translate an answer to english (if it's in Russian) it would be perfect!
Anyway thanks mate!
Semseddin
сообщение 12.12.2006, 19:10
Из: Turkiye
Пользователь №: 109 141
Модель телефона: Semseddin
Прошивка: Razr2 V8
Don't use that pack at all. I mean if you can't even make a call... What's the meaning of modding :)
SkW4R4
сообщение 12.12.2006, 22:29
I'm not using it.
I went through steps provided by Active
I mean:
1) Restored PDS and Full Backup (provider's one - r372...95r
2) "Flexed" with mini_flex_95r
3) Flashed elektro's mod
but it doesn't change anything,
Actually I'm using Mpx398_Final_49r and it works great
except I features that are in elektro's mod.
Anyone have this problem?
ApxuBatop
сообщение 28.12.2006, 8:22
Мото-Художник
Пользователь №: 65 512
Модель телефона: iphone 5
Прошивка: от Е398
Electro255 deleted some functions, that are not used in Poland, Russia and the most of other countries in Europe to improve firmware speed. Maybe your operator uses them, that's why you have a problem... Try to contact electro255, maybe he knows the solution...
Elektro255 V0.3 (based On 49r) - Can't Make A Call, phone hangs when trying make a call · For English speaking members · Forum
Текстовая версия Сейчас: 12.9.2025, 16:32
