23 страниц V « < 2 3 4 5 6 > »
Elektro255 V0.4 alpha 4 mod (4xR), 44R,46R,49R,79R
elektro255
сообщение 23.9.2006, 12:06 Закрепленное сообщение!
Из: Poland, Siedlce
Пользователь №: 53 130
09-04-2007
V0.4a4 Alpha: http://elektro255.ovh.org
08-04-2007
V0.4a3 Alpha: http://elektro255.ovh.org
07-04-2007
V0.4a2 44R Alpha: http://elektro255.ovh.org
20-12-2006
V0.3 79R Final mod: http://elektro255.ovh.org
27-11-2006
v0.3 for 49R Final mod http://elektro255.ovh.org/
26-11-2006
V0.3 46R Final mod: http://elektro255.ovh.org
НА Е1 Rokr с бутом 0А02 (оригинальный) НЕ ПОСТАВИТЕ БЕЗ Т.П.!
V0.4 alpha 4
Changes:
- Fixed problem with display timeout (fullscreen clock) when SMS/CALL received
Features:
- 4xR and 7xR MIX (use with 4xR flex)
- unlimited Video recording
- keypad automatic lock
- low battery alarm can be turned off or depend on ring style.
- Scheduled Ring Styles (ring style and funlight style can change automatically on given time and week day)
- flashlight shortcut (##)
- extra menu (shortcut *1 [shortcut is only for testing later will be changed])
- automatic menu enter, without sim card (emergency calls working too)
- new Java methods
- settings are stored on files
- no simlock checking
- Volume-bar sound can be turned off
- multiple menus (every skin can have one mma_ucp)
- Ported patches:
o SMS report significantly turned ON
o more folders in OBEX via BT
o removed unused folders from TransFlash
o Java have access to system files
o increased iTap user dictionary size
o no delete incall on SIM replace
o Bluetooth time changed to 3 minutes
o reordered camera store menu (store only is first)
o SMS alert is using default ringtone
OLD versions(V0.1-0.3):
Firmware changes:
- firmware based on 46R from StarterXP MP
- FULL SW access from Java
- LUMA&CHROMA tables moved to memory - now you can change JPEG compresion from Java
- StarterXP flex
- added dualboot
Flasher changes:
- if you have PDS_4013 flasher will no recreate this
Personalization tool changes:
- first version for 0.3_46R SW mod
- changing splash screen
- changing font (you can use *.fnt or *.smg CG4 files)
- you can turn on, turn off menu access without sim cart
- changing my shortcuts
Новая версия V0.4 alpha 4
Изменения:
- Устранена проблема с таймаутом дисплея(полноэкранные часы) при приеме смс/звонка
Новое:
- Прошивка создана как микс 4xR и 7xR (флекс 4xR ) В 44R она переименована для совместимости! Она близко не лежит к 44R на самом деле!
- Безлимитная запись видео (64мб макс как в 6х7х)
- Автоблок клавиатуры
- Звук разряженой батареи можно выключать или задать стилем оповещения(?).
- Расписание стилей оповещения (стиль оповещения и фанлайтмогут менятся автоматически по времени и дням недели)
- Фонарик по (##)
- Дополнительное меню (метка *1 [только для теста, после может изменится])
- Автоматический вход в меню без сим-карты (аварийные звонки работают)
- Новые методы в Яве (не от 79R, а новые)
- Настройки хранятся в файлах
- Не проверяется лоченость ПДС на симку (работает с лоченым пдс)
- Звук изменения громкости можно отключить
- Мультименю (каждый скин может иметь собственный мма_уцп)
- Портированы патчи:
o Оповещение о доставке SMS всегда вкл.
o больше папок доступно по OBEX из блютуза
o удалены неиспользуемые папки с флешки
o Полный доступ к системным файлам из явы
o увеличен размер пользовательского словаря iTap
o не удалыются последние вызовы при смене сим
o Время обнаружения блютуза - 3 минуты
o Меню сохранения видеозаписи (просто сохранить - первым пунктом)
o при приходе SMS играет "мелодия на смс", а не установленная на этого пользователя
Для версий 0.1-0.3
Изменения в прошивке:
- Создана на базе монстра StarterXP 46R
- Полный доступ к прошивке (симы, озу) из явы
- Таблицы сжатия фотографий перенесены в озу - теперь из явы можно управлять качеством фотографий (сжатием)
- флекс StarterXP
- добавлен дуалбут
Изменения флешера:
-Если ПДС версии 4013 (373 платформа), ПДС не пересоздается.
Изменения персонализации (Personalization tool):
- впервые для мода использована 46 прошивка
- замена заставки (на включение?)
- замена шрифта (лангпак, CG4)
- можно вкл. и выкл. доступ к меню без сим-карты
- изменен ярлык (копирайт?)
Для работы Personalization tool требуется положить в папку программы несжатый бинарный бэкап (32 мегабайта) под именем SW.bin
Прекращаем флудить, типа а когда выйдет новая версия, и.т.д.и.т.п, или придётся наказывать!
тему почистил, архив по 1 декабря тут:
Прикрепленный файл MotoFan_ru_electro.zip   ( 66.56 килобайт ) Кол-во скачиваний: 3902
Сообщение отредактировал elektro255 - 9.4.2007, 12:21
Bent
сообщение 2.12.2006, 10:55
MoTo Marvellous
Пользователь №: 63 874
Собственно вот две фотки одна сделана с пачем от electro255 а другая патчем от StrIk3r (UNSORTED_FOTOPATCH)
Фотки не чем практически не отличаются,только весом немного и всё(разница в 6 килобайт)...я ожидал большего эффекта.
_TRANE_
сообщение 2.12.2006, 11:34
MOTOmeloMAN
Из: New_Oskol_City(Бел.Область)
Пользователь №: 104 202
Модель телефона: E398+KOSS The PLUG
Прошивка: MPX 398 DeLuXe
p00p0k, Сэнкс за обьяснение теперь подскажи какой патч для камеры лучше поставить? drink_drunks;
слыште парни а откуда мона скачать FULLFLASH electro255 SW mod 03b (49r) а то с его офиц. сайта чёто не качает? blink.gif
juicedddd
сообщение 2.12.2006, 11:42
Из: Сыктывкар
Пользователь №: 77 458
Модель телефона: ~E398~
Прошивка: Dream a reality_79R
Обьясните пожалуйста чем 0.3 отличается от 0.2, кроме того что можно менять степень сжатия из ява ???
Есть ли какие нибудь другие значимые изменения ???
Bent
сообщение 2.12.2006, 12:02
MoTo Marvellous
juicedddd, Вверху же написали...это наверно главное отличие,в v.0.2 так не сделаешь(кроме бутсплеша его можно заменить но нудно)...я пытался :)
Ну и от себя добавлю что скорость отличная,прошивка стабильна-ни одного перезагруза,немного попарится с фото и будет всё в шоколаде,плюс сжатие фоток.
Вот собственно и всё.
_TRANE_,
слыште парни
Нормальным языком выражайся.Не в подъезде стоишь.
На данный момент этот лучший UNSORTED_FOTOPATCH by StrIk3r
_TRANE_
сообщение 2.12.2006, 12:14
MOTOmeloMAN
Bent, извини, ну а всё таки откуда мона скачать FULLFLASH electro255 SW mod 03b (49r) а то с его офиц. сайта чёто не качает?
AndreyD
сообщение 2.12.2006, 14:23
Пользователь №: 80 023
Прошивка: 49R
Bent, т.е. сначала fix от электро, а потом UNSORTED_FOTOPATCH by StrIk3r? или сразу после прошивки UNSORTED?
Bent
сообщение 2.12.2006, 14:36
MoTo Marvellous
AndreyD, сначала FIX потом UNSORTED.И программу для сжатия от electro255 не ставь-иначе такая фигня будет с фотками...качество будет плохое - почему? StrIk3r объяснил на страницах раньше :)
Frensis
сообщение 2.12.2006, 15:32
Пользователь №: 99 380
Прошивка: MotoWalkman49R
Я так скажу, парни!То что скорость значительно (!) выше это да, большущий +!Хочу заметить что видео при просмотре не тормозит, что оч приятно. clap;applo elektro,тебе респект very big!И всем остальным кто приложил усилия lol.gif lol.gif
ReLeFNIQ
сообщение 2.12.2006, 18:47
Пользователь №: 70 179
Модель телефона: Motorola e398(E1)
Прошивка: R373_G_OE.30.48R
А скажите как исправитъ чтоб Когда у меня присляют файлики по блутуут у меня сохраняет сразу в памяти телефона!!!Как изправитъ ето?I can't chose where to save files comming from bluetooh, i can't choose in TransFlash..>And also when I install games It doesn't ask me where to save the game..Срочно надо как изправитъ ето и возможно ли....СПАСИБО!!
Sanyok_
сообщение 2.12.2006, 19:15
MotoTeam
Из: Кременчуг Украина
Пользователь №: 48 061
Прошивка: пока 13 ведро :)
ReLeFNIQ, вот так Самые Известные Проблемы И Их Решение (#362976)
BackgaMan
сообщение 2.12.2006, 19:18
Мотоумелец
Пользователь №: 61 651
Модель телефона: E-398 Htc-p3300
Посмотри эту тему Прием Всех Файлов
ReLeFNIQ
сообщение 2.12.2006, 19:32
Цитата(Sanyok_ @ Суббота, 2 Декабря 2006, 21:15)
Спасибо но скажи пожалуйста где ето точно описано потомучто не нахожу где обяснено...
Nogay
сообщение 2.12.2006, 20:04
Из: Фёдоровка, Сургутский район
Пользователь №: 83 007
Прошивка: Mpx398 De Luxe
StrIk3r, нужно ли устанавливать ява-прогу после твоего второго патча?
StrIk3r
сообщение 2.12.2006, 20:21
Из: Великий Новгород
Пользователь №: 53 936
Модель телефона: E398@ROKR_E1_iTunes
Прошивка: R373...49R
Nogay,
как хочешь !
Nogay
сообщение 2.12.2006, 20:47
StrIk3r, ну ты посоветуй. Качество фотки будет лучше с прогой или без? А реально сделать фотки под 80кб?
AndreyD
сообщение 2.12.2006, 20:51
Прошивка: 49R
прога эта ни какой роли не играет........
пока... не играет ;)
Umka85
сообщение 2.12.2006, 23:20
Из: Кузнецк
Пользователь №: 46 099
Прошивка: разные
Вот Frozen выложил Рефлеш + патч, для тех, у кого с офсайта не качается.
http://filez.rutv.info/swel255_0.3_49R_reflash.rar
Bent
сообщение 3.12.2006, 3:18
MoTo Marvellous
ReLeFNIQ, пожалуйста тебе конкретика: Для включения выбора устройства сохранения приложений необходимо в seem 0032_0001 отключить по адресу 0A0 на 0E бит 2
Niko_First
сообщение 3.12.2006, 5:34
Из: Красноярск
Пользователь №: 88 579
Модель телефона: V3i
Прошивка: китаец
Выложите пожалуйста фулфлеш 49r v0.3, с офсайта не качается... evil_zloi;
С меня +.
p00p0k
сообщение 3.12.2006, 6:57
Пользователь №: 95 690
Прошивка: electro255
Вкладываю на райпидшару и на вебфайл!
Жди!
Фулфлешь с веб-файла
Фулфлешь с райпиды
Ovip
сообщение 3.12.2006, 7:13
Пользователь №: 85 143
Модель телефона: e790
Прошивка: 48 ща 49 щью =)
http://www.webfile.ru/1219134
вот держи на webfile
Сообщение отредактировал Sanyok_ - 3.12.2006, 7:17
p00p0k
сообщение 3.12.2006, 7:19
А вот теперь пришло время всех шокировать!
Вот принесли мне телефон вчера! Утопленник я его искупал в спиртовой ванне! Общую плату и плату клавиатуры!
Преде эти сняв камеру, динамы, и т.п.
Включил работает!
А в разделе мототюнинг я очень часто выкладываю фотки со своими творениями!
Т.к. панелька на моём теле а цифровухи нету я сфоткал свой телефон спомощью бывшего утопленника (прошивка стоит Moto_Sven New Bug Fix, которая стоит поверх 42_for_all)
Я чуть не упал! У меня до сих пор такой шок что мама не горюй!
Вот фотки:
Прикрепленное изображение 53.79кб Прикрепленное изображение 67.4кб
Прикрепленное изображение 37.06кб Прикрепленное изображение 57.58кб
Прикрепленное изображение 62.75кб
Неужели это камера? Или все же если я щас поставлю 42_for_all а поверх неё Moto_Sven New Bug Fix
у меня будет такое же качество?
Объясните мне дурню такому!
Для кого эта тема Е398,сделаем Наши Фотки Лучшими, там обсуждение всего этого, и прекращаем фотогаллерею делать в этой теме!
[OFF]Сообщение отредактировал BackgaMan - Сегодня, 10:43[/OFF]
Но мы вроде обсуждаем проблему качества съёмки в этом монстре? Или уже нет?!
Сообщение отредактировал p00p0k - Сегодня, 11:04
Судя по последним постам, это набивание постов!
Даладно какое набивание постов! Они просто ненужны если честно! Я просто удивлён были сильно! Ну да ладно извини!
Сообщение отредактировал p00p0k - 3.12.2006, 8:22
Bent
сообщение 3.12.2006, 8:13
MoTo Marvellous
p00p0k, Ну и что?У меня такое же хорошее качество.Качество съёмки зависит от многих параметров и одно из главных это сама Камера
А дальше ты уже можешь её улучшить и т.д.,НО если камера изначально косяченная или ты её сам закосячил(солнце снимал,бил,купал телефон) то тогда хорошего качества снимков тебе не видать.
P.S. и правда заканчивай фотки кидать ,парочку выложил и хватит.
Алекс75
сообщение 3.12.2006, 9:20
Мото-реаниматор
Пользователь №: 30 882
Модель телефона: XT502
Прошивка: Android 2.2
Народ...опрос на засыпку(просто уже упарился перебирать варианты) у кого на рефлеше 49R от elektro255 jimm версий 5.0.,5.1 или 5.2 коннектится по http протоколу?Я перебрал все моды ни один коннектится не хочет,причем опера мод 1.25 с теми же настройками коннектится без проблем,значит дело не в ОПСОСЕ!Может вопрос не совсем в тему,но мне кажется что дело именно в рефреше а не в аське.На 48R конектился и с 5.1 и с 5.0 без проблем.....и по wap и по http протоколу.
Ratmagor
сообщение 3.12.2006, 12:16
Из: Мск
Пользователь №: 59 289
Модель телефона: Motorola Moto Maxx
Прошивка: KitKat
Алекс75,
Ася поменяла протокол и старые jimm`ы к ней не коннектятся... Попробуй скачать последний... ИМХО проша не при чем..
p00p0k
сообщение 3.12.2006, 13:45
Алекс75,
У меня всё прекрасно работает! Причем специально проверил несколько версий! Все работают!
(попробуй включить безопасный режим)
F-ext
сообщение 3.12.2006, 14:43
Пользователь №: 108 168
Прошивка: 49r
Цитата(Bent @ Пятница, 1 Декабря 2006, 20:53)
Добавил на наш сайт RadioComm v.9.0.0 Качаем с Родного Мотофана :)
sori pf OFF TOP но всё же важно !!! evil_zloi;
Люди осторожно вместе с RadioComm'ом, из данного архива, устанавливаеться троян и появляеться svchost.exe в папке Windows !!! (AVP идентифицирует как Trojan-PSW.Win32.LdPinch.ro") ! Проверьте...
Bkmzv3
сообщение 3.12.2006, 16:09
Пользователь №: 78 094
Модель телефона: se w610 !!!
Прошивка: R6BC002
на этом монстре:меню->служебное->Instant Massanger как настроить ICQ?
~Gangs2er~
сообщение 3.12.2006, 17:45
MotoSkinner
Пользователь №: 93 787
Модель телефона: (M) E398
Прошивка: У вас такой нету))
ToAll: для тех кто ещё не знает, я сделал несколько патчей на съёмку фотокамерой лежат в Зтой теме!
Сергей_Motofan
сообщение 3.12.2006, 17:56
Из: г. Оренбург
Пользователь №: 85 146
Прошивка: CM 12.1 5.1.1
..::MotoLife::..
Люди. Тут такая проблема. Я постоянно слежу за малейшими изменениями в этой теме и на сайте у elektro255. Качаю всё чтоо там появляется. Но вот дня 2 назад случилась беда - после патча для улучшения камеры тело сдохло. Я ставил патч, затем у меня ФБ3 завис и не хотел отзываться... Я выдернул шнур и попытался включить тело....безуспешно. Даже Бэкап не помогает!!! Все темы по восстановлению я прочитал - ничего не помогает. Я ПРОШУ ВСЕХ, а в частности elektro255, может ты знаешь способы по восстановлению....
З.Ы. По всем темам я понял, что у меня убита Flash-память...
pes_voiny
сообщение 3.12.2006, 18:34
Пользователь №: 71 361
Прошивка: 49R_Elektro255_v0.3
2 all: Почему при запуске программы Personalize выскакивает сообщение You can use only... 1,2,3,4,5,6,7,8,9,0,*.# У меня стоит рефлеш от Электро, все остальное свое, в эту прогу я закидываю бинарный бекап SW.bin и при запуске выкидывает эту фигню!!!
2 all: И почему при входе в меню без сим-карты при выборе в меню Мультимедиа пункта картинки или мелодии или при входа в справочник, выскакивает табличка Идет подключение... и так бесконечно!!!! Ведь, при правке симов для входа в меню без сим-карты работали все функции,кроме GSM!!!
p00p0k
сообщение 3.12.2006, 19:07
Было где то на страницах упомянуто, что работать без симки может только iTunes.
Nogay
сообщение 3.12.2006, 19:12
Не только iTunes. Можно ещё пользоваться ява-играми и приложениями.Когда выскакивает табличка Идёт подключение... просто нажимаем на красную кнопку и вы в пункте Игры и приложения.
juicedddd
сообщение 3.12.2006, 20:22
Из: Сыктывкар
Мануал по созданию патч для смены Bootscreen в прошивке 0.3(49R)-=elektro255=-
!!! Внимание: Строка внизу с сайтом электро ОСТАЕТСЯ !!!
Так как заменить Bootscreen возможно только перед прошивкой программой Personalize, но согласитесь, что в любой момент может захотеться сменить Bootscreen.
Тогда создадим патч чтобы сменить Bootscreen и не получить труп.
Во первых в программе Motorola Bootscreen Replacer 4.1, в файле offset.ini добавляем следующие строки
[R373...49R(0.3) Electro255]
Electro255=C5FFFF
в принципе оффсет такой же, как и в 0.2 прошивке.
Есть два способа заменить Bootscreen через патчи.
1 способ (прохождение через труп):
1) После добавления в offset.ini нужных строк создаем патч (с любой картинкой) для нашей прошивки.
2) Применяем патч => Получаем ТРУП.
3) Далее необходимо войти в бутлодер или дуалбут (замыкание 4-5 контакта или как-нибудь по-другому)
Если интересно как это делаю я то:
[OFF]После получения трупа, вставляю кабель и жму зелёную и затем красную (т. к пользуюсь дуалбутом)
На сообщение компа "Устройство USB неопознано" не обращаю внимания.
Вынимаю, вставляю кабель, жму кнопки (зеленая и красная). Все это повторяю 5-7-10 раз и в один прекрасный момент тел. в дуалбуте.[/OFF]
4) После того как тел. буте применяем патч Восстановление трупа.
Все радуемся новому Bootscreen.
2 способ (без прохождения через труп):
1) Так же после добавления в offset.ini нужных строк создаем патч (с любой картинкой) для нашей прошивки.
2) Скачиваем патч Восстановление трупа.
3) Открываем наш патч блокнотом, находим конец цифр и с новой строки добавляем оффсет и цифры из патча Восстановление трупа.
Внимание: Оффсет и цифры из патча Восстановление трупа должны стоять последними т.е если его открыть патч "текстовым редактором WordPad"то он должен выглядеть так:
C5FFFF: xxxxxxxxx.....
C71DFF: 610881108.....
где xxxx-любые цифры полученные программой Motorola Bootscreen Replacer 4.1
Т.е Строка C71DFF: 610881108..... должна стоять ниже строки C5FFFF: xxxxxxxxx.....
4) После того, как все приведено в нужное состояние, применяем патч.
Если вы делаете по 2 способу и все правильно, то никакаго трупа вы не получите.
!!!За несоблюдение мануала и в последствии убитые телефоны ответственности не несу!!!
[OFF]1 способ для рисковых людей.
Мне кажется что 2 способ будет более востребован.[/OFF]
Несколько патчей от меня на Моей страничке (все работают, проверял на своем):
WindowsXP Mobile
LiguidSpace(не очень корректное изображение)
Sony Ericsson
Vista
В архивах присутствуют картинки (без строки внизу с сайтом электро) на которые меняется Bootscreen.
Не забываем о благодарности!
Сообщение отредактировал juicedddd - 2.4.2007, 12:03
Bent
сообщение 4.12.2006, 5:42
MoTo Marvellous
F-ext,
Благодарю за твою бдительность.Файл был удалён и заменён на новый.
EXmaloy
сообщение 4.12.2006, 6:53
Из: Геленджик
Пользователь №: 66 754
Модель телефона: v3,v600,mpx200
А как ставить эту прошивку. Там прилагается Flesher но у меня он не работает, что мне сделать
Doktor Кот
сообщение 4.12.2006, 7:03
Из: Красноярск
Пользователь №: 94 751
Прошивка: Electro_R373...49R
Всем привет! Кто нибудь может пожалуйста выложить флекс от прошивы 0.3 для 46R! Плюсы обещаю!
HUNTER_ok
сообщение 4.12.2006, 7:18
Из: Заозерный webstream :D
Пользователь №: 106 065
Модель телефона: SE W810i
Doktor Кот, Уже выкладывали! Тему почитай.
Вот reflash_49r
juicedddd
сообщение 4.12.2006, 7:26
Из: Сыктывкар
EXmaloy,
можно поставить с помощью FlashBackup, я так себе и ставил.
EXmaloy
сообщение 4.12.2006, 7:28
Из: Геленджик
Я пробовал поставить Флэш бэкапом, он на стирании памяти остановливается, или она очень долго на этой прошивке идёт?
Текстовая версия Сейчас: 21.7.2025, 21:37
