23 страниц V « < 3 4 5 6 > »
Elektro255 V0.4 alpha 4 mod (4xR), 44R,46R,49R,79R
elektro255
сообщение 23.9.2006, 12:06 Закрепленное сообщение!
Из: Poland, Siedlce
Пользователь №: 53 130
09-04-2007
V0.4a4 Alpha: http://elektro255.ovh.org
08-04-2007
V0.4a3 Alpha: http://elektro255.ovh.org
07-04-2007
V0.4a2 44R Alpha: http://elektro255.ovh.org
20-12-2006
V0.3 79R Final mod: http://elektro255.ovh.org
27-11-2006
v0.3 for 49R Final mod http://elektro255.ovh.org/
26-11-2006
V0.3 46R Final mod: http://elektro255.ovh.org
НА Е1 Rokr с бутом 0А02 (оригинальный) НЕ ПОСТАВИТЕ БЕЗ Т.П.!
V0.4 alpha 4
Changes:
- Fixed problem with display timeout (fullscreen clock) when SMS/CALL received
Features:
- 4xR and 7xR MIX (use with 4xR flex)
- unlimited Video recording
- keypad automatic lock
- low battery alarm can be turned off or depend on ring style.
- Scheduled Ring Styles (ring style and funlight style can change automatically on given time and week day)
- flashlight shortcut (##)
- extra menu (shortcut *1 [shortcut is only for testing later will be changed])
- automatic menu enter, without sim card (emergency calls working too)
- new Java methods
- settings are stored on files
- no simlock checking
- Volume-bar sound can be turned off
- multiple menus (every skin can have one mma_ucp)
- Ported patches:
o SMS report significantly turned ON
o more folders in OBEX via BT
o removed unused folders from TransFlash
o Java have access to system files
o increased iTap user dictionary size
o no delete incall on SIM replace
o Bluetooth time changed to 3 minutes
o reordered camera store menu (store only is first)
o SMS alert is using default ringtone
OLD versions(V0.1-0.3):
Firmware changes:
- firmware based on 46R from StarterXP MP
- FULL SW access from Java
- LUMA&CHROMA tables moved to memory - now you can change JPEG compresion from Java
- StarterXP flex
- added dualboot
Flasher changes:
- if you have PDS_4013 flasher will no recreate this
Personalization tool changes:
- first version for 0.3_46R SW mod
- changing splash screen
- changing font (you can use *.fnt or *.smg CG4 files)
- you can turn on, turn off menu access without sim cart
- changing my shortcuts
Новая версия V0.4 alpha 4
Изменения:
- Устранена проблема с таймаутом дисплея(полноэкранные часы) при приеме смс/звонка
Новое:
- Прошивка создана как микс 4xR и 7xR (флекс 4xR ) В 44R она переименована для совместимости! Она близко не лежит к 44R на самом деле!
- Безлимитная запись видео (64мб макс как в 6х7х)
- Автоблок клавиатуры
- Звук разряженой батареи можно выключать или задать стилем оповещения(?).
- Расписание стилей оповещения (стиль оповещения и фанлайтмогут менятся автоматически по времени и дням недели)
- Фонарик по (##)
- Дополнительное меню (метка *1 [только для теста, после может изменится])
- Автоматический вход в меню без сим-карты (аварийные звонки работают)
- Новые методы в Яве (не от 79R, а новые)
- Настройки хранятся в файлах
- Не проверяется лоченость ПДС на симку (работает с лоченым пдс)
- Звук изменения громкости можно отключить
- Мультименю (каждый скин может иметь собственный мма_уцп)
- Портированы патчи:
o Оповещение о доставке SMS всегда вкл.
o больше папок доступно по OBEX из блютуза
o удалены неиспользуемые папки с флешки
o Полный доступ к системным файлам из явы
o увеличен размер пользовательского словаря iTap
o не удалыются последние вызовы при смене сим
o Время обнаружения блютуза - 3 минуты
o Меню сохранения видеозаписи (просто сохранить - первым пунктом)
o при приходе SMS играет "мелодия на смс", а не установленная на этого пользователя
Для версий 0.1-0.3
Изменения в прошивке:
- Создана на базе монстра StarterXP 46R
- Полный доступ к прошивке (симы, озу) из явы
- Таблицы сжатия фотографий перенесены в озу - теперь из явы можно управлять качеством фотографий (сжатием)
- флекс StarterXP
- добавлен дуалбут
Изменения флешера:
-Если ПДС версии 4013 (373 платформа), ПДС не пересоздается.
Изменения персонализации (Personalization tool):
- впервые для мода использована 46 прошивка
- замена заставки (на включение?)
- замена шрифта (лангпак, CG4)
- можно вкл. и выкл. доступ к меню без сим-карты
- изменен ярлык (копирайт?)
Для работы Personalization tool требуется положить в папку программы несжатый бинарный бэкап (32 мегабайта) под именем SW.bin
Прекращаем флудить, типа а когда выйдет новая версия, и.т.д.и.т.п, или придётся наказывать!
тему почистил, архив по 1 декабря тут:
Прикрепленный файл MotoFan_ru_electro.zip   ( 66.56 килобайт ) Кол-во скачиваний: 3902
Сообщение отредактировал elektro255 - 9.4.2007, 12:21
EXmaloy
сообщение 4.12.2006, 6:53
Из: Геленджик
Пользователь №: 66 754
Модель телефона: v3,v600,mpx200
А как ставить эту прошивку. Там прилагается Flesher но у меня он не работает, что мне сделать
Doktor Кот
сообщение 4.12.2006, 7:03
Из: Красноярск
Пользователь №: 94 751
Прошивка: Electro_R373...49R
Всем привет! Кто нибудь может пожалуйста выложить флекс от прошивы 0.3 для 46R! Плюсы обещаю!
HUNTER_ok
сообщение 4.12.2006, 7:18
Из: Заозерный webstream :D
Пользователь №: 106 065
Модель телефона: SE W810i
Doktor Кот, Уже выкладывали! Тему почитай.
Вот reflash_49r
juicedddd
сообщение 4.12.2006, 7:26
Из: Сыктывкар
Пользователь №: 77 458
Модель телефона: ~E398~
Прошивка: Dream a reality_79R
EXmaloy,
можно поставить с помощью FlashBackup, я так себе и ставил.
EXmaloy
сообщение 4.12.2006, 7:28
Из: Геленджик
Я пробовал поставить Флэш бэкапом, он на стирании памяти остановливается, или она очень долго на этой прошивке идёт?
HUNTER_ok
сообщение 4.12.2006, 7:36
EXmaloy, Стирание памяти идёт около пяти минут.
EXmaloy
сообщение 4.12.2006, 7:58
Из: Геленджик
Ой перепутал, у меня ничем не получается прошить, там же расширение прошивки .bin как её можно флеш бекапом прошить, ли нужно сначало ещё что-то сделать?
Doktor Кот
сообщение 4.12.2006, 8:39
Из: Красноярск
Hunter_ok, нигде не могу найти! А рефлеш на 49R мне не нужен! Кстати, а можно на оригинальный е1 поставить флекс от 0.3? Если можно выложите пожалуйста флекс от 0.3 на базе 46R! Плюсы обещаю!
juicedddd
сообщение 4.12.2006, 9:25
Из: Сыктывкар
EXmaloy,
В FlashBackup 2.62 есть вкладка "создание прошивок" файл резервной копии выбираеш SW.bin и создаешь прошу и спокойно прошиваешь
EXmaloy
сообщение 4.12.2006, 9:34
Из: Геленджик
Цитата(juicedddd @ Понедельник, 4 Декабря 2006, 12:25)
EXmaloy,
Понял, спасибо!
Jordon
сообщение 4.12.2006, 10:28
Из: Оренбург<=>Москва
Пользователь №: 58 196
Модель телефона: нет
ПОдскажите какой сим надо править чтобы получая java файлы он спрашивал куда их ставить?
Trentemoller
сообщение 4.12.2006, 13:25
Из: Армавир
Пользователь №: 105 953
Прошивка: R373_G_0E.30.49R
Jordon,
В p2kTools 0.8.6 зайди other features>java>разное>выбор устр. хранения. (выкл/вкл)
Jordon
сообщение 4.12.2006, 13:45
это не мне надо- парень просил ему посмотреть- мне надо сказать ему именно в симах. Можешь посмотреть. У меня щас ничего по моторам нет..
MelkiY FAN
сообщение 4.12.2006, 14:40
[ Moto TIcux ]
Пользователь №: 104 390
Модель телефона: iPhone
Цитата(A.06 @ Пятница, 1 Декабря 2006, 15:22)
elektro255, could you make a patch which will play next song after playing previous in standard player ?
Do you think, tha it is realy?
ATeapot
сообщение 4.12.2006, 18:20
Пользователь №: 75 979
Модель телефона: E 398
Прошивка: 373...42r
Прошился 3-й версией, все радует кроме голосовых меток на интелект. клавише; а теперь вопрос как их оттуда убрать и назначить че нить свое. Про программу P2KMenuEditor знаю, однако она тут не поможет, т.к. автор монстра поменял кнопки местами!
Bkmzv3
сообщение 4.12.2006, 18:22
Пользователь №: 78 094
Модель телефона: se w610 !!!
Прошивка: R6BC002
Люди , ответьте пожалуйста на 294 пост <_<
Chili89
сообщение 4.12.2006, 20:07
Из: Питер
Пользователь №: 51 289
Прошивка: 373 R48
Пробовал ставить два патча для камеры.Не один не помог.Фотки весят по 65 килобайт(примерно).А вот сама фотка получается какаята фиговая(размазанная).У меня стоит 0.3 R49.
human83
сообщение 4.12.2006, 20:48
Пользователь №: 95 584
Модель телефона: E398@iPOD
Прошивка: 49R
Во встроенном hex-редакторе (в P2KTools) считывается 005b_0001 (как считывать: в поле seem водишь 005b, а в поле rec 0001 и жмёшь читать seem).
Или сливаешь сим 005b_0001 и открываешь любым hex-редактором.
Далее переходишь к смещению 15h и выставляешь 15, потом к смещению 16h и меняешь значение на 3f . Заливаешь сим обратно в телефон и перезагруз. тела. Всё!
Вот не большая таблица значений по назначению действий на любую клавишу:
Смещение - клавиша - стандартное значение
00 - 1 - 01
01 - 2 - 02
02 - 3 - 03
03 - 4 - 04
04 - 5 - 05
05 - 6 - 06
06 - 7 - 07
07 - 8 - 08
08 - 9 - 09
09 - * - 0a
0a - 0 - 00
0b - # - 0b
0c - 12 - посыл
0d - 11 - отбой
0e - 0f - правый софт
0f - 0e - левый софт
10 - 2c - джой вверх
11 - 14 - меню
12 - 2d - джой вниз
13 - 17 - громкость +
14 - 18 - громкость -
15 - 15 - смарт-клавиша
16 - 3F - фото-клавиша
0a - 2f - джой вправо
0b - 2e - джой влево
0c - 3d - джой - нажатие
Есть еще байт по смещению 0d со значением 11, его сущность не ясна: клавиш-то нет больше =)
Пример ручной правки сима 005b_0001 в прошивке elektro255_mod_v0.3_49R
A.06
сообщение 5.12.2006, 5:38
Пользователь №: 60 599
Модель телефона: e398 white
Прошивка: r373_g_oe.30.48r
А почему бы и нет?
по сравнению с доступом к озу это ИМХО пустяк.
pes_voiny
сообщение 5.12.2006, 8:30
Пользователь №: 71 361
Прошивка: 49R_Elektro255_v0.3
2 all: Почему у меня не работает фонарик по ## ??? Я прошил рефлеш 0.3!!!
ATeapot
сообщение 5.12.2006, 11:32
Прошивка: 373...42r
human83 огромное спасибо за такой исчерпывающий ответ!!!!!!!! А ты случайно не знаешь как сделать чтобы кнопка гарнитуры работала и при блокированной клавиатуре?
igorrius
сообщение 5.12.2006, 13:48
Пользователь №: 56 062
Прошивка: 49r
Включение/Выключение звука разряженной батареи
Для отключения этой опции править SEEM 004A_0001 offset 0x91 bit 0, или редактируйте этот сим через яву featurestorestate(1555,0);
так написано в закрепленном сообщении. как найти этот офсет в п2к тулсе?
Trentemoller
сообщение 5.12.2006, 21:08
Из: Армавир
igorrius,
Этот оффсет надо искать через p2kSeem, есть такая прога. Скачай ее и сделай, то что нужно.
igorrius
сообщение 6.12.2006, 4:59
Прошивка: 49r
Есть у меня такая. Я не знаю, как в ней искать...
AlexKooper
сообщение 6.12.2006, 6:06
Из: Йошкар-Ола
Пользователь №: 47 140
Прошивка: AlexKooper mod v.47
igorrius, посмотри проблемы и решения, я там в каком-то посте на примере P2KTOOLS расписал как оффсетя искать
pes_voiny
сообщение 6.12.2006, 6:38
Ответьте плиз на мой 185-й пост???
Bent
сообщение 6.12.2006, 7:18
MoTo Marvellous
Пользователь №: 63 874
pes_voiny, У всех работает,а у тебя нет...соответсвенно что то ТЫ сделал не так...поэтому все и молчат.
Пробуй ещё раз прошить CG1 и CG3 или FullFlash(мне кажется Full лучше,я всегда Full шью),если делаешь прошивку через Personalize то убедись что там стоят кнопки на фонарик.Желательно прошивай через Flasher(благо он теперь стабилен и не тупит...)
Doktor Кот
сообщение 6.12.2006, 12:47
Из: Красноярск
Привет, народ! Я уже второй раз буду просить подачки, ажно стыдно становится! =) выложите пожалуйста флекс от прошивы 0.3 R373...46R! Завалю плюсиками!
StrIk3r
сообщение 6.12.2006, 13:58
Из: Великий Новгород
Пользователь №: 53 936
Модель телефона: E398@ROKR_E1_iTunes
Прошивка: R373...49R
Doktor Кот, а зачем тебе этот флекс?
Прошив флекс ты изменишь себе только оформление!
Все вкусности прошивки ты не получишь!
_TRANE_
сообщение 6.12.2006, 14:20
MOTOmeloMAN
Из: New_Oskol_City(Бел.Область)
Пользователь №: 104 202
Модель телефона: E398+KOSS The PLUG
Прошивка: MPX 398 DeLuXe
Поставил я эту прошу, уже хожу 4 дня всё норма.
Только вот несколько проблем:1)Как сделать чтоб смс'ки
нормальными были а не пустыми (обьясните подробно).
2)Как сделать чтоб он спрашивал куда сохранять файлы
принятые по BT, а то он их сразу на телефон ложит.
AndreyD
сообщение 6.12.2006, 15:01
Пользователь №: 80 023
Прошивка: 49R
а 49-ый рефлеш можно заливать на 46R ?
Trentemoller
сообщение 6.12.2006, 15:24
Из: Армавир
AndreyD,
Можно, только предварительно сделай бэкап.
ATeapot
сообщение 6.12.2006, 15:57
Прошивка: 373...42r
Помогите пожалуйста. Поставил 3-ю версию ивозникла проблема при съемке фотокамерой иногда получаются вот такие фоткиПрикрепленное изображение и что самое плохое это происходит бесконтрольно, т.е. снимал, снимал на 5 минут положил и вот такая лажа.
_TRANE_
сообщение 6.12.2006, 15:59
MOTOmeloMAN
ATeapot, на патч поставь и радуйся!
ATeapot
сообщение 6.12.2006, 16:01
Прошивка: 373...42r
_TRANE_ огромное спасибо счас попробую.
А чем его ставить
BackgaMan
сообщение 6.12.2006, 16:23
Мотоумелец
Пользователь №: 61 651
Модель телефона: E-398 Htc-p3300
А чем его ставить
FlashBackup
_TRANE_
сообщение 6.12.2006, 16:47
MOTOmeloMAN
Help!!! Please!!! :( :( :( :( :( :(
Nogay
сообщение 6.12.2006, 18:09
Из: Фёдоровка, Сургутский район
Пользователь №: 83 007
Прошивка: Mpx398 De Luxe
Выложите кто-нибудь Flasher. :)
BackgaMan
сообщение 6.12.2006, 19:11
Мотоумелец
Nogay
сообщение 6.12.2006, 19:20
BackgaMan, спасибо :). Ты не знаешь каким ФБ желательно прошивать патчи? huh.gif И почему 2.62 прошивает за несколько секунд, а ФБ3 прошивает несколько минут, с чем это может быть связано?
Текстовая версия Сейчас: 1.8.2025, 15:20
