23 страниц V « < 4 5 6 7 > »
Elektro255 V0.4 alpha 4 mod (4xR), 44R,46R,49R,79R
elektro255
сообщение 23.9.2006, 12:06 Закрепленное сообщение!
Из: Poland, Siedlce
Пользователь №: 53 130
09-04-2007
V0.4a4 Alpha: http://elektro255.ovh.org
08-04-2007
V0.4a3 Alpha: http://elektro255.ovh.org
07-04-2007
V0.4a2 44R Alpha: http://elektro255.ovh.org
20-12-2006
V0.3 79R Final mod: http://elektro255.ovh.org
27-11-2006
v0.3 for 49R Final mod http://elektro255.ovh.org/
26-11-2006
V0.3 46R Final mod: http://elektro255.ovh.org
НА Е1 Rokr с бутом 0А02 (оригинальный) НЕ ПОСТАВИТЕ БЕЗ Т.П.!
V0.4 alpha 4
Changes:
- Fixed problem with display timeout (fullscreen clock) when SMS/CALL received
Features:
- 4xR and 7xR MIX (use with 4xR flex)
- unlimited Video recording
- keypad automatic lock
- low battery alarm can be turned off or depend on ring style.
- Scheduled Ring Styles (ring style and funlight style can change automatically on given time and week day)
- flashlight shortcut (##)
- extra menu (shortcut *1 [shortcut is only for testing later will be changed])
- automatic menu enter, without sim card (emergency calls working too)
- new Java methods
- settings are stored on files
- no simlock checking
- Volume-bar sound can be turned off
- multiple menus (every skin can have one mma_ucp)
- Ported patches:
o SMS report significantly turned ON
o more folders in OBEX via BT
o removed unused folders from TransFlash
o Java have access to system files
o increased iTap user dictionary size
o no delete incall on SIM replace
o Bluetooth time changed to 3 minutes
o reordered camera store menu (store only is first)
o SMS alert is using default ringtone
OLD versions(V0.1-0.3):
Firmware changes:
- firmware based on 46R from StarterXP MP
- FULL SW access from Java
- LUMA&CHROMA tables moved to memory - now you can change JPEG compresion from Java
- StarterXP flex
- added dualboot
Flasher changes:
- if you have PDS_4013 flasher will no recreate this
Personalization tool changes:
- first version for 0.3_46R SW mod
- changing splash screen
- changing font (you can use *.fnt or *.smg CG4 files)
- you can turn on, turn off menu access without sim cart
- changing my shortcuts
Новая версия V0.4 alpha 4
Изменения:
- Устранена проблема с таймаутом дисплея(полноэкранные часы) при приеме смс/звонка
Новое:
- Прошивка создана как микс 4xR и 7xR (флекс 4xR ) В 44R она переименована для совместимости! Она близко не лежит к 44R на самом деле!
- Безлимитная запись видео (64мб макс как в 6х7х)
- Автоблок клавиатуры
- Звук разряженой батареи можно выключать или задать стилем оповещения(?).
- Расписание стилей оповещения (стиль оповещения и фанлайтмогут менятся автоматически по времени и дням недели)
- Фонарик по (##)
- Дополнительное меню (метка *1 [только для теста, после может изменится])
- Автоматический вход в меню без сим-карты (аварийные звонки работают)
- Новые методы в Яве (не от 79R, а новые)
- Настройки хранятся в файлах
- Не проверяется лоченость ПДС на симку (работает с лоченым пдс)
- Звук изменения громкости можно отключить
- Мультименю (каждый скин может иметь собственный мма_уцп)
- Портированы патчи:
o Оповещение о доставке SMS всегда вкл.
o больше папок доступно по OBEX из блютуза
o удалены неиспользуемые папки с флешки
o Полный доступ к системным файлам из явы
o увеличен размер пользовательского словаря iTap
o не удалыются последние вызовы при смене сим
o Время обнаружения блютуза - 3 минуты
o Меню сохранения видеозаписи (просто сохранить - первым пунктом)
o при приходе SMS играет "мелодия на смс", а не установленная на этого пользователя
Для версий 0.1-0.3
Изменения в прошивке:
- Создана на базе монстра StarterXP 46R
- Полный доступ к прошивке (симы, озу) из явы
- Таблицы сжатия фотографий перенесены в озу - теперь из явы можно управлять качеством фотографий (сжатием)
- флекс StarterXP
- добавлен дуалбут
Изменения флешера:
-Если ПДС версии 4013 (373 платформа), ПДС не пересоздается.
Изменения персонализации (Personalization tool):
- впервые для мода использована 46 прошивка
- замена заставки (на включение?)
- замена шрифта (лангпак, CG4)
- можно вкл. и выкл. доступ к меню без сим-карты
- изменен ярлык (копирайт?)
Для работы Personalization tool требуется положить в папку программы несжатый бинарный бэкап (32 мегабайта) под именем SW.bin
Прекращаем флудить, типа а когда выйдет новая версия, и.т.д.и.т.п, или придётся наказывать!
тему почистил, архив по 1 декабря тут:
Прикрепленный файл MotoFan_ru_electro.zip   ( 66.56 килобайт ) Кол-во скачиваний: 3902
Сообщение отредактировал elektro255 - 9.4.2007, 12:21
Bkmzv3
сообщение 4.12.2006, 18:22
Пользователь №: 78 094
Модель телефона: se w610 !!!
Прошивка: R6BC002
Люди , ответьте пожалуйста на 294 пост <_<
Chili89
сообщение 4.12.2006, 20:07
Из: Питер
Пользователь №: 51 289
Модель телефона: E 398
Прошивка: 373 R48
Пробовал ставить два патча для камеры.Не один не помог.Фотки весят по 65 килобайт(примерно).А вот сама фотка получается какаята фиговая(размазанная).У меня стоит 0.3 R49.
human83
сообщение 4.12.2006, 20:48
Пользователь №: 95 584
Модель телефона: E398@iPOD
Прошивка: 49R
Цитата(ATeapot @ Вторник, 5 Декабря 2006, 1:20)
Прошился 3-й версией, все радует кроме голосовых меток на интелект. клавише; а теперь вопрос как их оттуда убрать и назначить че нить свое. Про программу P2KMenuEditor знаю, однако она тут не поможет, т.к. автор монстра поменял кнопки местами!
Во встроенном hex-редакторе (в P2KTools) считывается 005b_0001 (как считывать: в поле seem водишь 005b, а в поле rec 0001 и жмёшь читать seem).
Или сливаешь сим 005b_0001 и открываешь любым hex-редактором.
Далее переходишь к смещению 15h и выставляешь 15, потом к смещению 16h и меняешь значение на 3f . Заливаешь сим обратно в телефон и перезагруз. тела. Всё!
Вот не большая таблица значений по назначению действий на любую клавишу:
Смещение - клавиша - стандартное значение
00 - 1 - 01
01 - 2 - 02
02 - 3 - 03
03 - 4 - 04
04 - 5 - 05
05 - 6 - 06
06 - 7 - 07
07 - 8 - 08
08 - 9 - 09
09 - * - 0a
0a - 0 - 00
0b - # - 0b
0c - 12 - посыл
0d - 11 - отбой
0e - 0f - правый софт
0f - 0e - левый софт
10 - 2c - джой вверх
11 - 14 - меню
12 - 2d - джой вниз
13 - 17 - громкость +
14 - 18 - громкость -
15 - 15 - смарт-клавиша
16 - 3F - фото-клавиша
0a - 2f - джой вправо
0b - 2e - джой влево
0c - 3d - джой - нажатие
Есть еще байт по смещению 0d со значением 11, его сущность не ясна: клавиш-то нет больше =)
Пример ручной правки сима 005b_0001 в прошивке elektro255_mod_v0.3_49R
A.06
сообщение 5.12.2006, 5:38
Пользователь №: 60 599
Модель телефона: e398 white
Прошивка: r373_g_oe.30.48r
Цитата(MelkiY FAN @ Понедельник, 4 Декабря 2006, 11:10)
Do you think, tha it is realy?
А почему бы и нет?
по сравнению с доступом к озу это ИМХО пустяк.
pes_voiny
сообщение 5.12.2006, 8:30
Пользователь №: 71 361
Прошивка: 49R_Elektro255_v0.3
2 all: Почему у меня не работает фонарик по ## ??? Я прошил рефлеш 0.3!!!
ATeapot
сообщение 5.12.2006, 11:32
Пользователь №: 75 979
Прошивка: 373...42r
human83 огромное спасибо за такой исчерпывающий ответ!!!!!!!! А ты случайно не знаешь как сделать чтобы кнопка гарнитуры работала и при блокированной клавиатуре?
igorrius
сообщение 5.12.2006, 13:48
Пользователь №: 56 062
Прошивка: 49r
Включение/Выключение звука разряженной батареи
Для отключения этой опции править SEEM 004A_0001 offset 0x91 bit 0, или редактируйте этот сим через яву featurestorestate(1555,0);
так написано в закрепленном сообщении. как найти этот офсет в п2к тулсе?
Trentemoller
сообщение 5.12.2006, 21:08
Из: Армавир
Пользователь №: 105 953
Прошивка: R373_G_0E.30.49R
igorrius,
Этот оффсет надо искать через p2kSeem, есть такая прога. Скачай ее и сделай, то что нужно.
igorrius
сообщение 6.12.2006, 4:59
Прошивка: 49r
Есть у меня такая. Я не знаю, как в ней искать...
AlexKooper
сообщение 6.12.2006, 6:06
Из: Йошкар-Ола
Пользователь №: 47 140
Прошивка: AlexKooper mod v.47
igorrius, посмотри проблемы и решения, я там в каком-то посте на примере P2KTOOLS расписал как оффсетя искать
pes_voiny
сообщение 6.12.2006, 6:38
Ответьте плиз на мой 185-й пост???
Bent
сообщение 6.12.2006, 7:18
MoTo Marvellous
Пользователь №: 63 874
pes_voiny, У всех работает,а у тебя нет...соответсвенно что то ТЫ сделал не так...поэтому все и молчат.
Пробуй ещё раз прошить CG1 и CG3 или FullFlash(мне кажется Full лучше,я всегда Full шью),если делаешь прошивку через Personalize то убедись что там стоят кнопки на фонарик.Желательно прошивай через Flasher(благо он теперь стабилен и не тупит...)
Doktor Кот
сообщение 6.12.2006, 12:47
Из: Красноярск
Пользователь №: 94 751
Прошивка: Electro_R373...49R
Привет, народ! Я уже второй раз буду просить подачки, ажно стыдно становится! =) выложите пожалуйста флекс от прошивы 0.3 R373...46R! Завалю плюсиками!
StrIk3r
сообщение 6.12.2006, 13:58
Из: Великий Новгород
Пользователь №: 53 936
Модель телефона: E398@ROKR_E1_iTunes
Прошивка: R373...49R
Doktor Кот, а зачем тебе этот флекс?
Прошив флекс ты изменишь себе только оформление!
Все вкусности прошивки ты не получишь!
_TRANE_
сообщение 6.12.2006, 14:20
MOTOmeloMAN
Из: New_Oskol_City(Бел.Область)
Пользователь №: 104 202
Модель телефона: E398+KOSS The PLUG
Прошивка: MPX 398 DeLuXe
Поставил я эту прошу, уже хожу 4 дня всё норма.
Только вот несколько проблем:1)Как сделать чтоб смс'ки
нормальными были а не пустыми (обьясните подробно).
2)Как сделать чтоб он спрашивал куда сохранять файлы
принятые по BT, а то он их сразу на телефон ложит.
AndreyD
сообщение 6.12.2006, 15:01
Пользователь №: 80 023
Прошивка: 49R
а 49-ый рефлеш можно заливать на 46R ?
Trentemoller
сообщение 6.12.2006, 15:24
Из: Армавир
AndreyD,
Можно, только предварительно сделай бэкап.
ATeapot
сообщение 6.12.2006, 15:57
Прошивка: 373...42r
Помогите пожалуйста. Поставил 3-ю версию ивозникла проблема при съемке фотокамерой иногда получаются вот такие фоткиПрикрепленное изображение и что самое плохое это происходит бесконтрольно, т.е. снимал, снимал на 5 минут положил и вот такая лажа.
_TRANE_
сообщение 6.12.2006, 15:59
MOTOmeloMAN
ATeapot, на патч поставь и радуйся!
ATeapot
сообщение 6.12.2006, 16:01
Прошивка: 373...42r
_TRANE_ огромное спасибо счас попробую.
А чем его ставить
BackgaMan
сообщение 6.12.2006, 16:23
Мотоумелец
Пользователь №: 61 651
Модель телефона: E-398 Htc-p3300
А чем его ставить
FlashBackup
_TRANE_
сообщение 6.12.2006, 16:47
MOTOmeloMAN
Help!!! Please!!! :( :( :( :( :( :(
Nogay
сообщение 6.12.2006, 18:09
Из: Фёдоровка, Сургутский район
Пользователь №: 83 007
Прошивка: Mpx398 De Luxe
Выложите кто-нибудь Flasher. :)
BackgaMan
сообщение 6.12.2006, 19:11
Мотоумелец
Nogay
сообщение 6.12.2006, 19:20
BackgaMan, спасибо :). Ты не знаешь каким ФБ желательно прошивать патчи? huh.gif И почему 2.62 прошивает за несколько секунд, а ФБ3 прошивает несколько минут, с чем это может быть связано?
_TRANE_
сообщение 6.12.2006, 19:29
MOTOmeloMAN
Nogay, вообще тот который я выложил elektro255 советовал патчить FB2.62 но и я патчю им, а шью FB3
Nogay
сообщение 6.12.2006, 19:49
BackgaMan, при открытии Flashera выходит ошибка. Может быть архив битый.
Trentemoller
сообщение 6.12.2006, 20:57
Из: Армавир
_TRANE_,
Это все делается через p2ktools 0.8.6. Скачай и зайди в меню other features. Чтобы смс писалось нормально, зайди message>unicode (юникод) вкл или выкл. А чтобы спрашивалось, куда сохранять файлы после приема, зайди в ява>устройство хранения вкл или выкл.
Прежде чем ставить вкл или выкл - нажми "считать из телефона", а то такие косяки пойдут ;)
Сообщение отредактировал AlexKooper - 7.12.2006, 6:11
Мачо
сообщение 7.12.2006, 9:14
Из: Киров
Пользователь №: 8 569
Прошивка: Dream A Reality 2.0
Проблема .
Телефон расрывает GPRS сессию при простое , через 5 минут.
Прошу тех у кого этой проблемы нет, сделать бэкап всех симов в Программе P2Kae ( вкладка архивирование востановление сим)
список симов прикрепляю ( положить его в ...\P2KAE\Backup\SeemList.slt)
Вознаграждение гарантируется.
пс Ставил полного монстра v02 ( проблемы с gprs были), затем рефлеш v03 (проблемы остались)
качать полного монстра мне накладно ( gprs от мегафона)
dynamite
сообщение 7.12.2006, 12:37
Из: Солигорск
Пользователь №: 50 268
Прошивка: mpx398_49r
Стоял MotoWalkman49R_EM_by_Maxval_&_LexusRX400, все было стабильно. Прошил рефлеш Elektro255 V0.3 и FB перестал видеть тело. При загрузке MV пару раз перегружался, после отключения красной кнопкой не включается, пока не вынешь батарею. Откатился на v 0.2 все стало нормально, FB увидел тело...
Остаюсь пока на v 0.2
HUNTER_ok
сообщение 8.12.2006, 7:39
Из: Заозерный webstream :D
Пользователь №: 106 065
Модель телефона: SE W810i
dynamite, Попробуй FullFlash прошить может заработает.
Nogay
сообщение 8.12.2006, 10:38
dynamite, у меня тоже было такое. Это из-за того что ты прошил цифровую подпись, а нужно прошивать только Рефлэш.
Ктулху
сообщение 8.12.2006, 10:59
Moto К†улху
Из: Свердловская область
Пользователь №: 26 696
Модель телефона: Motorola Dyna-Tac
Цитата(pes_voiny @ Воскресенье, 3 Декабря 2006, 23:34)
2 all: Почему при запуске программы Personalize выскакивает сообщение You can use only... 1,2,3,4,5,6,7,8,9,0,*.# У меня стоит рефлеш от Электро, все остальное свое, в эту прогу я закидываю бинарный бекап SW.bin и при запуске выкидывает эту фигню!!!
Поддерживаю вопрос и прошу всеже дать ответ!!!
у меня таже пролема angry.gif zootaz;
optima
сообщение 8.12.2006, 11:50
Пользователь №: 16 563
Прошивка: 82R;wm6,5;4BR
Потому что у тебя Personalize для 46R. Страницы 2 - 3 назад я выкладывал Personalize для 49R для Алекс75. Ищи.
Vanich777
сообщение 8.12.2006, 12:14
~motoman~
Из: г. Хабаровск
Пользователь №: 41 249
Модель телефона: E398 ===> E1
Прошивка: Elektro255 V0.4 a.3
Цитата(Trentemoller @ Четверг, 7 Декабря 2006, 7:57)
_TRANE_,
у меня не получается включить unicode , после перезагрузки он снова выключается, что с этим делать?
после того как считаешь и включишь уникод - нажми "записать в телефон"
Сообщение отредактировал AlexKooper - 8.12.2006, 13:18
Trentemoller
сообщение 8.12.2006, 21:13
Из: Армавир
Фин,
У меня тоже такая-же хрень выскакивает, из-за этого я 3 мод и не ставил!
AleksX
сообщение 9.12.2006, 11:37
Из: Пермь
Пользователь №: 68 183
Модель телефона: L7e,Nokia 5700
Trentemoller, попробуй в P2KAE поставить unicode..У меня все нормально поставилось...
Trentemoller
сообщение 9.12.2006, 18:06
Из: Армавир
AleksX,
Я непросил, чтобы мне ответили, как вкл и выкл юникод, это я ответил на вопрос, как это сделать!
danger86
сообщение 9.12.2006, 23:15
Пользователь №: 72 895
Модель телефона: E1
0032_0001 off 3F bit 4 (№ 508)
Ктулху
сообщение 10.12.2006, 6:19
Moto К†улху
Сенкс! нашел! как то во все этом флейме прошлюй раз пропустил :) ща скачаю отпишусь о режультатах :)
Trentemoller, pes_voiny,
Personalize for 49R
Текстовая версия Сейчас: 30.7.2025, 14:02
