23 страниц V « < 4 5 6 7 > »
Elektro255 V0.4 alpha 4 mod (4xR), 44R,46R,49R,79R
elektro255
сообщение 23.9.2006, 12:06 Закрепленное сообщение!
Из: Poland, Siedlce
Пользователь №: 53 130
09-04-2007
V0.4a4 Alpha: http://elektro255.ovh.org
08-04-2007
V0.4a3 Alpha: http://elektro255.ovh.org
07-04-2007
V0.4a2 44R Alpha: http://elektro255.ovh.org
20-12-2006
V0.3 79R Final mod: http://elektro255.ovh.org
27-11-2006
v0.3 for 49R Final mod http://elektro255.ovh.org/
26-11-2006
V0.3 46R Final mod: http://elektro255.ovh.org
НА Е1 Rokr с бутом 0А02 (оригинальный) НЕ ПОСТАВИТЕ БЕЗ Т.П.!
V0.4 alpha 4
Changes:
- Fixed problem with display timeout (fullscreen clock) when SMS/CALL received
Features:
- 4xR and 7xR MIX (use with 4xR flex)
- unlimited Video recording
- keypad automatic lock
- low battery alarm can be turned off or depend on ring style.
- Scheduled Ring Styles (ring style and funlight style can change automatically on given time and week day)
- flashlight shortcut (##)
- extra menu (shortcut *1 [shortcut is only for testing later will be changed])
- automatic menu enter, without sim card (emergency calls working too)
- new Java methods
- settings are stored on files
- no simlock checking
- Volume-bar sound can be turned off
- multiple menus (every skin can have one mma_ucp)
- Ported patches:
o SMS report significantly turned ON
o more folders in OBEX via BT
o removed unused folders from TransFlash
o Java have access to system files
o increased iTap user dictionary size
o no delete incall on SIM replace
o Bluetooth time changed to 3 minutes
o reordered camera store menu (store only is first)
o SMS alert is using default ringtone
OLD versions(V0.1-0.3):
Firmware changes:
- firmware based on 46R from StarterXP MP
- FULL SW access from Java
- LUMA&CHROMA tables moved to memory - now you can change JPEG compresion from Java
- StarterXP flex
- added dualboot
Flasher changes:
- if you have PDS_4013 flasher will no recreate this
Personalization tool changes:
- first version for 0.3_46R SW mod
- changing splash screen
- changing font (you can use *.fnt or *.smg CG4 files)
- you can turn on, turn off menu access without sim cart
- changing my shortcuts
Новая версия V0.4 alpha 4
Изменения:
- Устранена проблема с таймаутом дисплея(полноэкранные часы) при приеме смс/звонка
Новое:
- Прошивка создана как микс 4xR и 7xR (флекс 4xR ) В 44R она переименована для совместимости! Она близко не лежит к 44R на самом деле!
- Безлимитная запись видео (64мб макс как в 6х7х)
- Автоблок клавиатуры
- Звук разряженой батареи можно выключать или задать стилем оповещения(?).
- Расписание стилей оповещения (стиль оповещения и фанлайтмогут менятся автоматически по времени и дням недели)
- Фонарик по (##)
- Дополнительное меню (метка *1 [только для теста, после может изменится])
- Автоматический вход в меню без сим-карты (аварийные звонки работают)
- Новые методы в Яве (не от 79R, а новые)
- Настройки хранятся в файлах
- Не проверяется лоченость ПДС на симку (работает с лоченым пдс)
- Звук изменения громкости можно отключить
- Мультименю (каждый скин может иметь собственный мма_уцп)
- Портированы патчи:
o Оповещение о доставке SMS всегда вкл.
o больше папок доступно по OBEX из блютуза
o удалены неиспользуемые папки с флешки
o Полный доступ к системным файлам из явы
o увеличен размер пользовательского словаря iTap
o не удалыются последние вызовы при смене сим
o Время обнаружения блютуза - 3 минуты
o Меню сохранения видеозаписи (просто сохранить - первым пунктом)
o при приходе SMS играет "мелодия на смс", а не установленная на этого пользователя
Для версий 0.1-0.3
Изменения в прошивке:
- Создана на базе монстра StarterXP 46R
- Полный доступ к прошивке (симы, озу) из явы
- Таблицы сжатия фотографий перенесены в озу - теперь из явы можно управлять качеством фотографий (сжатием)
- флекс StarterXP
- добавлен дуалбут
Изменения флешера:
-Если ПДС версии 4013 (373 платформа), ПДС не пересоздается.
Изменения персонализации (Personalization tool):
- впервые для мода использована 46 прошивка
- замена заставки (на включение?)
- замена шрифта (лангпак, CG4)
- можно вкл. и выкл. доступ к меню без сим-карты
- изменен ярлык (копирайт?)
Для работы Personalization tool требуется положить в папку программы несжатый бинарный бэкап (32 мегабайта) под именем SW.bin
Прекращаем флудить, типа а когда выйдет новая версия, и.т.д.и.т.п, или придётся наказывать!
тему почистил, архив по 1 декабря тут:
Прикрепленный файл MotoFan_ru_electro.zip   ( 66.56 килобайт ) Кол-во скачиваний: 3902
Сообщение отредактировал elektro255 - 9.4.2007, 12:21
_TRANE_
сообщение 6.12.2006, 19:29
MOTOmeloMAN
Из: New_Oskol_City(Бел.Область)
Пользователь №: 104 202
Модель телефона: E398+KOSS The PLUG
Прошивка: MPX 398 DeLuXe
Nogay, вообще тот который я выложил elektro255 советовал патчить FB2.62 но и я патчю им, а шью FB3
Nogay
сообщение 6.12.2006, 19:49
Из: Фёдоровка, Сургутский район
Пользователь №: 83 007
Прошивка: Mpx398 De Luxe
BackgaMan, при открытии Flashera выходит ошибка. Может быть архив битый.
Trentemoller
сообщение 6.12.2006, 20:57
Из: Армавир
Пользователь №: 105 953
Прошивка: R373_G_0E.30.49R
_TRANE_,
Это все делается через p2ktools 0.8.6. Скачай и зайди в меню other features. Чтобы смс писалось нормально, зайди message>unicode (юникод) вкл или выкл. А чтобы спрашивалось, куда сохранять файлы после приема, зайди в ява>устройство хранения вкл или выкл.
Прежде чем ставить вкл или выкл - нажми "считать из телефона", а то такие косяки пойдут ;)
Сообщение отредактировал AlexKooper - 7.12.2006, 6:11
Мачо
сообщение 7.12.2006, 9:14
Из: Киров
Пользователь №: 8 569
Прошивка: Dream A Reality 2.0
Проблема .
Телефон расрывает GPRS сессию при простое , через 5 минут.
Прошу тех у кого этой проблемы нет, сделать бэкап всех симов в Программе P2Kae ( вкладка архивирование востановление сим)
список симов прикрепляю ( положить его в ...\P2KAE\Backup\SeemList.slt)
Вознаграждение гарантируется.
пс Ставил полного монстра v02 ( проблемы с gprs были), затем рефлеш v03 (проблемы остались)
качать полного монстра мне накладно ( gprs от мегафона)
dynamite
сообщение 7.12.2006, 12:37
Из: Солигорск
Пользователь №: 50 268
Прошивка: mpx398_49r
Стоял MotoWalkman49R_EM_by_Maxval_&_LexusRX400, все было стабильно. Прошил рефлеш Elektro255 V0.3 и FB перестал видеть тело. При загрузке MV пару раз перегружался, после отключения красной кнопкой не включается, пока не вынешь батарею. Откатился на v 0.2 все стало нормально, FB увидел тело...
Остаюсь пока на v 0.2
HUNTER_ok
сообщение 8.12.2006, 7:39
Из: Заозерный webstream :D
Пользователь №: 106 065
Модель телефона: SE W810i
dynamite, Попробуй FullFlash прошить может заработает.
Nogay
сообщение 8.12.2006, 10:38
dynamite, у меня тоже было такое. Это из-за того что ты прошил цифровую подпись, а нужно прошивать только Рефлэш.
Ктулху
сообщение 8.12.2006, 10:59
Moto К†улху
Из: Свердловская область
Пользователь №: 26 696
Модель телефона: Motorola Dyna-Tac
Цитата(pes_voiny @ Воскресенье, 3 Декабря 2006, 23:34)
2 all: Почему при запуске программы Personalize выскакивает сообщение You can use only... 1,2,3,4,5,6,7,8,9,0,*.# У меня стоит рефлеш от Электро, все остальное свое, в эту прогу я закидываю бинарный бекап SW.bin и при запуске выкидывает эту фигню!!!
Поддерживаю вопрос и прошу всеже дать ответ!!!
у меня таже пролема angry.gif zootaz;
optima
сообщение 8.12.2006, 11:50
Пользователь №: 16 563
Прошивка: 82R;wm6,5;4BR
Потому что у тебя Personalize для 46R. Страницы 2 - 3 назад я выкладывал Personalize для 49R для Алекс75. Ищи.
Vanich777
сообщение 8.12.2006, 12:14
~motoman~
Из: г. Хабаровск
Пользователь №: 41 249
Модель телефона: E398 ===> E1
Прошивка: Elektro255 V0.4 a.3
Цитата(Trentemoller @ Четверг, 7 Декабря 2006, 7:57)
_TRANE_,
у меня не получается включить unicode , после перезагрузки он снова выключается, что с этим делать?
после того как считаешь и включишь уникод - нажми "записать в телефон"
Сообщение отредактировал AlexKooper - 8.12.2006, 13:18
Trentemoller
сообщение 8.12.2006, 21:13
Из: Армавир
Фин,
У меня тоже такая-же хрень выскакивает, из-за этого я 3 мод и не ставил!
AleksX
сообщение 9.12.2006, 11:37
Из: Пермь
Пользователь №: 68 183
Модель телефона: L7e,Nokia 5700
Trentemoller, попробуй в P2KAE поставить unicode..У меня все нормально поставилось...
Trentemoller
сообщение 9.12.2006, 18:06
Из: Армавир
AleksX,
Я непросил, чтобы мне ответили, как вкл и выкл юникод, это я ответил на вопрос, как это сделать!
danger86
сообщение 9.12.2006, 23:15
Пользователь №: 72 895
Модель телефона: E1
0032_0001 off 3F bit 4 (№ 508)
Ктулху
сообщение 10.12.2006, 6:19
Moto К†улху
Сенкс! нашел! как то во все этом флейме прошлюй раз пропустил :) ща скачаю отпишусь о режультатах :)
Trentemoller, pes_voiny,
Personalize for 49R
Flan
сообщение 10.12.2006, 16:31
Из: Уфа
Пользователь №: 54 940
Прошивка: R373_G_0E.30.48 and Snake flex
Люди у меня тело не прошивается, прога начинает прошивать читает PDS и тело просто выходит из бут и заново загружается, что делать??7
Mkiller
сообщение 10.12.2006, 16:44
Из: Набережные Челны
Пользователь №: 79 378
Прошивка: 48r
Через Personalize меняю заставку, отлкючаю шорткут с *5, шью тел не включается, определяется как неизвестное устройство.Помогоает только 4,5 замкнуть и заливка бэкапа. Whatsup?
danger86
сообщение 10.12.2006, 22:11
Модель телефона: E1
Я почистил все звонки и СМС и залил сим 0144, заполненный FF. И при восстановленных 51 СМСках счетчик памяти показывает "3". Так и должно быть? Будет 178 СМС и неограничено звонков?
Стасецкий
сообщение 11.12.2006, 16:49
Пользователь №: 38 504
Модель телефона: Е1 в черном
Прошивка: elektro255
странно,но у меня почему то нет этих 178 сообщений.сим правил,но нифига,максимум сто.
подскажите вчес проблема.как сделать 178 сообщений что бы помещалось?
pycha
сообщение 11.12.2006, 22:58
Пользователь №: 85 539
Я сижу из тел оперы. Трафик дорогой. Поэтому прошу меня понять и не обвинять во флуде. А прошу я ссылку на рефлеш R49 0.3. Чтобы он был на сервере с докачкой. Буду благодарен.
Archy
сообщение 11.12.2006, 23:10
Пользователь №: 40 468
Модель телефона: E1-L6-L7e-U9, iPhone
Прошивка: M-S1.5RC3 L7e_01.0AR
у кого "чего-то нет" - вы шили полные 32МБ через флешер?
Потому как я вот шью сейчас именно так - чтобы все прелести оценить...
Active
сообщение 11.12.2006, 23:19
Из: Зеленоград
Пользователь №: 104 027
Прошивка: Mpx398 DeLuxe
Помогите челу!!!
Цитирую:
Hi, this is my first post - sorry that in english but I don't speak/write in Russian :/
I've already posted my problem on motomodders.net no one there could help me :/
So here is a description of my problem....
I've downloaded v0.3 based on 49R by elektro255 (elektro255.ovh.org), flashed my phone, and everything seem to be fine except the fact I can not make a call, I mean... When I dial a number and press a Green-Phone Button my phone hangs (the only way to use phone again is to remove battery) :/
It also hangs when I type *5 (shortcut to open main menu - ie. when you don't have your sim card in the phone) or when I use a number (it doesnt matter if a number is from a phone book or from a txt msg).
But when set "Disconnect Network" to "ON" '*5' works fine and dialing a number results in appearing of "Action not Allowed" message. I reflashed v0.3 with R373_G_0E.30.49R (downloaded from e398.com) and now I can make a call but it doesn't make any sense, coz I've lost all features that 0.3 provides.
This is What I have in "Panics":
CODENum: 0001
Ver: 0e.30
TIME: 00:30:10 12-09
LENGTH: 0209
4900 0000 0000 0c2e 1610
c201 0060 0000 3310 0900
0000 0000 0003 fd9a c810
2330 3900 0000 0100 0000
0812 79c2 f012 7e50 0403
fd56!
I don't know if it matters but I found that CG1 from elektro is 12MiB while from R73_G_0E.30.49R is 5MiB
plus R73_G_0E.30.49R contains CG7 which is not present in elektro's
I tried to reflash this CG7 over elektro's but it doesn't help,
Maybe I am doing something wrong ?
To get this I already did:
1) Went back to my provider's soft
2) Flashed with 42_for_all_MP
3) Flashed with elektro's v0.3 49R mod
Result: can't make a call
Another Way:
3) Flashed with Starter XP (46R) - making calls works
4) Flashed with elektro's v0.3 49R mod -> making calls Doesnt work
Yet Another Way
3) Flashed with R73_G_0E.30.49R
Yet Another Way #2
5) Flashed back with R73_G_0E.30.49R -> making calls works
"Went back to my provider's soft" = Restoring PDS and FULL BuckUp.
I tried other MPs based on elektro255 - none of them let me make a call :/
Hope this helps to find a solution to my problem.
elektro255 doesn't respond on IM :/
All help appreciated
P.S.
If it's not a problem please respond in english.
~Best Regards
Собственно Тема
Сообщение прислал SkW4R4
lv333
сообщение 12.12.2006, 7:48
Из: Украина, Киев
Пользователь №: 45 916
Прошивка: СМ 10
Шил. :) Скажу сразу, не в обиду конечно Elektro255, наполнения и интерфейс мягко говоря корявый :) Это касается в основном шрифтов, настроек seem32 (лишние пункты всякие, да и не только). А на счет "чего-то нет" если руки от плечей растут конечно, то все можно поправить ;)
Сообщение отредактировал lv333 - 12.12.2006, 11:02
Стасецкий
сообщение 12.12.2006, 10:18
шил полностью.тока чрезе флеш бэкап,а не через флешер
dynamite
сообщение 12.12.2006, 12:03
Из: Солигорск
У меня еще такая беда вылезла. Ставлю патчь fix_jpg_bug и тело умирает, два раза пробовал и результат тот же :o
сообщение 12.12.2006, 12:10
шил полные 32МБ через флешер! Поверх мотосимбы 1,4 -прошилось все хорошо, дальше пошли баги - в свойствах настройки e-mail - зайти не дает - просит обратиться к опсосу, в П2КаЕ-все настройки перебрал - ниче не нашел :) , в справочнике баги есть - не всегда редактировать дает, патч на улучшение фото не пашет - причем вот этот: BIG_SIZE_FOTO_WITH_FIX - который по идее как раз должен работать, иногда слетают картинки и мелодии-не может опознать файл...Видимо все таки я что-то криво делал - сейчас все сотру и закину еще раз , но может у кого нибудь были подобные баги? Особенно с настройко мыла интересует - потому как без мыла я не могу - а маилмен глупо ставить -коль имеется встроенный клиент.
pycha
сообщение 12.12.2006, 16:26
Люди извините, но мою просьбу проигнорировали. Может и надоедаю но всётаки выложит ктото ссылку?
сообщение 12.12.2006, 18:18
pycha,
http://filez.rutv.info/swel255_0.3_49R_reflash.rarhttp://filez.rutv.info/swel255_0.3_49R_reflash.rar
Вот тебе рефлеш!
И не забывай - все ссылки на сайте автора- http://elektro255.ovh.org/
danger86
сообщение 12.12.2006, 21:26
Модель телефона: E1
Полный шил, за 178 СМС обещалось в версии 0.2, я думаю в 0.3 не убрали
pycha
сообщение 12.12.2006, 22:09
Я просил на сервер с докачкой, а на этой ссылке докачки нет. Но спасибо и за это.
Va-bank
сообщение 13.12.2006, 7:53
Пользователь №: 76 925
Модель телефона: L9 Vs. E398
Прошивка: **********
Прошил 49 ----- Elektro255_mod3_49 все работает отлично clap;applo , НО! Но не работает видеокамера :( !
Да и ещё можно ли воообще сделать патч для замены звуков?
По части видекамеры я разобрался, а по части патча для замены звуков НЕТ! Подкажите кто-нить че сделать можно!
Сообщение отредактировал Va-bank - 14.12.2006, 6:08
pdr
сообщение 15.12.2006, 7:14
Пользователь №: 52 137
Прошивка: e790
Люди, подскажыте , как сделать так чтобы поставить фишки мода электро, но чтобы осталась моя нынешняя прошивка мпх398??? или есть у кого мпх398 на моде от электро??
Va-bank
сообщение 15.12.2006, 7:26
pdr, прошей CG1.smg и CG3.smg lol.gif ! Ну в общем Reflash! А у тебя воообще прошива то какая, 49?
Да и нужно было внимательней читать тему! Там все написанно! bigsmile;
pdr
сообщение 15.12.2006, 9:28
Прошивка: e790
Спасибо огромное, а где их взять?? может ктонить выложит?=)
HUNTER_ok
сообщение 15.12.2006, 10:23
pdr, Вот рефлеш.
На будующее: в любом решлеше включены кодовые группы CG1 и CG3.
AlexKooper
сообщение 15.12.2006, 11:17
Из: Йошкар-Ола
Пользователь №: 47 140
Прошивка: AlexKooper mod v.47
сделано Mr. Kibenimatik
1) http://slil.ru/23551928
2) http://ifolder.ru/607601
Va-bank
сообщение 15.12.2006, 11:42
Люди дорогие, ответе на мой вопрос "Как сделать патч для замены звуков для Elektro?"
Неужели воооообще нельзя ничего сделать? :(
SkyFox
сообщение 15.12.2006, 12:11
Пользователь №: 111 477
Модель телефона: 398
Прошивка: 49r
почему прога Personalize на 49r у меня вылетает с ошибкой... всяко пытался один и тотже результат
так есть тема про патчи изменяюшие системный звук,
там посмотри мож чё найдёш
Va-bank
сообщение 15.12.2006, 13:43
SkyFox, увы там нету ни чего! Жаль! :(
trx
сообщение 15.12.2006, 18:16
Из: motoezx@conference.jabber.ru
Пользователь №: 105 004
Модель телефона: VE66
А есть у кого более полная таблица эвентов????Если не сложно скиньте плиззз
Текстовая версия Сейчас: 30.7.2025, 21:51
