23 страниц V « < 5 6 7 8 > »
Elektro255 V0.4 alpha 4 mod (4xR), 44R,46R,49R,79R
elektro255
сообщение 23.9.2006, 12:06 Закрепленное сообщение!
Из: Poland, Siedlce
Пользователь №: 53 130
09-04-2007
V0.4a4 Alpha: http://elektro255.ovh.org
08-04-2007
V0.4a3 Alpha: http://elektro255.ovh.org
07-04-2007
V0.4a2 44R Alpha: http://elektro255.ovh.org
20-12-2006
V0.3 79R Final mod: http://elektro255.ovh.org
27-11-2006
v0.3 for 49R Final mod http://elektro255.ovh.org/
26-11-2006
V0.3 46R Final mod: http://elektro255.ovh.org
НА Е1 Rokr с бутом 0А02 (оригинальный) НЕ ПОСТАВИТЕ БЕЗ Т.П.!
V0.4 alpha 4
Changes:
- Fixed problem with display timeout (fullscreen clock) when SMS/CALL received
Features:
- 4xR and 7xR MIX (use with 4xR flex)
- unlimited Video recording
- keypad automatic lock
- low battery alarm can be turned off or depend on ring style.
- Scheduled Ring Styles (ring style and funlight style can change automatically on given time and week day)
- flashlight shortcut (##)
- extra menu (shortcut *1 [shortcut is only for testing later will be changed])
- automatic menu enter, without sim card (emergency calls working too)
- new Java methods
- settings are stored on files
- no simlock checking
- Volume-bar sound can be turned off
- multiple menus (every skin can have one mma_ucp)
- Ported patches:
o SMS report significantly turned ON
o more folders in OBEX via BT
o removed unused folders from TransFlash
o Java have access to system files
o increased iTap user dictionary size
o no delete incall on SIM replace
o Bluetooth time changed to 3 minutes
o reordered camera store menu (store only is first)
o SMS alert is using default ringtone
OLD versions(V0.1-0.3):
Firmware changes:
- firmware based on 46R from StarterXP MP
- FULL SW access from Java
- LUMA&CHROMA tables moved to memory - now you can change JPEG compresion from Java
- StarterXP flex
- added dualboot
Flasher changes:
- if you have PDS_4013 flasher will no recreate this
Personalization tool changes:
- first version for 0.3_46R SW mod
- changing splash screen
- changing font (you can use *.fnt or *.smg CG4 files)
- you can turn on, turn off menu access without sim cart
- changing my shortcuts
Новая версия V0.4 alpha 4
Изменения:
- Устранена проблема с таймаутом дисплея(полноэкранные часы) при приеме смс/звонка
Новое:
- Прошивка создана как микс 4xR и 7xR (флекс 4xR ) В 44R она переименована для совместимости! Она близко не лежит к 44R на самом деле!
- Безлимитная запись видео (64мб макс как в 6х7х)
- Автоблок клавиатуры
- Звук разряженой батареи можно выключать или задать стилем оповещения(?).
- Расписание стилей оповещения (стиль оповещения и фанлайтмогут менятся автоматически по времени и дням недели)
- Фонарик по (##)
- Дополнительное меню (метка *1 [только для теста, после может изменится])
- Автоматический вход в меню без сим-карты (аварийные звонки работают)
- Новые методы в Яве (не от 79R, а новые)
- Настройки хранятся в файлах
- Не проверяется лоченость ПДС на симку (работает с лоченым пдс)
- Звук изменения громкости можно отключить
- Мультименю (каждый скин может иметь собственный мма_уцп)
- Портированы патчи:
o Оповещение о доставке SMS всегда вкл.
o больше папок доступно по OBEX из блютуза
o удалены неиспользуемые папки с флешки
o Полный доступ к системным файлам из явы
o увеличен размер пользовательского словаря iTap
o не удалыются последние вызовы при смене сим
o Время обнаружения блютуза - 3 минуты
o Меню сохранения видеозаписи (просто сохранить - первым пунктом)
o при приходе SMS играет "мелодия на смс", а не установленная на этого пользователя
Для версий 0.1-0.3
Изменения в прошивке:
- Создана на базе монстра StarterXP 46R
- Полный доступ к прошивке (симы, озу) из явы
- Таблицы сжатия фотографий перенесены в озу - теперь из явы можно управлять качеством фотографий (сжатием)
- флекс StarterXP
- добавлен дуалбут
Изменения флешера:
-Если ПДС версии 4013 (373 платформа), ПДС не пересоздается.
Изменения персонализации (Personalization tool):
- впервые для мода использована 46 прошивка
- замена заставки (на включение?)
- замена шрифта (лангпак, CG4)
- можно вкл. и выкл. доступ к меню без сим-карты
- изменен ярлык (копирайт?)
Для работы Personalization tool требуется положить в папку программы несжатый бинарный бэкап (32 мегабайта) под именем SW.bin
Прекращаем флудить, типа а когда выйдет новая версия, и.т.д.и.т.п, или придётся наказывать!
тему почистил, архив по 1 декабря тут:
Прикрепленный файл MotoFan_ru_electro.zip   ( 66.56 килобайт ) Кол-во скачиваний: 3902
Сообщение отредактировал elektro255 - 9.4.2007, 12:21
*A_L_E_X*
сообщение 15.12.2006, 19:49
Из: 26 Rus
Пользователь №: 87 412
Модель телефона: NOKIA 3250/5700
Доброго время суток всем!!! У меня такой вопрос: как сделать чтобы файлы принимаемые по блютузу сохранялись на карту?
FRE3StYLER
сообщение 15.12.2006, 22:32
Пользователь №: 52 040
Короче видео снимает нормально - а сохраняет долго-долго... даже дождаться не могу... подскажите что сделать?
Bent
сообщение 16.12.2006, 3:19
MoTo Marvellous
Пользователь №: 63 874
*A_L_E_X*,
скоро буду наказывать...за то что не хотите читать тему!Я уже писал на страницах как это сделать.Повторяю последний раз для ВСЕХ:
надо с помощью P2K Tools открыть Seem Editor выставить значения seem 0032 и rec 0001 и, нажав на кнопку Load From Phone, считать значения. Затем отключить offset 0AE бит 2 и нажать на кнопку Save To Phone. После чего перезагрузить телефон нажав на кнопку Restart.
offset 0AE - это 0А0 по вертикали и 0Е по горизонтали.
BackgaMan
сообщение 16.12.2006, 3:51
Мотоумелец
Пользователь №: 61 651
Модель телефона: E-398 Htc-p3300
Скорее всего это из-за формата, переключи с 3gp на мр4 программой P2K Advanced Editor
_26_
сообщение 16.12.2006, 16:47
Пользователь №: 90 123
Модель телефона: E 398
Прошивка: Electro255_mod_v_0.2
Вопрос к Электро. Появится ли монстр на базе 70 прошивок? Кажется была такая идея... Было бы не плохо, монстр с твоими фичами на базе 79r
X3MAL
сообщение 16.12.2006, 19:24
Из: Украина, Александрия
Пользователь №: 79 325
Модель телефона: MotoMing
Прошивка: Antarex Mod 14R
2ALL
А что никак нельзя звуковые патчи поставить на данную версию прошивки???
deadmoto
сообщение 16.12.2006, 19:28
Главный Новостник
Из: Омск
Пользователь №: 49 284
Модель телефона: Motorola
Прошивка: Motorola Original
Уже обсуждалось - можно... Ищи ответ в теме про монстр мрх398
X3MAL
сообщение 16.12.2006, 19:54
А при чём здесь MPX398?
OrMax
сообщение 17.12.2006, 5:14
Пользователь №: 77 730
Ребята, есть такая проблема на 0.3 моде, который на 46 прошивке, во время работы итюнса идет дозвон по последнему набранному номеру. Никак не пойму в чем дело. Подскажите ради бога, что такое может быть.
HUNTER_ok
сообщение 17.12.2006, 5:30
Из: Заозерный webstream :D
Пользователь №: 106 065
Модель телефона: SE W810i
А есть у кого более полная таблица эвентов????Если не сложно скиньте плиззз
На сайте electro255 посмотри, там есть.
Если лень искать то зайди в тему SynerjTools 2.0 из моей подписи.
Там есть таблица событий.
SkyFox
сообщение 17.12.2006, 8:29
Пользователь №: 111 477
Модель телефона: 398
Прошивка: 49r
а протом что там уже он изменён и поискать сами патчи можно
X3MAL
сообщение 17.12.2006, 10:41
Я знаю что такое патчи, как их ставить и где искать. Просто Va-bank писал что не получается у него поставить звук патчи, во многих темах вопросы задавал, вот и переспрашиваю:
"А что никак нельзя звуковые патчи поставить на данную версию прошивки???"
Если можно, хорошо, тогда почему этому человеку никто не ответит.
HUNTER_ok
сообщение 17.12.2006, 15:31
X3MAL, Я посмотрю и попробую портировать.
Просто у electro255 передалано окончание CG1, поэтому смещены и звуки.
Va-bank
сообщение 17.12.2006, 16:02
Пользователь №: 76 925
Модель телефона: L9 Vs. E398
Прошивка: **********
Наконец то меня кто то заметил!!! X3MAL, Посибо!
HUNTER_ok, да у electro255_mod3 много изменений! Я сделал патч от заводской он тело сдохло lol.gif !!! По идеи он дожен работать на любой 49R angry.gif , так оно и есть..... но electro255 исключение!!!! evil_zloi;
X3MAL
сообщение 17.12.2006, 17:03
Смотрю я что электро "нахимичил" с этим модом, в прошлом хоть можно было любые патчи ставить. Мда... а жаль. А где он сам? кто-то его видел?
Va-bank, незачто, мне тоже это очень нужно.
HUNTER_ok, разберёшся - потом обяснишь плз. как портировать. Спасибо что обратил внимание.
A-c-i-d-u-S
сообщение 17.12.2006, 18:27
Пользователь №: 75 365
Модель телефона: Motor E398
Прошивка: Moto-Symbian_1.5_RC3
У кого есть возможность выложите плиз CG2,CG4,CG15.Я поставил рефлеш от v0.3 на версию v0.2. Хочу его пользовательский набор посмотреть, а качать полную прошиву средства не позваляют! и еще вопросик, в v0.3 блютуз рработает из под явы для е398?
nsk_modder
сообщение 18.12.2006, 1:12
Из: Новодвинск
Пользователь №: 92 444
Модель телефона: Z6
Прошивка: Самосбор
у меня мрх49р стоит ли перешиваться и вообще как сама прошивка??? А то чем больше читаю тем меньше хочется перешиваться вообще blink.gif blink.gif blink.gif
ПРочитал все посты до конца и волосы встали дыбом. трындец, это получается что с первого раза нормално прошиться не реально????
сам уже не могу понять как и чего делать. выкладываете патчи после которых моторы мрут косяками. zootaz;
и вообще вопрос для продвинутых пойдет ли на эту прошу патч скины на диск а????
Vanich777
сообщение 18.12.2006, 10:13
~motoman~
Из: г. Хабаровск
Пользователь №: 41 249
Модель телефона: E398 ===> E1
Прошивка: Elektro255 V0.4 a.3
Шей, монстр хороший, патчи от 49R у меня работают нормально.
A911death
сообщение 18.12.2006, 10:56
Пользователь №: 63 317
Модель телефона: HTC Incredible S
Прошивка: оф. Android 2.3.5
Набор патчей лежит в теме про монстра NewStandart (собран v0.3) - все на 100% рабочие (сам проверял). Надеюсь теперь все вопросы на этот счет отпадут :)
2Elektro255
What firmware will choose for your next version of the Rokr E1 Sw Mod? I think that the most suitable variant is 79R, because it is rather stable, fast and it doesn't have any limits for video record :)
Zagoralsanya
сообщение 19.12.2006, 8:06
Из: г. Омск
Пользователь №: 84 851
Модель телефона: Sony Ericsson M600i
Прошивка: Other
Я так и не понял((( Если поставить рефлеш 49р на 49р(mpx398) то все сладости v 0.3 будут? такие как доступ к озу и т.д..
Инфа нужна точная! отпишитесь пожалуйста те кто ставил рефлеш.
Kepa
сообщение 19.12.2006, 8:21
Из: Уфа
Пользователь №: 86 486
Модель телефона: Qtec S100
Прошивка: HTCMAG_ROM_RUS_O2
Zagoralsanya,
будет автоблок, фонарик (##),замена бут картинки!!!!!
Zagoralsanya
сообщение 19.12.2006, 8:49
Из: г. Омск
Прошивка: Other
Kepa, а доступ к RAM?
HUNTER_ok
сообщение 19.12.2006, 10:38
а доступ к RAM?
Zagoralsanya, Будет всё, что есть в моде, от которого ставишь рефлеш.
Т.к. ты заменяешь только основной код прошивки, а графическое оформление и файлы не трогаешь.
Zagoralsanya
сообщение 19.12.2006, 12:04
Из: г. Омск
Прошивка: Other
Цитата(HUNTER_ok @ Пятница, 15 Декабря 2006, 13:23)
pdr, Вот рефлеш.
http://filez.rutv.info/swel255_0.3_49R_reflash.rar
На будующее: в любом решлеше включены кодовые группы CG1 и CG3.
А можно этот рефлэш по верх 48р ставить?
KLIMER
сообщение 19.12.2006, 12:13
Пользователь №: 78 315
Прошивка: MS 1.5_79R
Zagoralsanya, конечно можно!
Chili89
сообщение 19.12.2006, 14:05
Из: Питер
Пользователь №: 51 289
Прошивка: 373 R48
Ставил два патча не идин не помог.
Фото получаются такие:
(_Light_)
сообщение 19.12.2006, 17:48
Из: Latvia
Пользователь №: 48 530
Модель телефона: K3, E398, е1000, V6
та же ситуация, результат одинаковый
Bent
сообщение 20.12.2006, 3:34
MoTo Marvellous
Chili89, (_Light_), а вы ставили оригинальный патч от electro255?Если нет то перепрошейтесь и сразу ставьте его.
X3MAL
сообщение 20.12.2006, 11:04
Я так сразу сделал и проблем пока что не было (поплевал через левое плече :) )
HUNTER_ok
сообщение 20.12.2006, 13:40
Меня просили разобраться в звуковых патчах.
В общем я не разобрался. Не совсем понимаю технологию. Видимо здесь не простое смещение в прошивке.
Если никто не разберёться, то стучитесь к автору программы SysSound, т.е. к Vassio.
Zagoralsanya
сообщение 20.12.2006, 16:10
Из: г. Омск
Прошивка: Other
ребята, а может кто значки уровня сигнала сети из дрм выложить? а то я только рефлеш качал. вообщем буду благодарен .
elektro255
сообщение 20.12.2006, 21:35
Из: Poland, Siedlce
20-12-2006 - Final mod v0.3 for 79R
Firmware changes:
* have all functions from v0.3 49R, and unlimited video recording from 79R
* added buttons what making patches for FlashBackup
danger86
сообщение 20.12.2006, 21:56
Пользователь №: 72 895
Модель телефона: E1
HUNTER_ok,
[from X3MAL:]
Спасибо за заботу, но уже не нужно, там всё работает. Это Va-Bank по ходу что- то не так делал.
SANYO_K
сообщение 20.12.2006, 22:38
Пользователь №: 64 324
Модель телефона: ROKR E1 (E398)
Прошивка: elektro255!!! 49r
Сейчас 79r скачаю. Глянуть разве что ,потому что думая ,что с 49 по скорости она вряд ли сравнится. На 49r бенч выжимал макс 44. elektro255 MegaMotoRESPECT !!!
Zagoralsanya
сообщение 21.12.2006, 6:50
Из: г. Омск
Прошивка: Other
Bent, А там что значки уровня сигнала не такие как на 4 изображении? На том что в закреп. посте.
Хотел те что на изображении :(
Bent
сообщение 21.12.2006, 6:54
MoTo Marvellous
Zagoralsanya, ё-маё говорить же надо :) Я то подумал ты про v0.3 говоришь,а те что на скрине это v.0.2
Zagoralsanya
сообщение 21.12.2006, 7:12
Из: г. Омск
Прошивка: Other
79R кто протестил? отпишитесь пожалуйста. В частности меня интересует звук.
SANYO_K, скачал 79R?
сообщение 21.12.2006, 8:12
Пользователь №: 38 507
Модель телефона: motorola E398
У меня стоит мод 0.3 от електро255 и флекс MPX398 и вот такой вопрос. (Телефон Е398)
До этого содинялся через GPRS на ПК, загрузка страниц шла приличная около 4-5КБ/с.
Сейчас после прошивки попробывал законектиться (и не раз в разные дни) скорость вообще маленькая и не постоянная. УЖАС. Не уж то проблема в прошивке может быть или проблема в операторе ... просто совпало.
Никто не сталкнулся с такой проблемой?
Zagoralsanya
сообщение 21.12.2006, 10:47
Из: г. Омск
Прошивка: Other
79R кто протестил?
zolookas
сообщение 21.12.2006, 11:50
Пользователь №: 43 073
Прошивка: R373_G_0E.30.49R
Elektro255, personalization utilty for 79R has font bug:
Текстовая версия Сейчас: 30.7.2025, 3:21
